- Wiring Up Electrics On Corsa Doors!!
- Vectra Sri-ABS light comes on with fuel light !
- rear disc conversion
- simple wiring diagram required
- Lowering springs
- how do i refit nova windows... ?
- Braid hoses Corsa B
- corsa b handbrake cable? with rear discs
- Astra mk2 GTE 16V Springs
- Cruise Control stopped working 04 Vectra SRi
- Alloy radiators...
- Lowering Astra GSi (91) Problems..
- ATE Calipers
- astra coupe 2.2 airbox
- Boost gauge T+Ecu line
- omex problems
- corsa b hub
- Corsa Rear Coils
- Calibra boot lock problems
- Celica Clutch Problems
- powersteering hydraulic hoses for vectra
- Parrot Handsfree Car Kit
- battery in boot
- hydraulic handbrake and MOT
- corsa 1.4 sport on W or V plate two questions
- Fuel pump relay astra c20let
- XE Wiring HELP so close
- Cavalier Braking Troubles
- Useful tip for all diy mechanics
- Whats easiest way to measure the voltage on my pump
- cavalier 1.7 td saloon swap into cav gsi running gear ?
- 1.8 Sport MK3 Astra pads. Same as GSi?
- Strange metaly knock coming from front passengers side?!
- vacume pipes
- Vectra B Inner Door Hinge Split
- Help please mk3 astra van
- will 308's fit under turbo rims?
- Brake options
- Corsa B speedo not working!!!! where to start????
- second air intake
- what XEs had no lambda and used the 3 little plugs near the ecu?
- will 284s fit under a 15inch wheel?
- XE Nova starting issues
- apexi turbo timer into corsa c20let
- Electrical gremlins (nova)
- 99 to 2001 dti wiring changes
- C20XE wiring help required please
- Vauxhall dual fuel systems, anyone owned one?
- changing discs without changing the pads...
- hubs
- mk3 astra suspension?
- the difference between Tigta X16XE & Tigra X14XE
- astra g + z20let - abs = ?
- replacement wilwood discs?
- 1.8 brakes.
- Changing hubs and beam etc
- Golf rear discs on Corsa
- Astra GTE 16V What Coil Over Suspension kits are avaliable in the Uk for these Cars?
- Where do you get your AFM from? (C20LET)
- Vectra Rear Light Unit
- standard sard regulator is it ok for a turbo
- where is the sard regulator adjusted from
- 8 Speed Intermittent Wipers Problem
- octane plugs
- coilovers?
- c20let corsa fault code 15 cts hight voltage?
- ARE cav & cali handbrake mechs the same?
- What features will an Astravan merit have?
- corsa b 1.4 exhaust
- need astra mk3 gsi engine wirring loom with traction control
- Mk4 Astra Strut Mounts
- ecu light flickering on corsa c20xe
- Coolant Warning Light (2001 Astra 1.6)
- I have astra gsi c18xe and lack power
- lower arms and tiebars wont line up ??
- Mk2 Astra GTE, Strange Problem
- diagnostic plug on c20let corsa
- Diffrent size springs?
- Carlton panels
- Calibra turbo 4x4 light on
- Corsa xe, air con fan ok?
- Is this wire meant to get so hot??
- Fan coming on far too early??
- dash lights stopin on when ignation off
- Engine mounts//kits/advice please
- immobiliser chip
- vectra 2.5v6 ecu tuning
- Changing the springs on P reg Vectra
- Calibra rusty rear arch repair methods?
- Lowering Astra F GSi - Need Advice..
- Help with handbrake cable
- Master cylinder upgrade
- who can remap a 2.0dti vec to run 2.2 varyflow turbo
- Robbing parts from a higher model.
- Corsa Aircon Not working.
- battery removal
- Battery going flat on astra mk4 c20let
- Error codes Help!!!
- need help elec on morrettes
- Corsa drum bleeding
- c20let electric speedo
- How much does a gearbox weigh (f18)
- Cavalier Turbo Timer and Alarm help...
- factory front & rear parking sensors HELP
- fuel pump relay
- Will Corsa B front struts fit a Nova ?
- part number check
- Zafira 1.8 16v 1999
- What is this relay thing????
- Caliper piston size question
- anyone know the headlamp aim height for uk mot?
- 2ltr servo onto nova? will it help?
- Where does this bolt up to????
- Difference in mk3 astra gsi and std srpings?
- HID Problems
- Why is it so hard to get an astra mk3 low at the front
- V6 GTE - Will cavalier/cally springs fit?
- Cav central locking failure
- digi clocks
- Could someone read this fault code for me??
- Cav Mk3 Rear Wheel Tracking
- Tempature guage not working after new radiator fitted
- unknown light on dashboard
- Does Anyone Know the biggest size calipers & discs i can use???
- Smoking Valver Brakes HELP
- fitting walbro fuel pump?
- 2000 tigra diagnostics port
- mk3 astra reverse lights
- Front brake pipes smoking !!!!!!!!!
- power boost valves
- AutoGauges wiring....???
- Help Needed On Changing White Lockwood Dials!
- Fan relay died, what are the options?
- Calibra rev counter (randon bouncing)
- Brake Problem ASAP Help Needed!!!!!!
- Custom springs?
- turbo coolant hoses- where do they go? c20let
- total closure
- Calibra fuel pump
- Timing belt storage life
- battery light!!
- Loss of Brake pedal HELP !!!!!!!!!!!!!
- Will SRI suspension fit my 2.2 CD
- Calling Anyone And Everyone!!!
- Dashboard lights on 2001 Astra
- Blitz chipped ECU into Calibra V6
- Tigra Rear Disk's
- vectra sri 130 eco in corsa b starting problems
- turbo exhaust blade edge missing why
- Request for 16v rear disc info
- Corsa 1.6 16v firmware
- bigger brakes?????
- Corsa solid lower arm mount
- Exhaust
- remote central locking
- early xe alternator on later dispack engine ??
- Corsa B Rear Disc Brakes
- Anyone with LET oil pump knowledge pleeease help...
- wheels
- cone air filter on vectra
- SEH bottom pulley trouble
- cavalier rear disc bearings
- eco tech coneversion on corsa helppppp
- rear washer jets
- Steering Screetch/Squeak! Help!
- How to get the nova wiper linkage off?
- Nova gearbox mount
- Opel Monza air recirculation switch
- stiffer engine mounts?
- 'unichip'
- R Reg 1.8 Vectra - Steering Issue
- immobilizer problems
- m tech hubs
- feul pump random question
- driveshaft
- Cruise control on Vectra V6 (2.6) SRI 2001 plate
- brake discs on ebay
- Suspension fitting on a Mk4 Astra
- how tight should they be?
- Stack Dash owners....
- Is This Right??
- astra mk3....how low can i go???
- correct tyre pressure
- Cleaning CV grease of a wheel?
- cavalier 4x4
- Can stainless steel be mig welded
- clonking noise when turning
- ABS working when it shouldn't!
- Rocker cover cleaning help please
- what inner cv joints are 25 spline and fit f20 box ?
- Oil brether pipe c20let
- Rocker cover off whats best to protect it.
- Anyone got a picture of the alternator belt on c20let
- what cv joints are needed ?
- oil around distributor body
- Alternator?
- C20XE wiring loom Help !
- Corsa C20let tie-bar lowering bracket bolts?
- Solid mounts on road car
- How Thw Hell Do You Fit Cv Boots
- Astra Mk4 headlight removal...
- V6 front brakes straight swap to my 4 stud Cav ?
- starter motor sounding rough
- Megasquirt on C20LET? Idle valve PWM or Fidle
- astra hubs
- knocking astra g
- exhaust noise
- total closure module
- redrilling discs
- Astra coupe knocking noise
- Location of charging relay in vauxall corsa/combo
- MBE 967e Help Please
- 5 stud nova with vectra parts
- Brake disc spiggot rings- Are they 100% needed?
- Vx220 Jammed Rear Caliper?
- phase 3.5 what should boost be in 3rd gear
- Non-Immobiliser ECU into Immobilised ECU?
- camber adjustment bolts??? peoples thoughts please..
- chris Astley motorsport Hub's What CV?
- vectra c 2.2 front coil springs
- lowering blocks
- Removing the engine bay loom from my Vectra?
- best suspension
- Urgent help needed....Ive just put my new clocks (with rev counter) into my mk3 astra
- what size fuel lines for nova xe
- Astra GSI Dispack car to engine loom wiring?
- Steering rack help
- PAS hose;
- Braided Brake Lines on Pedal Box
- Fuel gauge has gone mad!
- astra 308mm brake conversion
- Puzzled Peugeot's best, can you help???
- astra spring twanging!!
- finding bits for 308mm brake conversion
- URGENT HELP Vectra C rear brakes seized
- Help With Part Numbers
- Where to get rpm signal off dispac XE?
- key won't turn in ignition
- Electric windows have a mind of their own
- hub diamiter
- problems with nova xe
- Mk2 Astra Wishbone pivot mount
- what brakes
- drive shaft questiom
- wishbone WTF!!
- Astra G rear brake pipes
- are these wires used ?
- 5 Stud Tigra Conversion
- Corsa Sebring Backbox
- handbrake adjustment...
