  1. [Nova]Upgrading master cylinder
  2. corsa cage
  3. Corsa quickshift linkage question
  4. Hall Effect Switch - High voltage
  5. Wanting to Check this looks right!
  6. Corsa GSi knocking
  7. Fitting ABS to an Astra G
  8. HELP needed to wire a coil to the dizzy
  9. Wheel bearing query for my gsi astra
  10. exhausted c20xe
  11. C20LET into vectra sri, wiring problems
  12. knock/icv plugs
  13. astra coupe turbo
  14. rear strut brace
  15. Cavalier Speed Sensor Wiring
  16. C20xe code 71, Unable to clear!
  17. Measuring current drain?
  18. Vectra B Radio Ariel
  19. Strut brace on corsa b
  20. Astra Mk3 ABS Problem
  21. Cav clocks
  22. loose wire in engine bay
  23. Nova fuel pipe size?
  24. corsa b suspension differences
  25. mk3 astra gsi rear abs sensors!
  26. changing brakes
  27. speedo help!!!
  28. Help needed asap with clocks.....
  29. Usefull link to Alternator repairing Video
  30. engine managment light!!
  31. omega heated seat not working
  32. any ideas what it is??
  33. radiator fan
  34. HELP Epas fitting/ fuse box issue
  35. Boot Light
  36. SPA gauge problems
  37. c20let rough idleing when warm.
  38. Wiring in a gauge to monitor the fuel pump voltage.
  39. Corsa electric speedo, can anyone help???
  40. pics of corsa/nova front hubs
  41. XE Knock Sensor/ICV wiring issue
  42. Measured Lambda Feedback and....
  43. oil pressure and battery voltage gauges HELP
  44. Help With Starter Switch And Button Wiring
  45. Grinding noise from wheel
  46. Changing PAS pump on XE corsa
  47. Calibra Guages in Corsa GSi
  48. 288mm Brakes under 15" Alloys
  49. Nova Avo coilovers + eccentric top mounts - help needed
  50. Nova adjustable rear spring platforms - where from?
  51. Cav turbo calipers
  52. Vectra B front hubs on a Nova
  53. fuel pump on a switch
  54. Oil Pressure readings
  55. steering wheel shakin when doing 46mph with 17" alloys on tires 225's any ideas
  56. cors 1.2 8v water out ov exaust chocolaty colour on oil cap
  57. Heated seats, where are wires ASAP please:(
  58. Corsa LET Diagnostics plug
  59. c20xe diagnostic port
  60. Which alternator to use for an X14XE single V belt?
  61. 16V
  62. problem with calibra turbo
  63. calibra front wheel bearing sizes
  64. fibreglass nova
  65. Top Speed?
  66. Help Wiring Front Fogs
  67. repainting brembo 4 pots?
  68. Diagnostic Plug wiring
  69. c20xe transponders
  70. Biggest Brakes under 16's
  71. Track Rod Ends keeps failing on the drivers side?
  72. ABS Sensors
  73. Dom's Frequency Pulse Converter
  74. Help Needed For Disc Identification.
  75. The Use Of Dianostic Instruments
  76. what are the E marked corsa b irmscher smoked rear lights worth
  77. Corsa B boot...
  78. Handbrake cable question
  79. 20XE Wireing problem. PLEASE HELP!
  80. Lots of fun fault fixing
  81. managment light with no cat
  82. C20XE Different ECUs
  83. abs - non abs master cylinder query
  84. help pls relays corsa c
  85. combo shaking above 35mph help please
  86. any good mobile wiring/sparkies in mids?
  87. Corsa SRI quick rack
  88. Just Cold air!
  89. Corsa Diesel no start/dash lights doing funny things
  90. gsi turbo warning light!! HELP PLEASE!!!
  91. Abs light permanently on.
  92. Mintex pads with M1144 compound
  93. what size bolts do i need for alloys
  94. Can I not just cut my springs?
  95. do i need a new spring?
  96. abs nova
  97. corsa wont start need help
  98. mk4 astra window motor removal?advice needed!!
  99. Astravan Sportive 2.0 DTI Kerbweight? (For Jacking)
  100. help, install a boost gauge, corsa C
  101. wiring diagram
  102. reading fault codes on 1.2 16v
  103. Could someone read this fault code for me please?
  104. Clocks, Electrics...doh! Please Help
  105. lamba sensor performance
  106. ajustable top mounts
  107. Coilover Servicing
  108. Worn middle main cap
  109. Astra MK4 2.2 SRi severe brake judder!!!
  110. Astra Mk3 Koni rear suspension
  111. Help advice please on steering.
  112. Corsa B Springs
  113. O.E number for Calibra Turbo Front Wheel bearing
  114. Top Shock Mount (Drivers Side)
  115. Corsa Speedo...Need Help!!
  116. rear discs on corsa help please.
  117. corsa b rear disc conversion problems
  118. Calibra struts and Vectra struts...
  119. Speed sensor cable
  120. Washer Jets, rear Mk3 Astra GSi 16V
  121. ANy common electrical faults on Cali??
  122. Calibra rear springs, all the same?
  123. I fitted solenoid now alarm problem...
  124. Corsa Car Radio Phone Mode!
  125. chipping a v6 vectra
  126. battery overcharging??????
  127. What would you use for a speed sensor on aftermarket guages?
  128. oil pressure/oil temp gauges (wiring help)
  129. c20let in corsa b fuel in the rail but not injecting
  130. 4X4 light on at idle
  131. Exhaust from an 8v Cav onto a 16v Cav?
  132. Vectra MFD
  133. The effects of using a different AFM on a Corsa 1.2 16v?
  134. Electric window probs
  135. corsa brakes
  136. where can i get a very powerful solenoid
  137. is et35 offset ok for a vectra
  138. Temperature Gauge Sender on X18XE engine
  139. Boot solenoid question please help
  140. clocks
  141. How easy to change a power sreeting rack??
  142. Getting Dom's pulse converter to work off ABS sensors
  143. corsa NE 8v wiring problem
  144. fuel pup on a c20xe'd corsa
  145. gte into corsa wiring
  146. TC Warning light on Dash. Vectra. What is it?
  147. No posstive feed to loom
  148. difficulty filling with petrol
  149. Water Temp guage issues
  150. what clips into this?
  151. Zafira hubs on an astra
  152. best place for exhaust pipe (3" straight length)
  153. Corsa B Indicator/Hazard light problem
  154. rear brakes
  155. Corsa XE Wiring Problem
  156. Corsa b suspension
  157. help with brakes??
  158. Astra Mk4 Eng. Fault Codes
  159. Nova Rear Beam
  160. 3 plugs im unsure about?
  161. 2002 astra, rear demister switch flashing.
  162. Handbrake problem
  163. Side mirror glass missing
  164. remote cental locking
  165. astra gte digi dash
  166. Corsa XE Conversion Wiring Diagram
  167. Help! Astra GSi fuel cut off??
  168. MAF sensor questions.
  169. vectra dti is engine ecu matched with diesel pump
  170. rear discs
  171. Any way to stop leaking driveshafts covers
  172. Calibra v Cavalier IRS Suspension
  173. ***How Low Can I Go?***
  174. calibra turbo exhaust manifold gasket
  175. MK4 Estate Coilovers
  176. corsa b arb lowering block dimensions
  177. spax now listing coilovers for cavalier
  178. Removing airbag
  179. Knocking calibra
  180. dti management light flashing wont start
  181. Still no spark C14se
  182. Air Bag Help Please
  183. 20SE wiring into corsa b HELP!!
  184. Anyone tried this Knock detector ?
  185. astra mk4 hubs
  186. help please fried something
  187. Vectra speedo not working
  188. carb 1.6 dizzy on to 2.0 XE problems
  189. Need desperate help with my corsa brakes!
  190. Loose ECU connection
  191. Split the drums, how do i adjust shoes?? PLEASE
  192. Car made a bang then ran like grap
  193. help with LED indicators bulbs
  194. HELP no igition or power
  195. wiring diagrams for c20xe
  196. Speedo not working
  197. helpp!! battery light problem
  198. steering woes
  199. Wiring ans for a engine conversion
  200. Whats the best way to adjust head lights!!
  201. Quaife RHD 2.5 quickrack kit
  202. Citroen ax rear brake (hand brake) help please
  203. gsi master cylinder...front or rear?
  204. Strange noise!
  205. Opel Astra F temparature sensor
  206. new lowering kit
  207. gearbox went
  208. zafira faults
  209. Fuel pump
  210. mass air flow sensor for corsa b
  211. Will this fit my f16 box??
  212. Anti Roll Bar
  213. Corsa C20XE Clocks
  214. Cooling fan is driving me nuts!
  215. 99 T Corsa 1.2 16v, starts, then cuts out. Any ideas?
  216. few nova related questions
  217. Cally Turbo, making strange noise
  218. Corsa XE Exhaust system
  219. Biggest size brakes for a corsa b?
  220. astra exhaust emssion warning light
  221. Guide Assembley Gear Linkage On Nova
  222. Motronic pin question
  223. Calibra turbo..cant trace this earth
  224. Will a mk3 cabby door loom fit a mk3 3dr gsi
  225. Power steering pumps
  226. what are uniroyal rainsport tyres
  227. nova v6 mounting kit ??
  228. Cavalier stub axles
  229. Astra 3 optimum plunge on shafts
  230. Astra H 55 Fuse for washers?
  231. Mk2 Astra GTE Heater System
  232. Steering doesnt straighten up after a bend
  233. Alternator Upgrade for Corsa B 1.4SRI - What will fit?
  234. lookin for info on this plug - late XE loom
  235. I have got a funny judder when braking??
  236. Alternator help please
  237. Non Vaux
  238. No feed to fuel pump
  239. Astra Mk3 Cuts out
  240. Mk3 Astra union size
  241. engine conversion in astra mk3 gsi
  242. corsa gsi wheels over 2ltr brakes??
  243. witch pins for paper clip test
  244. Digi Dash - speedo inop...
  245. Abs sensor
  246. wiring c20let clocks
  247. mk3 gsi wiring diagram
  248. Electrician needed (wiring loom)
  249. no spark C14se
  250. do astra mk5 hubs fit mk4
