- rust protection etc..
- Epas column whats needed.
- redtop in to nova cannot get starter going
- Brake hoses
- Vauxhall Vectra LS DTI 2.0 03 reg
- Thinking of getting tracking done but???
- all over the place when accelerating/decelerating issues
- fuel problem!!
- Tachometer Programming
- ABS light??
- Steering concern
- Corsa
- longer wheel nutz
- C20 XE fault code?????
- Astra G 2ltr Sri Bigger front brakes
- vivaro oil check
- 5 stud conversion
- steering rack corsa b
- Wheel Bearing Nightmare
- funny noise like a grinding sound
- Any decent tools for removing door pins?
- '96 GM diesel DDS immobiliser
- Battery For Corsa 20xe
- Battery drain when indicator sticks on
- c20xe diagnostic plug wiring?
- PJ and PK ECU
- vecyra gsi central locking problems HELP WANTED
- "cheap" xenon kits.....
- Aeroquip fittings, tightning!!!
- Air recirculation for heater/air con on a vectra
- corsa gsi questions
- brake bias valve
- Power steering pumps
- rear disc conversion on tigra
- New themostat for c20let
- Help wanted troubleshooting an Astra 1.7 TDS Isuzu charging problem
- Mk3 Cav heated mirrors not heating, any ideas??
- MK3 Astra GSi dimensions
- crankshaft sensor?
- crank position sensor on redtop
- Vectra C wipers...
- Astra G 5 Stud Conversion!
- Will Astra VXR Brakes fit with 17's
- fitting electic windows in an astra g
- vectra 2.0 dti 1-1.5 bar boost but no power
- Calibra suspension choices for daily use+n*rburgring
- Wash/Wipe Corsa B
- Wideband Lambda on standard managment?
- coilovers on ebay from belgium
- wipers
- nova xe
- corsa b equal length shafts?
- Mixture Adjustment Resistor Voltage Low
- Oil Temp Gauges
- Calibra c20xe braided brake hoses?
- Uprated alternator shops?
- Removal of c20let manifold advice needed???
- Nova 20xe diagnostic plug
- fuel gauge not working
- Mk3 Astra Suspension on MK2
- Corsa B angel eyes; help needed!
- blue or beige injecters c20xe
- help!! vectra immobiliser
- people with hids plzz help
- headlight bulb holders astra g
- Temperature Gauge Needle query
- putting a battery in a boot
- speedo cable
- Anyone know what wire is the ignition live on the redtop loom?
- Vectra Deadlocks
- master cylinder
- help bumpstops
- wtf!
- Speedo Not Working
- Braided brake pipes
- Soundproofing
- Which of these springs will be best?
- Nova shell structure
- 2inch 2.5inch Intercooler Silicone Hose Reducer c20let
- remus cs engine management lighht on!
- Brake callipers on wrong way?????
- No More Auto On Electric Windows !?!?
- Astra GSi mk3 water leaks!!!!!!!!
- corsa dash screen
- buckled wheel
- lower strut brace
- Water leak in my Vectra boot
- corsa c dials into a corsa b
- corsa redtop with cally turbo brakes
- vauxhall fuel pump relay partnumber ???
- whers best for a fuelpump relay
- morrettes mk3 astra
- c16se Wiring Diagram
- tubular manifold?
- Quick Question air/fuel mixture gauge how to FIT !!
- Spax RSX Setup
- Water Jets not working
- fitting remote central locking on a nova sr?
- 60mm drop on mk4 astra
- xe wiring help!!
- Battery/Alternator question
- corsa C dials into a corsa B
- which tyres??
- Problem wiring up nova back lights
- Starter motor relay
- 22 spline cv joint part number??
- Fuel pressure for dis xe? and which aftermarket reg?
- ecu types
- mk3 astra heater only working on speeds 3 and 4
- astra mk 5 dimming mirror into cav
- electric mirrors mk3 cav gsi
- swapping vectra central locking over from one car
- 5" rev gauge
- vectra brake dics
- Brake Flexy pipe size ??
- corsa coilovers
- tyre damage.
- confused about mk4 astra suspension!
- power steering
- Removing the washer bottle on a Mk4 Astra???
- Vectra none start?
- 288mm disks
- Calibra Redtop Heating Issues
- immobiliser problems
- eliminating spongy brakes. These any good?
- clutch cable, adjustable??
- Using xe manifold nuts instead of let ones
- Disable Passenger Airbag
- nova sr
- Corsa B 1.4 Sport Difficult to restart After A Stall?
- EGR valve on a corsa?
- knackered lamda sensor symptoms c20let
- Can i use any nuts on exhaust studs
- Is it hard to wire in a start button?
- lowering wit 18 inch alloys
- mounted speedo, tacho etc..pics anyone?
- Can you upgrade the master cylinder
- z20let/lel/leh wiring diagram
- corsa bushes
- does xe and let use the same exhaust?
- mk2/3 cavalier springs
- Any benifit fitting exhaust heat wrap
- 5 Stud Re-Drilling
- suspension kit MK2 Astra
- need help with alloys/brakes
- refitting mk4 astra door
- master cylinder, which lines go where?
- hit curb in tigra help
- Looking for dash ideas
- Can someone give a How To: fitting internal brake/fuel pipes please?!
- calibra v6 rear hubs on astra??
- Exhaust blow please help!!!
- astra conversion
- corsa xe strut braces
- Head gasket thickness
- Internal water temp guage thingy
- Vauxhall Astra MK3 N reg LOOSING BRAKE FLUID AND SPONGY BRAKE
- Retrofitting PAS to a Corsa V6.
- C16XE engine into nova SR wiring help
- Nova central locking can it work without the control box?
- Astra mk2 digi dash
- What bit do i need to buy
- Oil pressure ratings
- Caliper prices
- Gauges, boost, oil temp etc
- Arp rod bolt fitment, c16xe, need settings/instructions
- xe dispac loom wires help?
- starter motor
- V6 rev counter
- shaky steering
- High ideling
- lowered cavalier
- full wiring guide for c20xe into corsa b
- power steering cooler > is it needed!
- Electric window help needed.
- Astra mk3 electric windows wiring diagram
- HID Conversion - Astra G - "How to...."
- cavalier gsi
- nova internal pump fuel tank?
- 2002 Corsa brake lights not working when feed to ECU is connected?!
- corsa gsi PAS removal - help!
- FAO C20LET Experts - Loom differances!
- rear screen washer, corsa gsi
- Astra GTE VSS question...
- Intermitent Wipers Park Incorrectly
- Cav Fuel Tank sender
- fitting a oil pressure gauge onto my z20let
- corsa b starter motor
- nova rear discs
- vectra brake upgrade - what fits?
- Corsa C boot like a duck pond, are there any common faults?
- Astra GSi (F) Oil Leak :(
- External Temperature not working..
- c20let pistons
- Where is the xenon low beam relay?
- Cav master cylinder
- digi dash fuel level query?????
- sidelights on all the time!
- F-F-ffff-reezing!
- cav turbo track width
- Corsa b speedo stopped working
- Please help - Cavalier Fan N/W
- wanted scopion exhaust and decat pipe
- c20let alternator
- Quick question on Cav springs etc
- should the dash cruise control light illuminate
- HELP!!!!!
- Wiring behind heater control panel with a/c
- Brakes knocking
- Standard size of springs on a 95 Astra ??
- would fiat coupe turbo brakes fit?
- c20let fan on all the time???
- URGENT HELP Setting wipers on a 306
- corsa diesel 1.7 diesel izusu glowplug relay
- Recommended tyres for Corsa Turbo
- cav td starting problems
- Electrical problem help please?
- Fitting the PicBits Rev Counter Frequency Changer.
- ECU possibly dead?
- Fan Blades!! Pullers!!
- C20LET / XE Radiator Fan on cav / calibra turbo
- Astra MK4 wiring diagram needed
- quick q - fuel pump & relay wiring/volts
- yellowstuff pads - any good?
- Can anyone tell me what size head this is (let engine)
- Immobliser Trouble
- early gte digi dash question???
- fuel flap stuck closed on vec
- Astra GTE 8V Fuel Problem
- c20let nova running problems
- how to read faults on 1998 corsa?
- Battery earth
- Power steering failing! help
- horn not working mk3 astra?
- Indicators and Brake Lights not working.
- vectra diesel takes 4-5 secs to start in morning what operates the glow plug circuit
- Anyone fitted toggle switches in place of OM switches
- Problems with c20let dash
- Nova doors , whats the trick?
- this is for all cav gsi drivers !!
- Stupid!!!!
- Wot chip is best for C20XE
- cav imobaliser prob
- Vectra V6 CDX Anti Roll Bar Front
- Rear Brake conversion
- What is a double wishbone setup?
- sealant with new master cylinder?
- XE WIRING????
- Apparently I've lots to learn about taking alternators apart.
- Good auto electrician in sheffield?
