- Astra Gsi Computer
- corsa b could i put in a corsa c lump?
- mk3 gsi help needed
- Nova steering clunk
- astra mk4
- AstraVan boost
- WINDOW WASHERS WONT WORK !! pls help
- Inspection Notice
- 2.5 in a corsa??
- nova running
- battery warning light on but its charging?
- pours mod
- i need help people!!!thanks
- uprating standard suspention
- c,v question
- Would one happen to have
- Performance diference between these intakes?
- low voltage?
- 20ne or 20seh
- Nova Electric window + central locking wiring, Help!
- car electrics help...
- Is 12.3V a sign of a battery in good/bad condition?
- ECU/ESP Help?
- flat spot
- Astra MK3 airbag light reset?
- Disable Pas Airbag on a Corsa C
- Strange one.....
- paper clip test
- Universial joint
- astra fault code 24
- cv's
- starting/running problems
- the fastestr 4cylinder car is in malta pics inside
- Springs and shocks
- conversion help
- Astra coupe service - What parts do i need?? Help please :)
- anyone ever made a bellhousing adapter
- omega 3.0 into a cav??
- gte dash ????/
- reverse lights not working??
- Anyone got EPC installed can help?>
- Wiring Help
- Corsa Nova top mounts question
- vectra gsi diagnostic needed.
- does any one have a gemini alarm?
- im getting code 13
- how to do an external wastegate?
- vacuum fault
- Corsa B wiring question
- good powder coaters in liecestershire area?
- Calibra 3.0 V6 Now on the road...
- are my disks on wrong???
- Steering trouble
- Will Cavalier roof bars fit a 1996 Vectra Hatch ?
- Corsa Brakes
- immoboliser
- nova rear disk
- How to launch an auto from the lights?
- Corsa V6 ARB question
- Front suspension
- Twin 40's on an E16SE
- what does this mean?
- Astra Mk3 Heated Electric Mirrors
- Didgi-dash transplant gen?
- What would it be worth?
- knocking noise
- Fitting Indiglo dials
- Temp guage isnt working on calibra, what could it be?
- Suspension question
- mk4 sri. elec mirrors?
- Astra Mk4 fan problems
- Gauges
- Cavalier thermometer over-reading
- nearly overheating!!??
- Is this okay/Normal!!!!!!!
- which cv's
- big end shells
- 8v Tuning
- Tell tell signs of a dieing CV joint?
- sloppy shifter
- frontera wind up??
- Help from MBE Experts
- Nova door hinge
- Full Beam Problem On Astra Mk4 Sri
- cooling fan
- whitch brake calipers
- mk4 gsi, best mods?
- Tigra Rear Brake Conversion
- quick brake question
- juddering brake pedal - corsa b
- Vaux Specialist near Sheffield?
- nova windows
- judder/smell/when driving
- Astra G Cooling Probs
- Possible boost problem??
- Corsa V6 suspension problem
- squeeling from drivers side.
- Squealing whilst turning
- stalling vectra
- astra keeps stalling
- Digi Dash Problems (please help me)
- Car trailer hire in North East
- Different part numbers on ECUs
- 2.2 vectra power steering gone
- mk 3 astra v6 conversion
- Corsa sport speed signal?
- Cavalier V6 suspension question?!
- A couple of probs that i reckon you boys could help me with
- wheel stuck on
- corsa sunroof prob
- Rear Windscreen Wiper
- help with a fault code
- nova with v6 front brakes
- vectra door locks
- spare plugs?
- starting problems(corsa)
- 2.0 dti vectra air bag light help!!!!
- Lowered Suspension Help
- my dads astra failed to run today :(
- T reg corsa sport alarm wiring?
- Wrongly gapped plugs...
- Rough Running Cav???
- Brake part name?
- How to bypass a vectra immobiliser
- Opinons on bad starting please people....
- power hood mk2 ??? where to mount motor ??
- omega autobox P0730
- What size brakes?
- corsa speedo blowing fuses
- newbie!!!
- Astra Gsi V6 Suspension
- N plate calibra 16v remote alarm fob problem
- Opinions on condition of my plugs - PICS
- how low should a go
- astra g sxi em light on
- OE cd player advice
- which discs?
- best way to stop leaking rad??
- stepper motor
- funny prob with brakes
- Mk3 astra GSi Ecu
- Temperature Hand rising through the roof,
- Brakes have gone
- Brake Pad Help Needed - URGENT
- brake master
- Charge temp sensors
- HELP
- codes
- Quick help for NW peeps
- where can i buy 10mm magnacor leads from
- Ebay resistor mod TESTED on rollers by APT - results
- Front struts Mk2 -Mk3 the same
- ive sprung a leak
- who can do a good set up...im in brum
- Difference between a mk2 and mk3 strut??
- Apexi
- twin 45's angle?
- Dropping my corsa HELP
- blowin fuses
- springs
- Car not idling.
- Astra Sport ecu faliure!!!!!!
- Anyone know if Senator/Carton/Omega diffs are all interchangable?
- '02 Corsa steering wheel audio control
- Vectra Front Wings
- Calibra pulling to the left and knocking when Accelerating?
- Astra MK4 8v or 16v ?
- Vectra/Cavy shafts
- Battery light on dim on cold mornings.
- ABS problem
- Piston slap gen...
- Timing gun settings...
- c 16 se ?
- quick question ..
- 1600 Conrod Question
- nova handling
- over tightened bolt on rocker cover :/
- mvaux kits
- any cav gods out there?
- 19mm Drill bits
- 16se auto
- corsa wipers
- how much are they worth
- Fitting Omega electric sunroof motor into other cars???
- corsa b 1.5 td timing
- cheapest place for front swinging arms cavT
- What Gerabox??
- dyno figure weirdness....
- Alternator charge bulb and wire
- Anyone know about 24v Senators? Jus bought one! Probs!
- why does my car lie to me???
- corsa sport suspension??
- cdti starting problem
- v6 gauges
- Take your car to VXR !!
- cdti both fans
- Is my ECU broken on my corsa B?
- parts for full re-build
- Getting that extra bit out of an 16 16v?
- testing a water temp sensor?
- Omega immobiliser problems
- corsa gsi - springs
- Lowering help,not lowering lol
- help please im stuck
- Were 1.6 16v and 1.6 8v brakes the same?
- surely someone can help ?
- What size wheel studs - MkIV Astra?
- evo 5 software...anygood?..what will i need for it to work propely?
- Corsa C hub question
- '97 corsa sport 1.4 16v not blowing warm air?
- 95+98-a or b
- astra running worse than sh!t
- can u see these picks. electrical fault.
- Mk3 Astravan Lowering Help
- astra van clocks!
- cav GSi running problems
- Corsa vs Nova?
- Resistor mod....help please
- Problem with 2.5 v6 veccy
- car is possessed?!
- random plug on my v6
- COMBO C - CANBUS - query and questions
- vmax dudes
- Help! Help! Please Slow V6
- electrical probs (pictures)
- The probs all in one thread, plz help!!
- Noisy Air-Con
- Corsa B springs
- car is juddering at low revs :(
- are my springs on the right way round?
- Omega 2.5TD Hot Start Problem
- Tracking problems! Bolt seized?
- Suggestions for a stripped thread
- carlton rear caliper
- Airbox
- astra starting problems
- Corsa b heater box
- Timing up 2ltr ecosh*te
- Tail light problem mk4
- V6 Hit and Miss!
- flash codes
- Coolant Temp
- GT28 Actuator
- rear disc info
- Unipart brake pads - What do they fit
- 2.0l 8v into corsa from above?
- Astra Bertone binding brake
- Can i do a 50m Drop HELP ME!
