  1. heater matrix replacement 1995 n reg 2.0 gls 16v
  2. what would have to be done?
  3. evo5 software . website??
  4. Car heaters not working prop!
  5. astra mk1 gte seats into a mk3???
  6. wheels offline *HELP*
  7. corsa c derv em light...heater issue??
  8. astra g steering pump?
  9. diagram needed please
  10. Its the little things that make a difference
  11. Lexus Light Help Needed
  12. Cant get it in a stright line
  13. vecra sri 140
  14. no heater any idea why
  15. Removing Front Caliper - allen key size ???
  16. Brake imbalance
  17. Rea o/s &n/s break ligts not working, but highlevel break is... Why?
  18. calibra 16v lowwering springs fit other cars??
  19. tuning box advice for cdti neded
  20. 2.5 V6 ECU problems
  21. new snap-on techangle wrench
  22. battery charging?????
  23. easy to fit electric windows???
  24. Spring rate
  25. 2ltr 8v into nova Q's
  26. mainifold leak
  27. Corsa GSi nearside shaft removal
  28. Airbag Light (Omega)
  29. lowering corsa
  30. vectra door handles on cavalier mk3
  31. Where can I purchase.....
  32. Errr...whats this?
  33. ASAP - EML light with Digi dash - HELP
  34. Light Reflection
  35. eco tec management hassles
  36. question...
  37. F-28 Synchromesh Question, Help please!
  38. corsa c hubs
  39. help needed
  40. electrical gauge senders question
  41. 5 stud conversion on corsa! list ov parts i need?
  42. code 73 low voltage at airflow sensor
  43. electric short circuit problem
  44. Tracking woes!
  45. Corsa alternator - where is this from?
  46. Brightest bulbs possible for GTE 16v
  47. speedo problem. (digital dash)
  48. Clocks
  49. Cavalier MK3 heater light
  50. problem with started
  51. mk4 astra fuse listing
  52. Trying to find the 4wd Calibra conversion thread
  53. Toyota 3.0 V6 question
  54. cooling problems .
  55. lower than low tigra springs
  56. Serious kangarooing, running out of ideas?
  57. nova and corsa springs
  58. help
  59. Where do you get your parts from?
  60. Traction control for vectra b
  61. heater matrix mk3
  62. ICV disabled. how do I plug it in?
  63. just had bit of a bump :(
  64. Knocking noise when i go over bumps any clues??
  65. conversion release bearing?
  66. Engines..
  67. broken balljoint
  68. Running Problem on me tubby
  69. vectra heaters
  70. mk3 astra rear drum removal ?
  71. what size lowering springs are these?
  72. Error Codes
  73. gsi 2000 rear wheel bearing !!
  74. Would this work? 3.0 V6 on 2.5 management
  75. 2.0 Corsa - Front spring poundage..
  76. 308's
  77. help me please going crazy
  78. 1600 nova question
  79. 3 pot calipers???
  80. Mind of its own !!!!!!!!!
  81. car revving itself!!
  82. Monroe shockers? Any good?
  83. 3.0 V6 Bigends?
  84. nova master switch wiring?
  85. best place for new vauxhall plastics ?
  86. Best place for vauxhall parts?
  87. Tyre pressure light illuminated......?
  88. cavalier electric sunroof
  89. Fan kicking in when cold? Z22SE
  90. spigot rings v6
  91. Wiper relay, quick question
  92. good places to buy..........
  93. Axle Bush Problem
  94. Overheating problem
  95. 0 compression on cylinder 3
  96. 1999 vectra... fuse 29 keeps blowing
  97. Immobiliser Problems
  98. Simtec 70 fault codes
  99. digi dash lighting
  100. 8v rockers-Different types?
  101. corsa morrettes
  102. john noble motorsport
  103. jamex springs any good?
  104. corsa b
  105. Vernier Pullies
  106. Wiring a Armtech rev limiter to Nova?
  107. Nova push star button wiring?
  108. List of Rolling Roads
  109. Astra GSi Problems
  110. corsa help
  111. wat do you think of this????
  112. transponder problem
  113. these any good?
  114. corsa sport fault plz help!
  115. Cavalier SRI Saloon 1990
  116. Brake probs on my 106 !!
  117. E16se conversion
  118. WHITELINE ARBs where to buy from??
  119. ps2. lcd tv interference??
  120. nova poly bushes
  121. Brembo Help
  122. pluming in a fule pressure gauge
  123. Advice Needed Regarding a F*** Mondeo
  124. anti freeze
  125. relays
  126. Which Pad Wear Sensors?
  127. how do you change digi dash colour
  128. hi guys.....
  129. megasquirt ecu?
  130. coolant sensor
  131. car not warming up prop! whats wrong.
  132. what the feck is the point of torx bolts
  133. droning noise comin from calibra
  134. Quick question
  135. Battery not charging - alt light and handbrake light on???
  136. knocking coming from rear of nova
  137. Vectra sidelights...
  138. nova
  139. Grinding from the front when braking
  140. Astra MK2 Koni part number
  141. corsa 2.0 16v questions
  142. Astra van temp sensor??
  143. Wheel offset
  144. What's this suspension part called?
  145. Grinding/knocking noise at low revs
  146. 5 stud corsa + braided brake lines???
  147. Vectra Gsi or Astra Coupe T ?
  148. mk4 astra hellllp
  149. Mileage test’s
  150. wots wired wrong ?
  151. check out why my trans bx was not workin
  152. Quick Rack for Astra Mk2 Were rom???
  153. Help
  154. Mk 4 astra running probs
  155. part numbers
  156. corsa shafts
  157. Corsa Gsi TB's Advice Please
  158. can you re-use arp rod bolts???
  159. remus racing centre sections v6
  160. astra gsi window problem!!!!
  161. lowering springs
  162. few problems, wiring and vacuum?
  163. OMP 10 Bolt In Rollcage Any Good?
  164. FAO DOM
  165. Coolant sensor
  166. Wheel size for carlton brakes
  167. ASTRA MIS FIRE PROBLEM anyone HELP?
  168. wot a mission
  169. calibra heated seat not working
  170. Bore De-glazing?
  171. cav mk3 spring heights
  172. Mk3 Astra ABS bulb????
  173. how can i test HT leads?
  174. help needed
  175. Gunsons Eezi Bleed kit, what psi?
  176. what 'box is likely to be in:-
  177. Corsa 1.4 SRi Master Brake Cylinder
  178. calibra cutting out when hot. HELP PLEASE
  179. help please
  180. Does this sound about right???
  181. Corsa 2.0 16v probs :(
  182. Need A Replacement Siren For Clifford Concept 50!
  183. 5 stud??
  184. Rocker Cover
  185. converting manual to electric windows
  186. 20SEH GSXR TB 's Work in progress
  187. corsa b epas column
  188. Ha anyone actually put a nissan 200
  189. ignition lights
  190. tacho help
  191. Panel or Cone?
  192. digi dash speedo HELP!
  193. Illumination
  194. overboost....
  195. cavalier and calibra brakes
  196. Keronite koating... Where, how much?
  197. nikasil liners
  198. Trip Computer Error Codes
  199. Lightened Bonnet - cutting the supports off gen
  200. Girdle
  201. conversion mounts
  202. my new car, verdict!
  203. New car, got a few questions
  204. astra g mileage fault
  205. thinking of buying an astra coupe... help needed pls
  206. Gsxr K1 650 bodies - secondry butterfly modds etc?
  207. Hi all - omega dti glow plug removal
  208. Corsa- Tyre touch in wing
  209. corsa 1.7D suspension
  210. can anyone repair a diff retaining ring ?
  211. Filling a Nova with Resin
  212. vauxhall vectra alarm
  213. EPC Help needed
  214. 94 2.5 Omega Blaupunkt Dead
  215. what colour bulbs in my dash clocks(lockwood)
  216. astra mk3 electrics
  217. best suspension set up for a vectra gsi
  218. vectra sri 150 power stearing
  219. Anyone know a decent, accurate AFR guage?
  220. Vectra B central locking problems
  221. astra mk3 fuse board removal
  222. code 35
  223. mk 4 astra
  224. wireing help
  225. What size hex bit to remove brake servo from calibra? heeeelp!
  226. erm where is the MK4 astra fuse box?
  227. MK4 Astra Suspension
  228. what goes in this hole?
  229. electronic speedo problem
  230. cav lights goin crazy!
  231. g max suspension kits?
  232. Front Goodridge brake hoses
  233. Nova SR
  234. Lowering
  235. Battery drain
  236. Can someone help? C12NZ problems
  237. newbie help! 2.0 novas
  238. tranny box
  239. 1.7 DTL Starting problems
  240. TC on Astra H
  241. ECU pics
  242. tophat photos
  243. Need some help
  244. seized brakes
  245. Speedo Cable??
  246. digi clocks
  247. rear disc conversion?
  248. Vauxhall Vetcra B central locking problems
  249. Difference between Sri and Sport???
  250. whats this difference between singleport and twinport?
