  1. will a rear wheel bearing from a cav gsi fit a gte16v
  2. Making Wiring for GSI Comp and Stalk??!
  3. steerin wheel shaking
  4. dis pak wiring diagram
  5. quick grank wheel question
  6. cav v6 ecu wiring diagram
  7. possible abs / brake problem please HELP!!! NO BRAKES!!!!!!!
  8. What Brakes?
  9. Tow bar wiring
  10. Directly linking PAS pump to rack?
  11. Boulderlocks
  12. will mk1 fit?
  13. Think iv pin pointed my problem!
  14. 8v calibra has packed up! how easy to change to 16v?!!
  15. 8v calibra has packed up! how easy to change to 16v?!!
  16. GM Dis
  17. my wkd astra van progress pics
  18. front brake disc shields
  19. digidash
  20. electric sunroof
  21. spax suspension advise??
  22. uprated actuator
  23. need help!!cav gsi spring's?
  24. Corsa Sport Problem!
  25. finally found the cause of the clunking
  26. Vernier Pulleys are these any good?
  27. Corsa B SRi not running right?...
  28. what causes tyres to wear on outer edges?
  29. Fault code 113
  30. astra mk3 trip computer
  31. Blueprint performance.....contact number
  32. Astra G 4 stud rear disc conversion
  33. why NOT to use poly bushes on a mk2 astra wishbone
  34. 2.0 8v pic required
  35. Astra Brakes
  36. Anyone in here got a nissan terrano??
  37. Cavalier 1.7TD alternator, urgent help needed!
  38. Astra power fault
  39. will 235 tyres fit on a 7j rim
  40. rear wheel on cali t is towin out, pos chasis bent/ r/arm bent HELP!
  41. V6 Astra Temp Gauge
  42. non vaux renault laguna
  43. whats needed for a nova RWD
  44. cav beam on mk3 astra
  45. van 2.0 16v conversion problems, Where do i start?
  46. having trouble fitting alu top mounts to nova...
  47. megasquirt any good?
  48. Ate Rear Caliper???
  49. v6 brake conversion wont bleed
  50. Astra mk3 Front Wheel bearing
  51. None Vauxhall parts request.
  52. need a bit of advice
  53. Vectra 2.2DTi Glowplugs
  54. Nova horn upgrade problems!!
  55. Acetone?
  56. Biggest brakes that will fit under 15" Astra GSi rims?
  57. Swedish Plenums...........
  58. MPG testing and results
  59. swedish plenum
  60. Astra GTE bonnet vents
  61. Cally aircon pump question
  62. Dodgy conversion kits
  63. All Those With ARP Rod Bolts!
  64. Upgraded! (super charge??)
  65. Astra H fog lamps
  66. corsas and 4pot brakes.....
  67. car sorted thx 4 your help
  68. New shape vectra wiper faulty
  69. Thickness of sierra/saph cossie rubber mounts
  70. Cruise Control
  71. Steering rattles at full lock
  72. drilling in the footwell,
  73. Reyland brake kit owners...
  74. New Astra mk2 track car
  75. what is it????
  76. alarm fob
  77. missfire?
  78. "The round bit on the wheel is the wrong size"
  79. corsa dash
  80. Intermittent Car Problem
  81. corsa b suspension
  82. Cav wheels?
  83. corsa wont run help plz
  84. Cav not firing on cylinder 1
  85. FSE
  86. Calibra fix 95/100% we're almost there.....help
  87. Astra MKII Steering column
  88. big brakes
  89. how do i do the paperclip test
  90. orange light coming on my corsa sport
  91. actuator
  92. Is this thing on ebay just like a tech 2?
  93. Suspension top bearings/what size brake pipe?
  94. Whats that sound?
  95. Digi Dash Mk3 Cavy
  96. That astra with the t34/35
  97. Car not starting. Advice needed.
  98. iirc
  99. Price question
  100. Lowering a Gte
  101. Anti rattle pins for rear brake pads
  102. central locking out of sync
  103. Speedo Needle Wobbles
  104. Rear Brakes
  105. MOT - Where do we stand?
  106. Electric Power steering into Mk3 Astra - info required
  107. Calibra BackFire
  108. actuator
  109. torque settings
  110. Vectra C temperature sensor
  111. cav gsi
  112. compbrakes top mounts
  113. '03 Vectra Satnav upgrade? Can it be done?
  114. Sensor Bracket
  115. piston sizes
  116. Cav TD Alternator squeal
  117. new tigra tick over
  118. fiat uno single wiper motor
  119. Lumpy/rough tickover
  120. Help Help Nova Electrics Gone Mad!!!
  121. rear disc conversion on corsa b
  122. 2l transplant, need more info, anyone help???
  123. Back Boxs!
  124. cool running stat, why?
  125. clock needle help!
  126. found the cause of my synchro issue
  127. Re-winding Cav odometer
  128. TIGRA Boot Lid alignment / pissed 2ward drivers side REMOVAL
  129. Anyone in here got a gokart close by?!
  130. Anyone got the wiring Diagram for Clifford Concept 500?
  131. Please Fix My Calibra!!!!
  132. Trip Comp
  133. help
  134. EPAS Wiring Question
  135. Vecy steering wheel in a cav, whos done it, Require a little info pls
  136. Mix and match Nova engines lol
  137. Brake judder.. skim
  138. ABS - Mk2 GTE
  139. astra mk4 auto to manual any help
  140. Brakes
  141. Astra SRI Performance
  142. Astra mkIII steering arms
  143. Coolant hoses
  144. Is This A Good Deal For The Money....?
  145. how do u fit heated seat elements?
  146. Heaters only blow warm when revved
  147. ECU error code 73?
  148. those of you with braided hoses
  149. Dash Computer! Anyone else have this problem?
  150. Bleeding Brakes Are A Nuisance!
  151. brake hose cylinder thingy??
  152. corsa 20seh
  153. de locking doors
  154. help needed pls
  155. god help my gsi lol
  156. Windscreen Wiper Motor issues
  157. Chroming calipers
  158. removal of ashtray to fix 12v socket
  159. astra sri flat spot on acceleration
  160. nova air flow meter
  161. 5 Stud Nova Conversion.. Dimensions
  162. Tuning
  163. starting problems
  164. What Car had 4stud 288mm Discs as Standard
  165. rear engined nova help
  166. wilwood or Hispec kit
  167. fitting corsa c angel eyes
  168. Anyone know where the outside temp sensor is on astra mk3?
  169. any ideas how to......
  170. ongoing brake problem
  171. How to route cables from car to boot - Astra H
  172. Fraud cougar a/c
  173. can someone identify this mount
  174. urgant Help Please!!!!
  175. ** Turning my mileage back to what it should be - How?
  176. aircon in a non aircon mk3 astra
  177. corsa b boot door wont open.
  178. urgent help needed
  179. reverse lights not workin bulbs are fine
  180. gaz's melted piston........
  181. pulling f 20 input shaft?
  182. nova/astra accelorator pedal
  183. vibration through steering / floor
  184. rear brake pads, how to change, needed...
  185. changeing a hub/leg how?
  186. my car blew up after 40miles ! again
  187. electric windows corsa B
  188. Zafira hesitating/juddering
  189. Few questions about my 94 astra gsi
  190. 280mm discs/calipers on a corsa
  191. Bleeding/Flushing Chargecooler ??
  192. brake problem
  193. Vectra radio display?
  194. touque settings
  195. WANTED: someone to finish my car off
  196. Right, need to finaly get these vaccum pipes sorted!!!
  197. Vec GSi / Calli T Brakes
  198. does it need skimming
  199. weired idle on my cav t
  200. where can i get a sard regulator from the uk
  201. sudden really bad flat spot problem
  202. strange sound from corsa
  203. New disks needed?
  204. thottle body mod
  205. Strutbrace problem
  206. What does a relay actually do?
  207. Is this a sign of a warped brake disc?
  208. paperclip test
  209. Part numbers needed
  210. 4pots..
  211. vented rear discs
  212. hazard light switch
  213. Overheating Astra Mk3
  214. buying a Vectra TD
  215. Nova Rear Strut Brace
  216. Calibra sunroof
  217. V6 Vec problem
  218. tuning astra g Y17DT DTi
  219. ECU ok Mk2 GTE?
  220. newbie
  221. Annoying Toad Alarm on Calibra!!
  222. Torq settings
  223. Big favor of anyone with a MkIV 3-door Astra
  224. theres any good for nova suspention
  225. Ticking Noise
  226. Astra Coupe Dimming Interior Lights/Speedo Lights
  227. Nova abs??????
  228. cav v6
  229. Cruise Control & Electric Rear Windows For Vectras
  230. Would 225/45/16's fit on a cavalier?
  231. clunking from brakes
  232. annoying brake noise, any fix??
  233. speedo gage
  234. vectra problem
  235. Body kits!!!!
  236. 2.0ltr conversion
  237. cav relay help desperate
  238. Fan override
  239. Vectra 2.5 supertouring (Bang)
  240. gsi cav alarm prob
  241. what bit
  242. air box
  243. Universal Remote Central Locking
  244. Boost Pressure Deviation
  245. Will this solve my problems???
  246. plastic windows
  247. Rear Fog Wiring/Relay
  248. wheel wobble?
  249. anti role bar
  250. spigot rings
