- Fault Cose 57 on C20LET, can someone please help???
- indicator wiring
- Nova XE, no EML?
- MK2 Astra fuel filler
- what springs for corsa?
- Astra G Suspension
- Cavalier sri fron struts and wheel bearing problems
- nuts!!
- Nova seats in a corsa?
- digital vectra mileage correction wanted
- Voltdrop across coil (c20xe)
- Calibra Sunroof
- Cruise control MK5
- overiding fan switch
- does vec c have the same f23 as the vec b
- Corsa b Braking Problem
- Brake bias valve
- bottom arm issues
- ford maverick engine check light.
- bleed nipple thread on Astra Cavalier rear calipers
- brakes????
- Alarm and central locking major problem!
- how do i get brake servo out of my nova ?
- nova xe no fan
- Red and Blue Wire Running up steering column Corsa B
- Vectra door won't open!
- Electric Window Query - 'Autoup' = Perm live?
- Should my n reg corsa sport have pas?
- need cav2 dizzy, module and loom?? help
- Astra Mk3 front strut removal/refurb (56k no way)
- Bloody Vectra central Locking!
- c20xe redtop corsa wiring confused
- vectra b wiper motor?
- fault lights on dashboard
- Astra Mk3 1.7TD Speedo
- ignition barrell for cora b 1998 plate??
- cav/cally t, what size are the front discs?
- corsa b speedo
- Any issues using stainless steel nuts and bolts over mild steel???
- c20xe idle control valve wiring
- Calibra automatic windows/remote central locking windows
- remote cental locking reprogram
- Central locking on Corsa B
- whats gearbox oil for an f18
- not working!
- wiring a boot popper ?
- vectra 5stud disc "upgrade"?
- Vectra C rear brakes.
- Boot will not open.
- Can i fit epas to mk3 astra
- wipers wont return to correct position on intemitent
- battery removal - vectra
- Wipers/Washer jet issue
- fuel sender ohms help mk4 astra
- why does my rev gauge not work
- ecu change on astra mk3 sport. help!!!!!!!!
- Something is causing my cali to blow up alternators
- Rear disc conversion queries.
- rev gauge
- Mk3 power stearing
- VXR Z20LEH Wiring Diagram
- Driving without an alternator belt
- Astra Wheels on Lowered Corsa?
- TB loom hole on bulkhead?
- Heater Matrix
- Engine light comes on... but only for a few seconds
- How do you no when you need new brake discs
- idiots guide to calibra window motor
- sidelight problems
- Does my car need side repeaters?
- How much brake fluid in Astra MK3 GSI?
- Electric Supercharger
- EPC Help P/N: 9048 6460 / 1603 191
- headlights and MOT
- 308mm brakes
- dash handbrake light needed for MOT?
- cav brakes on corsa
- corsa gsi wiring?
- Omega clutch master cylinder replacement
- Fitting GTE Digital Dash Into a Corsa B
- dodgy kwik fit??? advice needed
- Suspension torque settings
- EPAS - electric steering conversion from Corsa
- Astra G Cabriolet Roof Trouble
- Burning out headlight switchs
- engine running rough and lumpy when cold
- Indicators not working
- Bugger.....
- The Great Brake Adventure - A step by step Guide
- Remote central locking
- Snapped Cam & Cam Help
- v6 electronic speedo conversion
- de-cat trouble
- Left hand Dipped/side light not working
- Cooling system (HELP ASAP)
- brake warning light& batt light on all the time??
- astra g cutting out
- Is the airbag light on an MOT failure??
- Fitting v6 brakes to a corsa
- heater fan speed on omega
- Diesel glowplug light stays on all time?
- corsa c20let radaitor fan
- No brake lights.
- fitting a dvd player to corsa b
- refurbed brakes, poor result? astra mk4
- Steering rack loose!
- pic & info on a mk3 astra gsi rear ARB
- Whover said replacing discs and pads was easy.....
- Zafira clocks...
- White/Black trace wire in MK3 engine bay multiplug?
- Auto Gauge - Fuel pressure wiring?
- c20xe in to c20let wiring
- will astra mk4 hubs fit on corsa c?
- info needed steering wheel shafts please
- urgent help needed plz
- push start button wiring
- Astra mk4 front fogs
- Uprated Clutch for CS4?
- corsa c epas/stalk wiring
- There must be a tool to do this!?
- anyone know what this magnex exhaust fits?
- any ideas why my windows dont work?
- Rear Brakes Nova
- Mk4 Astra GSi De-cat...
- c20let boost cut issues
- Vectra C Heated Mirrors
- calibra dials
- seats
- Can anyone tell me what's up with these wipers?
- Where to buy breather pipe?
- Vectra VSS issue (code 24)
- Corsa gsi calipers same as gte 16v??
- zlet sri turbo
- solder joints in the fuel tank?
- more power?
- anyone know how to install a tab lighter in car without the wires
- Poly Bushes
- air mass meter pipe/rocker cover breather pipe is it leaking
- Any VAPOR dash gen??
- rear calipers
- help needed please ugently
- Jacking points astra gsi mk3
- horn problem
- Battery??
- Astra Mk4 ECU Pinout Anybody?
- Dashboard Lights
- Suspension Advice needed please
- Opinions please.
- few problems
- Central locking wiring MK3 Astra
- How do you perform a paper clip test?????
- Astra mk3 Van
- vectra central locking
- eml on
- vectra cd changer
- mk3 astra bonnet hinges
- URGENT- C14XE, lost transponder chip !!!! bypass???
- Spray paint rattle cans???
- eml on
- C20xe exhaust size
- Saab 93 R Reg, will Suspension fit Calibra?!
- ecu
- ecu lamp wireing help
- Sunroof leak
- corsa gsi exhaust
- using motorcycle rad fans....
- Gsi coilovers?
- oil pressure gauge c20let
- astra mk4 van lowering springs
- are corsa c's ment to have middle exhaust silencers
- Power Socket Question
- new bolts for suspension
- Wiring diagram for cav rear electric windows.
- calibra brake help
- spax suspension on a Tigra
- Is it ok to use a 096 battery instead of 063
- Help with suspension advice
- cherry bomb silencers
- XE Nova...what suspension?
- Astra Rear Axle
- CV Joint Advice
- Shorter Belt to Remove AC Pump Guide Please
- oil press+ volt into nova? from cally
- Front brakes
- flip key conversion ??
- ECU Where??
- Whats this and will it effect my idle?
- burning live wire, HELP
- lmf 288mm brake kit
- Battery Reccomendation...I need new one now!!
- 20xe fuel pump relay
- astra gsi heater switch
- do corsa C shocks and springs fit on a corsa b??
- What are these wires?
- Nova owners using bias pedal box - few q's
- handbrake adjusting
- Speedo Astra G Sri
- 2001 Vectra Check display problems...
- Brembo caliper brackets
- dignostics
- c20let loom
- How to use a polishing machine???
- mk3 astra alloy top mounts
- 300mm rear brake set up on bells on corsa gsi
- Better braking/ Upgrades.
- L('94) Astra GSI mk3 rear disc removal ideas ??
- Rose Jointing Corsa b Gearlinkage
- corsa sport air con???
- c20xe wont start poss immobiliser?
- Corsa Fuel Pump Pressure
- Holding a grommet open
- C20XE swap over
- what brake servo will fit ?
- bonnet wont fully shut
- Are all power steering setups the same on mk3 astras?
- IRS Cav rear subframe bushes
- My headlight clicks when on...
- P0100 air mass sensor signal improbabale fault code
- 5 stud astravan????
- astra g mk4 heater control panel fittings
- EPAS pump temp
- wiring diagram for astra gte clocks into a corsa sport w reg.
- Brake upgrades
- Power Steering, Tough One !!!
- someone reversed into my car - is it dead?
- which strut brace for my conversion
- what does the temparature sensor look like?
- brake-pipe.co.uk
- electric windows
- bad brakes
- CAV GSi SPRINGS
- V6 Conversion
- interior electrics!!!!!
- turbo repair
- hi spec brakes
- how easy to fit brakes
- rear hubs
- Streatchy flexible tubing for engine loom?
- fuel computer
- Nova steering arms
- BIG brakes
- Astra MK3 replacing spring - do I need the hub nut off?
- What would happen if i cut this part off my brake calipers?
- No ECU light on nova turbo
- Battery Charger?
- radio display
- nova-corsa exhaust system??
- 1st gear ident switch mk3 astra LET
- Anyone know much about LED's ????
