PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Wiring help needed asap
  2. corsa c
  3. 2.5V6 in nova spider??
  4. nova master cylinder wot can i do?
  5. ABS Light
  6. Mk4 Wiper seizure
  7. Vectra brake problem
  8. Help Needed Urgent
  9. fitting an apexi to the nova the day - couple questions
  10. FAO Dom + anyone clued up on electronic speedos
  11. Final drive ratios, differences?
  12. toyo r 888
  13. Which calipers?
  14. Getting Fed Up Of Chasing Problems
  15. Soft Brakes on a corsa V6?? help
  16. alternator, which one?! help me plz
  17. CORSA SPI to MPI for V6 conversion
  18. cav still running crap
  19. pas mount
  20. cd player problem
  21. Quick brake question ... rear calipers
  22. wheres my posts gone ?
  23. trippin out
  24. Carlton Steering Unit...Price???
  25. nova tyres?
  26. Installing an A/F Ratio gauge.
  27. Nova fault code reading
  28. manual choke
  29. 02 sensors
  30. handbrake cable on a calibra
  31. Corsa B electric windows problem
  32. wonky wheel
  33. Nova - rear brakes locking
  34. torque? ft lbs - nm
  35. Cavalier - knackered rad fan switch??
  36. Any Body know the price of????
  37. Do they have the same?
  38. Rev counter
  39. leaking roof
  40. how do you put pics in these threads?
  41. Caliper reconditioning
  42. digital dash into a corsa?
  43. electrical prob
  44. Revving problem
  45. corsa c fitted with a 1.9cdti 150ps
  46. Rear brakes disc conv. Can I use cally?
  47. quick question....astra mk3/cav.
  48. corsa suspention
  49. Corsa fault codes
  50. lowering cav v6
  51. suspension driving me mad!!
  52. seam weldding
  53. lower teemp rad fan switch...
  54. reverse light (again, sorry)
  55. wheel centre bore question, mk4 astra van
  56. urgent help needed.. alternator removal
  57. Rear disc Brake conversion !!
  58. suspension opinions???
  59. Rear brakes locking - Nova, stripped & disc conversion.
  60. Redrilling 5 stud Disks... Template?
  61. Photo Request: Imoboliser transponder pickup
  62. Temperature Gauge Sender Unit
  63. Nova cuts out
  64. 20seh problems???
  65. Dodgy Alternator????????
  66. matching weber-dellorto jets etc
  67. Ogle my bits! (or just look at my plugs!)
  68. dim brake warning lamp
  69. aircon fan switch on
  70. cav gsi springs
  71. Overheating TD
  72. Help removing astra subframe
  73. coolant warning light
  74. Need help asap.
  75. Removal of calibra bumper - help !
  76. speedo problem
  77. Hesitation, Whats up!
  78. LED sidelight raplacements flashing - why?
  79. Door and boot lock
  80. Corsa window help needed!
  81. astra gsi running problems please please help!!!!
  82. Twin Bottle NoS Set-up, Advice please
  83. brake bleeding questions...
  84. astra 1.7 dti resonator box
  85. X17DTL Used from to when?
  86. 16v on 8v ????
  87. nova gte lumpy idle
  88. cav gsi
  89. How much to change speedo ring
  90. Lowering Astra MK4 30mm
  91. Uprated Brakes
  92. Digi dash
  93. corsa c column into nova
  94. uneven brake pad wear???
  95. Centre posts removal!!
  96. URGENT! temp gauge not working!
  97. URGENT! temp gauge not working!
  98. Rear disc question
  99. strange braking problem
  100. Cav GSi running problems.......
  101. remote locking: pulse timing question
  102. vectra traction control not working
  103. removing aircon
  104. Steering Lock stuck!
  105. astra mk4 brake upgrade to mk5 vxr spec
  106. Idle Problem – could this be a expensive fix?
  107. Astra G 2.2, stalls and cuts on normal driving
  108. vectra 2.2 ls. help
  109. software ASTRA H
  110. Nova Rev gauge
  111. O2 Sensor Circuit Malfunction WTF HELP ME
  112. Temperature gauge sensor ???
  113. manual boost controller advice
  114. air con pressure to much
  115. nova quickshift
  116. Traction control problem advice needed
  117. Electrical / Battery or alternator Problem
  118. Strange Fault
  119. battery flat but dash light comes on when the ignition is off HELP PLEASE!!!
  120. '96 Corsa - Aftermarket Air Con?
  121. What material are these intakes made of?
  122. Air con again :(
  123. Does anybody know what this noise could be
  124. **non vaux warning** noisey diff?
  125. Need Part Number Help!!!!!
  126. Replacing abs sensors?
  127. PC to ECU problem
  128. HELP PLEASE P0100 Mass or Volume Air Flow Circuit Malfunction
  129. Cav Brakes Have Gone Sh*t After Suspension Swap
  130. Altenator Wiring Problem!!
  131. coolant change - how often?
  132. Corsa V6 mounts
  133. **corsa gsi immobaliser help**urgent
  134. nova prob?
  135. speedo query, mk3 Astra
  136. no rev counter and battrey aint charging? changed alt twice
  137. changing 2e3 to a webber on a cavalier
  138. Feul line
  139. just a quick brake question for my mate
  140. can anyone tell me how to reset the airbag light on a mk3 astra?
  141. Astra MK3 16 Pin diagnostic port help please..
  142. dig dash
  143. How much to fit Discs and pads???
  144. 3000GT Tuning info please
  145. gauges
  146. battery light??
  147. Rattle Noise
  148. Bollox!
  149. loud water noise in corsa
  150. idel air vale
  151. bleeding problem
  152. Car has ran out of coolant and making weird noise, advice please!!
  153. Noooooooooooo
  154. Cav dash lights playing up
  155. Vectra C rear hubs nightmare
  156. how to change a wheel bearing?
  157. lost key!!!!!
  158. battery wont take any charge!!! ALTERNATOR HELP!
  159. Fitting ABS to a Corsa?
  160. whats bettaer?
  161. Astra mk4 gsi bake pad query
  162. 1992 Opel Astra ALDL
  163. charging a battery with a booster pack
  164. spax rsx set up
  165. Steering knock
  166. c.v joints
  167. annoying wheel noise
  168. got a prob wiv ma new cav
  169. steering rack removal? no haynes gen!
  170. Astra Ignition Install Probs
  171. anyone know of cheap air con re gassing in South East/Surrey/Sussex?
  172. rear disc conversion
  173. dying out!!!!
  174. Fault dode "74".Tried everything!
  175. ahhhhhh hot clibra any ideas
  176. How do you fit a sandwich plate?
  177. Vectra rear suspension bushes
  178. how lean can i go for motorway cruising ?
  179. nova suspension
  180. V6 4 Stud Brakes
  181. Rear brake shoes slack/sticking?
  182. cav is nearly dead
  183. how do i get my speedo to read right after conversion?
  184. 20seh running NOS
  185. calibra problems
  186. help air con
  187. Calibra disc sizes???
  188. suspension help
  189. Code 0412 on a tigra? what is this?
  190. Corsa B Power Steering Question
  191. Ignition question
  192. Speedo drive goes sometimes and doesnt other
  193. rear hub torque value 5 bolt hub vectra c with abs
  194. dis pack info needed
  195. whys heater motor/blower sticking?
  196. Astra H brake pad help please
  197. spigot rings?
  198. washers on rad fan switch
  199. shaking on ster wheel and brake pedal when braking??
  200. E16se - corsa b -management light query/dis cap adjustment
  201. vectra e/management light?
  202. Bleeding Wilwood 4-pots?
  203. traction control advice (sorry if its a repost)
  204. Anyone know where to get an external wastegate....
  205. Running on 2 cylinders
  206. Zafira Central Locking
  207. Screamer pipe and MOT.
  208. calibra/cavalier struts
  209. Possibility of making Custom adjustable Top mounts for Cavalier/Calibra
  210. Intermittent starting problem (GTE 16v)
  211. Cruise Control Problem Astra
  212. Air Con Gas Question....
  213. Multi Info Display
  214. Would this work?!!!!
  215. digi dash
  216. Hit Curb - Tracking Out Any More Damage??
  217. vectra ignition
  218. Urgent help required
  219. Cavalier whirring/humming noise
  220. Cavalier Top Mount Problem
  221. lowering springs ??
  222. Hot track days
  223. URGENT! Powersounder Problems
  224. Air Con Re-gas in Berkshire
  225. ECU type?
  226. help please guys what transducer is AA for??
  227. Cav Sri - What Performance Mods?
  228. frged pstons, doi need "frged" gugeon pns? dnt cme wth ne, shop sez 150 4 rngs & pins
  229. irs rear wheel bearing how?
  230. Warning Lights
  231. digi dash sender prob help!
  232. Astra Mk 3 alternator part numbers?
  233. Astra GSI running problems
  234. air con not blowing cold
  235. astra digi dash in k reg 1.2i nova?
  236. Nova Wiring Help !!!
  237. When posting about problems with your car...........
  238. ABS light coming on....need help urgent
  239. please help identify this part *pic*
  240. worrying noise
  241. Anyone got an arch roller they can rent me? Midlands (will travel to pickup)
  242. Anyone got an arch roller they can rent me? Midlands (will travel to pickup)
  243. Suspension
  244. Astra shocks and springs
  245. biting point is really low on pedal on corsa b. how does it adjust?
  246. hit kurb now susesion makes squeaky noise!! any help??
  247. vectra gls
  248. discs or drums?
  249. vacuum gauges
  250. Reverse Indiglo Dials
