- Good auto electrician in sheffield?
- question on calibra clocks
- Changing a rack on a corsa
- vivaro outside temp
- calibra / cavalier speedo clocks loom help?
- vauxhall corsa b eps help
- Where to get loom size wire from ??
- Corsa B Redtop Strut Brace
- wiring
- which discs for 4 stud turbo calipers?
- mk2 golf wheel bearing, astra hubs on a corsa???
- Turbos and manifolds made in China?!
- ecotec to xe but no rev counter
- broken cali but how to remove loom?
- suspension bushes
- mk3 astra 1.4 brake servo with willwood 4pots
- 2.2 Frontera Electrical Issues No Headlights
- does your eml light come on if speedo is not connected?
- cav dash removal pics / how to plz
- astra mk4 dash
- what can cause the txb to turn off?
- corsa b elctric windows
- cav gsi 2000 head light problem
- Very weird noise please help
- Car cut out when over taking
- Astra / Cav Suspension Question ??
- Rumbling noise from running gear
- Wiring in my digi dash into calibra
- Why has my passenger side central locking died?
- any1 have an oil and vault gauge from a cally to hand?
- c20let nova power steering
- dodgy hot start up....
- rear pads moving about
- Brembo Calipers 308mm .... 16"
- colour code please
- Vibration
- can any1 colour code/ identify these wires?
- what master cylinder?
- Corsa front suspension knocking
- The best 'budget' track day tyre
- digi dash top speed reading?
- nova rear brakes
- coilovers/topmounts
- Movano steering wheel controls
- Cruise Control Clutch Switch Part Number
- What boost gauge?
- how do i put the light out help
- Dry cell battery
- Exhaust rubber hangers
- Buy bosch hall sensors from here
- Electrical experts (Dom and others)
- Just put a white dial cally dash back in the cav, few probs
- Indicator relay buzzing
- Vectra Ecu + Immob Prob
- Secondary Air pump fuse
- oil and volt wires, which 1s, where?
- help with wiring again plz
- Wiring pRomplem with lights
- quick question on abs sensors.
- Cav Front headlight
- Corsa date/clock lcd thingy in calibra?
- Cav Front end pannel fitting
- How to change front wheel bearings? Please help!
- Cav Gsi and Turbo suspension
- vectra 5stud hub v's cav T hub
- GSI Trip comp
- Clifford Eagle (first one) wiring diagram wanted
- Mfd Trip computer into A Mk3 astra
- trip computer into a MK3 Astra
- Oh ****.. laughter down phone from garage - how much is it gonna hurt? (Suspension)
- ASTRA MK4 How do i change the side light ?
- Disc brake direction (Help)
- Alarm wiring diagram
- Nova saloon
- 51 plate corsa c PAS problem
- does any one know where i can get
- water up on 20xe dizzy 1990 model
- can someone please check me a part on epc.
- ford fiesta 1994 L - heaters/blowers inop
- Calibra headlamp adjuster failed?
- Best wire to use on guages???
- Astra g heater control bulbs
- LET wiring loom??
- boot lid for vectra sri 2.0 (w reg)
- need some quick confirmation please
- speedo reading
- mk3 cav outside temp LCD not working/reading ?
- atrsa mk3 hubs
- Anyone kno what the hall sensor in dissy looks like?
- Vectra Panels
- Vectra SRI Springs...
- 98 vectra battery fault?
- Nova turreting & geometry advice
- Help Needed on x14xe Wiring
- mk3 gsi turbo brakes?
- cav brakes
- what headlight bulbs does my vectra take
- Corsa B Sri(20xe Conversion) No Power Steering!
- Frame Strenthening
- any1 interester in c20xe powercap?
- 1.6 16v corsa engine in a nova need help with wiring
- Radiator fan
- any pics of a cav, cally with blue dash bulbs
- fuel pump replacement on a 1.6 16v Tigra
- Heating
- stereo unlock codes
- Astra g / Mk4 traction control
- Door pin
- astra coupe 2.2 - Traction Control Question
- power steering fitment?
- Nova dash conversion?!
- Corsa VXR brakes
- FAO All C20LET, C20XE Nova Owners
- Nova Digital dash conversion
- Quick hellp needed - stuck driveshaft!
- Air con relay location, dash issues, etc
- m.o.t fail
- Nova ARB question.
- vectra rear discs
- abs / speedo fault
- Cavalier TD Starting Problems.
- Suspension kit for astra van
- brake light adjustment
- astra mk4 1.8 cruise control???
- trailer light electrics on Wreg vectra
- Temperature guage not working on an 03 Astra?
- Cutting away at the circle inside the front arch!!!
- Battery light on faintly
- Astra digi dash problems
- wireing my xe help!!
- Is it possible to install a power assisted steering on Nova?!
- Corsa Gsi/Sri steering wheel question
- Has any1 got the link to the digi dash that guy made with check control lights?
- Mk3 phase 2 astra front legs n top mounts
- Suspension question
- How long should a completely flat battery take to charge?
- Corsa D Mirrors - "universal"?
- Can you name parts needed for handbrake shoes astra gsi
- Vectra ABS/TC module into Nexia
- Gaz shocks + Springs. Anyone rolling with this setup?
- neg camber on a corsa...
- What gearbox oil???
- do digi dash fuel readouts pack up much?
- Calibra/cav 4x4 manifold & downpipe
- Astra MK4 MFD/TID (LCD display) - help - km/miles display
- cars got a cold
- Astra GTE 8V Idle Fault Code
- Quick brakes Q's - Vectra Mk2 V6 calipers fit tigra/corsa ?
- Coilovers for Nova?!
- car alarms
- Corsa Sport Door Loom Wires
- MK3 Astra GSi XE - engine loom questions
- Spark and fuel but dont run
- Vauxhall Senator traction control fitting?
- no power to fuel pump
- bonnet release cable
- 288mm brakes
- Sus Suspension?
- Boost Gauge
- Quick rack
- mk3 astra track control arms
- car starts then dies
- hids in mk3 astra gsi
- changed abs sensor still no speedo
- Central locking wiring, what wire goes neg when locked (diagram)...
- where to get rpm signal from????
- Braking Problem
- h&r coil overs rebuild ???
- corsa b dials
- corsa rear coil overs?
- Corsa C Brake Upgrade
- Avo or GAZ coilovers for trackday nova?
- corsa turbo suspension
- Oil pump relief washer size
- Tools
- electrics gone crazy!!!! help
- strange battery/alternator issues.
- Not a vauxhall but hey
- Digital dash in a c20xe calibra?
- How hard to replace radiator corsa b
- mintex
- cavalier PAS pipes where from ?
- nova lowering
- Spotting a genuine SARD regulator on ebay
- Lowering Mk 4 Astra
- GE ECU what is it?
- astra trip computer
- Anyone local to Heathrow who can solder a chip into an ECU for me????
- Management light
- diesel to 5 stud
- corsa braided brake lines help needed
- How to measure voltage on fuel pump!!
- Battery problem
- I got no Spark
- Best place to get ready made rear turrets..
- Vectra B GSI electric recaro seats
- de-cat option?
- vectra brakes
- Corsa 1.5 Diesel Glow Plugs - No live feed
- Are these the same as yoyo chips
- Will astra VXR brakes and hubs fit on an astra G???
- Astra digidash temperature reading
- Removing bonded sideskirts
- What fuel filter should i use???
- Where is fuel pump on astra gsi turbo mk3
- PAS noisy??????
- Fuel Filter Location On Astra G
- Abs intermittant fault and no brakes....
- help with wiring in vectra tow bar!!
- Nova Rear ARB bushes
- noisy alternator
- Who to redrill 5 stud discs to 4 stud? (scotland)
- fuel pump needed
- reading fault codes on mk3 gsi turbo?
- How accurate are oil temp senders in the sump
- ECU light flashing
- Frontera Aldl Connector Location
- frontera A front brake pad question help
- Air bag light is on???
- Corsa ecu questions
- Best Brake Setup
- Corsa coilovers
- Serious Problem Please Help
- cruise control
- whats the part number for vectra 2.0 dti turbo
- Strut top mounts
- Corsa Electric Window Loom
- c20let ecu permanent live?
- Citroen X/Picasso Brakes Question
- Steering wheel
- Help no brakes!!
- astra mk3 coilovers!
- Fitting Single V Altenator to a Late LET
- Lowering with adjustable suspension...
- corsa sxi brakes Q?
- Urgent: Mk3 Astra Subframe bolt sizes
- calibra 2.0 8v brakes?
- mk2 astra estate lowering
- GTE digidash oil pressure gauge
- RPM and "speed" signal on Z20LET
- Didgi Dash Speedo!!!
- mk2 nova parts wanted!!
- Omega Variable Wiper Intermittent Query
- Astra Mk3 and Mk4 hubs/brakes 308
- Moving Brake Lines Inside the Car
- Engine warning light.... disappeared
- Is a battery box needed for a RedtTop 'racing' battery ?
- coilover adjusters?????
- no spark c20xe
- LET fan, suck or blow?
