  1. battery size
  2. Coupe headlights in mk4 hatch
  3. is anyone here has experience with coleman pro-lite Steering quickener ? ? ?
  4. help in wiring rev counter on c20xe coil pac please
  5. mk4 astra wiper issues
  6. corsa b eletric window advice please
  7. Corsa c drivers footwell leak please help!!!
  8. Astra Mk3 Saloon suspension into Mk3 Van - questions
  9. calibra camber help
  10. Zafira A front hub bolt - what size socket?
  11. No speedo tc or abs on vectra
  12. 2003 2.2 dti 16v Elegance brake issues?
  13. astra mk3 gsi phase 2 heater problums
  14. CNC machined Caliper mounts?
  15. Vectra b suspesion queries...
  16. powerflex bumpstops where does the grease go
  17. vectra brakes onto Corsa B?
  18. corsa speedo
  19. astra transponder and chip
  20. bottom ball joints on cavy
  21. zafira A traction control switch?
  22. C20let - 288mm Caliper - Recommend Me Some Brake Pads
  23. calibra turbo oil and battery gauges help.
  24. OBD1 to OBD2 Conversion Schema?
  25. corsa gsi suspension
  26. MBC Instal is this correct or wrong?
  27. A knocking has started since a wheel change
  28. Mk4 Astra Mutiple keys
  29. Wonky Cam Pulleys! Damaging Cam Sensor
  30. Vectra sri broken spring?
  31. cutting powerflex bump stops
  32. Headlight Buzzer Relay
  33. Corsa B rear braided hoses
  34. Corsa popping fuses
  35. MK5 Astra 1.7dti ignition barrell replacement?
  36. Astra MK3 electric window switch
  37. vectra subframe front bushes
  38. Corsa - Speedo out by 10 mph
  39. Brake servo studs
  40. removing corsa b steering column
  41. Astra Mk2 GTE Suspension Part No?
  42. Dash Lights Dimming!
  43. c20xe nova running problem backfiring when revved up
  44. holset turbo flanges??
  45. egr valve corsa b
  46. corsa b Exhaust advice
  47. astra gte rear reluctor ring?
  48. V6 into Astra Mk3 what radiator
  49. Angel eye headlights
  50. vauxhall cavalier gsi "rear droplinks"
  51. how much brake fluid to fill corsa b complete system
  52. how much power steering fluid to fill up corsa b from fresh??
  53. what Ib springs for corsa c20let
  54. 2.0 16v brakes question
  55. Omega B Caravan MV6 3.0 - Radiator Replace
  56. Digi dash top speed
  57. corsa b strengthening plates
  58. calibra wiper arms (driver side)
  59. corsa 1.4 16v 98 plate lowering 60mm load sensor
  60. Astra gsi remap?
  61. Zafira GSi slammed on coilovers today.
  62. corsa b 1.0 to c20let wiring
  63. Fitting cruise control to my 2004 1.8 astra coupe question
  64. Electric Window Motor
  65. corsa b springs
  66. coilover fitment mk3 astra rear
  67. Tech 2 neded in Sussex
  68. HELP, MK4 astra x18xe1 immob fault..?
  69. urgent help required
  70. Corsa b back kicking out when braking
  71. Corsa VXR wiring. Can someone identify these wires for me?
  72. someone with a cavalier 8v please help me out?
  73. 1.0 corsa 3 red/blue wires (help) with a pic
  74. spax adjustable should it have resistance when pushing down
  75. corsa b electric pas fitting
  76. suspension on the nova
  77. help needed z20let wiring
  78. corsa rev counter wiring.
  79. Mk4 Astravan help****
  80. Nova Bushes
  81. Fuel pump wire
  82. mk3 diesel x25xe conversion
  83. Astra SRI turbo, fitting turbo timer?
  84. Tigra/Corsa B suspension Upgrades?
  85. 3 Point Harness fitting
  86. Transducer wire comfirmation..
  87. Corsa B Headlight and Bumper Removal
  88. MK3 Astra GSi silicone hose kits?
  89. astra mk4 diesal tanks is there a pump in them
  90. Just Two Quick Questions!!!
  91. corsa b wiring loom
  92. fitting bigger brakes to my corsa b
  93. brake servo this is becoming a pain someone has the answer
  94. Standard Corsa GSi Exhaust - Rattle issues
  95. astra f brake servo plz help
  96. vectra c passenger seat wont move forward with pull lever at front
  97. C20XE Driveshafts
  98. Solid discs to vented discs
  99. Running without servo
  100. corsa c 1.2sxi faulty dash\engine cuts out
  101. Nova upgraded master cylinder and servo question
  102. Symptoms of a knackered ABS unit?
  103. Air conditioning problem
  104. Corsa Wheel Bearings
  105. Astra GTE Speed Signal Can Drive Cruise?
  106. C20LET & Bailey DV26
  107. Fitting big block CV's to a corsa correctly
  108. Astra mk4 gsi brakes
  109. xe/let fuel rail fitting
  110. Astra mk5 MFD help needed
  111. A little wiring prob (call me stupid)
  112. c20let loom, non-mni loom type
  113. testing a crank senser
  114. opcom hull
  115. [ELECTRICAL] DIGITAL LCD Kadett/Astra E GSI at NOVA 1.5TD
  116. has anyone powder coated coil springs?
  117. anti roll bar bushes should they be a tight fit
  118. steering rack noise
  119. Bike Carbs on the 20XE
  120. C20XE corsa no fuel or spark
  121. xe corsa conversion
  122. Op-com
  123. 1.6 16V ECU wiring
  124. Astra Mk4 wiring loom (with sneaky picyure of my car)
  125. Another Digidash Problem :/
  126. mk3 astra gsi fog lights - where from
  127. quick corsa gsi C20XE question
  128. ATE 16v caliper refurbing (seals etc)
  129. Brake Bleeding Squence
  130. front calibra leathers
  131. astra mk3 1.4 ..mk3 gsi C20XE engine swap ecu
  132. Astra Mk2 Gte 16v - no ABS teeth on new rear discs
  133. Vectra B Steering Issues Z22SE engine
  134. mk3 astra. Headlight, all identical wiring?
  135. Rear Coil Spring Replacement - Astra SXI 16V 2004
  136. Engine loom grommit / hole size needed!!
  137. wiring looms
  138. Astra f c20let brake problem
  139. OEM Shock Absorbers - Lowered Springs
  140. Brake Fluid - How much do I need?
  141. vectra gsi recaro seats not working
  142. Mk3 Cav/Calibre
  143. Mk3 Astra Sport 2.0. Brake Upgrade?
  144. Fan/Catifold Problems
  145. front hub
  146. Corsa B C20XE wiring question
  147. mileage correction
  148. any resident loom repaires/assemblers?
  149. vec gsi 3.2v6
  150. fuel problems
  151. a good NON silicone based brake fluid ?
  152. help to choose a good disc to go with my wilwood caliper's
  153. corsa making loud noise when turning wheel
  154. removing these brackets?
  155. Disposable work gloves, which are best?
  156. Which Bilsteins, B6's or B8's! Mk4 Astra GSi Turb
  157. Problem | I broke the water tank water port
  158. anyone running c20let ebay chips
  159. bigger discs on my corsa calipers
  160. is this bad
  161. mileometor not working? vectra 06 plate
  162. Fitting a Oil Pressure gauge to my LET. Help please...
  163. Vectra B Electrical Problem (Instrument Panel)
  164. Corsa b eps controller problem
  165. Mk3 Astra/Cavalier/Calibra front shock absorber....
  166. No plug for radiator fan???
  167. Can anyone advise pads to use with this wilwood caliper?
  168. Astra mk4 > C20XE conversion wiring question...
  169. my radio isnt working
  170. cavalier weight
  171. best method to press in wishbone pushes
  172. Bleeding brakes - Corsa B
  173. Thumping and shaking under braking
  174. anyone had custom brake bells made?
  175. digi dash not reading a speed
  176. difference between engine mounts
  177. 308mm Brakes on Mk3 Astra - Whats needed?
  178. Adj Corsa Top Mounts
  179. Corsa B brakes
  180. ecu
  181. identifying c20xe loom
  182. daewoo gte few probs
  183. Vauxhall Combo Fule pump
  184. c20ne nova
  185. Calibra Turbo dash lights problem
  186. Astra Coupé Turbo fuse 39 keeps blowing
  187. mk4 astra - Can anyone recomend any good coilovers??
  188. Corsa B Loom
  189. I need help fast !!!!
  190. Vectra OBD
  191. corsa b engine bay
  192. 5 Stud help please
  193. corsa b c20xe uprated master cylinder
  194. Windscreen washer jet hose
  195. C0256 - Engine torque reduction malfunction
  196. Corsa PAS pics needed please 1.4 8v and 1.6 16v
  197. x20xev into corsa 1.2 16v wiring help
  198. Corsa b 5 door questions
  199. is this a f28 digi dash transducer?
  200. 288mm or 308mm
  201. Corsa Brake Pedal and Servo into a NOVA!!
  202. CANbus system
  203. c20let ecu.... what are these wires??
  204. What spark plugs are you guys using with carbs xe
  205. astra 1.4 spi going to bike carbs, distributor wiring help needed
  206. Custom radiator
  207. Replacement dust boots - rear shocks
  208. afm plug?
  209. C20xe sensors
  210. Fitting VXR8 calipers to Cav Turbo - Brackets??
  211. corsa b driver door lock
  212. M.o.t fail help
  213. 1998 corsa b 1.0 12v coil pack
  214. fiat coupe brembo brakes
  215. Nova bonnet release cable - removal
  216. Stuck suspension
  217. random but any idea if mk5 lock set will fit mk3 astra?
  218. C20XE Power Steering
  219. Corsa C Boot Lock Problem
  220. Question reguarding saab and vectra shocks/struts
  221. c20let project. help needed!
  222. c20xe bottom pulley????
  223. Lotus Carlton Front Brakes on Astra mk3? Possible or not??
  224. C20XE - CTS thread size?
  225. Sunroof jammed half open.
  226. 1998 Astra Mk3 x20xev MAF wiring (Colors need)
  227. Astra MK3 rear calipers
  228. corsa c immobiliser problem
  229. C25XE conversion specialists west mids south west area??
  230. Anyone on here use Compbrake Calipers?
  231. astra mk3 gsi cat needed!!
  232. 288mm Calibra Discs Redrilling??
  233. Loose coilover piston......
  234. c20XE into 1.0 Corsa (12v) wiring help!
  235. corsa c caliper mount measurement
  236. C20xe on carbs on spark
  237. scored disc does this mean new discs are needed
  238. vauxhall combo milage not showing up.
  239. XE Corsa B master cylinder questions
  240. how to check if a disc is warped
  241. corsa c20xe no spark or fuel
  242. Corsa B P.A.S fault??
  243. 25xe superchip piggy back relocation
  244. strut brace
  245. Do I need to save any of the loom?
  246. astra gte digital clocks
  247. astra gte 16v calipers..
  248. broken front bleed nipple
  249. porous head on c20xe
  250. Frontera FMIC Pipe Diameter...
