  1. cutting out when warm
  2. Thread size nova
  3. tuning a 2.0 8v 20seh
  4. jumpy rev counter
  5. mk3 cav saloon suspension concerns
  6. Vectra B strut brace...worth doing ?
  7. astra van electric windows
  8. ecu question
  9. Frontera 2.2DTI issues
  10. Cavalier mk3 vs Astra mk3 Topmounts - Quick question
  11. corsa rear springs
  12. Koni problem
  13. 2001 Astra SRi
  14. brake system question
  15. manufacturers books
  16. Anyone with a Signum + Autobox....Start Praying
  17. P0720 Automatic Astra
  18. Clunking Noise
  19. car turns over but wont fire.
  20. i know nothing about nothing...help
  21. Cally V6 Brakes
  22. Best way to protect arches on cav?
  23. Alloy Top Mount (Nova)-Do I use.......
  24. dipped lights relay '97 vectra Di
  25. Quick Q - Can PAS rack run dry ??
  26. Liquid noise coming from under the hood when revved
  27. Few pointers please RE:- 20SEH Mk3 Cav
  28. Few pointers please RE:- 20SEH Mk3 Cav
  29. Can I Fit?????
  30. leads keep breaking down
  31. Cutting arches back - Nova
  32. ABS light not working in the Dash
  33. Help Me Please
  34. Warenty
  35. nova changed ball joints still clunking???
  36. what to look for when buying a corsa 2.0?
  37. temperature sensor
  38. Ex-police omega 3.0 V6's
  39. Bigger Brakes
  40. hazard warning diagram
  41. Omega Traction Control
  42. Characteristics of T28 v GT28RS
  43. calibra steering rack
  44. how can i turn traction controll off
  45. can i get wilwood calipers to fit over my standard 288mm disks???
  46. pic request of this roose conversion hose on
  47. Astra G Fog Light Wiring
  48. Astra G Fog Light Wiring
  49. Vectra DTI help please
  50. Anyone know about cr*ppy Fiats??
  51. koni part number
  52. verniers
  53. Eml Codes On Corsa B
  54. Difference between corsa & nova brake reservoirs?
  55. PAS Question
  56. !/4 mile in less than 13 s
  57. HT leads - how to check them using a multimeter?
  58. taking window out!
  59. MT6 piggyback
  60. How Many Grounds?????
  61. wastegate problems
  62. Vectra B 2.2 DTi SRi 130 Limp Mode
  63. central locking
  64. brakes queston
  65. Short shifters
  66. heater matrix
  67. general wastgate question
  68. I Want To Do a 5 Stud Conversion To My Astra Gsi
  69. rev counter
  70. help big problem
  71. Knock Sensor??????
  72. Mk3 astra front strut play
  73. Chris astley motorsport
  74. remote start Alarm fitting corsa
  75. lexmaul or mantzel
  76. kangarooing astra mk3
  77. low revs misire?
  78. Omega HELP locked out!!
  79. corsa 2.0 help
  80. zafira
  81. what calipers fit 284mm discs
  82. Stuck For Space.
  83. squelching behind dash?
  84. will 15" vauxhall alloys throw my speedo out?
  85. EML on astra
  86. rubbing me slicks
  87. Selling car
  88. Advice on MOT failure wanted please
  89. Cav Suspension myths
  90. cool running thermostat
  91. Does anyone know....
  92. Opel Manta GTE Advice
  93. will calibra front suspension/strust fit astra mk3 gsi
  94. corsas getting hard getting it into first and second
  95. Need advice on Astra
  96. savage nova understeer
  97. Urmmmm if been abit of a tit!
  98. Mk3 Cavalier Electrical Problem
  99. Astra GSI intermittent starting?
  100. astra gte 8v running problem
  101. Stupidity....
  102. electronic dash
  103. ECU
  104. Identify The Strut Brace?
  105. groaning sound
  106. good idea or not?
  107. Cant Find 5th or Reverse!! Can anyone help?
  108. subaru brakes
  109. MOT Guru Need Alarm-De-handled/locked Q
  110. Tigra - steering issues maybe??
  111. Vectra B brakes onto Mk4 Astra
  112. Is my astra G OBD2 compliant?
  113. electric sunroof probs
  114. radio problem
  115. L reg Corsa intrument cluster change
  116. corsa td some quick questions about tuning
  117. raising a corsa bonnet
  118. Nova front shock strip down?
  119. Handbrake problem - Astra G
  120. Astra tailgate problem rear door problem
  121. corsa rear window removal
  122. what boost shoulda 1999 dti run
  123. brake question
  124. Went into 1st at 50mph by accident-possible damage??
  125. tigra electrical faults
  126. DIY diagnostic dTC tool?
  127. vauxhall astra throtle body software update
  128. Whot can I undo this this with? pic
  129. piston rings............. £££
  130. 1999 2.2 engines?
  131. What do i need?? help!
  132. corsa eml light need help please
  133. Just a quickie...
  134. funky idle and cutting out
  135. Help please: Senator Digi-dash....
  136. external waste gate
  137. Measuring Handbrake efficiency
  138. Is it possible to remove tyres at home?
  139. Haynes Manual To Download, Save Me Money ?
  140. Corsa B with Vectra Rear Disks Questions
  141. who wants to come help me out
  142. Corsa B Triple Info Display
  143. Fault Code Question
  144. help me plz
  145. central locking
  146. Anodising
  147. want to move ma battery
  148. Digi dash into MK3 Astra with 6speed
  149. Which Back Box?
  150. astra gsi stalling
  151. Corsa b immob probs...help quick
  152. Wireless printer?
  153. Vectra Estate, Towbar wiring...
  154. How to find bad ground?
  155. 5-stud conversion
  156. diaonostics plug
  157. cav/vectra a instrument table - pinout?
  158. ETC flash's up randomly
  159. Renault kangoo van steering
  160. are aftermarket fault code readers any good
  161. pocketing a piston
  162. vaux Tigra vibrating at tick over - any ideas?
  163. Fitting a Swirl Pot?
  164. Astra GSi MK3 Shocker Top Mounts
  165. mk3 astra strut braces lower
  166. ecu to be earthed
  167. + - More dead battery woes + -
  168. I seem to rmember seeing...........
  169. Battery Chargers
  170. Cav GSi - Intermittent Starting Issue
  171. Fuse Keeps Blowing
  172. Strut brace
  173. em light flickering
  174. Astra Mk3 Rear Brakes
  175. Fitting abs to a nova?
  176. astra mk4 alarm problem
  177. geting there nova van nearly built
  178. Mk 4 astra wiring diagram
  179. Maxing out at 4000rpm
  180. my girfriends dead corsa sport
  181. how to adjust boost on external wastegate
  182. Steering Rack
  183. Non Vauxhall boost question...?
  184. Swapping auto box for manual Omega 2.5TD
  185. nova servo
  186. Corsa C Bucket Seats - Advice required please...
  187. EPC Part # Request Please
  188. Car pulling like hell and play on wheel
  189. Pierburg 2E3 choke
  190. Corsa C Bucket Seats - Help required please...
  191. Lost My Keys
  192. Noise from Suspension strut
  193. how to modify your airbox
  194. v6 brakes onto my astra boot
  195. mk3 astra rear disc conversion??
  196. guide needed for FSE reg
  197. can you reaf fault codes on a vectra by shorting out the pins
  198. elmscan 5 software
  199. electrical fault - fuse problem
  200. Recomendations for a torque wrench?
  201. urgent electrical help needed
  202. bore - cost and gains
  203. astra gsi speedo not working again
  204. Ignition Amplifier
  205. Will this work???????
  206. Irmscher Gernob
  207. Mk3 astra gsi brake upgrade
  208. help needed: Vauxhall astra estate 96 electrics
  209. Heating problems
  210. Testing the Ident Switch Wiring
  211. What's a MANN airbox? How can I check?
  212. Is this an MOT failure?
  213. Is this an MOT failure?
  214. irmscher back box 3 door / 5 door
  215. knocking/clicking noise (steering)
  216. HID Conversion Kits
  217. Disable Mk4 Astra Airbag light
  218. How to remove Mk4 Astra dial card
  219. do i need a new alternator?
  220. coscast rebuild
  221. heaters!!
  222. spongy brake pedal
  223. whats this for ???
  224. Is this right?
  225. Connect Front Fog Switch to Rear Switch ??
  226. electrical experts help needed, how does light bulb check control work?
  227. Omega brake upgrade ??
  228. rear fog lights
  229. Are Corsa B shafts all the same.
  230. astra gsi dash bulbs
  231. will on board comp work in vectra which has just the clock
  232. Corsa C Steering Alignment
  233. are they the same
  234. opinions on manual switch
  235. lotus carlton
  236. Corsa Laptop Conversion Ideas???
  237. Nova glass fiber bootlid fitting adivce please
  238. Weight of Corsa Sport
  239. astra gsi STILL will not start!
  240. cav diagnostic plug question
  241. Carton 3.0 GSi propshaft - What fits??
  242. rear calipers
  243. Starting problem
  244. Braided brake hoses astra onto corsa?
  245. Corsa B door seal gone, I think?
  246. corsa 2.0
  247. Advice needed - Lowered Corsa B Query
  248. Need an auto electricians help please!
  249. TIS help
  250. are they the same
