- Nova wiper motor backing plate...
- brake discs and pads...again...
- Digi dash into corsa - couple of things not sure of.
- P reg vectra cdx 2.5v6 auto overheating
- Removing Mk3 Astra Wishbone Bushes
- Mantzel help
- what trans fluid
- air lock
- Help me with water circulation problem please!!!!
- locked out my car
- coolant temp sensor
- 3.0L v6 conversion to a calibra
- corsa conversion
- koni adjustables fitting
- ABS Problem
- 5 stud conversion, whats needed?
- Those clips that hold the GTE side skirts on.
- Caliper piston diameter
- Elec Fan Query on V6
- Centre pipe mod required..
- Brake Pipes
- Wiring M6 Mirrors Quick Help Please!!
- Changing engines in a vectra...
- 300mm hi-spec 4 pots and speedlines???
- N reg Vectra being broken, Gls
- 2.0 16V Corsa Help
- undoing weird heater matrix pipe connection on V6 Omega (pic included)
- Suspension + MOT!
- taps
- non runnin nova
- icv symptoms
- Astra MK4 1.7dti (Isuzu I think?)
- Reverse lights
- Mk3 Astra GSi Creaking back end
- dwell gauge?
- smoking Habit!
- Making battery box
- Quick advise: How much for calipers?
- cooling fan problem
- 2.5 V6 In A Corsa C Help Needed!
- anyone with an omega haynes
- RWD t45'ed 2.0l 16v Help....
- how much is this using?
- how much is this worth?
- Fusebox on a Mk4 Astra???
- memory blank - what size are v6 front discs?
- One touch electric windows not working on Tigra - Help?
- lowering springs- do they fit?
- economy issue, whats next?
- why is my 3 bar reg showing 3.5 bar
- supercharger info
- LED's
- compreson test
- Corsa SRi advice..
- help please people (urgent)
- Cheapest/easiest and fastest 8v into a corsa b
- Is it possible to skim warped discs??
- Need to take out some dashboard bulbs. help
- upgrading shock's...
- de locking doors
- Nova rally car project
- corsa b radio/interior light stopped working
- Help with CR calculations
- anti roll bar question
- Brakes
- vectra airbag light
- vectra heating probs
- port and polish
- central locking
- HELP! Frontera Leccy Windows Prob
- Air restrictors
- Just fitted a -34 actuator. Feels far too stiff.
- Cavalier
- Could the lamda cause this?
- Lowering corsa B
- borking/splutering..
- MAF Sensor
- N reg astra sport, can you help?!!!
- Idling Problem
- Creaking front?
- Idling Problem
- Changing washer jets
- different types of cally calipers
- innovate wide band kit
- Nova Alloy Rack Mounts
- 16v T-Car Kaddett Tear in firewall plz advise
- nova rear disc help needed
- smoke from my cav gsi
- corsa judering
- Brakes by brembo
- brake pipe fitting sizes
- Can it be towed?
- Transferbox pic request and update on problem...
- v6 wiring into astra mk3
- astra gte brakes / bleeding
- rear disc conversions with abs??
- a few mods
- corsa sensor problems
- Trip meter clicking
- corsa/nova
- How2 advice needed
- incorrect use of jump leads
- Astrarally
- v6 into astra
- 1/4" or 3/16" hoses in Isuzu lump?
- How random..
- yellow light displayin, renault clio 2002 51 plater
- Corsa dash in a nova
- urgent help needed no drive
- What is this factory Astra Sat Nav?
- my astras not well
- What is the best offset
- what can i use?
- Replacing bulb in radio diplay/clock (Astra)
- poor idle and cutting out
- Corsa Overheating / losing water
- Buying a mk3 astra
- astra disc's and pads...
- Major Problem?
- Cav Gsi water connector fitting .
- vectra icv
- K1 plug leads
- air flow meter
- Switches (lots of input needed in this thread)
- RS500 Cooler on a MK3
- What have i found?
- Faulty brakes?
- Whats this plug for?
- tuning 14nv and rocker arms
- Wheres me earth connection for....
- Astra brakes
- rear brake discs....
- astra mk4 sunroof...
- ecu code... help
- Astra Rally Read This
- Astra 8v GTE calipers siezing
- leccy windows
- corsa front brakes
- Help - Vauxhall/Kit Car Custom Suspension
- quick ecu question
- astra TD electrical fault
- HELP none vauxhall/pug 306 for all you tech guru's
- This Is Why I Had So Much Blowby!!!! :(
- help gsi cav relays
- please help air flow meter needed
- inner cv snap ring
- MBE 912 ECU Software
- Nova Wiper Problem
- act cutting out
- cleaning my rad out
- Master cylinder upgrade
- abs problem? wireing broken
- Corsa disc conversion
- nova brake, hard.
- why are my tires egg shaped??
- starting troubles
- astra mk3 suspension on to corsa b
- tits off
- ECU light coming on after 3 mins
- nova lowwering springs
- Vectra '96 Major Electrical Problems......
- mk4 5 stud, 56.6 0r 65.1 hub size...
- Nova electric windows wiring??
- astra digi dash wiring
- Vacuum advance
- vectra windows
- How easy....
- Anyone used a master cylinder seal kit?
- Timing Q
- icv on astra mk3
- Traction Control light staying on intermitently (1999 Vectra SRI)
- New top mounts and lower arm
- Should a nova 1.2i VSS work a digidash?
- Squeeling brakes
- spacer for fiat disc conversion
- airbag removal
- V6 Custom Intake.
- rear bushes on vectra
- idle speed control stepper motor??
- no brakes! need help
- astra mk4 sri problems...
- Sigma SN30 (SG30 Car Alarm
- long shot, Q about fiestas
- FAO Astra coupe owners with ABS/TC problems.. quick question
- koni adjustables...
- SEH engijne rebuild about to begin
- Corsa B electric sunroof upgrade
- astra stalling
- 140mph, pulling on 1.5bar boost, big bang...
- vauxhall alarm 902
- how to remove vectra rear door cards? Help please!!!!
- Vectra rear bushes, what to change? ...
- Which sensor - what else could it be ?
- lamba sensor
- anyone bought a set of these?...(for nova)
- Digidash differences
- Help With Fitting 2.0 8v Into Nova
- corsa/nova/tigra adjustable spring platforms
- Brake discs..
- Cutting out Cavalier hatch spare wheel well...
- driver side brake problem(bearing maybe)
- my fans a fuse eater!!!
- Anyone know anything about Ford KA's? (Sorry for swearing!)
- Can I add cruise control to my 04 meriva design ?
- dodgey lighting problem.....
- clocks
- Got me cossie actuator (removing old one)...
- ABS question.
- Calibra Electric Window Motors
- vauxhall rwd
- digi dash
- Master cylinder on Nova with Cali T brakes?
- Digidash bulbs
- mates car losing water rapidly
- help with overboost
- what shall i salvage?
- Resetting ECU
- dash warning lights.....
- nova steering rack
- just found out ....
- emissions light
- would you?
- power steering rack help...
- Will Tigra lower arms fit a Nova?
- piston tight to push up and down in new bore?
- Guess what ive found or not as the case maybe!...
- Identify part
- help needed with Calibra electric mirrors
- EBC components
- Hubs
- road angel going daft under load
- octane plugs
- astra alloys?
- MBE 956E PIN Control Problem
- idle to high
- 308mm brakes
- Juddering pedal
- brakes and CV boots - mk2 GTE
- gapping piston rings ( fileing)
- definitive answer, Enem x13 specs
- Knock Sensor - ECU?
- Braided lines and fixings - where from?
- corsa speaker wires/rear(where are they)
- Fault code help! 2l eco
- looking for a tap
- corsa judderin
- tyre size causing abs and tc problems
