- any pug specialists on here? need advice on engines.
- Urgent : front suspension help needed
- Fitting Trip Computer in Mk4 Astra SRi
- smallblock, 5stud conversion. using mk5 astra parts?
- tyres...corsa gsi what size
- fuel gauge incorrect
- Astra Mk3 clicking when turning AND straight line
- clutch pedal
- one touch windows
- Mk3 Cav's
- nova front suspension top mounts
- fuel gauge
- 5 stud offset?
- astra gsi trip computer reading are all wrong
- rear brake discs?????
- Rev counter trouble
- v6 308mm brakes under 16's????
- astra gsi trip computer/how do i
- fk coilovers, they any good???
- Haynes Manual?
- Brake help
- Tempary patch on fuel Lines
- weight of a vectra?
- nova track rod thread size
- Lowering a nova
- Corsa B:Non-PAS to PAS
- HELP! - Where Can I Buy a New Engine Stabiliser Mount for a Cav ???
- Do mk4 astra's have electric power steering
- loud twang
- 1991 astra hatch/van Fuel Lines
- Calling all suspesion guru's help needed
- suspension
- worth a car swop?
- Help-me -please.
- Brake bias valves for rear disk conversion?
- xe nova reshell into corsa b
- V6 4 Stud 285mm Discs
- what new suspension & air filter to get???
- instrument bulb wattage (and size)
- HID kit?
- uprated master cylinder
- omega abs questions
- XE alternator not charging?
- i hate wireing
- GTE Headlights.
- nova hand brake help help
- GTE onto nova
- astra GSI vs. GTE
- Cav mk3 knocking noise on turning .. help
- Astra mk4 no diesel out of pump. HELP!!!
- Speedos snapped on the gearbox what part do i need?
- corsa flushed boot
- dimming leds
- Clifford Trouble!!
- A note bout SARD fpr's.... *original ones*
- Spax coilover springs
- Sunroof Help Please
- clicking
- lightend and balanced fly wheel for c16se
- corsa b 5 stud conversion.
- wheel hub
- wierd suspension question i need help with.
- corsa brake problem
- need help quick (let)
- Rear of Car NOT Level
- A lot of moisture/mist on the windows ...
- 51 plate corsa...L/H indicators stay on
- cavalier ABS fault
- steering vibrations
- 4x4 irs camber adjustment
- Battery Light Flashing
- wher to get 60mm springs for nova/corsa
- Vectra Hands Free Mobile Phone
- Is a rear wiper compulsory
- Boost gauge fitting?
- Electric Windows Help!!!
- Replacing dash bulbs on cavalier
- Dimming Dash
- Big brakes onto Mk4 Astra
- wheel vibration
- What breake pads?? Please help.
- lower strut brace on corsa B
- ETC Button
- Vaux steering wheel puller, where to buy?
- lack of heat
- need some wiring help
- cav hatch rear de-mister
- Squeaky corsa
- how good are these do you think
- wots the difference???
- Ball-joint replacement probs on 96 Calibra
- Instrument Lights
- wipers have lost memory
- Live feed to main beam
- astra v6 HELP :(
- Quick Question.... Calibra...
- digi dash readings
- lamda plug connector where?
- Is it poss to is to uprate wisebone bushes?
- How do i get this airbag bit off ?
- cav V6 auto ..... S flashing when cold??
- Boring out nova hubs for 2ltr conversion
- nova towbar help
- Need help with some wire colours
- can you get Koni red shocks refilled??
- need sum more help
- help please
- generator/110v Transformer Help
- Bleeding corsa none abs brakes?
- Removed abs
- Shock absorber removal
- Rear lights turn off randomly
- Where do heated mirrors on a Mk3 Cav, get their juice from??
- still stuck
- Nova GTE Ecu upgrade
- HELP! battery's dying!
- rodgerq advice ecu codes
- Oh no, HELP! Speedo/MFD Lighting
- MR2 Electrical Diagrams
- Non Start Astra
- Non Start Astra
- vectra dials don't light up?
- Jumping votages
- which towbar
- airbag wheel on a none airbag car
- Handbrake issues!
- Brake Disc Sizes
- brake pipe unions, how to undo with out rounding.
- Info needed on going 5 Stud
- Help!!! Vectra Steering gone light...
- ecu wanted
- Anyone know what this is ????.............
- battery life
- please help idleing problem need help
- Corsa brakes upgrade
- Pussy problems
- Mk3 / Mk4 Astra problem.
- binding osr brake 2.2 bertone coupe
- Please Help, Knocking Mk4Van
- MK3 Astra suspension
- Mot Failure
- cavy tank on to astra
- Hubs to disc conversion
- V6 hubs on an astra
- ** Can anyone tell me what discs I need from these part numbers?
- Cutting out problem on 2002 combo
- quick question about plug for cavalier gsi computer
- Corsa 2.0
- URGENT HELP REQUIRED - MR2 Electric Window
- Astra GSI rear lights
- who's the main man on mig for drilling and tapping
- Drivers Window Has DISAPPEARED!!! HELP!
- particulate filter
- astra mk3 owners
- OM Plugs - Iridium Plugs. Advantages
- Alternator list for Corsa B??
- Rite need sum help with lower arm bushesrite been changing the suspension on my bro
- Overheating Problem
- Help please
- Lights flickering
- Help !!!! My Car Beeps
- Corsa B windscreen removal
- do you know how to adjust koni stiffness?
- Flushing a Corsa B Heater Matrix
- quick calibra question
- Upgrading alternator cable.
- High revs
- HELP!!!!
- vectra 2.5 v6 info required
- retro fit top mounts
- AFR gauge
- strange bleed nipple problem on caliper
- Temp gauges and Theromstats
- m-tek hubs
- Problems with using TID with lights turned on
- Pollen/ cabin filter in Astra
- strut brace
- koni shocks..interchangable???
- manta problem.
- centre screen
- screw it, fixin the gte but need advice
- nova electric windows
- boot floors
- Is steering wheel on a corsa same size as cav/calibra?
- Can anyone recommend me a good AFR and EGT guage?
- Fitting a tv screen
- bulbs and fill of digi dash
- brakes
- AFR Gauge
- What can I use to tidy battery wiring up?
- help needed
- cavalier mk3 trip computer wiring (links found not working)
- vectra gsi 308mm caliper brackets part number
- cav springs fit cali?
- Help! what should i try
- do you know how to adjust koni's?
- Failed MOT
- Lamda sensor close enough?
- GTE LCD dash changing brightness randomly.
- Wheel hub bolt size
- tyre question: what's it's average life?
- random em light....?
- Help needed
- Tools to clamp braided hoses...
- Help with Omega Auto Dipping Mirror
- EPC Part number query
- Mate giving me these for free, are the worth it.
- 308 brakes
- 2003 astra 1.7 dti (y17dt)
- metallic paint touch up and blending in?
- C/L & horn wiring
- No EM Light???
- can anyone tell me the wieght of mk3 astra van?
- courtenay spings fitted car sitting high
- Auto Box Fault, I know nothing about them
- 2l16v to ford box
- mk2 astra touring car spec
- Wiring diagram for mk3 astra gsi
- Need wiring diagram.
- The V6 thread
- calipers....
- astra coupe suspension
- Revolution RFX Alloys
- update on repairs to my calibra ( pic)
- Vectra V6 brakes (lock up)
- No EML when trying to check fault codes?
- wiring diagram
- Cavalier Lower Front Arms...
- Lowered mk3 Cavalier Owners....
- twin 40s
- Astra mk4 Coupe astravan suspention
- removing aircon astra mk4
- loud horn?
- Uprated rear shocks
- Nova hubs
- nova chargecooler
- I think she's finally blown
- which bulbs?? :/
- desperate digidash to corsa wiring diagram
- code 65?
- project advice - conversion wise
- advice on list of codes my car has thrown out!!
- omega steering idler
- Quick Question?
- Brake fluid lost between master cylinder/servo
- actuator adjustment
- Gen me up. Cav shifter in a nova?
- Anyone know their Daihatsu van electrics?
- plug leads
- Speedo sensor advice needed.
