- Dastek Unichip Piggyback Ecu help
- Bias pedal box filling new fluid help
- corsa b front whiteline arb
- Electric Window Kit
- bypassing the brake pad were sensor
- !!!HELP!!! horn not working
- brembo caliper is ita rear or front caliper
- Astra and nova distributor
- astra convertible beeping like made hood not working boot electrics not working
- rev meter jumping in my LET calibra :)
- 270mm rear discs
- Week spark
- Zafira 1.8 comfort 2001 cooling ecu
- how to do nova tie bar mod?
- rear subframe rubber mounts
- Carbon Fiber Fuel Tank. Where?
- Corsa C speedo problems
- Corsa EPAS B & C upper section column lengths?
- Calibra turbo brake issue?
- 5 stud Mk4 GSi back beam?
- Attempted theft Corsa B please help!!
- mk3 gsi leg inserts
- Cavalier Gsi Alternator and Sri 130 the same??
- corsa 2.0xe WIRING
- Speedo Problem Calibra
- making the revs work on a digidash when fitted in to a diesel car
- C20XE Wiring HELP And Oxygen Sensor QUESTIONS!
- Steering wheel shaking at 80km/h
- 16 16V Corsa low on power
- cam sensor
- Brake disc securing bolt 'flat allen'
- cd player wiring
- Does anyone know where I can get this part?! "21462" "GM90467260" "BF"
- Calibra 308mm Brake Upgrade, double checking parts list...
- lowering mk3 astra
- Replace brake pads on 2001 Vectra 2.6 v6
- Biggest Brakes Behind Speedlines?
- corsa b gaz coilovers
- Squeak offside wheels on my Mk4 Astra G 2.0 SRI (2001) - already had brakes replaced!
- Failed mot on Handbrake (no Reading)
- How to fully disable TC?
- Vxr brakes on astra f
- Corsa b Electric Windows
- Astra MK4 Suspension Banging
- Anyone know what Oil Pressure sender i need for my 2.5 Vectra
- Astra C20NE new crank sensor & fuel solonoid still guttering, backfiring & underpowed
- Is mk1 Corsa/Tigra 1.4 driveshaft same as Astra 1.4 8v (C14SE)?
- corsa c centre section fitting ?
- Where can you buy Genuine V-Max EVO5 chips new?
- vectra c, flat battery, gone in to safe mode
- What fuel pump C25XE into DTI Astra
- vectra c and vectra b springs
- corsa 1.0 fuel pump for 1.6 16V conversion?
- ignition fault
- Easiest way to remove steering lock?
- Astravan 1.7 Turbo Diesel
- z20let water gauge install
- motorbike exhaust on tigra side exit ?
- Nova gsi
- Splitting ABS front hub
- headlight warning buzzer
- how to wire eml light? on digidash in a nova
- boss kit
- Cavalier Gsi ( early ) fault code 94.
- c20xe only sparking on 2 and 3, any ideas?
- 2000 astra G 2ltr sri cooling fans
- Turbo timer Astra Coupé
- 1.7 Diesel into Corsa - Relay socket?
- Vectra C steering prob
- P0100 Code.Vauxhall Vectra 2.0 DTI
- Mk4 Astra Tie rod end HELP
- MS2 V3.0 Build Help - Help Fellow Megasquirters !!!
- C20XE Coolant temp sender.
- Corsa b clocks
- Can i fit gte clocks to Mk4 Astra Van?
- Vivaro 1.9 Faults After Service
- Mk3 Astra GSi Lost key!
- engine light after manifold HELP
- dead guage cluster Mk4 Astra SRI
- Corsa/Tigra bottom ball joints
- Why are most electrical conectors on a car different to each other ?
- Corsa b redtop brakes help
- Side repeaters
- Indicator relay on a Corsa b
- Loads of things not working on a combo van ( corsa b shape)
- my dash clock is reading only half of the words?!?!? plz help!!
- any way of tellin z20let pump from c20let
- corsa 2.0xe
- Astra Coupe Turbo Traction Control Removal - How to?
- pcd size
- C20XE Rev counter under reading! 1.0 12V Corsa
- 1999 V Reg Vectra Getting Headlight Unit Out
- electric sunroof wiring help ASAP!!!
- calibra fuel pump wiring problem
- corsa b 1.2 16v to c20xe using sport dahboard loom NEED HELP
- Cleaning and treating CV joints, what will casue damage?
- Adjust camber
- Rough price for custom caliper brackets?
- C20let Phase 3 - Megasquirt Setup On Hall Sensor
- Corsa b arb help
- corsa b coilovers
- astra manual quick rack still avalible
- bad earth on brake lights :s
- Big brake upgrade to corsa c 1.8
- Top mounts for calibra coilovers
- Astra 1.8 coupe better brake setup suggestions
- rev counter problem - Corsa 20XE
- vectra b z16xe coil pack wiring.
- electic windows not closing
- C20let Ignition COil wiring help :)
- equal length driveshafts
- Pad recomendations for fast road use
- coil pack pinout?
- Help fitting coilovers guide
- Lowering astra van
- lowering a corsa
- calibra starting trouble
- vectra b cdx xenon headlight question
- wiring probs on my vec b saab turbo conversion
- Engine Cutting out with lights..?!
- GTE 16v Handbrake cable differences?
- mk2 gte ABS light on
- v6 speedo wireing amp question
- tell me about AEM widebands
- help please , zafira drive shaft collapsed
- Megasquirt V2 on Phase 3 C20let
- Corsa B non start
- Astra g rear disc
- C20xe (Astra Gsi) Wiring
- Vectra 2.2 SRI Battery / charging issue...
- help with blown digi dash component
- Vmaxx Coilovers - Corsa B ?
- strange mileage problem, HELP
- C20 seh ecu
- Astra GTE Brake Problems
- Vectra B ABS problem
- Wheel Problem..
- changing miles on digidash, can it be done?
- brake servo for a corsa b sport with brembo brakes
- vec b but wanting to upgrade to facelift headlights. Wiring help please.
- new ignition barrel and cant wont start!!!!!
- zafira battery cover
- Parking sensor Vectra SRI Edition 100 turbo
- Vectra y26se fan/temp sensors?
- astra mk3 aluminium steeringmounts
- Corsa b morette
- Corsa front end clunking
- calibra conversion wiring problem
- mk2 astra gte reaer axle problems and sh*te handling
- Brake master cylinder - application list
- EBC Red stuff Squeal
- digidash speedo not working
- Unusual battery question to ask
- astra coupe turbo trackion control can i turn it off
- ABS question
- 288mm calipers. Meriva discs?
- Digital Dash popping fuses & inaccurate speeds?!
- Buying new HT Leads, so looking at getting better spark plugs, advice?
- searching picture for 5x110 to 4x100 stud drill
- Another "Wheels fitting over brakes" thread
- MFD calibration
- rev counter
- Quaife ATB into a F23?
- Omega Speedo Not Working
- Astra GTE Power Steering Conversion
- fitting white line anti roll bar?
- 16pin aldl
- some numpty put jump leads on wrong way on my car
- are these coilovers any good for C20XE Nova?
- Vectra Remote Locking not working
- Corsa B Power Steering Removal
- 25 mm master brake cylinder + servo drum to Calibra V6
- eps :@
- cav mk3 electric window wiring
- corsa fuel pump
- In the middle of chipping my ECU
- astra mk3 springs on mk4
- corsa b brake lights :@
- question about seat belt/pre-tensioner astra gte
- thin black wire 1.2 loom melted help!
- astra gte battery fault
- Corsa B C20XE No Battery / Oil light on?? help!
- corsa B steering column motor
- Tigra 1.6 - ECU light on
- pic request - 20SEH on Megajolt
- Removing CV joint from driveshaft
- mk3 astra powerflex options
- help needed with rear brake problem!
- Astra mk2 GTE with Calibra turbo brakes questions
- is my car dead ????
- astra gsi trip computer wiring diagram
- 310mm brake kit
- £200 wideband kit, ALL of the wires have to be lengthened, surely that is not right?
- Astra GSi Mk3 MFD Help Please....
- Calibra turbo fuel lines
- Can SAAB 9000 brakes and/or struts...
- astra G boot solenoid
- What Front Bumper?? Mk5 Astra...
- Using calipers designed for larger discs on smaller discs
- omega wiper wont switch off??
- astra h sri 2.0t remap z20ler
- stack dash
- fitting cruise control & trip computer
- Zafira GSI Battery Draining
- Aircon removal on Z19 DTH
- corsa b brakes help plz
- C25xe sudden missfire
- t5 suite help.
- Will a mk3 astra electric window assembely fit a mk2?
- locking wheel nuts
- need auto elecrician linlithgow !!!!!!!!!!!!!!!!!!!!!
- 2001 1.6 Astra (Z16SE) thermostat question
- gsi vs 4x4,turbo & calibra
- Digital mileage not showing
- astra v6 immobilzer
- speedo help f20
- C20LET fault code 21, TPS high voltage
- Small gearbox - big hubs - driveshaft options
- c20xe loom
- Twin coil unit?
- Mk3 astra exhaust on a Mk2
- Corsa gsi 3.0l v6 exhaust bore?????
- corsa b help please
- Innovate lc-1 problems
- baileys dv26 or dv36?
- tracking being out affecting tires?
- corsa c rear calipers
- C20NE Running Engine On Floor
- changing suspension from JOM coilovers problems
- problem with late calibra turbo brakes uprated to 308mm
- SPAX RSX coilovers, anyone using or used them?
- I need help with wiring the A/C. /Astra GSi C20XE/
- xe wiring and few problems
- Vectra 1.6 driveshaft question
- what front f28 mount will i need when putting c20let and box into mk3 astra?
- what cv's (e conv corsa)
- 288mm fronts on nova. Smallest rim???
- 288mm v6 brakes keep locking up and pedal drops right down
- Meriva ABS light and Speedo not working
- Transducer/speed sensor problems PLEASE HELPP
- Mk4 Astra airbox/ cig ligher question
- Cavalier Turbo poly bushes
- Wheel bearing??
- Revisions in suspension Astra Mk2??
- c20xe oil/coolant wiring issues, help much appreciated
- Battery Relocation - What BMW wires to use?
- tc/esp help
- Vectra C Wiper Issue
- help! corsa c2.0xe brakes
- Astra G Wishbone/ Track Rod End Problem?
