- 5 stud...
- Corsa B Wiring A Temp Sensor
- Removing top mount
- Astra Mk3 2 Port Master Cylinder - which is front/back?
- re ign amp help
- can someone help me with advice..
- Cruise Control Installation
- sqeaky brakes on nova?
- carlton-omega suspension (springs)
- does v tuning still exist contact number needed
- calibra dials needle ilu wires ?
- Funny indicator and brake light behaviour...
- to annul alarm?
- Brake Disc's & Pad's Q
- digi dash - Blue wire film (bulb connectors)?
- hard wireing help needed
- knocking on drivers side front???
- Big brakes on cavalier/nova
- how to replace fuel gauge voltage regulator on corsa b?
- calibra brakes the same as astra mk 4
- corsa brake upgrade
- Mk3 Cav/Calibra Digi dash to FC wiring
- Part No of nova door locks.
- Time Display Fault
- Nova Rear Disc H/Brake Cable
- 308mm brake help
- koni adjustable question
- Are all corsa (gsi drums) the same
- How to set the clock?
- Astra 16v Rear Brake seal kit??? Where from
- Cav rear calipers (on a nova)
- eps power steering in corsa b
- What brake pads - low dust/good bite??
- help quickly please!
- Corsa C Number Plate Lights
- PAS making a really awful, whining noise
- adjustable pedal box
- astra gsi brakes wont blead up
- loom removal tips?
- astra mk3 - knocking noise on front wheel
- Xenon bulbs
- electrical boost gauge??
- Gauging interest - lightweight fibreglass front panels ?!
- Vectra C service message
- mk5 astra cruise control
- how do i find out whether my car is + earth?
- will a Corsa B strut brace fit a Corsa C?
- lightweight battery
- Astra interior into kadett E ?!
- air bag light HELP ASAP
- speedo cable, corsa GSI
- avo coilover,top mount - thread pitch size
- Rear calipers for MK3 Astra
- 4x4 brakes on nova
- Key won't turn to open or close drivers door
- airconditioning
- Tigra 1.4 rear wheel bearing
- part number
- which brake pads
- Any1 from pug or parts shops on here?
- Tigra Brakes
- nova roll cage
- Nova Chassis Measurement
- Cavvy sri fan alloys fit over veccy 288mm brakes?
- Broken cigarette lighter
- astra mk3 central locking module
- cav turbo suspension
- help: getting to the heater matrix
- corsa hetaer panel lighting
- Cheapest place for Koni rears..
- corsa sleeper
- TC light - V6 Calibra.
- Vectra central locking not working?
- How to wire up an EML on a Nova with no standard clocks!
- MK3 astra suspension fit mk3 cav v6??
- Wiring speedo to ABS signal on a Corsa
- Digital dash quick Q
- corsa cdti a/c
- Digi dash question
- Instrument Cluster Bulbs, what sort and where to buy?
- Radiator fan running when cold
- Omega electric sunroof not working
- Help required - Bonnet won't close properly
- 300mm discs and hispec 4 pot billet calipers under 15s
- Boot to heavy for lifters!!!
- mk4 astra haynes manual
- 2.0 Nova Wiring Please Help
- Will alpha brembo calipers offer up to a nova?
- Intermitant Wiper Relay
- 4 Stud To 5 Stud Conversion
- mk3 astra lights ???
- need a real workshop manual for the electrics of a auto astra
- Corsa B or C Electric power steering.....
- Bare shell weights
- vectra dti 1999 boost gauge reads below zero under load
- thumping noise
- 308mm brakes and softstars?
- nova windscreen
- Quick Pug question
- Leccy window
- Help - indicator problems
- Windscreen wiper troubles
- ABS problem on Cav GLS
- corsa epas
- alternator
- leccy window relay
- c20xe ecu diagnostic link.brown/white.what does this wire for?
- tracking
- 1995 omega steering column
- another problem , this time brakes
- Gas bonnet lifters
- changing astra 3 springs
- Brake conversion on Corsa
- Groaning and Squealing from front wheel
- identifying ecu pin numbers
- Bulbs and Supressor
- Cavalier *Clutch Spring Noise*
- Converting TID display into a MID one
- let wiring into nova xe
- Coilovers
- Suspension questions
- Dim Dip Control Unit Mk2 Astra/Mk3 Cav
- Big Brake Upgrade
- Adding variable wiper to Zafira 06
- esp/tc on astra coupe turbo
- Digi dash resisters
- mk2 astra ABS HELP PLEASE
- one touch cav rear windows
- Fuel pump stays on without ignition.
- Diesel stop valve wireing
- MK2 Astra ROLLCAGE
- Standard Corsa Gsi Ride Height
- Help: Leak in Astra TD Estate 1996
- Evo 9 Brembos + Nova??
- wiring a management light
- HID's put my ABS / TC lights on
- Astra MK3 V6 Suspension
- Omega Sunroof Wiring query
- changing pas rack on a v6 calibra?
- vectra dti 2.0 only 0.35v at the glow plugs
- Electrical Gremlin, HELP!...
- nova brakes
- Corsa Aerial Lead and Door Speakers questions??
- Strut Brace for Corsa B 20XE
- Astra Coupe shifting lever kinda stuck
- vectra 1999 dti no glow plug light coming on
- calibra front inserts????????
- Best Handling Vauxhall
- Nova fuel guage problems??
- power steering
- Omega brakes - clicking/clunking at low speed
- 3.0 v6 omega oil pressure HELP
- Bonnet stuck down
- EPC Relay Part names please
- astra mk3 gsi let radiator prob
- Brake Check Light?????
- Perspex/polycarb corsa windows
- omega check control help
- fitting an afr gauge, difficult?
- wheel bearing issue???
- astra gte exhaust
- sealing welds
- Astra Heater Problems
- suspension question
- suspension astra convertable??????
- Advise on a good lowering kit for my 2000 1.6 Tigra...
- Do these really work?
- Exhaust Recommendations?
- Corsa brake pedal conversion into nova
- short/voltage drop across fuse 23 on my 200ts
- **calibra braking - sporadic then they slam on - whats the trouble? please help!!***
- speedo on xe
- master cylinder
- Help ive broke my Electric Windows
- Steering lock/Barrel
- which tyres yokohama/toya/pirelli
- No Engine or Transmission Posts in Here please!
- Break IN
- central locking install
- 5 stud conversion for astra f
- I am looking for instruments for Astra/G & H
- bleeding brakes
- low coolant warning
- Should my Sri 150 have a top tint as standard?
- Running on the spare for a couple of days?
- Remote Central Locking Upgrade
- New bushes - Nova?
- changing radiators on calibra turbo
- Corsa fog light wiring help?
- any idea how much to replace locking wheel nut
- corsa B clock transplant problems
- Fan switch won't come out!
- Digi Dash in the Dark!
- Anyone got pics of MK3 Astra eibach springs?
- Replacing a tilt and slide sunroof (weight saving)
- Nova front suspension - rated for a C20XE??
- Nova rear disk handbrake cables
- Lubricant
- Gte Fire Help
- Miles to kilometers in multi-info display
- Astra Fuse Question
- air con condensor
- omega abs ecu
- 5 stud rear conversion problem, help
- vectra bonnet struts on a corsa
- pics of nova hand brake cables on car
- Knocking Noises!
- Put air-con in a non aircon car (mk3 astra)
- Astra 8V digi Dash
- Wiring diagram need for dash speedo
- mk4 astra rear calipers
- help again asap
- Astra H Sporthatch owners HERE...
- poor reception on calibra aireal??
- gte digi dash into corsa b
- Corsa Suspension Possible Problem.......
- how do i !!! asap help
- Central locking not working
- couple of corsa electrical issues
- Mk3 Astra GSi Central Locking ?
- handbrake
- Fitting an electric aerial to my mk3 astra
- Biggest brakes that fit under 16's?
- Aerial cable
- Braided Hoses & DS2500 pads
- dipped and ecoated?
- Who builds nice custom roll cages?
- out side temp sensor corsa b sri
- which brakes are these???
- Shortening nova group A bilstein rears??
- Diesel tank - Petrol tank
- astra smells like ****
- Step-by-step how to remove sunroof from cally
- Astra MK2 digi dash guide
- vectra v6 rear 5 stud hubs on astra gsi
- Which Wilwoods?
- what mk4 gsi suspension?
- Whats this electrical connector? - MK3 Astra
- Rear stub axle for mine
- removing air con from a v6 vectra
- type r rev counter
- Best way to drain fuel from the tank??
- Calibra Camber Adjustment
- Frontera power stering probs...
- indicators not flashing
- cav and vectra brake probs
- front springs
- hand brake cable snapped :(
- fitting a new rear/bootlid window?
