- phase 3.5 is my spark blowing at high boost
- need help asap with brakes
- M.O.T do i need a cat?
- c20let wiring, need help plz
- megasquirt V3.0 no spark
- i need a bigger master cylinder for my corsa
- Vauxhall multi plugs
- Vectra diesel Engine loom wiring
- Whats this Plug? Or what is it?
- Rear Disc Brakes on Corsa B
- No Jingle when leaving lights on
- Megasquirt I v3.0 communication problem
- Eml flashing
- fk coilover camber adjustments?
- Swirl pot, pumps and wiring?
- Front 5 Stud on a Nova
- my corsa splutters?!?!
- Astra 1993 Gsi Abs Plug??????
- speedo f23 astra mk4
- c20let- 1st gear switch
- tie bar lowering for f28 in nova
- 2.0dti vectra intermitant engine warning light
- Vectra hydraulic clutch diagram
- Hot emotion (Yonit sensor ) in X14XE
- z20let turbo ecu diagram pls
- Weird fault On Cavalier Engine
- Fuse on cav v6
- Exhaust bolt/nuts thread/size - calibra turbo
- Astra gsi redtop 94 abs light on???
- c20let oil pressure sensor?
- vectra brake backplate-rear wheel bearing separation
- What colour wires are on the 1st gear switch
- Corsa C20XE MOT time
- Suspension and Roll cage questions
- Brake Options.. What do you recommend?
- replacing rear spring on astra mk3
- CorsaB Wiring Diagram
- nova shell
- C20Xe, loom, removing the fuel pump relay!
- ECU help needed
- Vectra CD Heated sets?
- Vectra power steering
- corsa c rack
- More electric problems please help!!
- c20 xe distributer mod?
- coupe v6turbo conversion queries
- coilover rear
- Adjusting headlight beam on mk3 astra
- Astra mk4: Can I use the shocks from a 2.0 on a 1.4 ?
- unlocking standard vauxhall tape player
- HUBS
- Removing bleed nipple on brake calipers
- Vectra brakes
- c20xe and megasquirt
- autogauges! any good??
- Car and loom question please
- is there any differnce between corsa hubs ans astra ones?
- Corsa Door Hinge Clicking
- MK4 Astra x20xev ECU :(
- Astra mk3 alarm fob
- cav turbo front hub
- astra gsi mk3 brake problem
- quick answer needed rear wheel bearing torque
- Throttle/pedal problems
- Changing speedo backlight bulb on '02 Omega
- oil pressure &voltmeter for a cav gsi
- central locking system
- Problem with alternator???
- digi dash?
- turbo help please!
- What poundage front coilover springs-Small block nova
- random co-ax?
- astra mk3 suspension kits
- Which Master Cylinder for my MK3?
- Nova brake servo problem?
- corsa b sri clocks in to non sri with rev wire any one help ??
- Vectra C Automatic Motion Door Lock
- Tigra A/C unit pictures wanted
- Isuzu tacho pickup
- c12nz dizzy cap
- No Reverse Lights
- C20XE alternator pic wanted
- Jamex lifetime guarantee?
- Fual Pump Relay HELP !
- Nova braided hoses
- Astra gsi strutbrace
- astra g clocks into corsa b
- wiring for c16xe and x16xel engine into nova
- Astra mk4, c20let, aircon problem
- 1996 corsa cataytic conveter
- Wireing Digram Please !
- bottom end
- Mk3 astra van rear shockers
- c20let or xe icv loom?
- Where's best for a C20XE alternator?
- vauxhall omega electrical problem
- Tigra B headlamp change?
- Nova Group A Front Knuckles/Flanges?
- Calibra turbo clocks in a astra mk3
- corsa sport 1.4 16v
- Making up brake pipes
- Corsa B central locking
- Nova tie bar bracket bolt size and pitch
- help needed asap in wales for nova
- corsa gsi goodridge brake hoses
- nova horn wiring
- c20xe and brain problems
- brake upgrade for 2.0vectra
- where can i get an engine wiring diagram from for a c20xe as i need to make a loom
- cav v6 5 stud onto astra mk3...
- engine running but with lights on rev counter dont work???
- Remote central locking?
- Want to stiffan my engine mounts
- What's the Best Value Nova Competition Suspension?
- Can you use these holes to lift the engine
- how to tighten track rod ends???
- Knock Knock
- 256mm drilled discs - where from?
- Astra mk2 and Daewoo Nexia... Chassis
- fog lamps
- Irmscher calibra springs, any lower?
- HELP - Where can I get a genuine front panel?
- Running a 12v pump from a battery charger?
- Help with alternator
- vectra speedo needles
- Nexen tyres
- Corsa C 1.7CDTI rear disk conversion
- 160 mph cali t clocks into corsa, how?
- nova with xe, fan not working!
- What adaptors for oil temp and pressure guages.
- C20LET lambda wire trapped and melted!
- OMP REAR Strutbrace Fitting
- Calibra Turbo Exhaust Question
- v6 brakes on astra van what mastercylinder?
- wideband o2 sensor
- labeled diagram of c20let loom? pics plz
- would a mk4 astra rear disc conv fit a corsa B ???
- Astra gsi 1993 2l 16v cutting out!!!!!!!!!!!
- which MS should i buy?
- what's wrong with my car ?!?!
- Aluminium grades?
- Lowering Astra Gsi Mk4
- Economy tech discussion
- Vauxhall Astra - Poss. ABS problem?
- Traction control and charging light issue
- Vauxhall Nova... Trouble with high beam lights!?
- HID ballast stopped working
- GSi LCD in Calibra?
- Air con Guru - vectra B CDX
- power sreering fluid change
- 308mm disc centre bore size?
- Cav Coil + Nova
- Astra convertible rear shock absorbers
- Fly by wire to cable throttle - corsa c
- FAO anyone with a calibra ecotec
- Nova turbo strengthen
- Handbrake cable catching on exhaust
- Fitted a digidash in a nova not idling? Help
- where can i get nova sills?
- Corsa B interior loom
- calibra 8v leather question
- gauges
- C20XE into MK4 Astra?
- urgent! car electricians in notts
- thread size for track rod ends
- Steering Wheel Height Adjustment Retro Fit
- Stack dash into corsa C
- phase 3.5 chips what do i need to do with the map sensor
- Taking off calibra suspension?
- XE Crank Sensor Fit NE/SEH??
- Will this ECU work?
- Does Z20LET coilpak fit into the C20LET rocker cover ?
- Excessive play on wheels
- Power steering pump - elctric rather than belt
- Help me choose new springs/dampers kit!
- immobiliser only works when key is a certain way around?
- Drums to discs conversion?
- how do you convert from mech speedo to electrical ?
- C20LET loom, what are these wires?
- ecotec to v6 wiring questions
- astra gsi ecu fault codes?please help!
- novav rev counter ... how do i wire xe into it ???
- Corsa GSi (Fault Code 35)
- Astra Rear Braided Hoses URGENT HELP
- wiring calibra turbo 160 mph dials
- Why is my car pulling to the left when accelerating?
- Traction control
- turbo timer.
- Astra M3 GSi KONI front set-up concern
- corsa b rear discs??
- MK3 Front leg???
- small car batteries?
- multiwires going to the main live on battery
- fitting a tech edge wbo2 2j1 wideband unit!
- Battery and warning light
- x14xe into nova what radiator top hose
- HELP my brakes have gone to poo, why?
- nova xe lowered 60mm but the rear sky high
- Nova Tie Bars (Esp FAO of spanish, but for anyone)
- Astra Mk3 GSi with Koni top djustables
- Mk 3 cav electric window
- mk3 let brakes
- Quick Calibra Question..
- Corsa C Anti roll bar bush replace
- no didgi dash or ignition car wont start but lights work
- vectra dash clocks etc.
- how to remove a strut??
- Meriva Dashboard rattle
- Calibra: new dash installed interferes with mpg figures???
- Nova Rear Brakes
- Frontera speedo not working?
- 308mm disc problem
- mirrows with indicators but need help with wiring
- Rear beam cavalier anti roll bar size
- Quick rack or Power hydraulic rack
- z16se & z16xe throttle compatability
- A question abot water flynch
- vaux 4 to 5 stud adaptors anyone know?
- Vauxhall Frontera Steering Box ??
- Change Steering Rack From PAS to normal ! Help
- Citroen ax tow bars
- wiring calibra engine into mk3 merit
- ecu light question
- anti-roll bar links?
- geting spare key cut, chip?
- convert my nova to 5 stud ??
- astra mk4 speedo
- 288mm V6 4 Stud Discs - Where to buy?
- throttle potentiometer problems
- mk 3 astra suspension
- XE alternator same as Eco?
- racetech mechanical guages
- Astra mk3 Convertible Lowering Springs?
- wheel bearing symptoms
- Y17DT - diagnositcs plug
- Nova XE run out of electricity!
- Xe footwell plugs
- Vectra B Rear Suspension Bushes
- Knocking from front end
- calibra turbo fuel comp??
- astra mk3 coilovers?
- Ecotec Engine Keeps Running After Switch Off
- nova 1 litre dash lights
- Electronic speedo question
- Odometer Bulb in Astra G
- Big Toubles In Little Astra
- cire colour identicfication - wing mirror switch
- Removing Injectors
- Spongy brakes with engine running?
