- C20LET switched live colour?
- Hydraulic handbrake
- engine management light
- No ignition ? plz help
- FK angel eye problems please help!
- does a saloon loom work on a hatch?
- nova quickrack
- Calibra Rear ABS Issues
- rear caliper mounting holes
- ABS (i need help)
- can someone suggest some lowering springs for my mates tdi a4 ?
- Corsa EPAS ... gen me up please?
- braking problem
- 5 stud question
- Digi dash in a nova over reading
- high spec 4 pot discs
- renualt clio
- Cavalier Problems... Get Ready for it!
- headlights!!
- helkp with part number
- xe loom
- C20let ECU's quick question
- Corsa Interior lighting
- Astra Mk3 with Cav V6 Reab and 5 stud hubs
- help needed - corsa b let wiring with epas
- Belmont Exhaust
- msd or not msd??
- help fitting blitz boost controler
- c20let wiring
- Frontera Brake Bleed Sequence.
- 160 Mph Clocks In Astra Mk3.
- Door, speakers and water...
- Vectra SRI Mileage Display problem
- Strange brake problem
- trouble starting vectra b
- No heat :(
- corsa turbo power steering
- Min Tyre Tread Depth @ Network Q - One for the late nighters!!!
- XE loom how much?
- Electric Windows in Corsa B
- brake problems
- Digi Dash Help Please!!
- key wont work
- urgent help regarding coilovers
- reverse lights
- Vectra B central locking fault
- Gaz coilover problem
- 1.0 3 cylinder cosra cuting out
- x14xe turbo kit
- Turbo brakes on corsa B
- corsa gsi speed sensor?
- Speed sensor
- Big block or small block shafts?
- Fault Codes - Please Explain
- f28 manual speedo drive into corsa b clocks
- renault scenic cooling fluid
- help please digi clocks in a td nova??
- Wilwoods and XE conversion Hub Issues
- C20LET Calibra 4x4 Please Hlep
- changing c20xe ecu !!...HELP
- feul tank question????
- brakes grooves forward or back?
- What rad ?
- corsa gsi abs removal
- 308 discs????
- v6 cally dumping its water when rad fan on
- air/fuel gauge for caliy turbo
- F25 G/box & V6 speedo query
- Any1 with a dis pack redtop engine close to north london needed for help
- Astra MK4 unserviceable light switch panel??
- Corsa GSi - does battery terminal wiring have it's own loom?
- Digi Dash Milometre Not Working Why???
- Wheel speed sensor
- Electical Problems
- Internal Fan
- MK2 Astra GTE Cab a few questions........
- mk3 astra anti roll bars
- mk3 astra sri body panels
- Odd problem with fitting of prop on calibra??
- corsa brakes
- dehandled doors
- lcd dash
- 1.4 16V
- cav irs camber. who did the how to thread? oddball?
- C20LET wiring
- key coding question
- Top Quality Classic Fusion Flat Wiper Blades
- Where is the location of the ECU in an XE Cally?
- corsa rev counter help
- Headlight wiring.
- oil pressue sender (x14xe)
- senator 3.0 24v dash light help
- torx bolts on the corsa behind the back brakes or on the hub
- astra 2.0 gsi squeaking power steering belt? help
- indicator wiring
- brakes
- Astra Steering Racks
- Nova turbo suspension setup
- Nova Dash Wiring
- Over fuelling??(i think)
- Corsa / Combo 53 plate ignition barrel .
- Vectra 2L CDX and calibra turbo disks and calipers
- RWD Rear engined nova, who's done one?
- vectra pollen filter found two disconnected plugs
- leccy windows :D
- Cally / Cav Turbo Air con fuse / relay help req
- Can i make my own wiring for nova electric window motors?
- Cavalier map light question
- nova passenger window
- experiances with "V-MAXX" suspension/coilovers
- Steaming headlight !
- what colour wires on trailer hitch do what?
- help me wire up my immobiliser plug
- diagnostic plug, were is it on my Corsa
- Voltage when car is running?
- 16v ecotec 94 cav sri fault code 24
- (c20xe) fault code 16 and 31, crankshaft sensor,
- corsa b with alessio's and avo's
- Astra mk2 stepping out to the right under heavy braking???
- off the shelf corsa c20xe exhaust?????
- LCD Digital Clocks into a Cavalier Turbo
- Nova brake upgrades
- audi TT proper quattro ?
- turbo 2 ltr 8 v
- cavalier gsi window motor and regulator
- injectors for omex 600
- 308mm Astra G Upgrade
- Vectra MFD Stalk controlling a Cavalier Trip Comp
- Alloys
- tyre sizes ?
- hello again all bloody caliy prob???
- Bleeding 4 pots
- Lowering springs life expectancy?
- Astra Mk1 Help needed!!!
- Corsa 2.0 16v strut brace
- Speedo
- calibra turbo prob???
- Vectra keys in ign door bing..
- what brakes should I fit to my corsa gsi ?
- Calibra Rear shocks worn or not?
- Headlight issue
- Braided hoses, but!
- Overheating!!
- dead zafira key fob
- New battery for Corsa GSi - which one and where from?
- Part #90 052 750 - What is it?
- Will a brake master cylinder from a 1.2 Nova carb work on 1.2i?
- Nova 1.2i dizzy plug/wire??
- How to use a Multi Meter ?
- C20LET in a Corsa - which pump?
- serious suspension bushes upgrades
- Changing remote key fob battery (Astra)
- No blower motor and hot melted fuse - mk2 astra
- Corsa/nova stub axles
- INDICATORSstopped working ,Astra GSI
- Calibra cat???
- digi dash wiring diagram needed for mk3 astra
- AEM Wideband
- changing pads on vectra v6
- Sealing petrol tank
- omega electric seat help
- diagnostic plug, were is it on my vectra?
- Can use Nova 1.4 distributor a 1.2 engine?
- Superchips !!
- Oil Volt Gauges, how do i wire them in?
- Corsa Steering knock!!
- New discs and pads fitted...pads not making proper contact with disc?!
- 5 stud brake question
- C20xe: Engine light goes on when high reving and it goes porly
- Dented my Cally's rear panel
- vectra b steering wheel
- torque steer hell
- Would i be able to...fit air con to my MK2 Astra SRi? (18SE)
- indicator problem
- calibra turbo electrics
- calibra turbo
- Vectra trip comp with C20LET?
- is this possible
- Cav turbo tapping when warm.....
- koni Suspension help
- whole wireing diagarm for a astra gte xe
- nova alternator problem (please help)!
- Air con
- Urgent Help - Heater Matrix??
- unknown brake calipers?
- mot advisories :/
- Astra Mk3 Battery and brake fluid warning lights coming on.
- shuddering throught he steering wheel.
- Air or battery impact gun?
- brakes wont come alive!
- pas rack to manual conversion ??
- yellow plug behind cav clock
- leaf spring
- Corsa B C20XE Power Steering
- what alternator
- astra coupe turbo 2001,passenger cv joint?
- Nova camber bolts, how to set it?
- Wheel Balancing Problem
- Rear bias valve plumbing ,mk3 ast
- Maplin Ultrasonic Cleaner, ok for injectors??
- Astra Coupe Turbo Fuse Box
- wiring an XE in to a Daewoo Nexia
- Wiring up a towbar - what do I need?
- nova digital dash
- apexi avcr wiring diagram - c20let
- Replacing my suspension - wish me luck!
- Nova turbo battery size?
- Fuses
- Front Door windows
- Astra gsi decat question
- corsa xev immobiliser
- Fan switch fitting in a nova?
- Astra GTE digital dashboard in corsa c20let, what coolant temp should show
- 5 stud conversion astra mk3
- Corsa B GSi - which fuse for horn+headunit?
- cav td
- Help Needed Asap Please
- Replacing Center Console Lights, Guide ?
- Ebc rear pads?
- Astra Mk3 GSi MFD into Corsa GSi
- corsa xe exhuast bore size
- internal fusebox
- Astra Gsi - v6 brakes
- V6 Cavalier - Electrical Nightmare!
- How do i de activate passenger air bag??
- alernator light glowing even though i just fitted new alternator
- How do you centre a nova steering rack?
- what noise should you get from a screamer pipe
- Extending loom
- will renault wheels fit a vauxhall
- c16xe ecu chips 13bhp+
- ABS Fault Codes 43 and 56 - Poor man's Tech 1 used
- Squeeling Brakes
- exhaust query
- No cold air in astra gsi (1993)
- Aircon goes warmer at high revs
- Nova front tie bar bushes easy???
- ABS sensors AStra mk3
- Tophat temp unit?
- Heater fan not working
- nova digi dash (one step from being done!)
- Steering Wheel
- MK4 Astra questions
- backbox/silencer
- Changing shocks and springs....
- Hot AFM
- astra mk4, speedo probs. flickers!!
- Tracking manually adjusted, steering wheel now wonky
- Cavalier Flashing Battery Light, Airbag and Engine Light, Car jerky when coasting.
