- Indicators on 1996 Corsa
- best suspenion for mk3 astra
- Corsa TD battery light comes on when i select reverse??
- help with OMP rear strut brace
- Vec B Estate Trailer plug - where? pls Help
- lowering 60mm on standard shocks
- MK2 Astra top mount assembly - is this right?
- removing cav\cali turbo shafts
- AVC-R Selenoid Question ,
- urgent help needed (rover metro)
- Speedo cable nova.
- v6 brakes on a corsa
- vectra v6 rear disc hubs
- 140 speedo clocks and 160 speedo clocks
- xenon lights out of a cdx fit cdx ......
- LET Mech/ Elec Clocks?
- Astra v6 lcd dash
- strut top bolt size
- Coil pack wiring
- Corsa brake fluid
- Coilovers/tracking
- fuse help needed
- Suspension confusion
- Brake Discs for Mk4 Astra GSi
- would this work brake servo question
- XE conversion
- Corsa B Coilovers, Which are best?
- Knocking in rear of car
- Fitting a FATT Blitz Turbo timer
- spark plug leads
- Were can i get replacement headlamp glass????
- Wheel/Tyre Size Wide track Nova
- Towing a Frontera
- mk3 astra digi dash cant get fuel computer working
- Oil pressure sensor on GTE Digi Dash
- Steering lock jammed :(
- Vectra brake servo change?
- hiding those engine bay wires???
- Oil pressure sender
- nova brakes? please help me!
- Best place for standard MK4 Estate rear dampers
- corsa b lowering springs
- Electric Window fault - Wiring Diagram inside (Dom)
- central locking wires, which 1s?
- Lynx automotive ECU ??
- Corsa pad question
- Help needed wiring digi speedo
- LET ignition leads... whats best??
- Powerflow Exhaust - I'm NOT happy!!!
- Exhaust flanges...
- c20let astra gsi fault code problem
- Air-Bag Light NOT WORKING
- filling small hole in backbox
- Another Motorsport Spec wiring loom in progress
- digi dash into a corsa
- Nova brake pipe fittings -3
- Will I need a key for these..?
- Adding Rear Disc brakes to a previously Drum Cavalier, a couple of questions i have
- Coilover and helper spring - help!
- rust around wheel well
- MK2 Astra cage
- Rear coilover spring LB?
- Astra gte and astra gsi rear brakes
- Fault Codes...
- corsa c wiper relay
- Nova Fuel Tank
- key fobs
- cav gsi
- digi dash bulbs
- Non working fan of death!
- What pins do i need to short out?
- corsa imobiliser
- 308mm upgrade abd alessio 2s
- Quick immobiliser pickup wiring question
- Lowering a mk4 astra van?
- immobiliser
- nova rad and fan
- MK2 GTE (LET)Fan and horn stopped working. HELP please
- Sunroof Problem!
- George W. Bushes
- Mk2 astra gte suspension worries!!
- astra mk4 gsi exhaust fit zaf gsi?????
- Hitech Suspension Systems
- nova braided brake lines info asap
- Step by step - what to check on Aircon
- fitting air con to a Astra GSI!
- nova coilovers
- coilover quickie
- can someone answer this quick lol. starter motor turning over with out ignition on?
- warning lights.....again!!!!
- Which suspension? (Mk4 Astra with current suspension woes)
- Hi Spec 300mm Conversion
- Plug on a Mk4 Astra X16XE, what is it?
- how accurate is speedo on Astra mk3
- sealing a drilled hole
- 1997 tigra speedo not working
- mk3 astra electric mirrors
- Help me settle an argument!!!
- Cavalier MK3 CDX Ecotec problems - Help
- HELP! Corsa b exhaust
- cav gsi red top
- Digidash constantly flicks from mph to kph
- Known Issues With Vectra C
- Digital Dash
- Digidash Struggling in LET Nova
- Vectra Backbox on Cav?
- Will my handbrake pass the MOT ?
- Resetting a rear seatbelt after it's been removed.
- calibra turbo brake upgrade
- kenlowes again
- Wiper motor - recon/replace where to buy?
- gaz coilovers
- Paperclip Test
- replacing clock for computer?
- Astra GSi Traction control experts advice needed
- Brake Kit for 16" Wheels
- immobiliser chip
- 96 Vectra Central Locking
- Quick SARD reg question!
- MK3 Astra - horn stuck on
- Nova fuel system diagram. (MPi)
- New Car's Trip Computer + Sat Nav Question??
- starting problems
- C20LET Tachometer problem,
- ABS and TC fused????
- corsa missing at low revs???
- 3 pipe mod/cool stat?
- Vectra Trailing Arm Bushes
- rear disc conversion
- Vectra TID/TFD to Mid/MDF upgrade
- What tracking setting on a nova?
- Corsa B door loom
- tracking
- 2ltr 8v oil pressure gauge
- nova turbo and Speedlines, wot brakes???
- Changing the m/c...
- Astra GTE won't run
- Whats this and what does it do? (C20LET)
- cold start problem on zafira 1.8
- xe corsa arb
- Tyres that actually grip the road????
- koni adjustables
- wiring up 20seh to corsa b
- What does this tow bar fit?
- traction control
- ABS Sensitivity
- 8 point cage
- mk3 astra digi dash conversion
- any1 got an apexi avcr?
- Astra F Gsi Locking Problem
- Cruise Control into a Corsa C
- Corsa quick rack
- Calibra Steering Columb onto Corsa B for XE conversion?
- nova c20xe wiring help (i know i know, but its an odd one)
- Pug 106 brake parts needed and help guys!
- Internal Battery Box fitment - Race/rally bods
- corsa 236mm solid disks to vented, will this work...
- Dodgy Steering On a Corsa B SRI
- Warning light
- Wirring fault maybe?? Fusses popping.
- hi spec 4 pots
- Cavalier TD + air con
- PART NUMBER NEEDED - Fuel pump relay
- Front and rear fogs
- MK2 Astra Front Leg onto a Mk3 Astra...
- brakes need help!
- no spark
- Dash lights everywhere!!!!
- what suspension on an astra GSI saloon?
- very poor brakes
- bolt thread size question
- EML? any ideas?
- Wiring Fog lights to a Vectra 2001 LS
- Corsa B Ignition Barrel Change...
- Astra 1.7D (lpt) Back exhaust box - help needed please
- wiring
- XE loom - 5 pin connector for icv/knock loom
- Astra 1.4 Mk3 tyre speed rating
- nova rear turrets?
- Cavalier Remote Cantral Locking ????
- MK2 Gte springs onto mk3?
- Sat Nav Display
- please help
- brake upgrades on corsa c 5 stud.
- 106 brake upgrade! what do you think?
- Vectra Towbar
- omega dash woes, please help
- electric sunroof into corsa
- black/purple wire
- Very Quick Question (Brakes)
- quick question (mk3 gsi wing)
- Broken Fuel Cap
- Vectra GSI upgrade to climate control?
- A few questions
- vectra dti immobiliser wiring help,pin out
- Handbrake Cable and MOT?
- Rear disc conversion on a nova?
- 5 stud hub and bearing pressed into 4 stud leg?
- new keys for my cav??
- EML continuously flashes when reading the codes.....
- Need advise on Wiring.
- Lowering springs
- Nova wheel bearings easy to change??
- fuse size?
- stearing
- Lowering springs astra coupe
- 5 Stud conversion
- tight steering
- astra gte wiring issue
- press on brakes and em light comes on
- Alternator light on and intermittent EM light
- Better braking that doesnt cost the earth?
- quick izuzu engine question
- vectra v6 air con removal
- Best springs?
- exhaust manifolds
- Didgital dash HELP WANTED PLZ
- SuperChipped ECU?
- steering out with engine in?
- Gap in top strut mount on Cally?
- Fitting Traction Control - CAV CDX ECO
- Biggest drop on a CorsaB?
- Corsa dials/clocks conversion
- recommend any shocks
- Swapping rev counters (Mk3 Cav)
- need the rubber gromet for the vacuum hose in the brake servo
- wiring cav rear electric windows
- Vectra 2003 strange noise from front suspension
- oxygen sensor c20xe
- Nova Electric Sunroof Conversion??
- WIRING!!!
- astra mk3 ball joints, do i have to drill them out??
- corsa question - can someone do a quick check for me?
- chipped ecu help - pics
- any one know what this plug is for
- Can anyone find my fuel gauge wiring loom? Astra GSI
- gear change display
- Intermittent ABS light
- Creaking Tigra
- anti roll bar
- New 284mm brakes on a corsa?
- astra/calibra/cavalier track rod ends
- Creaking sound from steering on mk4 astra sxi
- high co emissions - cat or lambda?
- how do you wire the cally vdo guages up in the cav?
- 1.0l corsa b wiring
- Quick easy air bag question
- Fitting Powerflex Front Anti Roll Bar Eye Bolt Bushes To A Calibra?
- corsa engine light on
- cut wire from wiper relay
