  1. 308mm brakes from Vectra C to Calibra
  2. Apexi AVC-R Fitting Help
  3. vectra transponder wiring help needed
  4. injectors
  5. urgent help corsa electric speedo transducer wires
  6. where to find panels for a nova
  7. Any common problems with Isuzu alternators?
  8. ECU should it be earthed??
  9. Quick Rack
  10. My alternators alive (and now its dead)
  11. removing side indicator => rapid blinking
  12. wiring electric m3 morrors to calibra
  13. Car skips of the mark
  14. cavalier gsi
  15. fuel filling problems
  16. Powerflex rear bushes
  17. vague sterring
  18. Power steering fluid burning on my manifold
  19. calibra sensors help
  20. Corsa C Trip Odometer gone Blank...
  21. Brake lights not working right HELP PLEASE!
  22. what fuel pumps are bein used for nova turbos
  23. Coilovers...
  24. central locking problem. any ideas?
  25. Vectra B 1996
  26. V6 Calibra, No Voltage to ignition amplifier
  27. vectra v6 into astra gsi
  28. Thanks to all :)
  29. MK4 Astra Trip Computer & radio display
  30. cav gsi front bumper help
  31. cav gsi front bumper help
  32. Still leaking oil please look............
  33. Bosch 044 where from
  34. nova rear beam bushes??
  35. Central Locking Neg or Pos?
  36. What else to check before i replace the alternator?
  37. cav td idle question
  38. Alternator nightmare
  39. nova 1.2i ecu light on code 34?????
  40. Vectra central locking help please
  41. Vectra Fuel Light Flashing
  42. Help with Mk2 GTE rear strut brace
  43. astra gsi phase 1 phase 2 brakes the same?
  44. Nova tank sender unit
  45. Aircon light flashing
  46. Help Needed Asap
  47. Dodgy behaving lights. (not a vaux but a rover)
  48. Help Needed Asap !!!!
  49. HELP! - Seatbelt pre-tensioners
  50. Corsa C Power steering
  51. CORSA C... remove "F" light
  52. Full exhaust system for Astra 2.0 Turbo coupe
  53. top mounts(getting them off)
  54. what pads fit hiese brembo calipers? pics inc
  55. Fast & Furious Volt Guage
  56. Rev Problems!!
  57. airbags or coilovers kit
  58. 20SEH wont start!
  59. C20XE crank sensor issues
  60. Carlton 5 stud wheel bolt pcd???
  61. Brake help!
  62. Whats this!?
  63. Astra Mk4 - Rear Demister, Recycle & Air con buttons don't work
  64. MFD into astra
  65. nova roll bar/tie bar question with pics
  66. Anyone with a X20XEV Vectra Help please Loose Plug
  67. Pure copper brake pipe/Union sizes
  68. how do they repair buckled wheels
  69. what handbrake cable on 5 stud astra mk3
  70. caliper guide bolt snapped!!
  71. Rounded off brake union nuts
  72. astra 308mm brakes
  73. digi dash help!
  74. Mk3 1.6 8v brake size question
  75. NOT VAUX :( Escort Van Steering lock
  76. C/L problem speedo and alarm ???????
  77. Vectra 2.2
  78. A quick one for an MOT tester
  79. Help needed with part/serial number or identification mark on 288 caliper carriers
  80. Vectra dash mileage
  81. Callt T losing coolant
  82. dizzy cap
  83. ECU Code help
  84. AEM Uego Wideband
  85. engine code?
  86. strut brace
  87. ECU Identification
  88. c20xe conversion
  89. Power Steering
  90. Fuel Relay Buzzing
  91. clutch to flywheel tourqe settings?
  92. c20xe corsa fuel pump relay wire
  93. astra mk3 power steering
  94. rear brake adjusters not working
  95. 288mm brake problem??
  96. stage 3 chip problems
  97. Heater matrix
  98. can you tell what this is?
  99. wiring for engine management light
  100. Vectra brakes
  101. Charging a battery?
  102. does anyone have...
  103. Alternator or Battery? Not charging
  104. clutch cable fitting
  105. Tigra 1.4 Strut Braces
  106. Problem with 1st and 2nd Gears
  107. Lambda Sensor Problem
  108. Corsa B Model Query (PAS)
  109. top mounts
  110. rev counter dials
  111. corsa speedo and tempeture gauges
  112. knackerd tps sensor stop car from drivin smooth?
  113. how hard to fit in tank pump in astra gsi?
  114. how do u set the fueling up on c20let.
  115. Astra central locking
  116. Reversing lights....help!!
  117. heated side mirrors
  118. Cavalier - central locking!
  119. Retro fit electric rad fan. Non vaux.
  120. Fuel Gauge not working.Newbie help needed mk3 astra
  121. Flmare kit..
  122. astra sunnroof - total closure. advice...
  123. 1998 1.2 corsa heater fan bulbs
  124. Re-drilling Brake Discs
  125. N reg Escort electric problem
  126. suspension question Can i lower my calibra 60mm?
  127. suspension again!
  128. Oil Pressure Gauge
  129. electric windows
  130. where should temp gauge sit wen driving c20let?
  131. central locking
  132. MK3 Astra: Misting up
  133. main engine earth lead location
  134. C20LET 2000rpm idling???????
  135. aftermarket steering wheel
  136. Speed Signal From Electronic Clocks?
  137. Wot size Brakes!!
  138. Key Fob
  139. Any Dashboard warning light Gen
  140. electric sunroof on a mk4 - what do i need.
  141. Brake upgrade on Tigra 1.4?!
  142. Faulty Seat-Belt....
  143. xe cts wiring?
  144. how to: ridicously clean block
  145. Tigra Mk1 - 1.4...What lowering kit?!
  146. brake fitment question
  147. Drive shaft pops on full lock?
  148. what suspension
  149. any one heard of a company called auto dials?
  150. brake lines
  151. ETC fuse??
  152. SAFE MODE?
  153. where are the heated seat looms in the vectra
  154. Does any1 know.........which fuse it is for the cigarette lighter?
  155. corsa gsi dash/heaters
  156. Wiring help for 1.0 12v to c20xe
  157. astra gsi 5 stud question
  158. vectra climate control
  159. what fuel pump to use.
  160. leccy windows for my astra mk4
  161. Uneven Rear Tyre Wear
  162. rattle
  163. testing glow plugs on a vectra dti,how long to warm up
  164. Drilling v6 discs?
  165. mark 2 astra 1.4 wiring + DIGI dash?????????
  166. quick racks for corsa Bs any ideas welcome
  167. master cylinder
  168. oil temp sender
  169. Astra LCD temp gauge reading
  170. ANOTHER bolt thats rounded
  171. vectra dti power window fault
  172. Spigot rings for V6 conversion..
  173. MK3 Astra Suspension!
  174. speedo wont work!
  175. Vectra C Door locks
  176. calibra v6 - any other calipers fit?
  177. handbrake cable
  178. Quick Aircon question
  179. Digi dash transducer wiring
  180. Lowering spring issues
  181. help with the wiring on a nova gte
  182. Nova struts springs shocks etc,will they fit a corsa?
  183. bigger brakes for let astra mk3
  184. Koni rear adjustables
  185. typical rusting points on corsa?
  186. front and rear brake pads
  187. how to get temp gauge to work in new let conversion
  188. drilled and grooved discs
  189. Setting camber with FK coilovers..
  190. C20xe Corsa B Abs Problem
  191. corsa gsi interior
  192. Calibra Suspension
  193. Zafira GSI Turbo
  194. random bit of loom
  195. nova wiring - what colour wires are what?
  196. Anyone here scrap cars in the Chesterfield area?
  197. any good wiring people out there? clocks and leci windows stopped working!
  198. Fitting PAS to Corsa B
  199. Rear brakes (astra g)
  200. gaz coilovers
  201. nova sr gauges
  202. corsa c20let strut brace
  203. springs, will these fit?
  204. whats this part called(brake thing)
  205. Cavalier MID
  206. v6 calibra - brakes still poor after rebuild? help
  207. headlights stuck on full beam....
  208. is my voltage low??????
  209. Corsa springs on an Astra
  210. Late calibra turbo hub questions
  211. C20LET into '97 Astra Sport
  212. Differnce between brakes
  213. problems, trying to fit steering wheel
  214. correct rocker cover gasket?
  215. Astra MK2 Boonet Release
  216. ECU...... How do i know if its chipped or not?
  217. mk2 astra springs on a mk3
  218. URGENT Need Help
  219. Coolant Level Sensor
  220. DIY fitting tyres
  221. Nova brake line unions
  222. C20XE Into Corsa Wiring / Immobiliser Help (With Pics)
  223. decatting
  224. Changing Corsa C Fuel Filter ?
  225. tigra ghost
  226. jamex springs
  227. coilovers for cav T. found!
  228. cally fault code 19
  229. 5.5" x 14's compomotives
  230. astra mk3 distributor
  231. Corsa XE Digital Rev counter
  232. Battery Drain?
  233. vectra b dti fault code p1125 boost pres deviation and p1502
  234. xe loom
  235. petrol pipe
  236. Engine loom for big BHP
  237. back box help
  238. Weird Fault - Vectra Steering Wheel Controls
  239. MK2 Astra GTE Front suspension
  240. How does Cav/Cali 4x4 work?
  241. power steering rack, where from?
  242. Cav electrics
  243. Corsa steering
  244. Anyone with EPC ? couple of part numbers needed, Cheers
  245. reversing light switch location
  246. what calipers are these?
  247. spark plug location???
  248. Wheres wally? (CTS)
  249. will mk3 cav springs fit my mk2
  250. 1994 Astra starter problem
