PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Air bag light /ECU
  2. building again
  3. nova brakes and cost issues?
  4. vectra v6 throtle body
  5. nos or not?
  6. coolant problems
  7. Tigra/Corsa powerflex-TCA
  8. k reg nova 1.2i coolang fan fuse???
  9. v6 engiine problem
  10. 160 mph clocks
  11. looking at a nova...
  12. Is there a 100Amp Alternator that'll fit a 20SEH...
  13. RWD Mk3? Yay or Nay
  14. Megasquirt
  15. Rolling Road Print out posts?
  16. Astra GTE 16V COMPUTER DIAGNOSTICS RESULTS!!
  17. Wires
  18. irs conversion
  19. 2.5-3.0 Conversion.
  20. Vibration
  21. calliper rebuild kits
  22. double post - sorry
  23. sticking brakes again :(
  24. Electric mirror question
  25. Charge temperatures
  26. Snapped sister's VW Key - Help!
  27. Astra g air con advice
  28. paper clip test?
  29. Can someone with TIS do me a big big favour please ....
  30. Stainless Allen Key Bolts
  31. Help needed with my zafira
  32. cooling system cleaning help required
  33. help please?
  34. nova shell
  35. Astra problems
  36. Corsa Electrical Fault....
  37. Mk3 Astra Estate Shocks
  38. cars dead (help please)
  39. Cavalier SRI 2.0 8V.............Relays...
  40. suspension help!?!?
  41. Corsa C Performance Mods
  42. Distributor Help needed
  43. corsa b rear disks
  44. charging light
  45. 'Pimp OP's ride'
  46. FK Angel Eyes / Projectors Problem - To dim!
  47. Traction control problem!! Help Please
  48. electric mirrors stopped working, why?
  49. Advice on Lowering Corsa B
  50. vectra 4 branch
  51. CORSA SRi ELECTRICAL FAULT, HELP PLEASE
  52. Boot Poppers
  53. Magnex rear box off a saloon to hatch?
  54. Advice on magnecor ignition leads?
  55. Corsa Help Please!!!!!!!!!!!!!!
  56. DIY porting and polishing
  57. mileage not going up....plz help
  58. Ringing noise when accelerating
  59. Yokos Avs 100
  60. CORSA SRi ELECTRICAL FAULT, HELP PLEASE
  61. best place for an Apexi boost controller?
  62. RWD Cossie plenum pics ???
  63. Mk4 astra total closure question...
  64. Atra Mk4 Overvolting = Alternator problem?
  65. Vectra DTi
  66. Astra MK3 GSI Suspension
  67. Carrying capacity of a 1.7Di Combo Van
  68. no window washers
  69. O/S chassis leg on corsa B
  70. suspension v6 astra
  71. rear discs - corsa b
  72. What's that resistor on the rad fan for?
  73. new tyres
  74. Corsa sri 8v fault code 16, help??
  75. Chassi work
  76. cooler rad fan switch, which one??
  77. Airflow meter
  78. Strange Tinny Noise
  79. Whistling noise coming from front offside wheel
  80. Astra V6 wiring...
  81. Swirl Pots? are they any good?
  82. towing a caravan with a lowered car is it possible?
  83. Will mk3 astra rear springs fit a Cav mk3 with a rear beam??
  84. Shock Absorbers....
  85. v6 tappits
  86. Colour code - is this 'Classic Green'?
  87. corsa trouble!!!!!!
  88. Cav big brake upgrage to fit astra mk4??
  89. nova steering 'notchy'
  90. can somebody identify these ecus please
  91. Rev limiter
  92. vectra limited to 4600rpm
  93. Vectra GSi HELP WANTED!!!!
  94. brakes - someone with an Omega Haynes manual...
  95. Single Nut Wheel Conversion
  96. Vectra Slow Down
  97. P Plate Vectra Horn Prob
  98. code 145 immobiliser
  99. Vec V6 part identity help needed
  100. How do the pipes go on a late astra gsi for PAS?
  101. nova automatic windows
  102. can i get a ford car key cut localy or is a send away job?
  103. Remote central locking
  104. Auto windows
  105. Master cylinder seals...
  106. Fault codes
  107. What should I do with my Nova sunroof?????
  108. flamer kit wiring diagram needed for a dragon kit plz
  109. From Italy:technical data for my astra,please.
  110. noise when wheels turn. knocking. question
  111. info on custome made stuff please ....
  112. Light on dash
  113. fitting electronic power steering to a corsa b
  114. Renault Clio intermittent non start
  115. power steering
  116. 4 stud to 5 stud??
  117. Vauxhall calibra sounding like a scooby
  118. Corsa Suspension reccomendations
  119. second battery
  120. bled my brakes now pedal pulses
  121. tophat fitted.
  122. Suspension for GTE 30mm drop... where?
  123. Astra GSI play in steering?
  124. what suspension do u have in ur v6 astras?
  125. Bracket
  126. Mk5 noise
  127. Anyone here clued up on skylines ?
  128. Fitting power steering to a Nova?
  129. car cuttin out
  130. Wonder if any1 can help
  131. Astra Mk3 bonnet cable snapped! How do I open it?
  132. Quick calibra/cav suspension question
  133. will a rear wheel bearing from a cav gsi fit a gte16v
  134. Making Wiring for GSI Comp and Stalk??!
  135. steerin wheel shaking
  136. dis pak wiring diagram
  137. quick grank wheel question
  138. cav v6 ecu wiring diagram
  139. possible abs / brake problem please HELP!!! NO BRAKES!!!!!!!
  140. What Brakes?
  141. Tow bar wiring
  142. Directly linking PAS pump to rack?
  143. Boulderlocks
  144. will mk1 fit?
  145. Think iv pin pointed my problem!
  146. 8v calibra has packed up! how easy to change to 16v?!!
  147. 8v calibra has packed up! how easy to change to 16v?!!
  148. GM Dis
  149. my wkd astra van progress pics
  150. front brake disc shields
  151. digidash
  152. electric sunroof
  153. spax suspension advise??
  154. uprated actuator
  155. need help!!cav gsi spring's?
  156. Corsa Sport Problem!
  157. finally found the cause of the clunking
  158. Vernier Pulleys are these any good?
  159. Corsa B SRi not running right?...
  160. what causes tyres to wear on outer edges?
  161. Fault code 113
  162. astra mk3 trip computer
  163. Blueprint performance.....contact number
  164. Astra G 4 stud rear disc conversion
  165. why NOT to use poly bushes on a mk2 astra wishbone
  166. 2.0 8v pic required
  167. Astra Brakes
  168. Anyone in here got a nissan terrano??
  169. Cavalier 1.7TD alternator, urgent help needed!
  170. Astra power fault
  171. will 235 tyres fit on a 7j rim
  172. rear wheel on cali t is towin out, pos chasis bent/ r/arm bent HELP!
  173. V6 Astra Temp Gauge
  174. non vaux renault laguna
  175. whats needed for a nova RWD
  176. cav beam on mk3 astra
  177. van 2.0 16v conversion problems, Where do i start?
  178. having trouble fitting alu top mounts to nova...
  179. megasquirt any good?
  180. Ate Rear Caliper???
  181. v6 brake conversion wont bleed
  182. Astra mk3 Front Wheel bearing
  183. None Vauxhall parts request.
  184. need a bit of advice
  185. Vectra 2.2DTi Glowplugs
  186. Nova horn upgrade problems!!
  187. Acetone?
  188. Biggest brakes that will fit under 15" Astra GSi rims?
  189. Swedish Plenums...........
  190. MPG testing and results
  191. swedish plenum
  192. Astra GTE bonnet vents
  193. Cally aircon pump question
  194. Dodgy conversion kits
  195. All Those With ARP Rod Bolts!
  196. Upgraded! (super charge??)
  197. Astra H fog lamps
  198. corsas and 4pot brakes.....
  199. car sorted thx 4 your help
  200. New shape vectra wiper faulty
  201. Thickness of sierra/saph cossie rubber mounts
  202. Cruise Control
  203. Steering rattles at full lock
  204. drilling in the footwell,
  205. Reyland brake kit owners...
  206. New Astra mk2 track car
  207. what is it????
  208. alarm fob
  209. missfire?
  210. "The round bit on the wheel is the wrong size"
  211. corsa dash
  212. Intermittent Car Problem
  213. corsa b suspension
  214. Cav wheels?
  215. corsa wont run help plz
  216. Cav not firing on cylinder 1
  217. FSE
  218. Calibra fix 95/100% we're almost there.....help
  219. Astra MKII Steering column
  220. big brakes
  221. how do i do the paperclip test
  222. orange light coming on my corsa sport
  223. actuator
  224. Is this thing on ebay just like a tech 2?
  225. Suspension top bearings/what size brake pipe?
  226. Whats that sound?
  227. Digi Dash Mk3 Cavy
  228. That astra with the t34/35
  229. Car not starting. Advice needed.
  230. iirc
  231. Price question
  232. Lowering a Gte
  233. Anti rattle pins for rear brake pads
  234. central locking out of sync
  235. Speedo Needle Wobbles
  236. Rear Brakes
  237. MOT - Where do we stand?
  238. Electric Power steering into Mk3 Astra - info required
  239. Calibra BackFire
  240. actuator
  241. torque settings
  242. Vectra C temperature sensor
  243. cav gsi
  244. compbrakes top mounts
  245. '03 Vectra Satnav upgrade? Can it be done?
  246. Sensor Bracket
  247. piston sizes
  248. Cav TD Alternator squeal
  249. new tigra tick over
  250. fiat uno single wiper motor
