- uneven brake pad wear???
- Centre posts removal!!
- URGENT! temp gauge not working!
- Rear disc question
- strange braking problem
- Cav GSi running problems.......
- remote locking: pulse timing question
- vectra traction control not working
- removing aircon
- Steering Lock stuck!
- astra mk4 brake upgrade to mk5 vxr spec
- Idle Problem – could this be a expensive fix?
- Astra G 2.2, stalls and cuts on normal driving
- vectra 2.2 ls. help
- software ASTRA H
- Nova Rev gauge
- O2 Sensor Circuit Malfunction WTF HELP ME
- Temperature gauge sensor ???
- manual boost controller advice
- air con pressure to much
- nova quickshift
- Traction control problem advice needed
- Electrical / Battery or alternator Problem
- Strange Fault
- battery flat but dash light comes on when the ignition is off HELP PLEASE!!!
- '96 Corsa - Aftermarket Air Con?
- What material are these intakes made of?
- Air con again :(
- Does anybody know what this noise could be
- **non vaux warning** noisey diff?
- Need Part Number Help!!!!!
- Replacing abs sensors?
- PC to ECU problem
- HELP PLEASE P0100 Mass or Volume Air Flow Circuit Malfunction
- Cav Brakes Have Gone Sh*t After Suspension Swap
- Altenator Wiring Problem!!
- coolant change - how often?
- Corsa V6 mounts
- **corsa gsi immobaliser help**urgent
- nova prob?
- speedo query, mk3 Astra
- no rev counter and battrey aint charging? changed alt twice
- changing 2e3 to a webber on a cavalier
- Feul line
- just a quick brake question for my mate
- can anyone tell me how to reset the airbag light on a mk3 astra?
- Astra MK3 16 Pin diagnostic port help please..
- dig dash
- How much to fit Discs and pads???
- 3000GT Tuning info please
- gauges
- battery light??
- Rattle Noise
- Bollox!
- loud water noise in corsa
- idel air vale
- bleeding problem
- Car has ran out of coolant and making weird noise, advice please!!
- Noooooooooooo
- Cav dash lights playing up
- Vectra C rear hubs nightmare
- how to change a wheel bearing?
- lost key!!!!!
- battery wont take any charge!!! ALTERNATOR HELP!
- Fitting ABS to a Corsa?
- whats bettaer?
- Astra mk4 gsi bake pad query
- 1992 Opel Astra ALDL
- charging a battery with a booster pack
- spax rsx set up
- Steering knock
- c.v joints
- annoying wheel noise
- got a prob wiv ma new cav
- steering rack removal? no haynes gen!
- Astra Ignition Install Probs
- anyone know of cheap air con re gassing in South East/Surrey/Sussex?
- rear disc conversion
- dying out!!!!
- Fault dode "74".Tried everything!
- ahhhhhh hot clibra any ideas
- How do you fit a sandwich plate?
- Vectra rear suspension bushes
- how lean can i go for motorway cruising ?
- nova suspension
- V6 4 Stud Brakes
- Rear brake shoes slack/sticking?
- cav is nearly dead
- how do i get my speedo to read right after conversion?
- 20seh running NOS
- calibra problems
- help air con
- Calibra disc sizes???
- suspension help
- Code 0412 on a tigra? what is this?
- Corsa B Power Steering Question
- Ignition question
- Speedo drive goes sometimes and doesnt other
- rear hub torque value 5 bolt hub vectra c with abs
- dis pack info needed
- whys heater motor/blower sticking?
- Astra H brake pad help please
- spigot rings?
- washers on rad fan switch
- shaking on ster wheel and brake pedal when braking??
- E16se - corsa b -management light query/dis cap adjustment
- vectra e/management light?
- Bleeding Wilwood 4-pots?
- traction control advice (sorry if its a repost)
- Anyone know where to get an external wastegate....
- Running on 2 cylinders
- Zafira Central Locking
- Screamer pipe and MOT.
- calibra/cavalier struts
- Possibility of making Custom adjustable Top mounts for Cavalier/Calibra
- Intermittent starting problem (GTE 16v)
- Cruise Control Problem Astra
- Air Con Gas Question....
- Multi Info Display
- Would this work?!!!!
- digi dash
- Hit Curb - Tracking Out Any More Damage??
- vectra ignition
- Urgent help required
- Cavalier whirring/humming noise
- Cavalier Top Mount Problem
- lowering springs ??
- Hot track days
- URGENT! Powersounder Problems
- Air Con Re-gas in Berkshire
- ECU type?
- help please guys what transducer is AA for??
- Cav Sri - What Performance Mods?
- frged pstons, doi need "frged" gugeon pns? dnt cme wth ne, shop sez 150 4 rngs & pins
- irs rear wheel bearing how?
- Warning Lights
- digi dash sender prob help!
- Astra Mk 3 alternator part numbers?
- Astra GSI running problems
- air con not blowing cold
- astra digi dash in k reg 1.2i nova?
- Nova Wiring Help !!!
- When posting about problems with your car...........
- ABS light coming on....need help urgent
- please help identify this part *pic*
- worrying noise
- Anyone got an arch roller they can rent me? Midlands (will travel to pickup)
- Suspension
- Astra shocks and springs
- biting point is really low on pedal on corsa b. how does it adjust?
- hit kurb now susesion makes squeaky noise!! any help??
- vectra gls
- discs or drums?
- vacuum gauges
- Reverse Indiglo Dials
- Very loud brake squeek at low speed and pressure
- mk3 astra gsi WHICH fuse for dash warning lights?
- Wheel Alignment / Tracking seized
- Mk4 astra convertable remote roof operation...
- how to rectify fault code 66???
- Ignition lights on a Nova
- Ignition Barrel
- Deadlocking....it aint working
- Boost pipe sizes
- yes it's the management light again
- manual boost controller, yes? no?
- Battery light
- Does my gsi have air-con??
- air con
- Symbol
- cav t, PAS steering rack which models are the same
- PAS pump failing???? HELP
- Temp gauge not working...
- SPI ignition timing..???
- anyone supply mounts for conversions???
- CAV SRI some help needed please
- Help - Tigra wiring guru needed!
- driver window astra coupe
- Astra mk3 GSI weird knocking noise
- Corsa servo - running without one
- nova brake bleeding order?
- astra coupe wiring
- Fitting vacuum gauge
- Squeeling from nearside wheel
- air flow meter quicky?
- astra gsi dash warning lights?
- Fancy Doing sumthing a bit diffrent?
- max acceleration setup.
- help my car is being an animal :( lmao
- Omega temp gauge
- Help !!!!!!!!!!!!
- whats a cylinder recognition sensor????
- cars suck
- ABS Problem- HELP!!
- 2.5 v6 Vectra problem
- Corsa CL and Clifford Concept 100
- cav front susp
- Corsa L Reg Alarm Keeps Going Off When Driving To Work
- v6 4 stud drilled,grooved disks...what ones to best to buy
- if i said i need a 60 tooth -2 trigger wheel....
- Fault Codes and Reading them
- 4 more fault codes...
- How do you clean ICV? It looks like a closed unit?
- door lock wire colour...
- I need info on a Mk4 Astra
- Alternative to ARP bolts for 3ltr?
- Brake bleeding??
- PAS Yet again
- rev couter
- My Astra is beeping at me!!!
- The car is back... Some changes now!
- Where can i get 1 of these???
- got v6 calipers.....what disks do i get
- removing door pins ? ? ? ? ? ?
- hi Dash fault its weird
- Suspention Kits
- Brake Repair Kits
- ecu question
- fords! anyone in the know?
- Corsa Rear brakes locking up
- astra coupe
- Snapped studs
- Bit of a random thought about a new ecu. Experts needed
- Idle Control?
- Will a car still run if it has no clocks connected?
- electronic dash conversion
- Fault code 94 Hall Effect Switch (HES) High voltage
- car mechanic
- Few Problems
- MK3 astra side repeater wire colours?
- Help Corsa 2.0 16v broken CV which one?
- Tigra arch repair?
- Nova fan.
- BIG brakes.....
- Heater control column bulbs
- major economy issues
- What Alternator do i have?
- spongy brakes
- Tyre size?
- dastek wireing
- nova wiring
- Anybody experienced on Merc CLK's?
- Bleeding brakes
- MIG Challenge - Identify the CV Boot (With pics)
- what a turn off
- ECU Trouble
- scrap yard treasure or NOT!!!!!!!
- Nova Digi dash speed sender?
