  1. Calibra Rear shocks worn or not?
  2. Headlight issue
  3. Braided hoses, but!
  4. Overheating!!
  5. dead zafira key fob
  6. New battery for Corsa GSi - which one and where from?
  7. Part #90 052 750 - What is it?
  8. Will a brake master cylinder from a 1.2 Nova carb work on 1.2i?
  9. Nova 1.2i dizzy plug/wire??
  10. How to use a Multi Meter ?
  11. C20LET in a Corsa - which pump?
  12. serious suspension bushes upgrades
  13. Changing remote key fob battery (Astra)
  14. No blower motor and hot melted fuse - mk2 astra
  15. Corsa/nova stub axles
  16. INDICATORSstopped working ,Astra GSI
  17. Calibra cat???
  18. digi dash wiring diagram needed for mk3 astra
  19. AEM Wideband
  20. changing pads on vectra v6
  21. Sealing petrol tank
  22. omega electric seat help
  23. diagnostic plug, were is it on my vectra?
  24. Can use Nova 1.4 distributor a 1.2 engine?
  25. Superchips !!
  26. Oil Volt Gauges, how do i wire them in?
  27. Corsa Steering knock!!
  28. New discs and pads fitted...pads not making proper contact with disc?!
  29. 5 stud brake question
  30. C20xe: Engine light goes on when high reving and it goes porly
  31. Dented my Cally's rear panel
  32. vectra b steering wheel
  33. torque steer hell
  34. Would i be able to...fit air con to my MK2 Astra SRi? (18SE)
  35. indicator problem
  36. calibra turbo electrics
  37. calibra turbo
  38. Vectra trip comp with C20LET?
  39. is this possible
  40. Cav turbo tapping when warm.....
  41. koni Suspension help
  42. whole wireing diagarm for a astra gte xe
  43. nova alternator problem (please help)!
  44. Air con
  45. Urgent Help - Heater Matrix??
  46. unknown brake calipers?
  47. mot advisories :/
  48. Astra Mk3 Battery and brake fluid warning lights coming on.
  49. shuddering throught he steering wheel.
  50. Air or battery impact gun?
  51. brakes wont come alive!
  52. pas rack to manual conversion ??
  53. yellow plug behind cav clock
  54. leaf spring
  55. Corsa B C20XE Power Steering
  56. what alternator
  57. astra coupe turbo 2001,passenger cv joint?
  58. Nova camber bolts, how to set it?
  59. Wheel Balancing Problem
  60. Rear bias valve plumbing ,mk3 ast
  61. Maplin Ultrasonic Cleaner, ok for injectors??
  62. Astra Coupe Turbo Fuse Box
  63. wiring an XE in to a Daewoo Nexia
  64. Wiring up a towbar - what do I need?
  65. nova digital dash
  66. apexi avcr wiring diagram - c20let
  67. Replacing my suspension - wish me luck!
  68. Nova turbo battery size?
  69. Fuses
  70. Front Door windows
  71. Astra gsi decat question
  72. corsa xev immobiliser
  73. Fan switch fitting in a nova?
  74. Astra GTE digital dashboard in corsa c20let, what coolant temp should show
  75. 5 stud conversion astra mk3
  76. Corsa B GSi - which fuse for horn+headunit?
  77. cav td
  78. Help Needed Asap Please
  79. Replacing Center Console Lights, Guide ?
  80. Ebc rear pads?
  81. Astra Mk3 GSi MFD into Corsa GSi
  82. corsa xe exhuast bore size
  83. internal fusebox
  84. Astra Gsi - v6 brakes
  85. V6 Cavalier - Electrical Nightmare!
  86. How do i de activate passenger air bag??
  87. alernator light glowing even though i just fitted new alternator
  88. How do you centre a nova steering rack?
  89. what noise should you get from a screamer pipe
  90. Extending loom
  91. will renault wheels fit a vauxhall
  92. c16xe ecu chips 13bhp+
  93. ABS Fault Codes 43 and 56 - Poor man's Tech 1 used
  94. Squeeling Brakes
  95. exhaust query
  96. No cold air in astra gsi (1993)
  97. Aircon goes warmer at high revs
  98. Nova front tie bar bushes easy???
  99. ABS sensors AStra mk3
  100. Tophat temp unit?
  101. Heater fan not working
  102. nova digi dash (one step from being done!)
  103. Steering Wheel
  104. MK4 Astra questions
  105. backbox/silencer
  106. Changing shocks and springs....
  107. Hot AFM
  108. astra mk4, speedo probs. flickers!!
  109. Tracking manually adjusted, steering wheel now wonky
  110. Cavalier Flashing Battery Light, Airbag and Engine Light, Car jerky when coasting.
  111. Bent Nova axle.
  112. XE Corsa Springs?
  113. windows astra mk3 - repost
  114. biggest rear arb on non irs cav 3
  115. airbag/seatbelt light on
  116. nitrous on a vec v6
  117. Corsa B Electric Windows & Mirrors
  118. Help !!!! Couple of questions about Vectra brake overhaul
  119. c20 xe fault code 71
  120. Steering Rack
  121. Relocating Battery on Corsa B
  122. Heilcoiling
  123. Snapped bonnet cable...
  124. five stud conversion (astra gsi mk3)
  125. Suspension enquiry
  126. the verdict on the spax coilovers
  127. Mk 4 Astra Van
  128. Best Suspension set up to use on Corsas
  129. brake fade - help?
  130. what is safeguard?? pls help!!
  131. Vectra door switch
  132. 90 degree dizzy?
  133. can any help please, nova 1.3 sr with elec fault
  134. willwood 4 pots
  135. brakes
  136. Astra mk3 Turbo brakes, need some help
  137. Radiator fan switches for my Cavalier Diplomat
  138. 52 plate Vectra C towba electrics?
  139. How To Get Ford Wheels On A Cavalier?
  140. Help with suspension "knock" front noise?: NOVA 1.2S
  141. zafira wiper motor etc to astra g coupe?
  142. MOT - "Rear (across) brake pipe excessively corroded [3.6.B.2c]"
  143. vec v6 aux belt how to swap?
  144. Lost car keys - Any help appreciated!!!....
  145. vehicle weights??
  146. where to get cav top mount bushes from??
  147. Bad handling & grinding like noise?????my Cally
  148. Decent bench vice (or press).
  149. corsa washer jets
  150. what is it
  151. buying a new clutch Q.
  152. Longevity of Vauxhall disc + pad set
  153. astra mk4 wiper motor
  154. xe starter
  155. narrow band guage
  156. no side lights
  157. Hey chaps, Corsa heater matrix and dash query
  158. Alarmed?
  159. whats this?
  160. removing arch trims
  161. were is air con pump on a v6 veccy?
  162. roll bar to wisbone bolt removing
  163. Cavalier Turbo discs onto Vectra B????
  164. astra g lowering
  165. How To Remove Mondeo Dashboard? (not Vaux I Know Sorry)
  166. Nova fuel tank
  167. a OOOO noise
  168. Part check
  169. vectra C20XE Wireing?
  170. Leccy Windows
  171. Ignition module question
  172. Vauxhall CanBus info needed.......
  173. Calibra XE and LET steering rack the same?
  174. CO Potentiometer Values on AFM
  175. Hydraulic Handbrake!
  176. Help!! Where is the Traction Control/ABS ECU in a coupe??
  177. will calibra calipers and discs fir on my 1.4 mk3 astra?
  178. Cav Gsi 60mm rear springs
  179. C20XE Corsa - Solving Idling Problem
  180. Corsa 2.0 conversion help needed about lowering tie bars etc
  181. 2 codes wont clear!
  182. c16se wiring loom
  183. MAF sensor faulty
  184. Fitting Headlight Wipers/Washers
  185. Astra MK3 - Air con compressor rattles - fixable?
  186. cav electrical looms - which one? aircon with a turbo?
  187. Nova suspension
  188. need a 120amp alternator for 2.6 omega
  189. Camber? Daft question
  190. URGENT - mk4 astra estate rear pads problem
  191. Changing front vauxhall corsa fog light bulbs?
  192. Brake query
  193. ECU remap - flat spot problems
  194. cracked my coil overs
  195. lowering a G
  196. Corsa B rear springs (any difference between 1.0, Sport, GSi etc..)
  197. Polybushes and squeaky sound
  198. ESP ECU.................
  199. Cavalier/Calibra V6 Traction control into another car
  200. Electrical Gremlins! Zafira e/w + c/l
  201. Drive shaft washers
  202. Which Temp Sensors are controlled by the ECU?
  203. Mk3 Astra Digi Dash
  204. Calculating Degrees of Camber?
  205. dust bin lids for brake discs
  206. 1996 calibra v6 aircon question?
  207. digi dash fuel gauge prob - mk3 astra
  208. Question about reassembing std shock absorbers on corsa b
  209. 2.0 8v ecu
  210. Strut Brace fitting
  211. c25xe corsa b
  212. suspension tops
  213. Wiring Help - heated seats..
  214. 1.9CDTi Astravan - Decat ???
  215. 1.6to1.8 vectra conversion?
  216. another spal fan question... easy one maybe?
  217. V6 Speedo help!
  218. corsa gsi rear abs sensors fit 1.6 tigra?
  219. corsa B electric window problem, HELP!
  220. Calibra Anti-roll bar link???
  221. random loose wires in engine bay.
  222. cav gear selector
  223. braided brake hoses specs
  224. C20LET: How is it controlling boost pressure?
  225. Wiper problem, 95 astra
  226. astra hub question
  227. what brake calipers for 5 stud setup(astra)
  228. Corsa b TID date display
  229. Anybody help me?? 5 stud conver on mk3 van
  230. 7 - pin plug coming off later c20 xe loom
  231. just done a flash test on cav 2l 1v 1995, please read
  232. power steering
  233. Astra Gsi Mk3 Mfd
  234. cavalier and astra front struts
  235. toyota corolla brakes
  236. Cavalier Turbo rear brake upgrade
  237. where to buy SPAL fan fitting kits? (rollcage padding also)
  238. Headlights on, cigarette lighter doesnt work?
  239. Current C20xe problem
  240. Calibra V6 brake setup on corsa.
  241. pic request corsa rear beam with discs
  242. Corsa C rear Discs, possible fit on CorsaB/Nova?
  243. knocking going & slowing (mk3 astra help)
  244. help please crank sensor c20xe
  245. Corsa gsi xe help!!!
  246. things to know about astras
  247. *URGENT HELP* whats this part called? Cavalier related
  248. Weird - the ignition comes on when i press the brake pedal..
  249. more errors coming up!!
  250. Cav v6 heating prob
