  1. 5 rib or 6 rib alternators on MK3 Astras ?
  2. Senator LCD dash instrument cluster wiring
  3. Astra 1.7 Dti 2003 - Alternator replacment and now brake fluid leak
  4. mk4 astra power steering wiring (c20xe conversion) help needed
  5. auxiliary coolant pump astra mk4 gsi
  6. Coilovers with camber adjustment
  7. Lot of fault codes Z18XE after engine replaced
  8. C20xe Starter wont kick in
  9. Chipped ecu for c20xe corsa
  10. Fuel pump problem? MK4 Astra
  11. corsa b interior loom
  12. Astra MK3 Bias Pedal Box
  13. GTE Digi Dash wiring
  14. Nova starting loom on C20xe
  15. X14XE Corsa 16v 1998
  16. plumbing in my c20xe
  17. alternator tensioner problem x10xe help!
  18. corsa b c20xe wiring !
  19. Alternator replacement MK3 Astra
  20. drilling 4 stud discs to 5 stud?
  21. will 4 pots off a corsa fit astra F 5 stud ?
  22. Vectra c brake upgrades
  23. What are these shocks? HELP from picture..
  24. 256mm calipers onto 308mm discs
  25. inner cv joint excessive wear
  26. whats the best gold brake paint/spray
  27. 1/8pt fitment is it the same as 1/8 npt
  28. C20LET HT Leads where to buy?
  29. omega variable speed wiper stalk into a corsa b
  30. saalibra
  31. mk4 astra coupe window fault
  32. Zafira GSi Management System Light not on at all
  33. corsa brake upgrade
  34. Front Brake Pads for Mk4 Astra GSi with VXR Setup
  35. 288mm brakes spongy on my nova
  36. Electric oil temp sensor black and white wire where do they go
  37. Corsa B Strengthening For Rally Car Use
  38. Tigra/Corsa B - Suspension Question
  39. camber caster adjustment? anyone in the know?
  40. Vauxhall 5/30w long life fully synthetic oil. Ok for diesel and petrol?
  41. Mk4 Astra rear caliper carrier bolt size
  42. whats the shortest oil filter for let
  43. DTK diesel tuning
  44. Astra Mk3 power steering | Tightening
  45. Astra gsi check control in a Mk2 Gte 8v......
  46. astra g c20xe conversion + brake upgrade
  47. V6 calibra temp gauge / fan issues
  48. Rear door electric connector - Astra Mk5
  49. calliper attachment bolt thread size??
  50. what torque setting for c20let cometic gasket
  51. where can i fit an oil pressure sensor on an let
  52. vecra stearing
  53. Vectra cat code
  54. Front wheel Bearing to big????
  55. C20XE - Nova - No spark
  56. dash lights
  57. oil temp sensor is it ok in the sump
  58. oil pressure snder for digi dash and oil pressure gauge
  59. c20let fuel pump
  60. Mk3 Cav/Calibra Diagnostics Plug
  61. refurbing hispec calipers
  62. Astra Coupe Towbar? Which one?
  63. buffing
  64. C20let amal valve wiring
  65. GTE Digital Dash in a nova?
  66. digital dash illuminates green but no digits
  67. Vectra B 1.8 16v - Fuel guage issue
  68. astra mk3 electric mirror switches-interchangable?
  69. Astra 2002 2.2 - TC and ABS lights on
  70. Vectra thermostat help
  71. Coras B HIDs
  72. how to wire in a diagnostic port to a late C20XE
  73. rear end knocking
  74. C20LET Corsa - Jump leads the wrong way round!
  75. fog light switch help
  76. Brake pad retaining clips
  77. help im not gettin power to fuel pump ???? was fine this mornin
  78. Vectra B 2.5 V6 GSI - Juddering
  79. v6 cavalier front disc thickness
  80. afr gauge wiring help
  81. yaw sensor & steering angle sensor
  82. ignition wiring for carbs... HELP !!!
  83. opcom, how the hell do you upload it to ya laptop?
  84. C20xe no spark
  85. Are these genuine phase 3.5 chips or copies
  86. can i run 2 batteries from this alternator?
  87. Corsa c wiring diagram
  88. Help, my car has a mind of its own...
  89. Corsa c mfd clock wiring
  90. Corsa B Chassis/Gearbox Mod
  91. corsa b lower strut bar
  92. Wiring schemes for Vectra A 1.7TD
  93. C20LET - No spark
  94. What about TA-Technix springs? Astra MK3 GSI.
  95. Vectra central locking help
  96. help on conversion please
  97. CRANK/CAM sensor bypass
  98. c25xe ignition amp problems?
  99. Corsa let 3 bolt rear mount
  100. power steering "notchy" HELP needed in SA
  101. 1998 Astra F - ECU help
  102. HELP: Removing knackered sump plug?
  103. best place for c20let chips?
  104. Mk4 astra hubs fit Corsa C???
  105. mk4 astra dash bulbs
  106. wiring diagram
  107. Brembo Rear Brake Discs
  108. Power steering CORSA B 1.0 12V
  109. Electric windows.
  110. 1.6 8v in to corsa 1.2 16v
  111. mk3 astra front fog wiring
  112. Astra Mk3 Compbrake eccentric top mount bearing spacers
  113. No oil pressure light
  114. Need help fitting a starter button
  115. Mk3 Top Mount Bearings
  116. I need Astra digi dash bulbs
  117. Corsa Electronic speedo stopped
  118. T/C switch Vectra B - y reg 2001 sri 150.
  119. How do you pass a large number of wires through a bulkhead?
  120. Brake Upgrade Querie
  121. Who stocks inner cv joints
  122. 2001 Vectra B Sri - Handling issues
  123. gte digi dash into astra diesel rev counter problems
  124. Front upper strut brace -best one to buy adjustable or non adjustable
  125. Brake imbalance
  126. Loss of power
  127. Strongflex bushes
  128. uprated brake master cylinder
  129. What car is this for??
  130. 1.9 cdti into older car
  131. Mark 4 astra alternator removal
  132. Radiator
  133. High Flow Pump Fitting
  134. vectra B creeking and sqweeking
  135. Astra Coupe Z20LET Electrical Problem
  136. bleeding corsa b brakes??
  137. Track rod end help please
  138. 288mm Brakes on Corsa
  139. will astra mk5 brakes fit on to a astra mk4 gsi
  140. Relay issue mk4 astra van
  141. c20ne in corsa b ? help with wiring
  142. which pads for astra gsi
  143. mk4 coilovers 'fk highsport' info & help
  144. What is the best springs for a corsa b for a decent price?
  145. should a shock rebound itself?
  146. ACT fault codes
  147. hid kit
  148. c20let code 15???
  149. Fan not kicking in on xe corsa
  150. Astra GTE '90 Panel suppliers
  151. relocating a fuel tank
  152. what 4 pot brakes is there for a astra gsi mk4
  153. is anyone here able to check part No?
  154. Omega fault !!!
  155. v6 front legs
  156. renewing brake pipe help
  157. Tie bar spacers lowering plates?
  158. power steering
  159. What Coil pack for my XE?
  160. Coil Information
  161. Astra H instrument panel wiring diagram
  162. Corsa sport with no spark
  163. wiring in a 4 pin relay to run a rad fan
  164. 1.8 cav brakes?
  165. help with a rear axle
  166. 2000 Vectra rear shoes?
  167. Astra Coupe Suspension Set up
  168. corsa b help
  169. Mk 4 GSI queries
  170. let lamba sensor which wire does what
  171. coilover strength
  172. Tigra Twintop Headlamp
  173. Snapped wire (Amal Valve?) C20LET.
  174. coilover question
  175. Tigra boot problem
  176. Anyone done a brake servo on a mark 4 astra?
  177. How to change rear pads on vectra SRI
  178. Corsa XE Shafts?
  179. Gearbox Bolt Size? Anyone know it?
  180. brake pipes and ends
  181. 1.2 8v SPi Help please
  182. corsa c 1.7 dti fuel pump not working ECU?
  183. Could you tell me how to ::::::
  184. wiring for calibra vdo gauges! will it be behind the dash??
  185. remove a locking wheel with a pic
  186. Zafira blower issue
  187. Astra mk4 coupe and hatch coilovers any differances
  188. Nova and Corsa PAS steering racks
  189. C20LET, Starts and runs only when fuel relay bypassed?
  190. let phase 1 or 2?
  191. mk4 ignition cap rewiring???
  192. c20ne, no spark?
  193. The chassis interface plug?
  194. Injector Problem *urgent*
  195. rubber squeeking noise from driveshaft
  196. Please make the knocking stop!
  197. rear brake problems
  198. where to get 1 from?
  199. Bleeding abs pump
  200. Braking help please
  201. corsa b brake servo
  202. Cavalier - Sinking Brake pedal
  203. Vectra C rear bearing
  204. making a new loom
  205. Where can you get a steering wheel boss for Vectra B?
  206. 1996 Astra 1.6 16V - New PAS Steering Rack or Just New Bellows? Easy to remove?
  207. Brake problem no brakes
  208. mk2 astra gte knocking from front , anyone got a diagram?
  209. Corsa C rear wiper motor
  210. Astra mk4 fan staying on constantly
  211. omex loom and 5 pin connector from starter loom
  212. Battery draining over a few days
  213. digi dash into v reg corsa
  214. Z18XE problems
  215. c20xe no spark
  216. Early/Late Cav/Cali 5 Stud Hub Dimentions Explained
  217. mk4 astra auto no gear change in limp mode
  218. Brembos under 15's?
  219. Speedo not working?
  220. recognising positive boost
  221. tyres rubbing on front coilovers
  222. corsa b hub for xe????
  223. late vectra front door glass
  224. Mobile spark in Central Scotland
  225. What Vaux wheels - Mk2 Astra 5 stud with Vectra 288 disks & calipers?
  226. Astra VXR bearings, are they the same on any other model?
  227. best place to get eds 3.5 chips and fitted
  228. cavalier gsi fuel pump relay?
  229. ecu fuse
  230. mk 4 astra van 1.7dti problem
  231. power steering pump problems
  232. vectra sri 140 sppedo
  233. R1 fuel pump close to tank or engine for carb set up?
  234. Can someone check my logic please.
  235. corsa x20xev wiring diagram
  236. Monaro Brakes? on astra coupe turbo
  237. Home made r1 carb 20xe manifold
  238. C20xe won't start
  239. Whats the best Nova track suspension
  240. astra mk4 climate control
  241. C20LET conversion - No Spark or EML
  242. Running the engine with the engine loom independent from the car loom? c20let
  243. help ,where can i get the plugs/bit of loom from for a gte digi dash
  244. 2004 astra 1.4 16v p0302 fault code!
  245. x20xev no spark help
  246. one brake light on calibra
  247. Not firing....immobiliser? c20let
  248. code for dash bulbs in a calibra
  249. Help!!!
  250. c20let backfire after 4000 rpm
