  1. Cav v6 heating prob
  2. Brakes For Astra mk3 turbo??
  3. Flashing Fault Codes - Erratic
  4. PLX DEVICE to MOTRONIC 2.7 Wiring Question.
  5. Corsa Stub Axel
  6. LCD vectra (Cavalier) tacho - Kadett gsi (astra mk2 gte)
  7. Nova xe suspension?
  8. Fitting a Late Style Corsa/Vectra Wheel to a Cavalier CDX...
  9. I can feel a knocking through the pedals...
  10. 52 Combo van EPAS rack
  11. cigarette lighter
  12. calibra aternator
  13. is there a guide to fitting oil pressure gauge
  14. steering wheel vibrate, then dash, and knocking sound
  15. digi dash wiring diagram
  16. wideband decisions
  17. Need the correct name for the ABS dummy bar
  18. Cav 2.5 V6 water flow diagram
  19. rear suspension
  20. what clocks are these? nova i think... but what model? (pic)
  21. temp sensor
  22. lights
  23. 20 xe in to a astra van
  24. c14se fuel pump???
  25. ECU Help
  26. whats are these disks?
  27. info on getting new keys coded ?
  28. multi function computer gsi
  29. removed abs corsa gsi but need help
  30. AEM Wideband afr gauge wiring help
  31. Gearbox Spacer C20XE
  32. exhaust
  33. V6 Waterpump
  34. Corsa B SRI Help!!!
  35. Vectra Temp Display Wrong
  36. Nova handbrake problem after changing rear brake shoes
  37. vectra braking system question
  38. z18xe throttle body trouble
  39. pic of 5stud coil over'd nova/corsa front strut
  40. can i put calibra rear discs on a mk3 astra which has drums?
  41. What strut will fit my corsa b?
  42. Machined hub help!!
  43. Thread sizes
  44. Coolant temperature guage
  45. steering probs corsa b
  46. Help!! Electrics, I Dont Have A Clue! :)
  47. C20Xe ecu wiring diagram
  48. best way of removing alternator from corsa c20let???
  49. speedo doesnt work!
  50. mk3 astra van weight??
  51. How to change a Driveshaft guide??
  52. cam shaft sensor x20xev
  53. plug gap
  54. Gauges... Are these any good?
  55. Astra MK3 Wishbone change
  56. found this plug behind glove box?????
  57. gsi v reg fault code 5301
  58. Boot latch broken?
  59. Meriva speed pulse wire
  60. Calibra/caviler front suspension top mount
  61. The strangest thing.RE windscreen washers on my '96 Combo van.
  62. abs wiring diagram!
  63. wipers stop randomly!! mk3 astra
  64. carlton large throttle body TPS
  65. Fault codes 73 , 94 since engine reshelled??
  66. Tigra Brakes Sizes vs XE Brakes
  67. wiper fault on intermittent (astra 4)
  68. Corsa B not starting
  69. abs wiring..
  70. mirrors
  71. Black wire come of batterie( dont know what term it goes back on)
  72. Calibra V6 Swap but car won't start!
  73. Calibra headlight adjuster
  74. Mk 4 Astra clock display dull
  75. Is there any free obd software
  76. mk3 astra parts
  77. Corsa camber angles
  78. Corsa Brake Upgrade ?
  79. How many different speedo's were there?
  80. engine managements
  81. brake question
  82. mk3 astra gsi rear wiper not working?
  83. Corsa B Questions
  84. Calibra beam too high
  85. omega automatic not changing gear
  86. blue flame exhausts
  87. fiat coupe conversion wiring question
  88. dahboard lights on vectra
  89. Vacuum brake bleeding
  90. Mid/Tid system data on vecs.
  91. Leccy Sunroof motors
  92. Handbrake Cable....
  93. best way to lower my corsa
  94. alternator removal vectra eco tech
  95. corsa 1.4 16v magnex system onto 1.0 12v
  96. Should a new speedo cable need to wear in?
  97. ABS plug location??
  98. lambda sensors
  99. corsa b rear coilovers
  100. nova front brake conversions using v6/turbo setups.
  101. Relocate Battery
  102. MBE967 wiring
  103. Astra GTE Digi Dash in Mk3 1.4 Astra Merit
  104. Cav Keeps Cutting Out - All Sensors Changed - HELP!!!
  105. wiring loom trouble
  106. Mk4 Astra wiper fault
  107. wierd noises coming from front wheel
  108. is this bump steer
  109. Stripping interior of corsa, how much weight would it save
  110. Mk3 Astra gsi suspension
  111. Power Steering Pump
  112. corsa 5 stud, what hand brake cable set-up?
  113. Intermittant sparking
  114. Sill replacement tips on cavvy GSi??????
  115. opening an alternator :P
  116. 4 pot brake kits, corsa c20let
  117. 4 pot brake kits, corsa c20let
  118. corsa rear axle, whats this part called/do and do i need it?
  119. Leaking Corsa
  120. Getting Springs fitted
  121. calibra trip computer
  122. Nova; lower camber bolts (how to)
  123. camber adjustment??
  124. Cav Gsi suspension help..
  125. Steering problem, mk3 astra gsi!!!
  126. vectra help
  127. ambiant/inlet temp senders
  128. Nova rear discs...???
  129. nova master cylinder?
  130. Snapped Driveshaft
  131. is it possible
  132. bigger brakes
  133. power steering problems help......
  134. is vectra 5x110 or 5x112 pcd what is cebtre bore size
  135. ecu problems
  136. mk3 astra abs light
  137. mk 3 astra standard rear springs
  138. light on dash o.O
  139. Changing the Fuel Tank
  140. vectra door hinges
  141. Fog Lights Not Working???
  142. Changing Battery, How to disable Powersounder?
  143. Those darn pedals !
  144. coilover fitting help
  145. coil over discussion
  146. Brake Howling When Turning (Not Vaux)
  147. 60mm lowering springs
  148. ebay xe chip
  149. outside temp
  150. Heated seats not working
  151. electric window motor
  152. c20xe idle problem
  153. V6 brakes(288) on a Nova-Opinions?
  154. Mk3 Cav ignition switch question....
  155. astra estate rear discs
  156. anybody fitted wilwoods to nova?
  157. coilover comparison
  158. citreon/pug powersteering
  159. corsa 2.0 16v speedo wont work
  160. Lovely French Megane .
  161. temp sender and fan switch problems
  162. DIY Rpm to Voltage Converter
  163. corsa b gsi, poor brakes! HELP
  164. Messy chassis
  165. Corsa B GSi Parts
  166. cally dooughnut bushes, where from?
  167. GAZ coilovers
  168. can anybody help on this problem
  169. Starting Problems??
  170. Suspension for mk3 gsi with a v6
  171. Ncdr 1100 & Tmc
  172. Squeaky camber bushes
  173. Strange Calibra Fault
  174. mk2 billys will they fit mk3 gsi astra
  175. Corsa Models
  176. How low on Bilstein Blacks? (rear) Astra Mk3
  177. calibra rear bushes, need info
  178. Fault code reading? which plug and wire?
  179. isuzu diesel minor wiring help
  180. Spot that sound! Please :-)
  181. tracking....
  182. Speedo over reading
  183. retop, ecotec fuel pump
  184. Xe Nova torque steer.
  185. 288mm brake discs..........
  186. Wheel repairable?
  187. can i map an ecu to how i want?
  188. Wiring in an epas pump on the corsa
  189. trip comp and some dash lights gone
  190. let fan wiring, not working
  191. Need help with ECU,chip codes.
  192. early X20XEV into Vec no holes in head
  193. Installing EDS phase 2
  194. coilovers
  195. corsa C c20let
  196. Corsa B GSi Help
  197. Help please, nova LET has no indicators or hazards
  198. Vectra - Problems - Can anyone help ?
  199. astra fault codes
  200. No Pressure Build up in brakes
  201. Corsa B GSi buttons?
  202. peugeot 106 brake question
  203. Air con condenser gone - where to buy?
  204. will these fit my corsa??
  205. Wheel bearing sizes? iv got an odd pair??
  206. Hot Start Problem
  207. Corsa 2.0 springs
  208. Corsa Bodyshells
  209. help with wireing
  210. Astra F Steering wheel
  211. Flooded Heater
  212. Full Braided Brake Lines Throughout
  213. ECU chip carriers.
  214. dashboard computer
  215. Calibra Turbo Rear Suspension And Powerflex Poly Bushes?
  216. Is my thermostat broke? I cant change heater controls to cold
  217. Calibra V6 master cylinder bore size??
  218. Corsa gsi -40mm spax springs on c16xe nova- how low?
  219. handbrake light illuminating while driving?
  220. cheapest place for wilwoods
  221. fuel problems
  222. New discs on Calibra-now brakes feel awful.
  223. vectra c 60mm rear springs.
  224. Nova Handbrake - Rear Discs
  225. lost nova keys?
  226. Any mechanic minded people in Romford ?
  227. Turbo Converted Vectra Question.
  228. Indicators Flashing TOO FAST
  229. OBD II port location? (diagnostic plug)
  230. Polyurethane Exhaust Hangers
  231. From Air Con To Climate control
  232. braide brakelines help
  233. Car written off, light front bump, what will it take to repair?
  234. brake pad light
  235. air con fan
  236. astra MK3 suspension questions
  237. Vectra heater controls > Calibra
  238. Lowering a Mk4 Cabrio?
  239. corsa c sidelight bulbs
  240. coil pack (cavalier)
  241. Brake problem
  242. Sheared XE/LET top alternator bolt ?
  243. Nova wiring questions
  244. corsa b air con query..
  245. corsa central locking wires
  246. remote central locking
  247. corsa b foglight wiring HELP!
  248. Astra MK3 rear suspension
  249. problem with c20xe in mk4
  250. Vectra V6 in Mk3 Astra - PAS pipework?
