- How to remove nova wing ?
- corsa let suspension
- What size LED?
- digi dash corsa b !!!!!!!
- HELP!!! massive dash probs corsa b 1999
- putting c20xe in to combo van???? help!
- front wheel bearing gone on 1998 Tigra.
- HELP corsa 1.2 16v to c20xe dizzy type wiring !!!!!!!!!!!
- Heaters Astra g
- Brake bells. Who makes them?
- Vectra V6 rear tyre problem
- Omega front wheel bearing
- camber angles
- tigra wheel shake
- Vectra B GSI MSD Recaro seat height adjustment not wokring - which fuse ???
- some sort of cheap speedo needed
- Power Steering fluid level
- c20let reving its self up.
- retro fit - Coupe Turbo Brembos
- Need help with ABS error 19
- Pic needed - C20XE coilpack loom
- Questions regarding coilovers, ARBs and brakes
- corsa and caibra axle width??????
- brake pedal pulsating
- Is this an issue/warning? (new car)
- x16xe> C20XE conversion wiring help?
- vectra b engine management light
- no rear fog lights on astra diesel estate
- Rear brake discs on tigra help
- cavalier wiring
- DigiDash Td
- speedo problems help!!
- fitting epas to a corsa b. whats needed and how hard?
- Maximum disc size Brembo 4pots
- C20let fueling and Wiring Problems
- Gaz Coilover Problem Corsa B
- Female torx sizes
- Brake servio probs with bike carb manifold
- wots the deal - instrument bulbs ?
- problem with immobilizer\central locking
- 1.6 8v X16SVR ECU Part No - EPC?
- possible Zafira front wheel bearing
- Astra v6 probs
- Power steering!
- v reg vectra v6 gsi warning lights help
- Exhaust really rattling ... hitting axle...
- Vectra B rear springs- changing them!
- Will a cav exhaust fit a calibra?
- Nova quick rack + adjustable top mounts
- alternator rubbing corsa c20xe
- Agila Speedo and power steerig fault
- cali oil pressure/voltmeter connection
- Wiper Problem
- wiring diagram for late model Mk4 astra PAS pump
- mk4 astra wiring diagram wanted
- got Vectra want to put in c20 let wot wiring do i need to change?
- Cutting slam panel for conversion ???
- alternator
- Zafira hub problem!
- astra mk4 accessory wire arrrrrrrrrrrrrrrrrrrrr
- battery prob
- no spark and pulsing fuel pump
- Corsa B heated rear screen not working
- nova steering rack to dash alu clamps
- custom made speedo cable
- just changed my altonator belt and can't find where a little black cable goes??
- Battery trouble
- What size masters on nova pedal box setup?
- redtop suspension
- Vectra C Temp Gauge O Dash
- shocks & springs
- Nova common rust areas
- Corsa b digital dash
- Brake Master Cylinder problem
- bleeding brakes
- Any one on here sell Nova chassis plating kit?
- Astra mk3 suspension advice
- Heater control lights on with ignition
- mk4 astra little problem
- vectra b central locking issue
- which water pump
- digital milage correction
- What pads do people reccomend
- 100mm springs nova
- Unlock VDO CDR 500
- 3rd stalk in Vectra B
- will astra mk3 lowering springs fit mk4? honest answers please
- mk2 digi dash into mk3??
- wheel spacers for corsa that hold spiggot ring in place
- Front wishbones upgrade - Astra MK3
- shorted cigarette socket; dashboard problems!
- Wiring in temp/tacho
- redtop cavalier gsi
- 4pot brembo(evo). need advice with pads size
- brake problem?
- 160mph clock conversion, plug missing ?
- Aahh heck! eBay, new wheel bearings!!
- Cheapest place for eibach springs?
- astra mk3 gsi
- EPAS removal
- x14xe keeps cutting out!!??
- Ecotec Coilpack on C20XE
- sbd ignition only kit
- fse power boost valve
- XE Nova, Anti roll bar or not?
- Fault codes - hell!
- belmont fuel gauge and blower
- Brake upgrade
- Help! Ordering Nova Polybushes
- fitting a steering rack
- need help in a radiator
- brakes problems
- goodridge brake lines
- wiring for rear fog light
- Hard wiring my satnav.
- how many relays on c20xe conversion?
- Changing hubs - Cav GSi
- Flashing eml light on corsa b
- C20let weird problem
- Handling the Torque steer.
- help needed engine light/cutting out/speedo
- HELP!! astra mk3 master cylinder connections
- Buying a digi dash without a transducer
- suspenion problems
- combo A axle flip, any ideas?
- Astra mk3 - Total electrical failure!
- gt3071 race spec turbo
- ebay turbo
- astra Fuel pump wiring
- battery light
- Astra gte clocks need bulbs
- possible cause inner tyre wall wear( not camber)
- mk3 astra estate V's van shocks....
- Spax suspension failure
- wipers
- corasa arb lowering blocks
- Caibra decat help wich side is wich?
- heater trouble
- Let Corsa b diagnostic plug
- c20let loom tidy!
- De Catting the Astra
- 50amp Alternator. Enough?
- How to set clock?
- What brakes, 256mm red dot setup or std 288mm?
- coscast do they have larger valves +1mm and guides as standard
- astra mk 4 susspension top mount bearings
- Will this exhaust be too loud???
- identifying mk4 astra model from radiator part number?
- Dim dip switch trouble..?
- pas on a corsa
- Took Digi Clock out of my corsa how do i rewire normal clock
- mk3 cav suspension
- Mk4 Astra Lowering
- nova sri cutting out ?
- corsa 1.4 clocks in a 1.6 corsa????
- zafira 1.6 can i do the paper clip test..?
- Need some 9164475 ECU help
- anyone know anything about HID headlights?
- sport clocks
- astra g mfd (trip computer version)
- Astra Coupe Headlamps
- saxo (sorry) brake problems
- c20ne ecu loom in mk3 petrol van shell with phase 2 dash loom
- Air bag light!
- RHD steering pump on LHD astra G
- corsa engine light contantly flashing
- c20let map sensor info
- Zafira Heater Vent Problem
- cav gsi help my rad fan will not work put a new rad switch on still no luck
- alarm going off
- wishbone and powerflex video & pic inside
- Suspension
- front spotlights astra sxi
- astravan dash loom (z20let conversion)
- Astra Mk2 rear dampers
- wipers dont park, they just stop
- changing power steering rack advice needed
- Brake upgrade for Nova 2 Litre Turbo
- 206 gti heator problems PLEASE HELP
- help needed
- astra mk 4 brakes
- Air-con removal
- weird electrical problem astra mk4 gsi
- Calibra cavalier decat the same?
- Vectra Mk1 HID's - CDX into SRi
- C20let Air Flow Meter (AFM) resistance. How to test the air flow meter?
- Vectra B Which Steering Rack
- Can anyone please tell me what this part is called....
- Nova/Corsa B suspension on Astra
- Converting a narrowband afr gague to read as fuel
- Better to have a low front end or low back end?
- ceramic coating
- Astra g bilstein b14, strut top bearing std?
- astra mk3 cab roof probs!
- Where does this go???
- corsa/tigra 16v rad fans size
- C20let/Corsa B GSI wiring issues!Please help!!
- Vent controls
- Strange photo request
- cav/cali rear suspension
- nova gsi wiring??
- Standard C20LET Chips?
- air/fuel ratio gauge, help needed
- Vectra Abs Lights On
- Useless blower in my astra coupe
- c20xe into my nova, wiring??
- Vectra OPC rear suspenion is knocking..
- Ron Switch? a?b?
- need a new plug...
- Narrowband Setup?
- radiator fan for c20xe corsa
- best castor setup for road
- Rear stub axle and bearing Astra GTE
- People who know Bias Pedal Boxes. Please help.
- Nova tie bars question. Advice needed
- Best bulb upgrade for cali angel eye lights
- Battery light glowing yet alternator giving 13.8v
- Manta front hub - how many bearings?
- NO reversing lights on my Astra coupe any ideas??
- ABS Sensor Bracket Mk3 Astra
- Hub nut too tight???
- mk4 Heater controls bulb
- paperclip test shows CTS (high voltage)
- Brake Upgrade
- Problem wiring electric speedo to 2.0 8v.
- sppedo problems
- powerflex engine mount
- speedo problem
- Spax shocker issue on mk3 Astra
- c20ne tbīs
- Diagnostic Tool for my Tigra. Help
- c20let loom icv and knock sensor
- Newer style steering on tigra mk1
- Calibra turbo rear calipers....
- Need help I can't see!
- wiper speed
- MK4 Astravan power steering?
- engine mount, 1.6 astra g
- Valve spring tool -1.2 16v
- astra mk3 heater
- Fault code unknown to mechanic
- combo van springs?
- Corsa home diagnostics
- Corsa B Coilovers
- Bloody frontera fuel relay.
- astra mk3 bushes advice
- Nova SR/GTE clocks swap
- Is anyone using a lightweight battery? Or know of one?
- Best camber angle for grip and tyre wear on 4x4
- electric windows
