  1. i have codes...how do i fix them?
  2. rear wheels
  3. Anyone got access to a Vaux EPC ?
  4. corsa front suspension q
  5. Rear discs on a Corsa.
  6. Manta B rear discs?
  7. cant setup boot popper right?!
  8. bilstein shocks tool
  9. HELP! Wiring prob (non-vaux).
  10. vectra subframe
  11. which transducer??
  12. any one know the part number........
  13. Can I shotblast callipers?
  14. Mk4 Astra Ignition switch
  15. cavalier gsi refuses to start please help
  16. Bleeding brakes on corsa b
  17. need 12v terminal with ignition on only - vaux Tigra
  18. corsa idlein problems
  19. Steering rack turns
  20. How Anoyying
  21. Cav Cdx V6
  22. "height" of brake discs?
  23. Problems with wiper/motor
  24. Airbag steering wheel change...
  25. Need partnumber from fidanza!
  26. Astra GSI Mk3 Speedo Question
  27. right here goes!!
  28. needed of some help
  29. Can some one please help me!!!
  30. Tech2, Tech32, Tech40 ???
  31. Fitted the 440cc's but....
  32. rear disks info
  33. Braking problems
  34. leccy mirrors!
  35. Central locking problem on 1996 vectra
  36. corsa sri revving to 4500 rpm all the time
  37. Steering wheel vibration?
  38. Helicolding advice
  39. help on lowering my car
  40. t40 jeting
  41. calibra steering rack brace
  42. Have I got an ATB?
  43. Cavalier Problem
  44. recutting a thread, thread...
  45. Help
  46. Suspension
  47. Brakes really poor on MK4 CD
  48. lowering emissions???
  49. Nova track rod ends? Same as corsa?
  50. Help Wiv Corsa Ex Conv
  51. Nova door pin removal
  52. Rusty brake discs, too far gone?
  53. 2 speed cooling fan question
  54. cheapest way to get a new key and fob for a vectra
  55. digi dash dull
  56. battery warning light on when driving!
  57. these any good...
  58. prob with MFD... ASTRA.
  59. Astra Mk3 Angel Eyes
  60. surface rust on discs
  61. Newish Fiesta central locking keyfob problem
  62. so whats the air pump thing infront of the battery?
  63. mk3 astra (gsi) expansion bottle
  64. Electrics Voltage problem !!!!UPDATE!!!!
  65. MPi
  66. Omega Total Closure Sunroof problems
  67. Corsa Speedo Not Working
  68. gsi starting probs
  69. vauxhall flip key
  70. Electrics Voltage problem
  71. limiting 4.5rpm
  72. Help Needed!!!
  73. best brake pads for low dust?
  74. Grooved disc & EBC brake disc question
  75. Hyd hand brake and pedal box question Help please
  76. connecting a car dvd player...?
  77. cavalier central locking fuse
  78. vauxhall mfd's
  79. car kept going
  80. car kept going
  81. anyone got a tech2 ?
  82. Vectra gsi v6 knock sensor 2
  83. starting motor?
  84. cant change display on mfd!!!!!!!!!!!
  85. compression ratios
  86. Glovebox light wires question
  87. zafira mfd question
  88. Adding Cruise to 06 Zafira - New stalk, no cruise
  89. gsi starting problems
  90. Jetronic airflow sensor and backfiring
  91. MK3 Astra 1.7TD blowing steam?
  92. Anyone got any of these they wanna donate/give/sell to me??
  93. Interior Light Wiring Info Needed
  94. my dizzy cap
  95. water loss suddenly
  96. steering wheel/airbag change?
  97. Changing ECU Unit on Corsa ?
  98. Snooper wiring
  99. vectra b rear lights prob?
  100. Quick Wiring Help....
  101. brown octane plug
  102. vectra st steering wheel
  103. HiSpec 4 pot calipers
  104. Vauxhall Discs vs EBC
  105. Vauxhall Discs vs EBC
  106. Is an astra coupe wing mirror same as normal astra?
  107. PAS hose hard as concrete! is that normal?
  108. Side lights HI/LO module thingy...where is it??
  109. Astra g steering wheel in corsa B
  110. butterfly questions
  111. More deisel trouble
  112. mk3 gsi windows no worky??
  113. service light
  114. Difference in hub size on Calibra rear discs
  115. Life after 100k...?
  116. Nova front suspension
  117. how long to convert a corsa
  118. brake probblem on coupe ??? unsure ???
  119. rear door window conversion - astra mk4
  120. reset an ecu
  121. droning noise from the back
  122. Starting Probs, Please help...
  123. Very crap MPG!!
  124. HELP!! How can I remove the std alarm/immobiliser on a calibra???
  125. Why does a SPI 1.4 astray have a 70A alternator?
  126. cavalier brakes
  127. taking in alot more air- and its working!!
  128. SHES RUNNING!! WOOHOO... but i have codes
  129. vectra gsi-fitting a power steering rack?
  130. 308mm brakes behind speedlines
  131. mk3 astra help
  132. vivaro 1.9dti power+speedo problems!
  133. lamda sensor
  134. Vectra warning light
  135. Temperature gauge problems.
  136. help asap!!! timing on 20seh
  137. K reg MK2 Nova Buzzing from fuse box?
  138. Help/Info for replacing the standard aerial on a Cavalier...
  139. moving batt to back of car
  140. Corsa WRX?
  141. piston rings Fitting
  142. management light comes on when i accelerate?
  143. Replacing Cavalier Anti-rollbar Links
  144. Overheating Cav T
  145. Astra MK3 ignition switch woes - I think ..??!
  146. traction light and ABS light on all the time.
  147. help help help
  148. Aaaahhhh s**t, is this buggered??
  149. Help Needed!!
  150. help needed
  151. rear wheel touchin arch
  152. vectra 2.2 sri airbag
  153. Is this why my car runs so crap and failed MOT emissions (pic)
  154. will bargain gmax kit fit my corsa - help ?
  155. electricity short circuit
  156. Which Aircon Compressor for 2.2 astra
  157. steering lock woes
  158. vectra dash
  159. Cav clocks in a corsa
  160. help with speedo!
  161. Reasonably priced electric impact wrenches.
  162. Non Vaux help
  163. Electric window probs
  164. are the brakes from mk4 astras the same as zafira?
  165. To change Coolant Temp Sensor, partially drain water??
  166. vectra b remote locking
  167. cav windscreen
  168. Cav Mk 2 Help Please!
  169. Front bumper with foglights
  170. Preston Garage
  171. boost from a compressor
  172. Kangaroo problem NOT SOLVED! More help guys:)
  173. Astra Coupe 2.2 mods
  174. Need some advice on technical jargon
  175. v6 flat after 3500rpm????
  176. Astra pulls to left
  177. Stupid Angel Eyes
  178. 20 se and seh
  179. firing order
  180. HT Leads in the way after top end rebuild
  181. Please help im in deep poo poo
  182. How hot will powdercoat withstand????
  183. Anyone with a VXR Astra/Zafira in the Reading/Berkshire area?
  184. Air sensor or something similar... where is it....
  185. Tech specs on 2.5TD Omegas
  186. Calling al mk3 astra owners thats fitted a v6 badboy..
  187. big brakes with 15''
  188. Are all Corsa hubs the same?
  189. cav gsi mk3 problems
  190. x-police v6 cav.. 6 speed or not
  191. Nova conversion
  192. How to unplug drivers wheel airbag?
  193. 3.0 V6 with cone filter...
  194. best suspension?
  195. urgently needed tonight, brake pads cav't
  196. Quick question - Astra GTE 8v & 16v shafts
  197. Calibra 2.5 v6 traction control
  198. MOT Emissions failure, advice please
  199. angel eyes
  200. Hydraulic lifter bore problem...
  201. 95 astra ignition switch
  202. inner cv joint poping out
  203. Fitted bilstein front shocks, now sticky steering
  204. Cruise control.........
  205. Corsa GSi Running Problems
  206. Need some help for my wierd problem
  207. immobiliser vectra 51 plate
  208. best brake pads to use????
  209. CORSA C wiper problem help please
  210. 2 questions
  211. car chokes at lights?
  212. ECU pin data
  213. peoples oppion on megasquirt ms2 kit?
  214. squeaking shock
  215. nova bleed nipples??
  216. cav fan switch
  217. Cruise control..............
  218. Nova changed brakes help!!!
  219. Will Calibra ignition & door locks fit Corsa
  220. URGENT! 17s on a corsa
  221. Quick and easy one (I hope)
  222. S button on Auto box
  223. fitted new tapets...
  224. 1.7dti problem
  225. Air bag Light
  226. Momo wheel onto corsa with airbag
  227. will this work ?
  228. speedo question (newbie)
  229. Parts I ll need .. help
  230. Black Rubber Hose suppliers
  231. Corsa advice
  232. 4 Wire o2 Sensor Question
  233. lowering help
  234. fitting a fan switch
  235. best place to buy corsa suspension ??????
  236. astra convertable roof
  237. Electric mirrors???
  238. i have issues
  239. high mileage??
  240. 95 Corsa key number
  241. Cavalier squeaking like mad..
  242. saxo vtr's a little tech help please...
  243. power steering probs
  244. Seat Heater Switch
  245. Bolting aftermarket seat side mounts to the floor pan - safe?
  246. would this work?
  247. cav ecu wiring
  248. omega v6 problem fault code
  249. Silicone vacuum hoses
  250. Cav v6 faults
