PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Cavalier - central locking!
  2. Retro fit electric rad fan. Non vaux.
  3. Fuel Gauge not working.Newbie help needed mk3 astra
  4. Flmare kit..
  5. astra sunnroof - total closure. advice...
  6. 1998 1.2 corsa heater fan bulbs
  7. Re-drilling Brake Discs
  8. N reg Escort electric problem
  9. suspension question Can i lower my calibra 60mm?
  10. suspension again!
  11. Oil Pressure Gauge
  12. electric windows
  13. where should temp gauge sit wen driving c20let?
  14. central locking
  15. MK3 Astra: Misting up
  16. main engine earth lead location
  17. C20LET 2000rpm idling???????
  18. aftermarket steering wheel
  19. Speed Signal From Electronic Clocks?
  20. Wot size Brakes!!
  21. Key Fob
  22. Any Dashboard warning light Gen
  23. electric sunroof on a mk4 - what do i need.
  24. Brake upgrade on Tigra 1.4?!
  25. Faulty Seat-Belt....
  26. xe cts wiring?
  27. how to: ridicously clean block
  28. Tigra Mk1 - 1.4...What lowering kit?!
  29. brake fitment question
  30. Drive shaft pops on full lock?
  31. what suspension
  32. any one heard of a company called auto dials?
  33. brake lines
  34. ETC fuse??
  35. SAFE MODE?
  36. where are the heated seat looms in the vectra
  37. Does any1 know.........which fuse it is for the cigarette lighter?
  38. corsa gsi dash/heaters
  39. Wiring help for 1.0 12v to c20xe
  40. astra gsi 5 stud question
  41. vectra climate control
  42. what fuel pump to use.
  43. leccy windows for my astra mk4
  44. Uneven Rear Tyre Wear
  45. rattle
  46. testing glow plugs on a vectra dti,how long to warm up
  47. Drilling v6 discs?
  48. mark 2 astra 1.4 wiring + DIGI dash?????????
  49. quick racks for corsa Bs any ideas welcome
  50. master cylinder
  51. oil temp sender
  52. Astra LCD temp gauge reading
  53. ANOTHER bolt thats rounded
  54. vectra dti power window fault
  55. Spigot rings for V6 conversion..
  56. MK3 Astra Suspension!
  57. speedo wont work!
  58. Vectra C Door locks
  59. calibra v6 - any other calipers fit?
  60. handbrake cable
  61. Quick Aircon question
  62. Digi dash transducer wiring
  63. Lowering spring issues
  64. help with the wiring on a nova gte
  65. Nova struts springs shocks etc,will they fit a corsa?
  66. bigger brakes for let astra mk3
  67. Koni rear adjustables
  68. typical rusting points on corsa?
  69. front and rear brake pads
  70. how to get temp gauge to work in new let conversion
  71. drilled and grooved discs
  72. Setting camber with FK coilovers..
  73. C20xe Corsa B Abs Problem
  74. corsa gsi interior
  75. Calibra Suspension
  76. Zafira GSI Turbo
  77. random bit of loom
  78. nova wiring - what colour wires are what?
  79. Anyone here scrap cars in the Chesterfield area?
  80. any good wiring people out there? clocks and leci windows stopped working!
  81. Fitting PAS to Corsa B
  82. Rear brakes (astra g)
  83. gaz coilovers
  84. nova sr gauges
  85. corsa c20let strut brace
  86. springs, will these fit?
  87. whats this part called(brake thing)
  88. Cavalier MID
  89. v6 calibra - brakes still poor after rebuild? help
  90. headlights stuck on full beam....
  91. is my voltage low??????
  92. Corsa springs on an Astra
  93. Late calibra turbo hub questions
  94. C20LET into '97 Astra Sport
  95. Differnce between brakes
  96. problems, trying to fit steering wheel
  97. correct rocker cover gasket?
  98. Astra MK2 Boonet Release
  99. ECU...... How do i know if its chipped or not?
  100. mk2 astra springs on a mk3
  101. URGENT Need Help
  102. Coolant Level Sensor
  103. DIY fitting tyres
  104. Nova brake line unions
  105. C20XE Into Corsa Wiring / Immobiliser Help (With Pics)
  106. decatting
  107. Changing Corsa C Fuel Filter ?
  108. tigra ghost
  109. jamex springs
  110. coilovers for cav T. found!
  111. cally fault code 19
  112. 5.5" x 14's compomotives
  113. astra mk3 distributor
  114. Corsa XE Digital Rev counter
  115. Battery Drain?
  116. vectra b dti fault code p1125 boost pres deviation and p1502
  117. xe loom
  118. petrol pipe
  119. Engine loom for big BHP
  120. back box help
  121. Weird Fault - Vectra Steering Wheel Controls
  122. MK2 Astra GTE Front suspension
  123. How does Cav/Cali 4x4 work?
  124. power steering rack, where from?
  125. Cav electrics
  126. Corsa steering
  127. Anyone with EPC ? couple of part numbers needed, Cheers
  128. reversing light switch location
  129. what calipers are these?
  130. spark plug location???
  131. Wheres wally? (CTS)
  132. will mk3 cav springs fit my mk2
  133. 1994 Astra starter problem
  134. Nova quick rack
  135. No Spark :(
  136. exhaust/back box
  137. Flat Battery
  138. Brake question 4 astra gsi
  139. Brake upgrade on Agila?
  140. Help! - Cali Rear Subframe Swap
  141. corsa 'b' rear shock dimesions wanted please.
  142. Astra GSI Turbo Mark 4 intercooler fitting help...
  143. list what i need for v6 brake set up please!!
  144. Haywire LCD display
  145. Mk2 Astra Oil Pressure Sender Thread
  146. any difference ? cav gsi ecu or calibra ecu for xe
  147. Anti-roll bar
  148. calibra back box help
  149. cavalier redtop (gsi)
  150. vectra sri 130 dti battery light
  151. vectra sri 130 dti central locking fault
  152. vectra sri 130 dti fault with front windows
  153. calibra brake troubles - Rusted backplate !!!
  154. 4 pot rev counter to work on a v6
  155. How much lower will nova be with a 1.5td engine in it?
  156. Vectra B front Spring
  157. Fault codes
  158. coilovers
  159. Brakes Upgrade on a Tigra
  160. help-abs and trac.control light go on and off
  161. quick corsa door question
  162. can bosch 803 injectors be run with phase 3.5
  163. Help with wiring
  164. Handbrake - keeps failing MOT
  165. Track Rod Ends
  166. Astra mk3 electrical problem
  167. changing PCD
  168. *How do you use a tap & die set?*
  169. new battery for c20let
  170. CV boots leaking
  171. V-Max Chips
  172. VIN plate
  173. Suspension Bushes
  174. Vauxhall radiator fan switch for Daewoo Nexia X20XEV
  175. Swapping Omega plip info needed
  176. Mk3 Astra external temp sensor
  177. astra loom info
  178. cav redtop gsi
  179. car pulling to the left
  180. 1st and 2nd Stage on Radiator Fan
  181. Proper Procedure for Tightening Handbrake
  182. Winter Prep
  183. A/B Emissions plug, longest Q ever...?
  184. MK4 Astra Check Control Messages
  185. digi dash in corsa
  186. alternator or charging problem
  187. Astra MK4 Sport Query
  188. c20xe dizzy type not sparking
  189. CV boot clips, how to tighten them?
  190. Spring Difference.
  191. another ebay fairy tale?
  192. corsa redtop
  193. suspension kits, coilovers or not??
  194. Astra CDTI Aircon
  195. replaced discs....q's?
  196. corsa gsi fuel tank
  197. how easy is it to switch suspension (title edited)
  198. 2004 vectra pad warning light, how to turn off?
  199. Corsa B switch gear
  200. fuel pipe bust
  201. easiest way to open a corsa gsi bonnet without damaging anything?
  202. Steering Astra F
  203. Corsa Info needed asap
  204. quick question on suspension please.
  205. Signum Wiring to connect towbar
  206. Help cant bleed brakes!!
  207. coil for 1.3 on twin 40's
  208. 4 stud turbo brakes
  209. Megasquirt stand alone ecu?
  210. warped discs
  211. c20let conversion help?
  212. clocks stopped working
  213. starter location 1.5td quick replys please
  214. What does this mean "oil lack"?
  215. calibra lights motor not working?? help needed
  216. Clutch question
  217. 310mm 4pots under speedlines
  218. Dead Tigra
  219. Astra k reg CD loom into k reg LSi
  220. Anyone got a pic of rear beam bushes?
  221. steering rack bias?
  222. Earth leads ????
  223. two questions
  224. where the best place to buy good blue leds for vectra dasha and mid
  225. elecy speedo signal
  226. Headlight loom removal
  227. Where are the fuel sender wires on a 95 cav 2l?
  228. Engine management light Nova
  229. Radio not working
  230. shock top help please!!
  231. engine management light
  232. corsa c clock removal
  233. chips?
  234. cav turbo running like poo,help.
  235. Whats the size of calibra turbo rear disc (1996 n-reg)
  236. clocks stopped working
  237. body control module z18xe
  238. c20 xe conversion
  239. electric sunroof wiring help????
  240. help Photo needed
  241. immobiliser on a corsa c ?
  242. X14XE Vs C16XE differences
  243. would this work and any good.
  244. what wire is missing
  245. c20xe in 1.5td corsa
  246. calibra elec sunroof help
  247. Why are y brakes so crap and cant get a pedal.
  248. Cally Turbo Clocks into Mk3 GSI
  249. fitting climate control/consumtion digital displays??
  250. Inlet Heater matrix hose
