- Corsa b - 288mm brake upgrade
- 99 astra heating system diagram help needed.
- 15.5v too much across battery?
- Interior lights
- correct poundage springs
- Bleeding Wilwoods
- Nova/Corsa bushes the same ??
- What speedo drive for F28 in corsa GSI?
- Electric Mirrors
- Wiper motors?
- 16v rear calipers the same as turbo?
- master cylinders
- mk3 astra gsi wiring diagram needed!
- torque settings for head bolts cav 1.8
- Corsa B heater control adjusters
- Should New Astra Estate Shocks Extend Automatically?
- Clutch release bearing - fitted wrong ??
- corsa b rev guage wiring
- C20xe - Different loom/ecu
- Width of a vectra b front track?
- **What the hell is this!**
- Saab Alloy wishbone upgrade problems???
- Lowering Suspension Help Needed
- battery light
- overheat problem
- Central locking
- clutch cable for a 95 cavalier 18 expression is the same as anything else
- zafira gsi hubs????
- corsa C20NE wiring?
- How do i check my bushes?
- calibra sonroof seal
- 53 Plate Vectra Radio in Safe Mode
- brakes
- why the wheel nuts on my 3.0l v6 callibra keep snapping as i am driving
- astra sri turbo
- Air bag wheel for non .
- knocking noise
- Rear disc conversion measurements ??
- c20xe in mk4 astra (Wiring)
- Biggest brakes under 17's??
- speedo nova2ltr
- Knocking suspension, what could it be?
- does this astra have a twin downpipe?
- RADIATOR Problems, and stuttering
- Cavalier Mk2 switches
- Mk1 astra top mount required
- Major electical fault mk4 astra poss alternator?
- X16XE wiring loom issue on xe corsa (pics)
- coilovers
- Reyland brakes - what wheels??
- My speedo is 10mph out?? (xe speedo drive)
- Corsa B Master Cylinder Upgrades?
- Corsa B Radiator fan not coming on post XE'd
- Battery light keeps coming on
- Calibra Headlight Rewiring
- Suspension
- grinding noise (nissan sorry)
- xe loom to a let loom (different)??
- wiring up a volt gauge (corsa b gsi)
- TX Autosport
- calibra fuel pump / sender unit
- Electric Power Steering connectors.
- C20let engine wiring/connections. Where?? HELP!!
- Will Mk3 Astra GSi Springs fit straight on a MK3 AstraVan?
- Astra H ESP FAULT
- advice on what type of wire to use
- Removing abs???
- Threaded bar - left & right handed threads
- Corsa c Anti Roll Bar Bushes
- Electric Power Steering...help
- Leda or bilstien coilovers?
- Omega Air con charge and pressures
- Vectra GSI 308MM carriers, part numbers?
- Wiring fog lights Corsa B
- MOT
- Fittings for 308mm Calipers
- How many bias valves ???
- Nova/Corsa wishbones interchangeable???
- Engine Management Light!
- astra mk3 poly rack bushes
- Fault codes??
- camber ???
- Steering quickener, the best solution to steer faster!
- Cruise control
- V6 Cav, Calibra or Vecta C brakes onto a mk3 AstraVan?
- astra 18.i elite 08..suspension.
- Improving the driving "feel"?
- analogue rpm needle goes everywhere...
- Wilwoods, What They Like
- Brake caliper upgrade - size help required
- astra mk3 sport
- home made leccy windows :D
- Brake fluid.........
- Cav lowering suspension.
- DTA loom - what is what, help!!
- Battery Laws ????
- Rear disc lock up but WHY is this ????
- Radiator Position 4 a corsa let...
- 20xe TPS
- headlight problems
- ecu live
- vectra td 1994 no keys .how do i bypass the alarm,(its not pinched)
- ABS Techy one!!
- Driver window not working
- mk1/mk2 astra - same steering racks??
- rear discs corsa b
- non starting astra g
- Equal Length Shafts
- Any Peugeot bods about, electric window q.
- How to find out whats draining a battery?
- quick brake question ASAP
- What you reckon on these gauges ?
- lil help replacing glass on nova
- C20XE comp oil pumps
- Fitting after market steering wheel
- c20let oxygen sender colours ????
- Strut Tops
- Help with nova SRI wiring
- Immobiliser over ride for 95 gsi ecu
- ABS sensor for 5stud conversion
- Vectra C Heater/Fan blowup!
- really wierd electrical problem mk 4 astra
- starting problem
- brake lights wont go off when main lights are on?please help
- Anyone know what bulbs are in these headlights (astra Mk4)?
- vectra rear bushes
- 2.0 hubs for swap. "-s" or "t-"
- ID of springs on nova avo coilovers?
- extra bhp for 1.8 16v
- Double the guages!
- corsa x16xe question
- pulling to the right and general wandering?
- Car hard to start after oil change???
- Gauges from calibra to cavalier
- c20xe no spark stressing out now..
- corsa b strengthening ?
- corsa rear disks
- coilover springs for nova c20let
- Need some 2002 renault clio advice - screenwash pump
- how do you adjust the aim on mk1 vectra headlights?
- Horn
- ABS pump after engine conversion
- Rear Wiper Centre Position
- astra G handbrake sticking
- 5 stud drums???
- vectra b ellectric windows not working....
- Hot start valve ??
- Removing mk3 astra wishbone
- Corsa b coilovers???
- Whats involved in lowering a Vectra C ?
- blitz turbo timer confusion :(
- Mk3 astra adjustable steering column
- Brake issue, doing my head in!!
- Bleeding Brakes
- Best way of removing stubborn bolts
- Springs , what do they fit .
- cavalier gsi
- decent suspension (Nova)
- Part number
- M.O.T blunder, please help!!!
- mk3 sport problem (warning long thread)
- Can't open Corsa C bonnet
- Help! what size thread on corsa b track rod ends
- Window Settings after new battery
- Magnex Mainifold - power steering pipes and rad
- VX220 Dials in a MK3 Astra
- engine crossmember?
- oil sensor level
- Wilwood kit for Cavalier SRI plus brake disc queery.
- astra battery light on
- lowering kit for corsa B
- astra electric windows?
- lecy window switch ?
- WHere can I get hose kits for C20XE Corsa B/C??
- paper clip test
- c20xe problem
- Mk3 Astra Deisel Estate to a 2.5 V6 Petrol
- Mk3 Astra MFD just stopped working?
- 2.0 16v corsa
- couple of things
- handbrake back plates on a calibra
- corsa sprint/ trackday car
- fault code reading
- c20xe rev problem
- vectra electric seats no worky
- Gauges
- Vectra B Intermittent Wiper Fault
- spark problem few checks
- vectra total closure
- another corsa turbo problem
- Corsa C20xe speedo drive??
- reverse lights
- Making own loom.
- xe/let airflow meter (telling the difference)
- corsa abs fault, help please Gen required.
- Corsa 1.2 lx jerky engine
- rear caliper bore size??
- Corsa 1.0 12v
- c20xe loom questions
- Lumenition ECU?
- slam panel ???
- vectra b heater blower system fault
- Rear Fog Light
- diesel to petrol wiring looms change
- replacing a corsa standard radiator?
- Big Brake conversion.
- corsa brakes
- Picture request.... heater matrix pipes c20let
- chip identificaton help.
- 2.0 8v help
- fitted adjustable fpr and pump died
- nova gsi clocks, fuel gauge and oil [ressure switch
- I have for some time had a clunk comming form the front passenger side.
- Rear Disc Conversion
- cav gsi/turbo headlamp wipers and parts fitted to another model cav
- is it worth it?
- who knows about isuzu diesel alternators
- Mk3 astra estate odd starting?
- Code 94 Hall effect swich
- battery light is on but its not the alternator! HELP
- Lowering mk4 astravan
- astra/cav springs
- Help on Resetting Dashboard
- Cavalier loweringsprings - TÜV
- Flashed out the ecu codes and am now confuzzled
- nova lights
- 2 speed rad fan on cali only working on slow speed??
- rear breaks calibra what are bigger
- C20XE Temp Gauge Fault
- vectra v6 rear bushes
- corsa b rear anti roll bar ???
- speedo on 96 vectra diesel playing up?
- fluffy steering
- vectra, flat battery now wont start
- Coincidence or not ?
- x20xev - c20xe wiring Help please!!!
- 2.0 diesel fuel pump fault
- Nova rear inner arches
- ABS Light on dash
- c20xe crank sensor
- vectra b brakes
- corsa b rear disc guide ?????
- C20XE Wires
- lotus carlton rear brake judder
- ECU codes won't flash out
- 1.7 td cavalier isuzu starter
- Code Reader
- 308mm brakes from vectra b (irmscher or vaux GSI)
- Nova wheel bolts (chrome/stainless), best place to get..
- Car won't start!!!!
