  1. Fitting Vectra Digi Dash in Astra Mk2/Kadett GSI
  2. Astra F Estate Rear Springs, What Else Fits ?
  3. water pipes??
  4. Running A PAS Rack Without Fluid
  5. Redtop corsa speedo and rev counter problems
  6. amal valve hoses
  7. astra gsi wiring problem
  8. Corsa D vxr brakes?
  9. vec b hand brake ??
  10. Camber kit on Astra F (mk3) GSi?
  11. c25xe 1995 non imob camshaft sensor pins 1.2.3
  12. problem with mk4 astra 1.8 16v suddenly looses power...!
  13. Snapped terminal off fuel pump...
  14. No power and indicators going nuts
  15. Do i need to bleed power steering
  16. speed wire
  17. A few questions, regarding Astra G / MK4 2.2 parts
  18. cavalier calibre 2.5 v6 wiring problems.
  19. signum s/wheel on a mk4 astra?? would controls work?
  20. Horn and Reverse Lights not Working on Calibra.
  21. vectra c steering wheel radio controls HELP
  22. Corsa c wiper fault
  23. Astra G front powerflex mount query?
  24. 2004 astra 1.4, where is the diagnostic port?
  25. movano non start
  26. xe corsa suspension??
  27. Corsa B eps please help!
  28. Astra Rear Spring
  29. corsa 1.2 8v air flow problems i think :/
  30. 2.0 8v corsa cant get 4th or 2nd?
  31. What is this noise ?
  32. 2004 astra coupe 1.8 electrical fault HELP Please
  33. calibra digital dash
  34. mk2 cav steering rack
  35. C20NE Into Corsa 1.4 16v BATTERY WIRES HELPPP!!!
  36. Mk2 and Mk3 Astra shafts and hubs
  37. what are these plugs part 2
  38. 2.0xe plugs NGK BCR7ES or BCR8ES?
  39. Hi, My Corsa c 1.7DI heater's dont seem to getting hot...HELP?!?
  40. Brake pipe kits
  41. Astra Van loom is it one loom for all
  42. gte digital dash into cavalier gsi
  43. help with what these plugs are for with pics
  44. Anyone had experience of Bigg Red?
  45. Turbo damper kits for 2.0 Ltr Vaux blocks
  46. 2.5 v6 gsi vectra engine into cavalier ecotec
  47. corsa c letted
  48. Good all round road tyres ....
  49. Vauxhall Corsa without keys
  50. remote central locking and door poppers?
  51. EML coming on below 20MPH ? ? ?
  52. corsa horn not working
  53. Any differences between Koni shocks for Astra mk3 and Calibra?
  54. possible leak at manifold
  55. corsa b rev counter
  56. z20let conversion on astra van
  57. Corsa Sport Reverse Light Switch...
  58. Vectra B brakes on to Corsa B (Front)
  59. Corsa b electrical problems!
  60. Conversion help on wiring needed
  61. Someone has disabled the eml on my vectra cdti ( how would this be done??)
  62. P0400 EGR FAULT, cleaned the EGR + the inlet manifold
  63. corsa c not starting and ecu light flashing
  64. Crown wheel in a F28 gearbox help
  65. ford fiesta fds eon code
  66. 2.5 V6 Gsi ecu to 2.5 V6
  67. Engine mount or tiger seal ?
  68. C20let gearbox?
  69. Calibra turbo, Is this right? gap under top mount? pic attached
  70. 2002 vectra 2.0 DTI paper clip test
  71. Brake system probs-pedal on the floor!!? help needed asap
  72. ignition staying on without the key in
  73. Corsa B tailgate - All the same?
  74. brakes not bleeding need help!!!!!
  75. Thinking to buy Astra g bertone help please
  76. wiring 2.0 8v into corsa b
  77. Urgent: 5 Stud Cavalier on Drum Brakes
  78. help needed please
  79. Astra G lighting & heating issues
  80. Corsa SRi 8v, Injector Valve - Low Voltage?
  81. Damage free corsa break in...
  82. c20xe wont run
  83. How hard is it to fit a corsa gear stick set up to a nova?
  84. LET redline
  85. bypass immobiliser on 1.7td isuzu astra
  86. corsa b c20xe speedo not working,changed manuel to electrconic in gearbox
  87. Rear disc conversion on Corsa B
  88. Astra G turbo top mount problem. Please help me I'm loosing the will to live!
  89. Front 280 mm. brakes for Corsa B
  90. astra mk3
  91. What power steering rack setup
  92. Remote Central Locking
  93. advice need for corsa rally car
  94. astra g knocking
  95. Runnng digi dash/ electronic clocks in Corsa GSi...
  96. Z20let ecu problems??
  97. astra g brakes
  98. Corsa V6 non starter
  99. Corsa B Coilovers
  100. someone tell me how they have spaced the tie bar down on the bottom of the wishbone!!
  101. Motronic 2.5 Condensation damage?
  102. key programe
  103. track rod end help
  104. Corsa b drum brakes
  105. Astra mk4 abs fault code - any ideas what it refers to?
  106. Ignition lights problem!
  107. fuel pump not priming on my corsa help please
  108. Corsa B Won't Start, Total Silence. Need Help Please :)
  109. zafira 1.8 2000 exhaust emission light on/maf sensor egr valve fault?
  110. lights on my dials
  111. road speed on corsa sport with digi dash HELP
  112. Vectra 2.2 DTi ABS light
  113. Electric windows on a '97' Tigra
  114. Astra GTE dash (again)
  115. C20LET stand alone systems
  116. Mk3 Alarm HELP !!!
  117. Updated Alternator Supplier ?
  118. C20LET Brakes
  119. astra 02 convertable
  120. GTE digi dash - Testing Illumination
  121. poly bushes?
  122. 1998 Vectra Wipers Staying On.
  123. C20XE Corsa B - Late Type ECU Immobiliser
  124. is the f28 front gear box mount the same as the v6 auto 1 from a cav??
  125. Ignition leads
  126. Stiffer Front springs for MK3 Astra.
  127. Nova steering fault
  128. Couple of little niggles i need to sort, central locking and leccy mirrors
  129. accuracy of dash temp
  130. 16v conversion to my 8v astra gte
  131. OPCOM- can it generate MPG readouts?
  132. Retrofitting eps to Corsa B
  133. 2000 mk4 astravan heaters being weird....
  134. Turbo charge 20XE eith Saab loom/ECU/Turbo?
  135. Instructions or Diagram-Wiring up elec sunroof to mk3 astra phase 2?
  136. Tigra Front Wheel Bearings
  137. Braided earth strap on F20.
  138. fitting electric windows
  139. vectra decat
  140. mk4 astra coupe c20let
  141. Remove immobiliser on c25xe?
  142. Can anyone identify this Rear Anti-Roll Bar?
  143. Air flow sensor
  144. Corsa c brake disc help?
  145. juddering 2000 vectra 2.2 help !!!
  146. Any different engine swaps?
  147. fto wishbone
  148. mk4 astra - spare key, cheapest way?
  149. Forum Rules - Thread Titles
  150. Central Locking
  151. lights on dash
  152. rear abs rings on 8v calibra
  153. No reverse lights on corsa C
  154. corsa conversion rev counter trouble
  155. Tail light goes out wen i press brake! Help?
  156. Brake Bleed nipples
  157. Fuel Pump
  158. rear disc conversions?
  159. dash speedo not working?
  160. Manual Power steering issue
  161. 3.1 V6 won't rev to more than 5500rpm, new crank sensor, still problems
  162. How to spot fake parts?
  163. nova oil pressure sender any good on a c25xe
  164. knocking noise on the front of my corsa B?
  165. mk4 astra van wiper problem
  166. astra GTE dash in a mk1 nova help
  167. Trouble getting mk3 astra low at the back?any ideas..nova springs??
  168. Central locking problem
  169. mk3 astra electric mirrors.
  170. vec b relays
  171. ? keep MFD with after market head unit
  172. do i need a dash to pass an mot?
  173. combo spanner light on advice needed pls
  174. Corsa B track rods and balljoints
  175. 1.7 GM Diesel Tacho
  176. Corsa C BCM
  177. Quick Release Bosses
  178. Astra mk3 gsi Handbrake cable part no. (discs not drums)
  179. ABS Advice
  180. Corsa B Top Mounts
  181. ABS Brake problem
  182. Hyundai Coupe 2000 cruise control not working!!
  183. redtop wiring problem, with pics.
  184. calibra turbo problem
  185. Vectra 1999 - What springs fit?
  186. imobilzer problem, wont unlock doors, hep please!!
  187. omex 600 afew questions
  188. opcom - any info?
  189. Jump start now an ecu light and battery overcharging
  190. obd scanners for pre 2000 vauxhalls
  191. Vectra brake servo
  192. Non start - Immobiliser / Fuel Pump - Swapping ECU Questions
  193. Calibra/Cavalier 5 stud Hub
  194. Corsa b 20xe front coilover springs (what lb do you use?)
  195. Corsa Bs and 4 pot brakes - do they work well ?
  196. Mk3 astra 8" width wheel?
  197. Combo/corsa b central locking problem
  198. vectra brake upgrade
  199. will corsa b clocks fit in a mk3 astra?
  200. Nova front Strengthening Kits? Needed or no?
  201. cavalier anti roll bar
  202. corsa b clocks
  203. Welding struts for mot
  204. Removing PAS / ABS questions
  205. Any Car Electricians on here?
  206. Astra H abs , problem .
  207. Start charge loom quick question? Help
  208. handbrake fitting kit
  209. Heater Problem (urgent help please)
  210. dta management help
  211. power steering removal help
  212. Vectra B, Speedo not working.
  213. Astra H 1.7CDTI Alternator change
  214. Mk4 Astra 4 to 5 Stud
  215. battery voltage gauge?
  216. Corsa 1.0 Conversion
  217. Calibra knocking in front (WTF)
  218. astra mk4 x20xev what CAT to go for?
  219. astra g electric sunroof problem
  220. New Brake Pads for 4 pots but what ones?
  221. urgent help needed on brake discs
  222. will calibra suspension fi cavalier?
  223. C20let no spark and dont think the injectors are opening :/
  224. xe loom converted for carbs??
  225. help deciding on shocks
  226. Elm327 v1.4 on a 1999 Vectra B Gsi expert advice required
  227. Brake noise?
  228. Transponder wiring
  229. astra mk4 seat recliner....
  230. sounds silly but what air filter?
  231. Downpipe to cat pipe gaskets (fire rings)
  232. Oil pressure gauge adaptor? M24X1.5 TO 1/8NPT ??
  233. Corsa b shocks!
  234. Button next to interior light in Opel tigra 99
  235. Corsa b 1.6 16v Brake upgrade HELPP!!!
  236. Advice needed on Corsa B bolt-in OMP cage
  237. C20Let Corsa No EML
  238. do i need uprated front springs for my spax krypton kit for corsa c20let????
  239. Help with no interior heating diagnosis please - Astra 1.3 Diesel
  240. C20XE AFM
  241. What makes light bulbs break regularly ?
  242. Corsa B Epas wiring diagram and a question or two
  243. Electrical fault
  244. Vectra C coilover fitting guide with pics
  245. MK3 astra heater problems
  246. Alternator Problem need help ASAP
  247. Best way to fit nova strength plates
  248. Nova strengthening kit photos.
  249. drilling an ally intercooler for a water injection nozzle?? (pic)
  250. etb dd2 digi dash problem?
