- Corsa / Nova suspension???
- 06 zafira - trapped water?
- Corsa electric power steering
- Corsa Suspension Qestion
- Brakes Brakes And Starter Motors !
- Quick question - Non vaux. Power steering fluid
- Central Locking
- How to tell what type rack is fitted to my cali?
- wiring up a switch to a pacet fan
- 1.6 16v into a 1.2 16v corsa Wireing HELP
- Corsa B 1.2 16v ECU Location
- Suspension Help Astra GSI
- Where are the bolts holding a Cav front bumper on?
- Fitting lowered suspension on mk3 astra
- Pro Sport Gauges
- chassis rot :(
- corsa b whiteline arb?
- astra 308mm discs = vectra 308mm discs?
- Corsa C front fogs(not working)
- Corsa 20XE & Astra GTE 16v front brakes
- mp3 head unit
- 65 Viva spaceframe
- Which tca's for a 1.5td corsa m'94'
- Not a vauxhall but need help on battery issue
- New panels???
- traction control and exhaust emmision ligts on dash on.
- How screwed am i?
- Cavalier Rear Electric Windows >>> Astra Saloon
- Cavalier >> Astra - Front & Rear Brakes?
- rev counter
- Vauxhall corsa B central locking fault
- key snapped in ignition(106)
- astra gte cabby 2.0 8v engine wiring diagram
- Vectra Gsi Ign. barrel.
- How do I turn off the service light??
- pedal box
- 98 1.0 corsa relays..help..
- Relays?
- Restricted to 3000 revs when hot
- is my fog light red enough?
- spongy brake pedal
- corsa 1.4 16v
- 2ltr 8v or 2ltr 16v brakes???
- lmf 308mm f/brake conversion
- can i ount my intercooler/rad rigid or do they need flex
- Astra F Dashboard - Installing a CHECK CONTROL
- Steering fluid res - can it split from pump?
- astra mk3 rear calipers which way up?
- How to fit a flamer kit :(
- Omega Rev/Speedo Stuck Up ?!?!?!
- Corsa into Nova Parts
- c20let rev counter trouble
- nova hid fitting problems
- picture of inside m3 astra gsi wheel arch required
- Dot 5.1 Brake Fluid
- zafira not getting hot
- Crank Sensor - Where?
- Heater matrix help
- omega v6 calipers on corsa b, what disc's?
- Who is using Fiat brake discs with their V6 calipers?
- X16XE ECU Decoding? Who can do it?
- is it worth having 3" bore from turbo
- speedo not working
- Vectra need some advice
- vectra central locking not working
- Cavvy mk3 frt anti roll bar inner bush fitting
- Fitting AVCR on Z20LET
- Heater blowers not working!!
- 5 stud conversion questions
- Hub fitment
- opinion on high spec 285-300mm kit
- bearing enquirey
- wiring up gauges
- Fitting windscreen in corsa b
- Corsa cv joint gaiter
- Nova tail lights keep on blowing fuse
- Speedo reading incorrect?
- floor in a 4x4 calibra
- Corsa Sri
- bad running when warm
- Help.. mot urgent.. No fog lights, no dash lights
- Battery/starting problem on Cavalier Help!
- Cav heater blower resistor location
- fmic help
- water leaking in my car please help
- 1999 vectra gsi v6 2.5 ignition prob
- Corsa B Clocks
- corsa c 308mm brakes
- corsa b rev counter help
- Gauges lowdown (oil press, temp and voltage)
- brooks gilmore
- Impending project: X14XE into Nova
- Astra mk 4 rear bearing
- How to find the relays for an ASTRA MK3
- How do you replace this water tube c20let
- In-car electric heater - info required please!!
- Reverse light wire MK4 coupe
- Faults 13 and 24 - Help!!!!
- how to secure a battery in the boot for mot
- Cav Diesel Alternator Grief
- ignition,
- converting c16xe loom to run with emerald
- dampers/coilovers
- astra mk4 cd player??
- Standard Tigra shocks/springs on a Nova?
- Motorbike ThrottleBodies tapered 45-37mm ideas?
- Fitting Cruise to Mk3 Astra Diesel?
- some thing draining
- Corsa B 1.4 16v, spped sensor.
- Will Cav TD rear shoes fit my GTE ??
- Central locking going BALLISTIC
- alarm and lights going off constantly
- whats up with my shock ?
- Where to get lightened bottom pulley
- vectra 2.0 dti has slow throttle response
- is it worth fitting just front braided brake hose
- petrol light in cav gsi !
- corsa/saxo power steering setup?
- Redtop Nova running problem under load
- Astra gsi mk3 trip computer
- Vectra 1.8 16v problem
- How To: Join Cables
- Astra Mk4 Power steering
- Corsa B - Lot of condensation issues
- v6 clocks
- fullservices on xev engines!
- phae 3.5 let how big an intercooler can i have
- sard regulator how do i tell if its genuine
- Master Cylinders On Pedal Box
- Corsa MOT Failure!
- rear spring question
- New Vauxhall Nova Lowering Kit
- Cavalier MK3 Digital Dash
- astra mk3 heaters
- Flasher Relay Help! :)
- ignition barrel removal, special tools?
- What's this?
- windscreen repair DIY
- water coming behind drivers seat at back please help
- Phase sensor voltage low problem???
- My st rack is shagged! How hard to DIY replace?/
- Changing Frontera Rear Leaf Springs, any info, advice...
- Astra Mk4 (G) outside temp display not working.
- MK4 astravan drive shafts???
- 20xe power steering
- Kw kit var2 on Corsa B GSi- What spring rate?
- C20XE engine loom earth?
- nova master cylinder
- Nova 1.3 Brake Problem.
- Calibra Front end damage
- which of these tanks goes on xe nova
- Cav ignition barrel problem.....
- 205/40/17 or 205/35/17, is there such thing???
- 95 Vectra, Suspension HELP ASAP :S
- '95 Vectra Faulty Electrics
- HELP PLEASE - corsa rear screen
- MK4 astra interior loom wiring diagram please
- C20XE into a Nova 1.2 SPi Wiring diagram
- nova front hubs
- zafira gsi alarm keeps going off
- wiper arms...
- hard suspension..
- Nova Rear Spring and Anti roll bar help
- Could someone confirm this is a pot flywheel c20let
- corsa let wiring
- Mk 4 astravan drive shafts?
- Nova Fuel sender agony
- nova disc conversion
- will cavalier
- How to change a thrust bearing?
- CAV diesel (Izuzu) alternator removal
- euro style exhausts
- Corsa gsi speedo not working and rev counter flickering
- changing 2001 vectra ECU
- C20XE Management
- Corsa Electronic Power Steering information
- Can a starter motor off a C20xe be used on a 1.8i?
- astra gte clocks into corsa
- ASTRA GSI MK4 any good?
- Corsa C power steering
- Alternator light on 2001 Astra TDI
- wipers
- C20XE gearbox mount spacer
- bubble gum pink astra advice
- Anyone know cause of play/knock in steering
- spax shocks
- C20let astra blowing warm air
- Help needed quickly... Pass window glass
- Can this be fixed on the road side??
- brake up grade
- Full Closure
- help needed
- mk3 astra front electic windows ??
- corsa c20xe
- 308m front brakes fit 15inch wheels
- reset milage to zero
- Corsa B wiring help needed, please!
- how to get door cards off?
- digi dash film,plasma sheeting?
- wheres coolent pipe go from header tank?? c20xe
- Electric Windows in MK3 Astra
- Zafira lowering springs - which way up?
- Concentric top mounts
- Carrying load on roof rack!
- hoe do i do a compression test on my vectra 2.0 dti
- corsa b calibra heated seats wiring
- Corsa C20xe Quick Rack Fit??
- Help engine management light on a vectra, Vaux tech needed...
- mk3 astra front camber adjustment
- astra mk3 brakes on to mk4
- cheapest tyre sites online for toyo proxes
- help - suspension just snapped whilst reversing!
- 306 brake help
- Coilovers for a Nova????
- someone with bannana
- Nova steering rack poly bushes
- temperature sensor
- mk3 astra gsi suspension
- corsa/tigra
- suspension bushes! powerflex or gm?
- Nova. Rollcage advice?
- 5 stud q's
- Help Please!
- Knock sensor problem?
- c20let in corsa b gsi
- Zafira heater problem - electronic valve?
- Removing Astra G Clocks/Mileage Correction
- Seized Calipers
- astra vxr brakes on a nova
- Coil Overs V Springs and shocks
- battery light
- Faulty rev counter Astra TDS (Isuzu)
- brake lights
- I want wide track on my corsa
- Funny steering corsa b
- C20LET Lambda fault above 70mph?
- What dash lights are needed?
- Astra G Battery Light / Charging issues
- changed discs now problem!
- Corsa C20LET mods??
- EPC / part number help
- How Much: New Distributor for C20LET
- rear suspension knock (fiesta)
- breather hoses...
- Dash lights
- corsa xe brake problems
- Corsa B EPS Problem
- Something is wrong with steering on my cali
- Corsa 1.0 to XE Wiring problem
- Mk1 Astra Top Mounts (I Have The Solution)
