- Cavalier Fuel Tank Sender
- Rear Brake Bias Valve
- bilstein shocks
- LET standard spec battery?
- engine managment light need advice
- strut brace mk2/mk3 astra
- electric window problems
- Digital climate controll problems
- Brake advice Astra Gsi
- Corsa c16xe problem starting?
- astra 1.8 starter loom plug???
- corsa xe temp gauge
- 5 stud conversion - corsa
- V6 Rev counter fault
- top mount snaped.. ok to drive??
- lowering an astra vxr??please help??.
- nova steering rack- anyone had one in bits?
- Aircon leak in calibra( is there a regular point they fail)
- corsa coilovers
- GTE Digitial Dash into MK3 Astra GSI (wireing)
- Building a dash...
- Airbag wheel, Whats this? (pics)
- corsa xe conversion speedo???/
- Rear Suspension Spring Rates
- Bouncy Bouncy
- Help Please
- Search experts required
- big brake convertion
- Error codes after ECU swap..
- Lotus 'Tweaking'
- megasquirt map c20xe
- Corsa b rear brakes not bleeding, advice?
- Corsa 16V front engine mounts
- cav v6 gearbox
- Corsa B C20LET running problem!!!!!
- poly bushes
- Nut and Spring on Steering Rack
- Not sure if these spigot rings will fit??
- wot to change to convert to 5stud on corsa
- cally turbo servo and mc onto corsa b???
- key fob not working,help!!
- Steering Issues
- 4 Pot question
- vectra brake warning light on
- gmax coilovers
- Corsa B clocks question
- De cat pipe
- Frontera locking/alarm probs...
- where to buy a std astra gsi exaust from !
- c20let starting probs
- corsa c power steering pins
- insignia 4x4 system
- no reverse
- What plugs into this?
- C20XE into CORSA B help!
- digital dash in my 3 cav
- front wheel bearing help
- brake pads
- Interior clock and cigarette wiring??
- fitting rear brake bias to ABS corsa?? help please.
- Help! Relay location
- anyone know what connects to this??
- cavi rear calipers
- z20leh wiring diagram where?
- Nova anti Roll bar MK2
- vx220 style starter button in a corsa
- Nova Rear Coilovers?
- hand brake tightening
- Cavalier Gsi 4x4
- KWP2000 Simtec 70 Flashing Problem (ECU not recognised)
- O.M.P disc brakes
- how can i check which cv joint has gone
- Corsa B Horn
- HELP heater problem vec c
- c20 xe chip
- immobiliser
- C16xe In Nova
- 2 litre springs 60 mm
- speed dial problems
- Polybush/ uprated bushes for front of a corsa
- rough ride - astra mk4
- Is this a NS or OS astra mk3 electric window motor?
- Any experience of Bilstein Streetline suspension ?
- Help: How to mount the stock skirt on Astra G?
- Coilovers on Tigra
- ht leads
- MK 2 Astra gte head lights possessed?
- c20xe in a corsa-b
- Uprating alternator
- Emissions light - EGR valve?
- Water Pump For X14XE
- can i retain my deadlock function using an aftermarket alarm
- eml on in frontera when battery broke ?
- CV joint?
- vectra rear discs
- cali turbo disc size
- Oil filler for AR25 Auto box on Omega
- rear vibration on a cali
- Knocking noise when i set off
- Help with ID on ECU's for c20xe please?
- best coilover setup for corsas?
- wilwood disc/bell upgrade
- x16xe transponder maybe...
- MK3 Astra Van 5 stud Conversion
- The code of Nova Dash bulbs?
- c20let fuel rail.. in and out?
- corsa sport c20let ( burst power steering pipe) what pipe is required???
- nova master cyclinder
- ignition live wire on corsa-b
- Mk2 Astra GTE 2.0ltr 16v Redtop C20XE Drive Shaft Conversion To Fit Corsa B
- Brakes for my nova turbo
- Will this rim fit?
- Loom grommit hole size
- c20let coolant temp sender
- If your strut top mounts were fecked.......
- Which models have mechnical rear calipers?
- c20xe tps
- starter, diesel, solenoid,
- gsxr throttle position sensor on c20xe
- help please (CAM SENSOR CAMSHAFT c18xe)
- Flashing dash lights
- corsa speedo cable
- Corsa ecu light stays lit
- How do you reset the airbag light?
- Anybody used any of these coilovers?
- C20let management rebuild
- are eagle steel con rods good quality
- Independent Suspension Conversion :)
- ecu light
- Help Wanted Plz - Re-wiring
- which braided hoses?
- Hub Nuts - What size?
- brake problem?
- astra gsi electric window question
- Nova Clocks into Corsa B...Possible..?
- problem with calibra to corsa b brakes
- Dodgy Steering
- Where to buy a Hall sensor?
- wiring my C20Let loom into my 1998 Astra loom???
- Rollcage Trouble!
- Eletric window problems
- dash clocks, help needed.
- Tie Bar Bolts for Corsa C20LET?
- Aluminium top mounts
- Changing Calibra heater matrix
- Locking wheel nut torque
- switched live on c20let????
- Lowering mk3 astra van. need advise.
- fitting digital dash
- Oil low level sensor .
- C16SE Ecu Help
- ecotec ecu question
- What COULD be here?
- Oil from exhaust stud?
- Which suspension springs have i bought?!
- Astra GSi Brakes under 16" Wheels???
- V6 Brakes on a corsa B pedal travel
- Astra brake sizes
- mk3 astra clocks
- locking nut problem
- Air con compressor
- battery connected in reverse consequences?
- C20LET Fault 21, Idle 1500RPM?
- astra gte digi dash
- settings for spax rsx coilovers?
- Astra GTE digi's in mk4 astra with f23
- Clock Prob
- Removing 2 litre ATE caliper dust seals
- Are mk2 Astra GTE seats compatible with mk3 GSI?
- turn the key but nothing happens ? xe corsa
- On going astra c20let help
- Knocking Noise
- c20let to corsa gsi fuel pump wiring
- bike throttle bodies + air intake sensor
- 8v induction kit question (re:afm)
- corsa twitchy back end
- clicking wen i turn the key c20let
- 160mph clocks
- GTE 16v MOT repairs - brakes.
- How to add traction control switch to astra z20let
- Side repeater bulb resistance?
- Bilstein 40mm inserts?
- Speedling Alessio 2 problem
- New Remus Just Fitted
- 2002 corsa diesel climate control problem
- Astra MK3 Alarm FOB
- astra c20let exhaust connector???
- external wastegate spring
- Rack question (quickie)
- Help with motronic 2.8
- Avarage PSI of a BMW Mini Supercharger
- Rear Spring Rates
- speedometer - needed for MOT?
- electric windows into van mk3 astra
- Vectra 2.2 SRI cruise control?
- nova heated screen relay
- I parked it up to find the brakes had completely gone Astra MK3
- Sport Suspension
- Calibra Mechanical speedo
- car shopping: yellow tab popped out
- MK3 Astra: Interior Fan
- nova brakes problem help needed please
- old school help fitting a set of twin 40 carbs to a nova gsi engine.
- display meaning
- Electrical peeps ? (dom :D) Remote start issue
- what power steering pump on corsa deisel conversion
- 16v calipers on corsa b!! Do i need 16v carriers?
- Where could i find my fuel pump relay
- Double Master cylinder
- Heaters staying on when ignition is off
- Calibra drivers window not working
- Vectra MID incorrectly functioning
- 60mm calibra/cavalier springs?
- Help ...Are my Brakes dodgy??? Calibra!!!!
- battery light
- mk3 astra 4 stud to 5 stud converion ?
- M.O.T Question
- Wire location on astra c20let
- 5 stud hubs on Nova / Corsa
- Suspension Geometery Setup
- Corsa B Central Locking Help
- abs light?
- Corsa b rear light problem
- when should a new car have its first service
- Electrical buzzing noise, until I brake! Any ideas?....
- Where do these things go to on my c20let
- Strange thing with the brake pedal - pushes back
- Urgent help needed with corsa XE please
- brake shoes sizes?
- Astra mk3 steering rack problems (no feel whatsoever)!!!!!!!!!
- looking for a my diagnostic plug on my astra gsi
- corsa c20 let
- astra mk3 steering gator
- Calibra 4x4 brake Compansator?
- help finding cause of wheel drift/ knock!
- Equal length shaft carrier pics/diagram request
- C20LET standard ecu
- V6 bracks on corsa gsi 20xe help???
- Calibra strut top mount bushes
- Auto electricans opinions needed
- locking wheel nut?
- Fitting rear Golf brakes
- mk3 astra rear shocks
- corsa gsi to let wiring quick question
- Electric window problem
- Corsa B Goodridge Braidied lines
- Brake master cylinder
- Vectra B rear bush replacement
- Gaz coilover poundage? problem
