PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Astra MK3 ignition switch woes - I think ..??!
  2. traction light and ABS light on all the time.
  3. help help help
  4. Aaaahhhh s**t, is this buggered??
  5. Help Needed!!
  6. help needed
  7. rear wheel touchin arch
  8. vectra 2.2 sri airbag
  9. Is this why my car runs so crap and failed MOT emissions (pic)
  10. will bargain gmax kit fit my corsa - help ?
  11. electricity short circuit
  12. Which Aircon Compressor for 2.2 astra
  13. steering lock woes
  14. vectra dash
  15. Cav clocks in a corsa
  16. help with speedo!
  17. Reasonably priced electric impact wrenches.
  18. Non Vaux help
  19. Electric window probs
  20. are the brakes from mk4 astras the same as zafira?
  21. To change Coolant Temp Sensor, partially drain water??
  22. vectra b remote locking
  23. cav windscreen
  24. Cav Mk 2 Help Please!
  25. Front bumper with foglights
  26. Preston Garage
  27. boost from a compressor
  28. Kangaroo problem NOT SOLVED! More help guys:)
  29. Astra Coupe 2.2 mods
  30. Need some advice on technical jargon
  31. v6 flat after 3500rpm????
  32. Astra pulls to left
  33. Stupid Angel Eyes
  34. 20 se and seh
  35. firing order
  36. HT Leads in the way after top end rebuild
  37. Please help im in deep poo poo
  38. How hot will powdercoat withstand????
  39. Anyone with a VXR Astra/Zafira in the Reading/Berkshire area?
  40. Air sensor or something similar... where is it....
  41. Tech specs on 2.5TD Omegas
  42. Calling al mk3 astra owners thats fitted a v6 badboy..
  43. big brakes with 15''
  44. Are all Corsa hubs the same?
  45. cav gsi mk3 problems
  46. x-police v6 cav.. 6 speed or not
  47. Nova conversion
  48. How to unplug drivers wheel airbag?
  49. 3.0 V6 with cone filter...
  50. best suspension?
  51. urgently needed tonight, brake pads cav't
  52. Quick question - Astra GTE 8v & 16v shafts
  53. Calibra 2.5 v6 traction control
  54. MOT Emissions failure, advice please
  55. angel eyes
  56. Hydraulic lifter bore problem...
  57. 95 astra ignition switch
  58. inner cv joint poping out
  59. Fitted bilstein front shocks, now sticky steering
  60. Cruise control.........
  61. Corsa GSi Running Problems
  62. Need some help for my wierd problem
  63. immobiliser vectra 51 plate
  64. best brake pads to use????
  65. CORSA C wiper problem help please
  66. 2 questions
  67. car chokes at lights?
  68. ECU pin data
  69. peoples oppion on megasquirt ms2 kit?
  70. squeaking shock
  71. nova bleed nipples??
  72. cav fan switch
  73. Cruise control..............
  74. Nova changed brakes help!!!
  75. Will Calibra ignition & door locks fit Corsa
  76. URGENT! 17s on a corsa
  77. Quick and easy one (I hope)
  78. S button on Auto box
  79. fitted new tapets...
  80. 1.7dti problem
  81. Air bag Light
  82. Momo wheel onto corsa with airbag
  83. will this work ?
  84. speedo question (newbie)
  85. Parts I ll need .. help
  86. Black Rubber Hose suppliers
  87. Corsa advice
  88. 4 Wire o2 Sensor Question
  89. lowering help
  90. fitting a fan switch
  91. best place to buy corsa suspension ??????
  92. astra convertable roof
  93. Electric mirrors???
  94. i have issues
  95. high mileage??
  96. 95 Corsa key number
  97. Cavalier squeaking like mad..
  98. saxo vtr's a little tech help please...
  99. power steering probs
  100. Seat Heater Switch
  101. Bolting aftermarket seat side mounts to the floor pan - safe?
  102. would this work?
  103. cav ecu wiring
  104. omega v6 problem fault code
  105. Silicone vacuum hoses
  106. Cav v6 faults
  107. How much?????
  108. Just Need Some Advise Please:
  109. Wrecked another tyre. Height Issuses or Suspension Issuses?
  110. The 3.0 Calibra Awakens!
  111. Brake light wire
  112. Astra G rear calipers
  113. My Chavalier has a floppy knob....
  114. vectra charging problems
  115. 02 sensor
  116. replacing calliper piston seals
  117. Front Fog Light Switch Wiring
  118. v6 brakes
  119. weight?
  120. Rolling Radius
  121. Electronic speedo drive cables question. Help Please.
  122. i know its not a vaux but does anyone know about renaults
  123. urgent help needed b4 pod on sunday
  124. where can i get the wee tie-wrap type things for mounting a fan to a rad?
  125. Calling all Bike Mechanics....
  126. thread size of water temp sensor?
  127. Start up problems!
  128. 16" irmscher softstars and big brakes?
  129. Cav GSi wouldnt start...???
  130. Astra 2.0 Dti Fault, error code 1651
  131. 98 Omega, strange beeping sound.
  132. Compbrake components, anygood??
  133. Temprementle boost problems
  134. Where is this ment to go?
  135. Watertemp sensor on 20SE
  136. URGANT help....DV problems
  137. gsi2000
  138. DIY big disc kit.
  139. any advantage of putting steering arms below the knuckle - nova
  140. battery bag / cover where from ?
  141. squeaky brakes
  142. pas pump/pulley, squeeling/squeeking/noisy
  143. gsi sunroof
  144. Can you remove / replace Nova bonnet hinges ?
  145. MK3 Astra fuse box relays? Should i have 6?
  146. Quick Silly Questions - Brakes - Removal of Guide Bolts on Caliper
  147. Any Jaguar forums or anybody clued up on their jags?
  148. Free gift for you !!!
  149. vauxhall astra rear wheel bearings
  150. Free gift for you !!!!
  151. Rod ratios - What figure to aim for?
  152. buying and refurbing brake calipers ?
  153. 12V compressor from Frontera / airhorn
  154. Electric Windows - Corsa C
  155. help needed with omega ht leads
  156. not vaux, but for auto box??
  157. clio question..... (non vaux i'm sorry!)
  158. air box mod???mk3 astra gsi
  159. IDEAS for selfbuild centre console for mk3 astra
  160. standard nova rear string length anyone?
  161. subie doe's a 9.1 at 157mph, given my m8 an idea! please read
  162. astra gsi
  163. my astra is p!ssing me off again...
  164. Boost Problems
  165. nova lamp pod connector
  166. Help Needed Urgently
  167. nova boot release with a difference- help
  168. anywhere in Surrey besides Vauxhall who has Tech 2?
  169. Astra Bertone 2.2 ABS+TCS MIL on start up
  170. where to get mounting brackets to fit calipers?
  171. 2l eco runings prob's??help please??
  172. astra 1999 weird noise
  173. quick question-nova door
  174. whats the best brakes as close to £500 that will fit under 15" wheels for my zafira?
  175. Siemens 5wk7331
  176. Speedo/Rev Counter wiring
  177. Lowering springs
  178. astra mk3 mfd set up with cav gsi switch?
  179. advice needed for my mums 02 plate corsa
  180. Astra F, Slow idle
  181. fitting cobra suzuka seats to nova
  182. Problems!!!!!!!!
  183. Nova revving high
  184. v6 holding back
  185. Coolant guage acting weird
  186. Should my Hub look like this?
  187. Grinding \ Rubbing Noise From Passenger Footwell
  188. Cylinder 1 misfiring badly.
  189. Need a clip for a cv boot - how big are they?
  190. Just bought me a 2.2 astra coupe
  191. 16v conversion
  192. Speedo swap
  193. need some corsasport measurements
  194. rear disc conversion on corsa b
  195. have all corsa gsi's got f15 cr box in??
  196. ABS Problem
  197. differences between 16v and 8v
  198. Battery Giving off Fumes, Is it ok?
  199. abs problem
  200. EM light on Astra Coupe
  201. Can I get new key to replace lost one without new lock set?
  202. Does this look like a calibra front strut brace?
  203. car pulls slightly to left - what's the cause?
  204. Audi TDI problem... Slow as fook...
  205. Re-fitting Cav front nearside window ?
  206. trip computer
  207. fault codes 15 and 113
  208. Safe revving ????
  209. Corsa Brakes?
  210. ANYONE HERE USES MSD ignition amplifier(DIGITAL 6 PLUS)
  211. Astra MK4 - problems with Safety Lock
  212. Bleeding Brakes on T-Reg Corsa 1.2 16v
  213. Automatic to manual
  214. nova outer CV quickie...
  215. Urgent PAS Question
  216. ECU Light coming on during deceleration and no speakers!
  217. contact number for msd in blackpool?
  218. quick digidash question
  219. rad options on a mk2 astra
  220. blower
  221. Fault finding diagnostic plug
  222. Boost Pipe Q
  223. New To Forum, Couple Of Questions
  224. legalities of hydralic handbrake?/opinions?
  225. best place to buy polybushes corsa b
  226. Wedged socket
  227. Idle CO potentiometer
  228. What would you recomend?
  229. single point to multipoint questions
  230. Steam and pipe split
  231. tigra automatic window
  232. Calling all Emerald ECU owners or anyone who might be able to help!
  233. Tyre size on a Vectra?
  234. How to work out how much my cars lowerd?
  235. astra mk3 up the ante
  236. nova gsi 2.0 16v vs corsa gsi 2.0 16v
  237. Vectra brake light switch
  238. Corsa Sri 8v into Nova ?
  239. 2002 astra front hub assembly???
  240. Astra Mk3 RPM Meter
  241. corsa front end strength
  242. 2L 8V advice needed
  243. cossie boost sorted!
  244. Vectra 2.2 DTI.. Cold starting Problem..
  245. How to adjust lights hight in astra G?
  246. Boost + ECU problem error 113
  247. ive gon n broken it aint I
  248. ABS Removal Help Corsa GSI
  249. 4 stud rear disc conversion on mk4 astra
  250. FAO anyone using a widetrack kit on a nova
