  1. Advice please on removing power steering
  2. hi
  3. Advice please on removing power steering
  4. Corsa Gsi Overall weight????
  5. major flood now i got blue smoke
  6. Fitting a Kenwood car stereo into a new Corsa
  7. Installing Electric Windows
  8. urgent electical prob
  9. Stereo Lock Code
  10. Performance Gains
  11. how to take door apart
  12. F15 in place of F10
  13. ignition fubard
  14. Cavalier - How Do You Remove The Cashaft?
  15. how to hotwire a car?
  16. Mk3 GSi cutout & won't restart
  17. stalk switch interchange
  18. whats the diff
  19. where can i get spigot rings
  20. Steering rack trackrod arms
  21. 1 owner 30000mls,astra gte 8v small problem???
  22. Cheap Cavalier Spares
  23. over drive on or off
  24. km in to miles
  25. FAO anyone with EPC(part check)
  26. what is the difference between an mbc & standard set up???
  27. Urgent Help please!
  28. suspension question
  29. Battery not being charged??
  30. how do I reprogram a key??
  31. Omega Rear Suspension ?
  32. Fault Code
  33. Faultcode 116
  34. HELP! Name RWD 6 or 8 cylinder cars of the last 20 years please! Thanks
  35. corsa b lowering
  36. 2.0 Corsa Rough Noise..............
  37. corsa
  38. much......
  39. Starting problems
  40. digi dash - 2 red switches on top???
  41. V6 vectra 2.5 into new car
  42. Calibra probs
  43. Stiil pulling to the left........
  44. Astra G Airbag problem
  45. This is not a vauxhall but can anyonee help me?
  46. Rubbing/grinding noise
  47. Wheel wobble.......
  48. Coupe wheels
  49. Shocks top nuts
  50. question about the amel vavle
  51. can eny one help 2.0 eco in to a nova
  52. Vectra remote key stopped working
  53. cav speedo clocks in nova!
  54. Need help please
  55. Astra - Speedometer problems! Electrical?
  56. Where to source Lotus Omega piston?
  57. Vectra Gsi Mkii Tyre Pressures Please !
  58. Cant Go Backwards
  59. ECU light after fitting boost gauge
  60. Changing to dry cell help
  61. In-car boost..
  62. can someone tell me where these pipes go
  63. Lumpy Idle
  64. Can anyone tell me what this symbol on the dash in a cav sri means??
  65. Brake Light Switch Omega?
  66. Should a brake fluid (!) light come on with ignition?
  67. Transducer help
  68. Air Con
  69. Another coolant problem
  70. Flat spot
  71. Needle
  72. Someone Help Me!! Coolant!!!!
  73. Astra G 1.7td GM to 2.0 16v dohc
  74. what management should i get?
  75. Hissing
  76. final drive ratio
  77. tigra air con not working
  78. Corsa Power steering load controller
  79. corsa digidash prob
  80. Help!!!!!! Wires
  81. V6 Wiring question.
  82. Astra mk3 - bigger brake discs
  83. Astra steering Lock
  84. vectra immobilizer
  85. Alarm problems .... HELP
  86. emerald management no knock control
  87. brake fluid?
  88. SPi to MPi conversion
  89. mk2 astra digital dash problems
  90. Few Calibra IRS/rear brakes questions
  91. steering shake when braking/ movement in f/d/s wheel?
  92. Astra H - Test Mode/Service Menu
  93. Is it worth changing discs and pads myself???
  94. ABS Problems
  95. chevette 1600
  96. omp rear strut brace fitting
  97. Omega Manual G/box bits question.
  98. Corsa Electrical Help Please!!!!!!
  99. corsa start problems..
  100. another dam problem
  101. Suspension set up & handling
  102. 51 plate 3dr astra alarm keeps going off
  103. ** Changed to rev counter clocks - is my speedo reading correctly?
  104. Need help about installing an alarm on a Corsa B
  105. rear windscreen wiper not working!
  106. digi dash
  107. Anyone running MVAUX kit??
  108. Vectra Air Con problems?
  109. Dyno test without a Dyno?!?!?!
  110. Mk4 astra wiring diagram
  111. strut brace on a corsa
  112. corsa ecu imobiliser
  113. 1.9 air box assy..
  114. whats my next upgrade going to be???
  115. marangoni tyres?
  116. 5 stud bmw wheels fit vauxhall ?????
  117. E16se into corsa b 8v Sri
  118. Stock-V-Cone Filter
  119. speedo
  120. Air bag light /ECU
  121. building again
  122. nova brakes and cost issues?
  123. vectra v6 throtle body
  124. nos or not?
  125. coolant problems
  126. Tigra/Corsa powerflex-TCA
  127. k reg nova 1.2i coolang fan fuse???
  128. v6 engiine problem
  129. 160 mph clocks
  130. looking at a nova...
  131. Is there a 100Amp Alternator that'll fit a 20SEH...
  132. RWD Mk3? Yay or Nay
  133. Megasquirt
  134. Rolling Road Print out posts?
  135. Astra GTE 16V COMPUTER DIAGNOSTICS RESULTS!!
  136. Wires
  137. irs conversion
  138. 2.5-3.0 Conversion.
  139. Vibration
  140. calliper rebuild kits
  141. double post - sorry
  142. sticking brakes again :(
  143. Electric mirror question
  144. Charge temperatures
  145. Snapped sister's VW Key - Help!
  146. Astra g air con advice
  147. paper clip test?
  148. Can someone with TIS do me a big big favour please ....
  149. Stainless Allen Key Bolts
  150. Help needed with my zafira
  151. cooling system cleaning help required
  152. help please?
  153. nova shell
  154. Astra problems
  155. Corsa Electrical Fault....
  156. Mk3 Astra Estate Shocks
  157. cars dead (help please)
  158. Cavalier SRI 2.0 8V.............Relays...
  159. suspension help!?!?
  160. Corsa C Performance Mods
  161. Distributor Help needed
  162. corsa b rear disks
  163. charging light
  164. 'Pimp OP's ride'
  165. FK Angel Eyes / Projectors Problem - To dim!
  166. Traction control problem!! Help Please
  167. electric mirrors stopped working, why?
  168. Advice on Lowering Corsa B
  169. vectra 4 branch
  170. CORSA SRi ELECTRICAL FAULT, HELP PLEASE
  171. Boot Poppers
  172. Magnex rear box off a saloon to hatch?
  173. Advice on magnecor ignition leads?
  174. Corsa Help Please!!!!!!!!!!!!!!
  175. DIY porting and polishing
  176. mileage not going up....plz help
  177. Ringing noise when accelerating
  178. Yokos Avs 100
  179. CORSA SRi ELECTRICAL FAULT, HELP PLEASE
  180. best place for an Apexi boost controller?
  181. RWD Cossie plenum pics ???
  182. Mk4 astra total closure question...
  183. Atra Mk4 Overvolting = Alternator problem?
  184. Vectra DTi
  185. Astra MK3 GSI Suspension
  186. Carrying capacity of a 1.7Di Combo Van
  187. no window washers
  188. O/S chassis leg on corsa B
  189. suspension v6 astra
  190. rear discs - corsa b
  191. What's that resistor on the rad fan for?
  192. new tyres
  193. Corsa sri 8v fault code 16, help??
  194. Chassi work
  195. cooler rad fan switch, which one??
  196. Airflow meter
  197. Strange Tinny Noise
  198. Whistling noise coming from front offside wheel
  199. Astra V6 wiring...
  200. Swirl Pots? are they any good?
  201. towing a caravan with a lowered car is it possible?
  202. Will mk3 astra rear springs fit a Cav mk3 with a rear beam??
  203. Shock Absorbers....
  204. v6 tappits
  205. Colour code - is this 'Classic Green'?
  206. corsa trouble!!!!!!
  207. Cav big brake upgrage to fit astra mk4??
  208. nova steering 'notchy'
  209. can somebody identify these ecus please
  210. Rev limiter
  211. vectra limited to 4600rpm
  212. Vectra GSi HELP WANTED!!!!
  213. brakes - someone with an Omega Haynes manual...
  214. Single Nut Wheel Conversion
  215. Vectra Slow Down
  216. P Plate Vectra Horn Prob
  217. code 145 immobiliser
  218. Vec V6 part identity help needed
  219. How do the pipes go on a late astra gsi for PAS?
  220. nova automatic windows
  221. can i get a ford car key cut localy or is a send away job?
  222. Remote central locking
  223. Auto windows
  224. Master cylinder seals...
  225. Fault codes
  226. What should I do with my Nova sunroof?????
  227. flamer kit wiring diagram needed for a dragon kit plz
  228. From Italy:technical data for my astra,please.
  229. noise when wheels turn. knocking. question
  230. info on custome made stuff please ....
  231. Light on dash
  232. fitting electronic power steering to a corsa b
  233. Renault Clio intermittent non start
  234. power steering
  235. 4 stud to 5 stud??
  236. Vauxhall calibra sounding like a scooby
  237. Corsa Suspension reccomendations
  238. second battery
  239. bled my brakes now pedal pulses
  240. tophat fitted.
  241. Suspension for GTE 30mm drop... where?
  242. Astra GSI play in steering?
  243. what suspension do u have in ur v6 astras?
  244. Bracket
  245. Mk5 noise
  246. Anyone here clued up on skylines ?
  247. Fitting power steering to a Nova?
  248. car cuttin out
  249. Wonder if any1 can help
  250. Astra Mk3 bonnet cable snapped! How do I open it?
