- Juddering
- Astra MK4 Van
- Polyurethane/uprated uspension bushes.
- Need some help on Tigra/Corsa front wishbones.
- Corsa no. plate light fuse
- avo coilovers on corsa
- Wierd question, indicators have stopped working! what do you think?
- LET ECU rev counter pin out
- corsa 50 or 60mm rear springs
- wiper arms
- can i fit 18s????
- brake disc size upgrade
- nova battery
- Suspension higher at rear
- Astra mk4 help.
- cav 3 strut top bearing, would it cause?
- corsa dials (swap)
- Cavalier digital clock/temp sensor staying on.
- Corsa B Rear Disc Beam Handbrake?
- Wiring up Angleyes
- Cav Mk2 SRi: Suspension clonking?
- Electronic powersteering on Corsa?
- Steering/wheel problem
- mot failed, handbrake
- ABS light prob help pls
- Removing Clutch Pedal; Corsa sport
- Power steering on a Corsa LET?
- mk3 astra gsi rubbers
- heaters damp ?
- astra mk3 turbo brakes
- remote locking not working
- fault code says"air mass meter low voltage"
- Whats the best Air mass/fuel meter....
- Can anyone help with Cavalier heater matrix ?
- morette lights
- Noise when turning left..
- Plumbing in a Brake Bias adjuster and hydraulic handbrake?
- Bias valve thread on nova?
- Vec gsi estate springs
- induction kit
- heaters wont work
- quick nova wiring q - should be easy!
- What type of relay is a fuel pump relay? SPNO?
- 4 pots that will fit under 15s (RL7S)
- de cat
- which way round do grooved discs go
- steering wheel noise with airbag wheel?
- Spigot rings to fit Turbo brakes
- fiat coupe turbo 284mm 4 stud discs fitment
- Omega Not Starting... X30XE
- loom on a c20xe into corsa
- Calibra Battery
- MAF sensor for Gsi 1.6 problem need help
- Removing electric window regulator
- Single wiper corsa B
- Exhaust noise
- cooling fan not working
- C25xe Wiring help
- ABS light's on.
- v6 calipers on a corsa, reducing pedal travel.
- Electric windows
- corsa /nova rear strut brace's??
- Can you overtighten hub nuts?
- cav gsi & sri front dampers
- Indicator Problems Need Help!
- Starting Issues
- no eml light on startup
- Window help
- Cav Turbo Wheel Bearing
- OMEGA 3.0 V6 Elite Electrical Probs
- KPH to MPH Odometer
- KPH to MPH Oddometer
- Changing lights behind heater controls - Corsa B
- fuel pressure gauge
- mk3 astra fuel pump relay, and wiring.
- Toyo Tyre pressure
- Nova Brakes
- 1999 Mk4 Astra 1.6 SXi Wiring guide
- Astra G OPC / Coupe Headlights
- horn wires
- engine mod wiring problem
- Indicator Flasher problem ... help!
- Charging Fault On C20-XE Cavi
- Rover 25 front wiper problem
- traction control/ electric speedo
- extra wires
- mk3 astra angle eyes wiring ?
- XE to LET loom
- Quick answer needed - Multitimer
- Astra handling
- corsa LET spax coilovers question
- Corsa XE PAS
- Best setup for double wishbone suspension
- Testing a fan
- Remote brake servo ??
- Nova front bumper and radiatotor removal to fit new crossmember??
- Fuse
- Brake Load Sensor - Adjustable?
- Castle nut torque
- Getting a bit frustrated now...
- 90357303 & 90357304, whats the difference
- Strange Calibra Electrics fault
- Range on fuel comp no voltage on wire??
- GTE cross member cutting
- Omega X30xe High Miles Pcb Fault???
- Cav windscreen
- Central Locking Intermittant fault Mk 3 Astra
- Corsa Electric Power Steering
- Do you need a flexi joint between downpipe & system ?
- Electrical fault,nothing works except ignition lights?
- Brake Seal Kits (avaliability)
- Steering wheels boss for 86 nova..
- Nova major anti roll bar problems
- Turbo brakes
- Auxiliary Ignition Switch.
- Corsa C steering wheel
- leccy windows
- Indicators on 1996 Corsa
- best suspenion for mk3 astra
- Corsa TD battery light comes on when i select reverse??
- help with OMP rear strut brace
- Vec B Estate Trailer plug - where? pls Help
- lowering 60mm on standard shocks
- MK2 Astra top mount assembly - is this right?
- removing cav\cali turbo shafts
- AVC-R Selenoid Question ,
- urgent help needed (rover metro)
- Speedo cable nova.
- v6 brakes on a corsa
- vectra v6 rear disc hubs
- 140 speedo clocks and 160 speedo clocks
- xenon lights out of a cdx fit cdx ......
- LET Mech/ Elec Clocks?
- Astra v6 lcd dash
- strut top bolt size
- Coil pack wiring
- Corsa brake fluid
- Coilovers/tracking
- fuse help needed
- Suspension confusion
- Brake Discs for Mk4 Astra GSi
- would this work brake servo question
- XE conversion
- Corsa B Coilovers, Which are best?
- Knocking in rear of car
- Fitting a FATT Blitz Turbo timer
- spark plug leads
- Were can i get replacement headlamp glass????
- Wheel/Tyre Size Wide track Nova
- Towing a Frontera
- mk3 astra digi dash cant get fuel computer working
- Oil pressure sensor on GTE Digi Dash
- Steering lock jammed :(
- Vectra brake servo change?
- hiding those engine bay wires???
- Oil pressure sender
- nova brakes? please help me!
- Best place for standard MK4 Estate rear dampers
- corsa b lowering springs
- Electric Window fault - Wiring Diagram inside (Dom)
- central locking wires, which 1s?
- Lynx automotive ECU ??
- Corsa pad question
- Help needed wiring digi speedo
- LET ignition leads... whats best??
- Powerflow Exhaust - I'm NOT happy!!!
- Exhaust flanges...
- c20let astra gsi fault code problem
- Air-Bag Light NOT WORKING
- filling small hole in backbox
- Another Motorsport Spec wiring loom in progress
- digi dash into a corsa
- Nova brake pipe fittings -3
- Will I need a key for these..?
- Adding Rear Disc brakes to a previously Drum Cavalier, a couple of questions i have
- Coilover and helper spring - help!
- rust around wheel well
- MK2 Astra cage
- Rear coilover spring LB?
- Astra gte and astra gsi rear brakes
- Fault Codes...
- corsa c wiper relay
- Nova Fuel Tank
- key fobs
- cav gsi
- digi dash bulbs
- Non working fan of death!
- What pins do i need to short out?
- corsa imobiliser
- 308mm upgrade abd alessio 2s
- Quick immobiliser pickup wiring question
- Lowering a mk4 astra van?
- immobiliser
- nova rad and fan
- MK2 GTE (LET)Fan and horn stopped working. HELP please
- Sunroof Problem!
- George W. Bushes
- Mk2 astra gte suspension worries!!
- astra mk4 gsi exhaust fit zaf gsi?????
- Hitech Suspension Systems
- nova braided brake lines info asap
- Step by step - what to check on Aircon
- fitting air con to a Astra GSI!
- nova coilovers
- coilover quickie
- can someone answer this quick lol. starter motor turning over with out ignition on?
- warning lights.....again!!!!
- Which suspension? (Mk4 Astra with current suspension woes)
- Hi Spec 300mm Conversion
- Plug on a Mk4 Astra X16XE, what is it?
- how accurate is speedo on Astra mk3
- sealing a drilled hole
- 1997 tigra speedo not working
- mk3 astra electric mirrors
- Help me settle an argument!!!
- Cavalier MK3 CDX Ecotec problems - Help
- HELP! Corsa b exhaust
- cav gsi red top
- Digidash constantly flicks from mph to kph
- Known Issues With Vectra C
- Digital Dash
- Digidash Struggling in LET Nova
- Vectra Backbox on Cav?
- Will my handbrake pass the MOT ?
- Resetting a rear seatbelt after it's been removed.
- calibra turbo brake upgrade
- kenlowes again
- Wiper motor - recon/replace where to buy?
- gaz coilovers
- Paperclip Test
- replacing clock for computer?
- Astra GSi Traction control experts advice needed
- Brake Kit for 16" Wheels
- immobiliser chip
- 96 Vectra Central Locking
- Quick SARD reg question!
- MK3 Astra - horn stuck on
- Nova fuel system diagram. (MPi)
- New Car's Trip Computer + Sat Nav Question??
- starting problems
- C20LET Tachometer problem,
- ABS and TC fused????
- corsa missing at low revs???
- 3 pipe mod/cool stat?
- Vectra Trailing Arm Bushes
- rear disc conversion
- Vectra TID/TFD to Mid/MDF upgrade
- What tracking setting on a nova?
- Corsa B door loom
- tracking
