Google
PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165
  1. nova/corsa steering column comparison...
  2. Leccy Wing Mirrors
  3. Opinions on 2.0 8v GTE
  4. help
  5. clocks
  6. sunroof calibra help
  7. quick question: calibra-astra suspension.
  8. Aircon question...
  9. evaporator ? what does it do ??
  10. What a bodge !!!!!!! shocked !
  11. Removing the ignition key lock surround??
  12. HELP! sports button!!
  13. astra f central lock problem?
  14. Diff change on F15CR
  15. Metal rollers
  16. 200SX Big End Bearing Change
  17. Cooling Questions...
  18. what wheel hub to get for a corsa 2.0 wiv cali v6 disks
  19. calibra fan wont kick in!!!
  20. question!
  21. A very new angle on home made T bodies..
  22. how to clean
  23. in dispare
  24. Electric windows on Calibra....
  25. Random starting problem
  26. mk2 astra..bad earth????
  27. What a game a GTE is...
  28. inspection symbol
  29. F.A.O Someone who know's bout mk3 astra
  30. Quick temp gauge question
  31. thick
  32. quick calibra back box question please reply asap
  33. core plugs
  34. Gsi Ecu
  35. speedo playing up
  36. help needed ASAP............... please???
  37. aircon problem. help please !!!
  38. Astra Mk3 is it GSI or Sport
  39. ecu
  40. Mini Cooper superchargers
  41. Thick black negative wires by doors in a Calibra
  42. Brake Disc Help
  43. fan
  44. Vectra Rear Deadlock
  45. Digi dash bulbs, Where can you buy them from?
  46. AIR CON pump leak can it be helped ...
  47. Mounts
  48. astra rev counter
  49. mk3,bonnet
  50. nova conversion
  51. 1,7 td too 20dti!!!!!!!
  52. Air conditioning system - could it be faulty?
  53. nova 2.0 16v zorst
  54. Interior fan speed a bit pants
  55. new cars heater/blower power is cr@p
  56. FAO clifford concept 300 owners
  57. Are master cylinders ever pressurised ??
  58. torx bolts
  59. transistors
  60. Anyone needed to replace a Vauxhall auto box?
  61. Strange Electrical issue. (Vectra)
  62. dis-pack question?
  63. Removing steering wheel with airbag?
  64. Urgent!! No battery light
  65. Corsa lack of and adding Rev Counter
  66. Q; squeeky brakes.
  67. Widest Tyres
  68. need help quickly-knock sensor
  69. cav airbox?
  70. Fitting Air Con to a Calibra
  71. Mpg
  72. Small device on H/Matrix with rubber hoses on V6 Calibra
  73. Opening up digidash
  74. 16v conversion help needed..
  75. ABS prob
  76. Air Leak
  77. Alternator probs
  78. quick question steering colums
  79. rev limit problem
  80. Getting shot of the airbag!
  81. What springs
  82. how to ?
  83. "F" in Cally T time/temp display?
  84. Stretched bonnet pull - adjust or replace it?
  85. 2ltr gsi in a tigra??
  86. 160 clocks
  87. Vectra Brake Issue
  88. Goodyear or Avon?
  89. INDICO hoses...?
  90. Custom Airbox's
  91. ASTRA 1.7 D M reg. Gettin` Hot
  92. Core Plug Help Needed
  93. Will this...(Nova Strutbrace)
  94. Omega info...
  95. Short Socks
  96. Stats please
  97. seal sets
  98. rear disc conversion...
  99. Fault Codes
  100. cool running thermo and switch? how do i know if i hav 1
  101. wheres my ht leads gone???
  102. Cavalier 2.0l 16v Mreg
  103. Moving battery to boot, a few questions please...
  104. Jacking up a nova back end, where to?
  105. Checked tyre treads religiously. Advise please
  106. Vectra Di starting problems were to look first!
  107. Part numbers needed
  108. wiring fan so stays on with ignition off
  109. Thermostat in my Astra?????
  110. Calibra 8v Starting Probs
  111. Corsa C Wingmirror
  112. Fan not cutting in at 102!
  113. question
  114. Homemade front strut brace?
  115. Do any ABS brake master cylinders have different bore sizes?
  116. Someone Please Help
  117. ecu wont clear the fault codes????
  118. Urgent Assistance Required (vectra 2 Ltr Eco-tec)
  119. where does the lamda senser go? (bad spelling)
  120. Trip computer
  121. any one know cost
  122. backfire when cold?
  123. How to wire a fan override switch
  124. 20 SER fast idle???
  125. What's happened to my brakes?
  126. Question about front TOWBAR on a corsa B
  127. 57i on vec gsi
  128. How does a jig work?
  129. speedo's stopped working....
  130. Rev Meter !!!!!
  131. Cav MKIII error 92
  132. Parts Prices
  133. speedo behaving oddly
  134. Peugeot 405 td tuning
  135. Fanny switch
  136. 1.5TD questions?
  137. Help!!! I'm locked out
  138. Basic Car Check Info
  139. Dizzy for 45s
  140. Eps
  141. how easy is it to change bulbs on centre console
  142. maybe this thread should be in the humour section
  143. Solid or Vented Discs??
  144. fooking error codes !!!!
  145. Astra Mk2 GTE 16v Strut Brace
  146. Which suspension ??
  147. V6's in MK2 astras
  148. Air con questions
  149. info needed, astra gte
  150. tigra/corsa clocks
  151. FSE PBV Codes
  152. Ignition Barrel Replacement
  153. Corsa sunroof
  154. windscreen
  155. wiring harness
  156. Astra GSi - What's that plug under the boot for?
  157. ABS coming on
  158. v6 calibra auto....
  159. Astra gsi rear axle HELP
  160. Trip computer
  161. Digi Dash into Corsa b
  162. Removing reservior from mk2 Astra GTE master cylinder....
  163. Calibra V6 onto Mk2 Astra
  164. Stalling problem (Eco crap)
  165. removing servo on a mk2 astra
  166. front brakes creaking
  167. No Middle Box??
  168. leccy sunroof
  169. if the tracking is out......
  170. WTF is with my ABS?
  171. Brake disc sizes...HELP!!
  172. immobiliser....
  173. help
  174. BRAKES!!! Vectra v6 sri...
  175. Black Distributer Cover
  176. urgent cars dead
  177. No brakes!
  178. V8 in a Calibra?
  179. i want the softest suspension for astra mk3? what is it?
  180. Bilstein Sprintline > Calibra
  181. over heating
  182. Lmao
  183. PAS Rack on Mk3 Astra GSi...
  184. Why can't I post a thread in for sale?
  185. Wiring in Small LED's ???
  186. V6 on TBE's ?
  187. doh, my sensor plugs dont fit :( (pics)
  188. Digi dash miles???
  189. MBE 941 Config File
  190. ABS code 16 .
  191. 3.0v6 into cav...
  192. temp problem
  193. hall sensor code
  194. Starting Problems
  195. astra mpi
  196. Rust Problem!
  197. gsi trip computer problems
  198. Metal on metal sound on full lock...?!
  199. central locking not working
  200. Brakes dont work!!!!!
  201. SPI to MPI
  202. ECU light comes on ??.
  203. Cruise Control
  204. Boost gauge issue
  205. fitted digi dash now have problems.
  206. Cutting cross member?
  207. is a volt gauge,a good idea
  208. Digidash speedo calibration?
  209. cally upgrades
  210. MK4 Cabby roof small problem with it sticking
  211. problem with bleeding brakes off
  212. Wireing Diagram!
  213. distributor required?
  214. any good
  215. GTE clocks in a GSi
  216. Rear discs upgrade.
  217. Error code help please
  218. Which one..
  219. Front Windows Playing Up
  220. faulty distributor caused car to stall?
  221. Astra mk3 handbrake stuck on - crunch!
  222. Astra TD....Were does this pipe go???
  223. Handbrake/Warning Light keeps coming on
  224. digi dash red switch on top and transducer?
  225. Rear Windscreen washer problemo
  226. will v6 brakes fit behind astra gsi rims?
  227. Tigra Suspension Change
  228. Astra Coupe Millage Not Displaying Or Full Beam Wont Work???? :s
  229. brake lines
  230. what to do
  231. Ahh, but which CV boots...
  232. Longer rear handbrake shoe pins, do they exist? Banana?
  233. couple of questions
  234. how do i turn the service inspection light out on a mk4 astra?
  235. wiring diagram for corsa c mfd?
  236. Nova Gsi Do We Realy Need The Exhust Heat Sheild?
  237. corsa gsi inner wheel arch
  238. lights not working
  239. need help badly lol
  240. any suggestions ? .....
  241. 2.0 8v omega's
  242. boot lifter and solenoid
  243. little ends
  244. Removing underseal
  245. Lowering front Astra Mk3
  246. Astra wheel bearing kit - which one?
  247. help needed please
  248. fao dom/electronic bods
  249. temperture needle
  250. Can someone in here help wit this?
