  1. No Spark :(
  2. exhaust/back box
  3. Flat Battery
  4. Brake question 4 astra gsi
  5. Brake upgrade on Agila?
  6. Help! - Cali Rear Subframe Swap
  7. corsa 'b' rear shock dimesions wanted please.
  8. Astra GSI Turbo Mark 4 intercooler fitting help...
  9. list what i need for v6 brake set up please!!
  10. Haywire LCD display
  11. Mk2 Astra Oil Pressure Sender Thread
  12. any difference ? cav gsi ecu or calibra ecu for xe
  13. Anti-roll bar
  14. calibra back box help
  15. cavalier redtop (gsi)
  16. vectra sri 130 dti battery light
  17. vectra sri 130 dti central locking fault
  18. vectra sri 130 dti fault with front windows
  19. calibra brake troubles - Rusted backplate !!!
  20. 4 pot rev counter to work on a v6
  21. How much lower will nova be with a 1.5td engine in it?
  22. Vectra B front Spring
  23. Fault codes
  24. coilovers
  25. Brakes Upgrade on a Tigra
  26. help-abs and trac.control light go on and off
  27. quick corsa door question
  28. can bosch 803 injectors be run with phase 3.5
  29. Help with wiring
  30. Handbrake - keeps failing MOT
  31. Track Rod Ends
  32. Astra mk3 electrical problem
  33. changing PCD
  34. *How do you use a tap & die set?*
  35. new battery for c20let
  36. CV boots leaking
  37. V-Max Chips
  38. VIN plate
  39. Suspension Bushes
  40. Vauxhall radiator fan switch for Daewoo Nexia X20XEV
  41. Swapping Omega plip info needed
  42. Mk3 Astra external temp sensor
  43. astra loom info
  44. cav redtop gsi
  45. car pulling to the left
  46. 1st and 2nd Stage on Radiator Fan
  47. Proper Procedure for Tightening Handbrake
  48. Winter Prep
  49. A/B Emissions plug, longest Q ever...?
  50. MK4 Astra Check Control Messages
  51. digi dash in corsa
  52. alternator or charging problem
  53. Astra MK4 Sport Query
  54. c20xe dizzy type not sparking
  55. CV boot clips, how to tighten them?
  56. Spring Difference.
  57. another ebay fairy tale?
  58. corsa redtop
  59. suspension kits, coilovers or not??
  60. Astra CDTI Aircon
  61. replaced discs....q's?
  62. corsa gsi fuel tank
  63. how easy is it to switch suspension (title edited)
  64. 2004 vectra pad warning light, how to turn off?
  65. Corsa B switch gear
  66. fuel pipe bust
  67. easiest way to open a corsa gsi bonnet without damaging anything?
  68. Steering Astra F
  69. Corsa Info needed asap
  70. quick question on suspension please.
  71. Signum Wiring to connect towbar
  72. Help cant bleed brakes!!
  73. coil for 1.3 on twin 40's
  74. 4 stud turbo brakes
  75. Megasquirt stand alone ecu?
  76. warped discs
  77. c20let conversion help?
  78. clocks stopped working
  79. starter location 1.5td quick replys please
  80. What does this mean "oil lack"?
  81. calibra lights motor not working?? help needed
  82. Clutch question
  83. 310mm 4pots under speedlines
  84. Dead Tigra
  85. Astra k reg CD loom into k reg LSi
  86. Anyone got a pic of rear beam bushes?
  87. steering rack bias?
  88. Earth leads ????
  89. two questions
  90. where the best place to buy good blue leds for vectra dasha and mid
  91. elecy speedo signal
  92. Headlight loom removal
  93. Where are the fuel sender wires on a 95 cav 2l?
  94. Engine management light Nova
  95. Radio not working
  96. shock top help please!!
  97. engine management light
  98. corsa c clock removal
  99. chips?
  100. cav turbo running like poo,help.
  101. Whats the size of calibra turbo rear disc (1996 n-reg)
  102. clocks stopped working
  103. body control module z18xe
  104. c20 xe conversion
  105. electric sunroof wiring help????
  106. help Photo needed
  107. immobiliser on a corsa c ?
  108. X14XE Vs C16XE differences
  109. would this work and any good.
  110. what wire is missing
  111. c20xe in 1.5td corsa
  112. calibra elec sunroof help
  113. Why are y brakes so crap and cant get a pedal.
  114. Cally Turbo Clocks into Mk3 GSI
  115. fitting climate control/consumtion digital displays??
  116. Inlet Heater matrix hose
  117. wiring help please!!
  118. fault codes for z18 xe
  119. dash bulbs on or off ????
  120. Front speaker size
  121. rev counter probs
  122. phase 3.5 only 1.2 bar in second gear
  123. wiring diagram
  124. digi dash into cav mk3
  125. Drawing current from battery in boot?
  126. corsa c timing
  127. Crank shaft sensor pic
  128. Bleed nipple and vauxhall main dealer
  129. '51 Reg Astra SXI - PAS Rack
  130. Rover Metro 1.1S Problems! Please help !!
  131. Girling master cylinder fittings
  132. Hydraulic handbrakes and mot's?
  133. Tightening a cavalier Handbrake Cable.
  134. digi dash speed senseing?
  135. What brake servo or master cylinder will fit a mk2 astra?
  136. alternator issues
  137. egr valve wanted corsa gsi ecotec
  138. ABS problem
  139. 16xe fuel pump relay clicking while cranking
  140. Vectra B Hid Lights as standard
  141. Xenon conversion kit
  142. ECU Code 25???
  143. 2.0 caliper brackets to allow 284mm discs
  144. Help Needed 2 seperate Problems
  145. sunroof problem
  146. No Brakes
  147. 2.2 sri astra
  148. where can i buy disks?? wilwood calipers, corsa redtop
  149. how do i check my alternator amp output using my voltmeter
  150. Check Oil Level Warning On Astra Coupe
  151. no EML light?
  152. nova strenghtening plates
  153. how do i wire the sunroof up to the fuse box?
  154. bypassing my immobiliser
  155. izuzu engine cavalier
  156. Where can i get???????
  157. Tidying up the loom
  158. epas how does it fit the corsa
  159. Removing ignition barrel, Help
  160. strange fuel reading yesterday
  161. C20XE starter and alternator wiring
  162. Air mass C20let
  163. vectra comp calibration cant find ianv6
  164. cav mk2 to xe wireing help
  165. Mk4 Astra ABS /TC warning lights.
  166. what gauge is normal car speaker wire?
  167. Anyone got the measurements of front wheel bearings?
  168. nova conversion questions...
  169. GTE lower strutbrace
  170. anyone changed there steering wheel to non vaux one?
  171. ecu light
  172. Frontera Jack and Brace Location???
  173. Corsa B big creaking noise when turning right
  174. Paint job needed!!!
  175. steering wheel horn wires... help!!!
  176. help with vectra air bag
  177. airbag steering wheel in non airbag car?
  178. diesel speed signal?
  179. vauxhall sunroof looms to switch
  180. ABS Fault Code
  181. Rounded off nut into master cylinder!!
  182. corsa gsi -60mm drop?
  183. Tigra rear springs
  184. trip computer on dti not accurate
  185. nova rear axle
  186. vectra remote central locking
  187. Stainless Exhaust systems
  188. **Help astra mk4 gsi z20let**
  189. mk3 astra c20let strut brace
  190. Where To Start Modding ?
  191. x12xe to c20xe wiring help
  192. how much for a loom for the leccy sunroof from Vaux ?
  193. astra problem
  194. LET Corsa.. Rear discs or not?
  195. Snapped handbrake cable on Astra
  196. corsa gaz coilover problems
  197. a good auto electrical place i found
  198. fitted variable wiper stalk to vectra but relay has six pins
  199. anyone good with switches....
  200. Rear brake conversion help!
  201. vectra pretensioner/harness system question
  202. Brake Pads
  203. tv/ps2 in dash, custom. need help.
  204. Wobble at full throttle?
  205. gauge wiring help
  206. 5stud conversion
  207. Dash2 Display Unit in Corsa??
  208. Eps in Corsa Let Help please!
  209. corsa speedo?
  210. fitting the trip computer + switch
  211. brake servo removal -- how?? -- mk3 astra
  212. fuel pump relay location
  213. Nova brake cylinder popping its seals
  214. how easy to change springs?
  215. power steering rack with no fluid in it, will it work?
  216. Mk3 Astra Heater blower
  217. electric windows on a cav
  218. Nova/Corsa steering racks
  219. Multi function display problem
  220. Fitting a GTE digi Dash into a Corsa B? help?
  221. XE nova stronger bottom arms.
  222. Brake servos upgrades
  223. F28 Blue Ring
  224. v6 vectra 4 pot upgrade
  225. wiring for steering wheel controls astra mk4
  226. deadlock
  227. Fuel hose clips on Mk2 Astra?
  228. No Key For Lock Wheel Nuts
  229. Wiring Vectra GSi seats in.
  230. mk4 astra aircon
  231. 97 omega elite 3.0 v6 leak problem
  232. cavalier window mechanism
  233. Dump Valve fited wrong...what happens???
  234. 1.0 corsa c20xe conversion wiring help
  235. Vectra B central locking
  236. engine managment codes
  237. Questions for those with Astra V6's
  238. MK3 Astra EPAS Setup (pics) need fluid resevoir!
  239. battery light on
  240. Where does this wire go?
  241. 4 Pots. Where and who from?
  242. diy coilovers for cavs and astra from rally design
  243. Help needed terrible understeer
  244. wiring an XE into an Ecotec astra GSI
  245. ABS and Brake Disk Warning
  246. V6 brakes need replacing. Best place to buy from?
  247. ASTRA GTE Transducer Needed for C20XE Conversion
  248. CODE 113 Boost control out of range HELP
  249. Which Vauxhall
  250. What does this handle do?
