PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Just a few little questions
  2. AVO Springs?
  3. central locking, mk4
  4. FAO 6 speed MK2 Astra drivers...
  5. will mk2 astra gte rear springs fit on a mk3 astra gsi
  6. how do you remove cav/cally dials?
  7. A/F gauge all over the place??
  8. CavTD charge light AGAIN!!!!!
  9. somone help please
  10. astra mk4 - wiper problem
  11. Strange noise from steering column area
  12. quick quick advice please
  13. I got a fault code today!
  14. Bilstein Springs / Dampers for Carlton GSI 3000 24v
  15. leccy windows on cav
  16. Making brake light a tail light
  17. Rev counter has a mind of its own
  18. Steaming Form Rad Hoses
  19. CV stuck in hub
  20. v6 into mk3 astra, 20mm spacers?
  21. wheres the id number?
  22. Does anyone here know about BMW 525's? **off topic**
  23. Radweld??
  24. Mk3 Astra V6 Conversion Mounts HELP
  25. motorsport tyre size conversions
  26. Knocking noise (again)
  27. Hub Nut
  28. Mk3 Astra van pickup
  29. Rad
  30. Which Vauxhall models share calipers? Info needed!
  31. Speedo Transducer Question
  32. are there any car tuners online?
  33. con rod's?
  34. Paperclip test MK3 Astra Problem
  35. how do i wire rev counter
  36. Central Locking "Kiekert" Pinout
  37. What is Auxilery Fan??
  38. arp rod bolds
  39. Help!!!!!!!!!!!!!!!!!!!!!!!!!!
  40. frontera dianostics plug and fault codes
  41. Starting Problem
  42. Coolant Level
  43. Tyre width on starndard vauxhall 16" twin spoke alloys
  44. *Need help* Re-intsalling Toad AI606 alarm system...
  45. Brake Servo fault?
  46. Part Number Needed for 3.0 Litre v6 Con Rod Shells
  47. non vaux problem (mx5)
  48. whats it called
  49. how do i know what software i have
  50. Coolant trouble
  51. weight of a nova?
  52. Where are the reversing light wires on calibra v6 auto?
  53. what brakes on a v6 nova
  54. Elec sunroof wiring (omega/one touch system)
  55. astra g temp gauge(conversion)
  56. urgent quick replies please. brake info needed
  57. Astra G - noise from front nearside
  58. Mpg sensor on Astra sport mk3 has gone mad, any1 know how to sort??
  59. Some Scrote!
  60. whats the best way to make a nove gte quick?
  61. astra subframe
  62. fitting kit corsa B?
  63. Sport Springs?
  64. i little help guys
  65. Mega Squirt ECU
  66. cav 1.7td izuzu
  67. Corsa Gsi idles high somtimes
  68. what are the best lowering springs for corsa b
  69. rev counter
  70. Rattle
  71. nova mk1 dash to mk2 dash!!
  72. Heater Controls
  73. Rear wheel shake...balance?
  74. Opinions sought on 2.5 V6 Vectra Estate
  75. big brakes.. are they worth it?
  76. How to remove stubborn wheel nuts??
  77. How do i remove Carsa C steering Column?
  78. Split CV Joint(Hard to change?)
  79. Front wheels dragging on full lock
  80. Manual to Electrical Mirrors & Windows?
  81. Paul Here's A Message For You!!!
  82. can anybody tell me where the ignition relay is on an astra mk2 SRi ?
  83. Help
  84. diagnostic port
  85. car still juddering...
  86. Confused
  87. no vacum
  88. Anyone corner weighed a Nova?
  89. problem with Gmax lowering kit on 1990 Cav GSI
  90. Astra MK3 standard suspension?
  91. any gen on where this lower brace fits?
  92. were can i get a turb from?
  93. daewoo nexia
  94. replacing my rev counter
  95. fitting a/f gauge
  96. Whats up with my car
  97. Another Corsa Conversion Question.
  98. Slight running fault on Corsa B Sri 8v
  99. Astra mk4 Estate Bumper
  100. my alternator is charging at 13.3volts
  101. Installing a rev counter
  102. Gsi Trip comp
  103. Coversion Kits Where To Buy
  104. nova dash wiring
  105. Steering wheel SHAKING at 60 mph WHY??? HELP plz!!
  106. Steering wheel SHAKING at 60 mph WHY??? HELP plz!!
  107. idling problem with escort 16v
  108. Radio and rear screen de-mister
  109. How many revs is fast idle??
  110. Cavy Front Splashguards
  111. hw much diff does port matchin make???
  112. Plug gap for V6 eco
  113. Vauxhall Astra Estate
  114. V6 heater matrix
  115. electric power steering
  116. mk3 cav and astra mk3 front leccy windows the same?
  117. astra troubles
  118. Air Flow Meter help needed in Manchester
  119. Going to get a gauge tomorrow .
  120. do i need a heater matrix?
  121. Ignition Leads - Is there really a difference?
  122. New astra rattle
  123. Omega electric sunroof in to Mk3 Astra
  124. cav v6 cv joint queiry
  125. heating problems!!!!!
  126. standard boost hose dia
  127. mk3 pas rack (how hard to change??)
  128. leak down test RESULTS
  129. how hard is it to bend a car?
  130. 4 pot brakes really that good??
  131. horn?
  132. CDCR 700 Stereo advice please (one with the phone)
  133. ecu light on
  134. Have I got the most expensice brake pads on Mig - it feels like it
  135. astra struts mk 3 mk4
  136. Getting under astra mk4 side panels without breaking anything!
  137. Mis-fire on low revs
  138. rev counter out of v6
  139. Astra Sport 2 litre, why am I getting 20mpg??? :(
  140. 1400 mpi difference to spi??????????
  141. Rev Counter
  142. cavy gsi rev counter
  143. Belmont 1990 18SE Disc brakes
  144. Front of car Knocking!
  145. Calibra running problems
  146. Brake pads
  147. Probably been asked a million times before
  148. Nightmare Conversion CF/M to LB/M
  149. astra gte 8v-16v
  150. Nova SR Help Please!!!!
  151. bad starting
  152. North London, Harrow Help pls
  153. Cav Stalkes into Nova
  154. nova rear disc convertion
  155. Cav Brakes - Part No????
  156. which ECU???
  157. run stop run stop
  158. Diagnostic Problems !!!
  159. Astra cabby hydraulic fluid???
  160. crunching noise
  161. Astra mk4 2.0 Sri
  162. Mk4 Astra SXI problem - please help!!!
  163. v6 brakes
  164. ECU differences
  165. Manta B question
  166. enigne temp
  167. Vauxhall Service Price?
  168. mk4 astra 2.5 V6 what engines fit???
  169. What springs to replace the Ventura's with
  170. another strange noise
  171. T34 kits from matheus updates...
  172. My car rattles like a tumble dryer
  173. Indigo lights/Dashboard light
  174. Vectra MFD Question
  175. Erratic idle
  176. Cruise cable/actuator
  177. Temp never rises above 90.
  178. Hissing Air Recirc
  179. Cavalier - Wet Carpets
  180. vauxhall silver alloys-but what silver? as they don't give a paint code!! please help
  181. how to remove ignition barrel
  182. ignoring lamdna on 20ne
  183. Revs
  184. ECU Question (Ford Related - sorry)
  185. help!!! what offset do i need
  186. What does the Hall Effect Switch do?
  187. digi dash into corsa sport
  188. thumping noise from nearside wheel.cav mk3 v6
  189. Timing
  190. Judders
  191. idle speed problem
  192. abs lamp on cav gsi
  193. ECU dfifferences on Cav SRi 2.0 8v
  194. Help please
  195. What does a hump hose do?
  196. vx220 clocks
  197. ECU help
  198. K+n?
  199. Heater blower not working, what can I check?
  200. suspension
  201. Reesetting a vacuum gauge??
  202. Will Cav GSi suspension fit a Calibra
  203. Where's my BOOOOOST?
  204. HELP PLEASE!!! Nova keeps dying at lights etc!
  205. Help needed please
  206. what to do about my front end.
  207. Astra Mk3/F Slam Panel
  208. electronic speedo systems??
  209. VVT Technology
  210. Bump Stops
  211. Astra Mk3/F Facelift Version
  212. have a part no. wats it for??
  213. Vectra door handles on Calibra: help needed please!
  214. inside of tyre rubs anti roll bar and wheel arch on full lock
  215. Code 35 - Idle Stepper Motor
  216. Compression test on Lotus Carlton
  217. Does anyone know what I/C this is? Found it at scrappy!
  218. tryin not 2 get angry with my corsa
  219. Astra Mk3 & Calibra - Common Components
  220. Help on Astra Mk3 Heater + Fan Probs!
  221. Corsa Cracked B Pillars
  222. can anyone tell us what 303 fault code is please?
  223. Nova rear springs
  224. looking for switches
  225. calibra rethink!!
  226. After a bit of help - thanks.
  227. Tech 2 Fault showing Low Voltage?
  228. ticky rebuild
  229. Boost gauge problem
  230. Vauxhall Calibra Washers
  231. replacing steering wheel with an airbag
  232. where should this pipe go?
  233. Where is the ECU?
  234. astra/cav/cally struts all the same??
  235. ? about fog light on dash
  236. vectra v6 and cav v6
  237. Jacked car up, now squeaks like a mutha!
  238. Ford people, need some advice quickly
  239. help
  240. help please.digi dash into a mk2 astra 20l 8v
  241. HID fitting help please...
  242. loan of leak down tester needed !
  243. more possible trouble
  244. Number plate lights - Astra Coupe
  245. Argh! Damn Car!
  246. Please I.D. this fuse...
  247. Urgent!!! Please I.D. water pipe?
  248. v6 calibra central locking
  249. ok can we have a definitive on this please. emission check question
  250. Central Locking issues
