PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Bleed nipple and vauxhall main dealer
  2. '51 Reg Astra SXI - PAS Rack
  3. Rover Metro 1.1S Problems! Please help !!
  4. Girling master cylinder fittings
  5. Hydraulic handbrakes and mot's?
  6. Tightening a cavalier Handbrake Cable.
  7. digi dash speed senseing?
  8. What brake servo or master cylinder will fit a mk2 astra?
  9. alternator issues
  10. egr valve wanted corsa gsi ecotec
  11. ABS problem
  12. 16xe fuel pump relay clicking while cranking
  13. Vectra B Hid Lights as standard
  14. Xenon conversion kit
  15. ECU Code 25???
  16. 2.0 caliper brackets to allow 284mm discs
  17. Help Needed 2 seperate Problems
  18. sunroof problem
  19. No Brakes
  20. 2.2 sri astra
  21. where can i buy disks?? wilwood calipers, corsa redtop
  22. how do i check my alternator amp output using my voltmeter
  23. Check Oil Level Warning On Astra Coupe
  24. no EML light?
  25. nova strenghtening plates
  26. how do i wire the sunroof up to the fuse box?
  27. bypassing my immobiliser
  28. izuzu engine cavalier
  29. Where can i get???????
  30. Tidying up the loom
  31. epas how does it fit the corsa
  32. Removing ignition barrel, Help
  33. strange fuel reading yesterday
  34. C20XE starter and alternator wiring
  35. Air mass C20let
  36. vectra comp calibration cant find ianv6
  37. cav mk2 to xe wireing help
  38. Mk4 Astra ABS /TC warning lights.
  39. what gauge is normal car speaker wire?
  40. Anyone got the measurements of front wheel bearings?
  41. nova conversion questions...
  42. GTE lower strutbrace
  43. anyone changed there steering wheel to non vaux one?
  44. ecu light
  45. Frontera Jack and Brace Location???
  46. Corsa B big creaking noise when turning right
  47. Paint job needed!!!
  48. steering wheel horn wires... help!!!
  49. help with vectra air bag
  50. airbag steering wheel in non airbag car?
  51. diesel speed signal?
  52. vauxhall sunroof looms to switch
  53. ABS Fault Code
  54. Rounded off nut into master cylinder!!
  55. corsa gsi -60mm drop?
  56. Tigra rear springs
  57. trip computer on dti not accurate
  58. nova rear axle
  59. vectra remote central locking
  60. Stainless Exhaust systems
  61. **Help astra mk4 gsi z20let**
  62. mk3 astra c20let strut brace
  63. Where To Start Modding ?
  64. x12xe to c20xe wiring help
  65. how much for a loom for the leccy sunroof from Vaux ?
  66. astra problem
  67. LET Corsa.. Rear discs or not?
  68. Snapped handbrake cable on Astra
  69. corsa gaz coilover problems
  70. a good auto electrical place i found
  71. fitted variable wiper stalk to vectra but relay has six pins
  72. anyone good with switches....
  73. Rear brake conversion help!
  74. vectra pretensioner/harness system question
  75. Brake Pads
  76. tv/ps2 in dash, custom. need help.
  77. Wobble at full throttle?
  78. gauge wiring help
  79. 5stud conversion
  80. Dash2 Display Unit in Corsa??
  81. Eps in Corsa Let Help please!
  82. corsa speedo?
  83. fitting the trip computer + switch
  84. brake servo removal -- how?? -- mk3 astra
  85. fuel pump relay location
  86. Nova brake cylinder popping its seals
  87. how easy to change springs?
  88. power steering rack with no fluid in it, will it work?
  89. Mk3 Astra Heater blower
  90. electric windows on a cav
  91. Nova/Corsa steering racks
  92. Multi function display problem
  93. Fitting a GTE digi Dash into a Corsa B? help?
  94. XE nova stronger bottom arms.
  95. Brake servos upgrades
  96. F28 Blue Ring
  97. v6 vectra 4 pot upgrade
  98. wiring for steering wheel controls astra mk4
  99. deadlock
  100. Fuel hose clips on Mk2 Astra?
  101. No Key For Lock Wheel Nuts
  102. Wiring Vectra GSi seats in.
  103. mk4 astra aircon
  104. 97 omega elite 3.0 v6 leak problem
  105. cavalier window mechanism
  106. Dump Valve fited wrong...what happens???
  107. 1.0 corsa c20xe conversion wiring help
  108. Vectra B central locking
  109. engine managment codes
  110. Questions for those with Astra V6's
  111. MK3 Astra EPAS Setup (pics) need fluid resevoir!
  112. battery light on
  113. Where does this wire go?
  114. 4 Pots. Where and who from?
  115. diy coilovers for cavs and astra from rally design
  116. Help needed terrible understeer
  117. wiring an XE into an Ecotec astra GSI
  118. ABS and Brake Disk Warning
  119. V6 brakes need replacing. Best place to buy from?
  120. ASTRA GTE Transducer Needed for C20XE Conversion
  121. CODE 113 Boost control out of range HELP
  122. Which Vauxhall
  123. What does this handle do?
  124. nova brakes
  125. megajolt question
  126. My cars braking problems?
  127. Nova XE wheel bearings
  128. zaffy standard alarm
  129. Roll cages
  130. Mk3 Astra TD Idle
  131. fuel pump
  132. astra mk3 gsi shake
  133. vmax evo5 chips
  134. MK3 astra coilovers
  135. vacum gauge
  136. Need side on pic of MK3 astra arches (front N/S)
  137. XE astra mk2 sideshafts
  138. Indicators not working... Help!!
  139. the coilover nightmare continues...
  140. help please!!!!!!!!!!
  141. corsa semi auto easytronic probs any vauxhall peeps on here?
  142. help please
  143. Ecotec starting issues (pump working ish)
  144. gearbox linkage pin
  145. Problem! : Converting brakes to GSi (mk3 astra)
  146. corsa 3 and 5 door electric windows???
  147. Koni Suspention on Mk3 Astra - help required
  148. Corsa C wiper relay
  149. Caliper Recon.
  150. How to get speedo working?
  151. keeping engine cool
  152. Strut Top Fitting
  153. C20XE wiring in Nova - URGENT HELP REQUIRED
  154. X18XE1 Afm code. Is the ecu to blame?
  155. Caster setting?
  156. VXR Injectors....
  157. Mk5 Astra Central locking on a Mk3 Astra
  158. Any Vw mechanics on here
  159. fitting computer what controls the brake light bulb warning on vectra computer
  160. best nova suspension for about £600
  161. turreting rear suspension corsa b
  162. Digi Dash
  163. PCD 4x98, will they be ok???
  164. Car not running after connecting fan??
  165. do i need eccentric top mounts to run coilovers?
  166. "Damp" fuel tank
  167. Tool for oil change
  168. URGENT!! astra 5-stud rear hub problem
  169. Turbo vs Hatchback rear springs. Help needed
  170. urgent help with brakes
  171. What is it?? Part of redtop inlet...
  172. Eccentric ajusterball top mounts Astra gsi mk3
  173. Converting corsa b to electric power steering
  174. cav doorlock unlockin but no lockin??
  175. installation of POWERFLEX rear beam mounts on ASTRA MK3
  176. V6 Mk3 van electrical problem
  177. Removing master cylinder?? Mk3 astra
  178. Replacing Steering rack
  179. corsa c 1.2 16v -Any one had problems with all speedo/ warning lights pod failing?
  180. what throttle cable (c20xe on tbs in a nova)
  181. Help Angel Eyes
  182. dizzy cap on c20xe
  183. Airbag problem
  184. Does this work?
  185. calibra rad???
  186. Electric Power Steering MK3 Astra
  187. Mk3 Astra Battery In Boot?
  188. I have a really light corsa backend, how can i make it sit lower?
  189. Water in front lamp, help!
  190. 1.5TD into Nova 1.2 what do i need?
  191. nova topmounts
  192. Can anyone help? : Brakes on Mk3 astra
  193. electric windows .. mind of their own
  194. Warping front discs (Vectra)
  195. found this plug and a dodgy wire
  196. C20XE Rev counter and alternator belt
  197. Wilwood brakes, how did you find fitting them......
  198. indicator problems!
  199. FOGLIGHT question. URGENT
  200. gsi fogs as indicators?
  201. Nova electric window fault
  202. corsa quickrack with a LET and lsd?
  203. My omega is too low!
  204. Ingition Module
  205. Help ! Snapped Bolt !
  206. Fuel Pump Relay: part number???
  207. electrical problem
  208. Locked out of Calibra
  209. Omega axle to Senator?
  210. Manta brake upgrade...
  211. What is this? (picture)
  212. 235/60/14
  213. CaviGSI2000
  214. Weird Nova dash problem.
  215. ecu remapping in south east
  216. Cavalier top mount question
  217. Astra Dash Wiring
  218. cavturbo weight?
  219. Astra3 upper steering column bearing removal..
  220. 2ltr seh wiring
  221. power steering reseviour relocation!
  222. PTFE Tape on Wilwood calipers
  223. vectra sri 140 air con
  224. abs
  225. astra mk4 - engine stalled when headlights put on??
  226. suspension question
  227. Corsa rear disc conversion?
  228. Calibra Fuel Computer HELP NEEDED!
  229. nova let quick shift
  230. digi dash-quick question
  231. Weird Electrical Issue - EML on, Slow Wipers + Radio Cuts Out
  232. Question about Plug
  233. best brakes?
  234. C20LET switched live colour?
  235. Hydraulic handbrake
  236. engine management light
  237. No ignition ? plz help
  238. FK angel eye problems please help!
  239. does a saloon loom work on a hatch?
  240. nova quickrack
  241. Calibra Rear ABS Issues
  242. rear caliper mounting holes
  243. ABS (i need help)
  244. can someone suggest some lowering springs for my mates tdi a4 ?
  245. Corsa EPAS ... gen me up please?
  246. braking problem
  247. 5 stud question
  248. Digi dash in a nova over reading
  249. high spec 4 pot discs
  250. renualt clio
