- gj
- Astra H(Sports hatch) help needed
- won bottle heater fitted now running few tests
- No juice
- Corsa c 1.2 rear disc conversion?
- straight thru centre pipe question
- suspension question......
- Digital Dash ....Pulses
- 'flat spot' in the steering
- vx220 clock transplant
- -31 actuator...
- problems with corsa
- another boost problem
- central locking kit
- 284mm V6 Brakes To 288mm V6 Brakes.....
- 3000rpm Cold Startup
- ecu immobalisor
- brake and battery warning lights come on while driving - astra mk3
- Being lazy - Nova Steering rack thread?
- GOOD WEB SITE for tech info
- couple nova niggles
- vectra c
- can i do this to my mk3 astra
- Unidentified Wire
- can you get silver powdercoating?
- strange wobble on breaking...please help
- total closure
- vauxhall dealership charges?
- Vectra V6's and GSi's
- stearing wheel controls
- Astra TDS GLS Shuddering
- Help!!! Cant Get My V6 Calipers And Discs To Fit My Corsa B
- Erratic Idle
- Couple of questions about 2.0 16v nova conversion
- GTE Stabiliser Bar
- cruise control wiring help
- corsa epas ina mini?
- total vauxhall mag
- estate/van mk3 rear clear lights
- didgital dash help !!
- Low mileage or not?? Can you tell??
- faulty corsa epas column
- ABS lnitials on the unit???
- 2.0 corsa interesting mount at scrappy...
- where on a mk3 astra can i find....
- Help please, Hydraulic handbrake
- Uhhh Ohh - Help! Ive broken my heater!
- Astra MK3 suspension question...
- factory fit alarm
- "funny" compression? ecocrap!
- No dial lights!!!
- nova 16v Conversion Parts
- Help Please Wheres The Fuse???
- frontera
- Lady Owner Astra TD 1.7 results of prob :((
- Strange behaviour - help
- alarm problems
- arp re-use cap bolts torque ?
- random 3 wheeled body roll
- mk3 astra - front tyres worn on inside edges
- please can someone help me out with these big end queries
- big end bearing question
- fittin tripple gauges and pillar pod?
- 0-60 longer than expected
- 3.2 Frontera V6 into Cavalier?
- Rear Disc Conversion
- Need a bit of help with plugs .
- Overheating
- V6 DIS Pack
- remote locking help
- Has anyone done a 2.5 V6 conversion to a Mk4 Astra/van?
- Omega 3ltr V6 conversion into my MK3 cav
- 2.o 8v accel increase
- Brake Fluid Capacity??
- Autovaux cant source a part! anyone?...
- towing a caravan with a astra gsi!
- how many co sensors............
- Rounded hex bolt - help!
- Digital Dash problem
- calibra alarm
- Rear axle problems on a nova
- now im pi$$ed with my cally
- tensioning alternator gte 16v mt196 kit
- Actuator help!
- ignition barrel
- v6 coolant leak
- Heated seats
- Less revs more speed
- Calibra 2.5 V6 into Nova
- Wiring Diagram
- window fault on calibra
- LandRover Tech info wanted
- Astra GSI MK3 Brake probs
- Cav MK3 Electric Sunroof Into A Nova Can It Ben Done? Please Help
- vectra c towbar
- project help needed
- Length of Mk2 16v brake lines?
- Cliffnet Pro (installer version)
- Electri power steering on corsa b
- ecu pin number ?
- Just a quickie!
- anybody with tech 2???
- Water gurgling noise in dash
- Replacing big end bearing
- EPC check please!!!
- Air bag replacement
- Cav Hatch into Saloon
- Battery Light Flickering
- releasing pressure from coolant system
- astra td sport rev counter
- v6 brakes on an astra
- combustion pics tell a story
- quick rack fitted - i knew it was gony be tighter but fook me....
- i need some 288 discs drilled to 4 stud
- help! damsal in distress!! :)
- Car Rotisserie Gauging Interest
- calibra owners!
- Nova Rose Joint Lower Arms - where to get rose joints?
- Fitting Cruise control to a Electronic speedo calibra
- Different type of screamer pipe
- mk 4 astra calipers....
- cav sri still not starting!!!!!!!!!!!!!
- Coolant sensor
- Realistic outage?
- renault clio 1.2 dynamique inertia swtich
- Wilwood 4 pots on the rear of a Corsa?
- corsa brake line end sizes please help??
- faster faster!
- Ideas on steering lock problem
- BERU ht leads? autovaux?
- Corsa b heater blower
- digital dash ????
- 2006 MK5 Astra H Sidelights...
- a.b.s fuse cav mk3 sri 8v
- Anyone know how to stop the leak in my booton my Nova??
- Astra Gsi Towbar!
- missfire
- how to lower a car with torsion bars
- creeking noise from the back of car
- Piston movement
- 1995 Astra: Help diagnosing noise in the front of car
- odb port
- annoying astra antics
- Very confused Running trouble ???
- crash damage advice!
- 5 stud convertion on mk4 van
- T40 GSi Help Please!!
- Glo Plug Blues(Black more like)
- alarm and central locking help plz
- Stand alone ignition systems
- question on tb
- Reverse lights staying on?
- JUST GOT A 2.0i K REG CAV HOW DO I MAKE IT FASTER?
- no reverse lights?
- NOise!!!
- V6 running on kanagroo juice
- coolant leak on v6 sri
- Help - No Water Pressure
- Astra MK3 lower suspension arm Help
- suspention
- code 44 help needed
- what is this wire????
- Removing a Corsa immobiliser
- Nova Wide Track Suspension
- Brake clicking noise
- Help required - Nova GSi mounts & stuff
- More Cav T Problems !!
- rs2000 help
- 2.5 V6 to Astra G
- Whistling/Squeak sound
- rad info
- wiring info
- wat should i do???????
- new on hear and need a bit of help please
- shell swap
- ARP Conrod bolts
- Servicing a Nova?
- duff actuator?
- CV joint / wheel bearing problem symptoms, or geaerbox mount?
- V6 air box mod
- removing rear wheel hub astra 3
- Vectra GSI brake pad issue
- astra mk3 van weights???
- vectra v6 misfiring
- rev limiter
- G-Max Shocks
- Removing Dynamat
- Need help soucing some parts please...
- 1995 Astra, purpose of fluid reservoir (pics)
- short shift, have i got everything????
- corsa troubles
- Rear brakes on a corsa!!! Pressure regulators????
- good breakers for mk4 stuff
- astra v6 strut brace
- OMP Brake hoses on MK3 GSi problems
- Vehicle speed sensor
- Not happy - leccy windows!
- Help! Please!!!
- Astra3 TFD - dodgy display
- Locking wheel nuts - ffs no key
- where the hell is my ECU?
- ATS Fault
- Fitting ARP rod bolts
- LED Sidelights....
- Glo plug change wrong plug
- Anyone got the MPG figures for the Nova GSI?
- ecu replacement
- external wastegate springs
- actuator?
- does any1 have.........
- Please Help!!!!!!!!!!
- How easy to remove doors?
- Help please
- temperature gauge
- maf
- preventing ecu from checking lamda
- Check control problem
- did vauhall make a 2 liter SPI ?
- fault codes 13 and 19
- sorting squeeks and knocks...
- HEAVY tapping
- Hall Effect Switch (code 93)
- what's the deal with drilling brake discs? ive got 5 stud porsche discs i want 4 stud
- cav gsi ecu pinouts/ wiring ?
- Coolant leak in '96 1.7TD Vectra
- Quick problem...
- Temperature gauge transmitter
- Fault codes 0200/0340, please help!
- couple questions
- Does any1 have diagram for illuminated rear grab handles?
- ecu reprogram
- What do you think of this? (ebay ecu flasher)
- Vectra and mk3 GSI astra shafts same??
- suspension info
- Corsa lowered 60mm
- tyres for ppl in the west midz area!
- Corsa C clocks into corsa B, possible?
- heater info
- test 2 ECU reset, in the midlands.
- V6 Ignition Lead diagram
- Dodgy name tyres - Any comments?....
- big problem, please help
- Nova Question....
- corsa epas into nova Q...
- Where to buy mk2 Astra sills?
- Mobile Tracking Service?
