- Just Need Some Advise Please:
- Wrecked another tyre. Height Issuses or Suspension Issuses?
- The 3.0 Calibra Awakens!
- Brake light wire
- Astra G rear calipers
- My Chavalier has a floppy knob....
- vectra charging problems
- 02 sensor
- replacing calliper piston seals
- Front Fog Light Switch Wiring
- v6 brakes
- weight?
- Rolling Radius
- Electronic speedo drive cables question. Help Please.
- i know its not a vaux but does anyone know about renaults
- urgent help needed b4 pod on sunday
- where can i get the wee tie-wrap type things for mounting a fan to a rad?
- Calling all Bike Mechanics....
- thread size of water temp sensor?
- Start up problems!
- 16" irmscher softstars and big brakes?
- Cav GSi wouldnt start...???
- Astra 2.0 Dti Fault, error code 1651
- 98 Omega, strange beeping sound.
- Compbrake components, anygood??
- Temprementle boost problems
- Where is this ment to go?
- Watertemp sensor on 20SE
- URGANT help....DV problems
- gsi2000
- DIY big disc kit.
- any advantage of putting steering arms below the knuckle - nova
- battery bag / cover where from ?
- squeaky brakes
- pas pump/pulley, squeeling/squeeking/noisy
- gsi sunroof
- Can you remove / replace Nova bonnet hinges ?
- MK3 Astra fuse box relays? Should i have 6?
- Quick Silly Questions - Brakes - Removal of Guide Bolts on Caliper
- Any Jaguar forums or anybody clued up on their jags?
- Free gift for you !!!
- vauxhall astra rear wheel bearings
- Free gift for you !!!!
- Rod ratios - What figure to aim for?
- buying and refurbing brake calipers ?
- 12V compressor from Frontera / airhorn
- Electric Windows - Corsa C
- help needed with omega ht leads
- not vaux, but for auto box??
- clio question..... (non vaux i'm sorry!)
- air box mod???mk3 astra gsi
- IDEAS for selfbuild centre console for mk3 astra
- standard nova rear string length anyone?
- subie doe's a 9.1 at 157mph, given my m8 an idea! please read
- astra gsi
- my astra is p!ssing me off again...
- Boost Problems
- nova lamp pod connector
- Help Needed Urgently
- nova boot release with a difference- help
- anywhere in Surrey besides Vauxhall who has Tech 2?
- Astra Bertone 2.2 ABS+TCS MIL on start up
- where to get mounting brackets to fit calipers?
- 2l eco runings prob's??help please??
- astra 1999 weird noise
- quick question-nova door
- whats the best brakes as close to £500 that will fit under 15" wheels for my zafira?
- Siemens 5wk7331
- Speedo/Rev Counter wiring
- Lowering springs
- astra mk3 mfd set up with cav gsi switch?
- advice needed for my mums 02 plate corsa
- Astra F, Slow idle
- fitting cobra suzuka seats to nova
- Problems!!!!!!!!
- Nova revving high
- v6 holding back
- Coolant guage acting weird
- Should my Hub look like this?
- Grinding \ Rubbing Noise From Passenger Footwell
- Cylinder 1 misfiring badly.
- Need a clip for a cv boot - how big are they?
- Just bought me a 2.2 astra coupe
- 16v conversion
- Speedo swap
- need some corsasport measurements
- rear disc conversion on corsa b
- have all corsa gsi's got f15 cr box in??
- ABS Problem
- differences between 16v and 8v
- Battery Giving off Fumes, Is it ok?
- abs problem
- EM light on Astra Coupe
- Can I get new key to replace lost one without new lock set?
- Does this look like a calibra front strut brace?
- car pulls slightly to left - what's the cause?
- Audi TDI problem... Slow as fook...
- Re-fitting Cav front nearside window ?
- trip computer
- fault codes 15 and 113
- Safe revving ????
- Corsa Brakes?
- ANYONE HERE USES MSD ignition amplifier(DIGITAL 6 PLUS)
- Astra MK4 - problems with Safety Lock
- Bleeding Brakes on T-Reg Corsa 1.2 16v
- Automatic to manual
- nova outer CV quickie...
- Urgent PAS Question
- ECU Light coming on during deceleration and no speakers!
- contact number for msd in blackpool?
- quick digidash question
- rad options on a mk2 astra
- blower
- Fault finding diagnostic plug
- Boost Pipe Q
- New To Forum, Couple Of Questions
- legalities of hydralic handbrake?/opinions?
- best place to buy polybushes corsa b
- Wedged socket
- Idle CO potentiometer
- What would you recomend?
- single point to multipoint questions
- Steam and pipe split
- tigra automatic window
- Calling all Emerald ECU owners or anyone who might be able to help!
- Tyre size on a Vectra?
- How to work out how much my cars lowerd?
- astra mk3 up the ante
- nova gsi 2.0 16v vs corsa gsi 2.0 16v
- Vectra brake light switch
- Corsa Sri 8v into Nova ?
- 2002 astra front hub assembly???
- Astra Mk3 RPM Meter
- corsa front end strength
- 2L 8V advice needed
- cossie boost sorted!
- Vectra 2.2 DTI.. Cold starting Problem..
- How to adjust lights hight in astra G?
- Boost + ECU problem error 113
- ive gon n broken it aint I
- ABS Removal Help Corsa GSI
- 4 stud rear disc conversion on mk4 astra
- FAO anyone using a widetrack kit on a nova
- Battery light
- lower suspension arm bolt slightly bent - is this ok?
- Wot strut brace
- Brakes dont work, then they do....
- Do you know what this is?
- ABS pump keeps running
- Urgent Help!!!!
- Will V6 calipers clear these alloys?
- What strut brace?
- Pic's of big end.
- Centre silencer annihilation device.
- Anti roll bars.
- speedometer unit
- Corsa B eps Steering UJ to rack bolt
- Locked Transx box or not *PIC*
- who makes the custom digital dashs for mk3 astra
- corsa electric windows....?
- urgent urgent help needed!
- my roof won't close astra convertible
- Equal lenth shaft on a NOVA any done it?
- suspension info
- nova hazards problem
- Which Vaux Has The Same Front Struts As A Senator?
- fuse trouble
- ignition barrel
- Astra G Sri Overheating
- twin webbers
- Opel Manta Wheel Conversion Plates
- vectra rear discs
- my car lost drive
- No boost on Sierra Cosworth?
- Where do you buy you tools ie cheapest place
- hot hot hot
- Short Bodied Strut Conversion
- anyone help with mvaux kits
- finally my van is ready
- Corsa rear beam?
- KYB shocks?
- Corsa B master cylinder gen
- V6 28mm disks on tradeclub weirdness
- Reversing Lights
- Loud squeek when i go left???????
- 2.2 direct
- corsa suspension will it fit
- Astra Leather Interior
- 2002 vectra 2.2 sri traction control?
- creaking/groaning Astra3 front end.
- Fixin car and spotted something I dont like - leaky leaky!
- track attack!
- Damp centre console, water in the heater vents...... Knackered Matrix?
- Gen on Nova sunroof and non sunroof cage fitting
- Anyone know mk3 Astra wiring really well?
- can anyone make sence of this guage?
- Astra MK3 V6 conversion direction
- Alternator problem
- 5 stud conversion on a mk3 1.6 sport, is it poss?
- chevette conversions
- Dash earth?
- Mike's car question
- corsa gsi help wanted
- car drives like a dog (handling/torque steer)
- cavalier springs
- Cavalier uprated mounts
- converting Wber ALPHA gold kit to run on dispac??
- auto close windows on remote locking?
- Mk4 Astra Strange Noise
- Replacing Resonator box with pod filter
- whats this wire??
- air bags
- hybrid needed any ideas where??
- perished bushed on mk.3 ast est
- V reg Vectra B airbag fault.
- couple of stripping<>tool questions
- 92 Astra rear brake locks on at speed !
- Nova Springs in a corsa c ? Help please,,
- mk2 & mk3 astra strut brace
- second hand master cylinder
- leccy windows
- Please help me out!!
- Ht Lead sequence for Gte
- Fault code, corsa gsi!
- Knocking Noise - Corsa C
- Hoses.
- stalling problem/rough idle
- My car is buggered............i think
- Inner CV joint replacement question?
- MFD Wiring (FAO Mark T)
- cavalier electric sunroof
- astra coupe rear anti-roll bar???
- Speedo cable into 6 speed box
- anti role bar fit ment
- cooling system excessive pressure!!!
- Where can I get...
- Bore of trotle body???
- just fitted
- Central locking
- Digi Wiring Diagram
- Are 8V and 16V shells the same?
- Fan switch thread
- speedo question
- putting air con into mk3 astra
- astra fly by wire
- ignition help......
- mk3 astra gsi trip computer??
- Sunroof Rebuild
- Conversion questions (with pics)
- SRI 130
