- Quiafe ATB
- Abs fault code plug
- switch on top of digi dash
- P.S.I question
- Winter Reminder!!!
- Best Car the get?
- just done the paperclip test
- The infinitive Corsa 2.0 guide????
- gsi mount
- wiring please HELP LADS
- Brake Pads
- corsa
- Insurance Group Question, Rather Confused!
- EBC Brake Pads
- nova dimentions
- Air flow
- werid boost
- astra hesitation
- ARP rod bolt fitment (problems)
- Mechanical Problems!!!
- Corsa + powerflex bushes
- Uprated Rad Fan Fixings?
- Nova Door Lock
- Astra G How to test wheel sensors?
- Bigger battery ?
- Nova cv boot problem ???
- paperclip trick
- One touch windows
- what would i all need for 2 litre conversion
- performance parts central london
- heated seats
- Knocking noise???????????
- vaux tech dianostics software?
- Corsa gsi rear disc conversion
- Diff question
- Fault Code 38 - I'm lost and in need of urgent Help!
- been sold damaged goods! what to do?
- n reg cavy yellow plug
- Temp Warning Light
- Stuck Tigra sunroof
- need abit of help
- help asap
- Heaters still not blowing hot air??
- prob with batterie light glow( could it be batterie?)
- Window motors
- Corsa B front and rear ARB's
- Help suggestions (video included)
- Diff change on vectra GSi
- code 31
- central lockin astra mk3
- cv joints
- Brake Problem on Nova sri
- volvo d5?
- corsa sri water temp sensor.....
- some corsa conversion help
- Cav vs Cal
- My New Car - E16se conversion
- strange one for ya???
- Astra G rear brakes on corsa B
- Coolant pipe > Intake........?
- what does orange bulb light on dash mean??
- nova-corsa ecu swap info needed!!!
- webers on sri corsa?
- Can someone check a part number for me?
- *help*
- Corsa C power steering coloumn
- NGK iridium BCPR7EIX - BCPR7EVX11 difference?
- power steering not working
- V6 into mk3 gsi.....immob question
- Anyone got TBs on a GSI Corsa
- ******* of a Job Power steering rack chnging
- calibra heated seats polarity
- calibra suspension
- astra mk4 juddering problem
- Cav 60mm lowering springs... help
- Dash Lights - Cheapest Way To Fix Pls ??
- Distributor Sensor - What is it?
- E16se problem - For the clever people?
- Help me please im baffled
- corsa 2.0
- q
- nova rear disk convertion
- What Insurance Group ??
- conversion question
- speed reading on astra trip computer
- What can i do next...
- Spax RSX Kit
- brakes for corsa gsi 2.0 16v
- corsa c clocks
- Anyone with knowledge of Corsa GSi PAS rack
- Urgent Help Needed On My Nova.....
- master cylinder
- Paperclip test results. Help Need!
- apr conrod bolts
- how much?? cheers lads
- accumulator bulb,
- Will a worn rear wheel bearing rumble when turning>
- Electric windows have packed up. Which fuse?
- bad noise
- conecting up 20SEH
- o2 sensor wires joining
- K29 hybrid
- easy or quick way to spilt a ball joint??
- front wheel spinning
- Astra mk3 (HI-T) ?!
- info display
- Fitting 4pot brakes onto Corsa - (willwood material)
- EML Light Again!
- Info on lowering a coupe required please..
- Part Number
- V6 heat exchanger question
- Tigra idle problem!
- Corsa b epas - into nova mk2?
- Nova Anti-dive/lowered tiebars
- Cav TD cold start problem due to worn shims ??
- lost keys need to get into car lol
- Suspension trouble
- management light issues
- ABS fault code 19 - How to fix???
- Changing a Power steering rack..how easy?
- Got my speedo cable so.......
- spanish zafira
- Quick bit of help needed
- Speedo problems
- roll cage
- Easiest Way to change g.box on nova?
- digital display
- K&N
- Immobilizer Problem 1lt 12v to 1.4 16v
- fitting cruise control to an 04 Meriva
- Help please
- Help - adding cruise control to an 04 Meriva ?
- overheating problem!!! water flying out of bottle?
- Sintra problem - advice anyone?
- * Uprated corsa suspension but only 15mm drop?
- MOT fail - advice needed on repairs (CV Joints)
- remote central locking problem, help needed A.S.A.P
- Compression ratio question???
- Corsa GSi black plug
- emissions on 2l corsa
- Think my actuator is naf, can i test it??
- Anti freeze
- car judders when i accelerate hard???
- batterie light glows when heated seats on???
- LED Dash Lights
- Cav T problem again (running lean)
- Dip stick keeps popin out
- front brakes across the range
- keronite coating
- Buzzing F***ing Relay!!
- Oxygen Sensor Issue
- Corsa B: modifying Castor Angle
- Need help quik
- vauxhall vectra 2.2 sri 150
- MBC has been fitted :-)
- High Idle first run of the day only
- astra door mirror glass, is the coupe different?
- hardly any boost
- has any one seen this??
- cav electric sunroof?
- Help !!
- Anti roll bar drop link replacement
- Corsa EPAS not working?
- Which fuse Astra Mk5 dipped beam ?
- settle an arguement?please??
- Fitting a isuzu 17td in a mk3 astra?
- Tigra airbag removal
- Gsi 2000 Trip Computer Help
- Corsa cutting out help!
- Automatic to manual
- uprate internals?
- nova ride height?
- Getting paint off
- Battery problem ?
- Does this have an imboliser?
- Removing a rounded bolt
- Corsa brakes - yet again another person with problems
- corsa rev counter
- mantzel fitting help
- havin trouble wiv my car! help!
- cav gsi not charging after crash help plz
- Corsa C Cruise Control
- Cavalier Cooling Fan Problem
- AE wiring pics
- Part No help needed on epc, 90209811
- Another fault!: error 113
- whats wrong with my rear lights?
- when courtanay say high boost what's that?
- Corsa cutting out- help
- Cav GSi steering-racks?
- part number request
- Ford KA blowing relays?
- would this fit
- astra gte digital dash into corsa b gsi wiring help needed please
- mk3 astra air flow sensor
- What joins the anti-roll bar to the wishbone?
- vectra bumper lights
- Info about megasquirt
- mk3 astra gsi trip computer into astra merit
- EPC guys, part comparison
- diagnosis wiring help
- FD swap, just need a final push to finish the job.
- calibra revs question
- Clicking noise from inside 06 plate Astra
- Td out v6 in
- Ecu Light On Corsa
- Cav GSi power steering
- Isuzu non Start
- boost surges do i need boost control ??
- corsa c rear drums!
- Rear wheel out by 3
- sounds like a hoover under the bonnet
- Arghhh, strut brace fitting problem.
- hi guys can anyone help
- 3.2 v6 into a Cavalier????
- where is PVD?
- 2 Astra mk3 questions??
- vectra b rear brake problem...
- ***Advice needed asap****
- No boost at all .
- anyone know how an ignition amp is??
- please help
- Astra 16V Mk2 Rear Antiroll bar stiffness
- Plz Help Me
- help needed with stereo!!
- Anyone here work for Vauxhall or know someone that does??
- Emmisions (non Vaux)
- whats a good way to...
- anyone help here?
- Red-Line Idling
- Vauxhall's new VVT... is it like the toyota system?
- numbers on my actuator
- OH CRA*!! Any ideas?????
- corsa 2.0
- 7k clock where 8k were
- Z17 Dtl, Z17 Dth
- Astra mk3 brakes behind 17"s
- help my cars died
- Question bout saxos and hyabusa engines..
- Cold blowing heater - Veccy
- brakes???
- bore sleeving ok or not??
- rear window seals
- Door pin removal.
- Airflow Meter and Pipes
- Mashed compressor wheels .
- Just bought, couple of questions
- Immobilsers!!
- Astra G MK4 Heater control bulbs
- FAO Anyone Used a Bias Pedal Box + Hyd Hbrake??
