PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. c16se Wiring Diagram
  2. tubular manifold?
  3. Quick Question air/fuel mixture gauge how to FIT !!
  4. Spax RSX Setup
  5. Water Jets not working
  6. fitting remote central locking on a nova sr?
  7. 60mm drop on mk4 astra
  8. xe wiring help!!
  9. Battery/Alternator question
  10. corsa C dials into a corsa B
  11. which tyres??
  12. Problem wiring up nova back lights
  13. Starter motor relay
  14. 22 spline cv joint part number??
  15. Fuel pressure for dis xe? and which aftermarket reg?
  16. ecu types
  17. mk3 astra heater only working on speeds 3 and 4
  18. astra mk 5 dimming mirror into cav
  19. electric mirrors mk3 cav gsi
  20. swapping vectra central locking over from one car
  21. 5" rev gauge
  22. vectra brake dics
  23. Brake Flexy pipe size ??
  24. corsa coilovers
  25. tyre damage.
  26. confused about mk4 astra suspension!
  27. power steering
  28. Removing the washer bottle on a Mk4 Astra???
  29. Vectra none start?
  30. 288mm disks
  31. Calibra Redtop Heating Issues
  32. immobiliser problems
  33. eliminating spongy brakes. These any good?
  34. clutch cable, adjustable??
  35. Using xe manifold nuts instead of let ones
  36. Disable Passenger Airbag
  37. nova sr
  38. Corsa B 1.4 Sport Difficult to restart After A Stall?
  39. EGR valve on a corsa?
  40. knackered lamda sensor symptoms c20let
  41. Can i use any nuts on exhaust studs
  42. Is it hard to wire in a start button?
  43. lowering wit 18 inch alloys
  44. mounted speedo, tacho etc..pics anyone?
  45. Can you upgrade the master cylinder
  46. z20let/lel/leh wiring diagram
  47. corsa bushes
  48. does xe and let use the same exhaust?
  49. mk2/3 cavalier springs
  50. Any benifit fitting exhaust heat wrap
  51. 5 Stud Re-Drilling
  52. suspension kit MK2 Astra
  53. need help with alloys/brakes
  54. refitting mk4 astra door
  55. master cylinder, which lines go where?
  56. hit curb in tigra help
  57. Looking for dash ideas
  58. Can someone give a How To: fitting internal brake/fuel pipes please?!
  59. calibra v6 rear hubs on astra??
  60. Exhaust blow please help!!!
  61. astra conversion
  62. corsa xe strut braces
  63. Head gasket thickness
  64. Internal water temp guage thingy
  65. Vauxhall Astra MK3 N reg LOOSING BRAKE FLUID AND SPONGY BRAKE
  66. Retrofitting PAS to a Corsa V6.
  67. C16XE engine into nova SR wiring help
  68. Nova central locking can it work without the control box?
  69. Astra mk2 digi dash
  70. What bit do i need to buy
  71. Oil pressure ratings
  72. Caliper prices
  73. Gauges, boost, oil temp etc
  74. Arp rod bolt fitment, c16xe, need settings/instructions
  75. xe dispac loom wires help?
  76. starter motor
  77. V6 rev counter
  78. shaky steering
  79. High ideling
  80. lowered cavalier
  81. full wiring guide for c20xe into corsa b
  82. power steering cooler > is it needed!
  83. Electric window help needed.
  84. Astra mk3 electric windows wiring diagram
  85. HID Conversion - Astra G - "How to...."
  86. cavalier gsi
  87. nova internal pump fuel tank?
  88. 2002 Corsa brake lights not working when feed to ECU is connected?!
  89. corsa gsi PAS removal - help!
  90. FAO C20LET Experts - Loom differances!
  91. rear screen washer, corsa gsi
  92. Astra GTE VSS question...
  93. Intermitent Wipers Park Incorrectly
  94. Cav Fuel Tank sender
  95. fitting a oil pressure gauge onto my z20let
  96. corsa b starter motor
  97. nova rear discs
  98. vectra brake upgrade - what fits?
  99. Corsa C boot like a duck pond, are there any common faults?
  100. Astra GSi (F) Oil Leak :(
  101. External Temperature not working..
  102. c20let pistons
  103. Where is the xenon low beam relay?
  104. Cav master cylinder
  105. digi dash fuel level query?????
  106. sidelights on all the time!
  107. F-F-ffff-reezing!
  108. cav turbo track width
  109. Corsa b speedo stopped working
  110. Please help - Cavalier Fan N/W
  111. wanted scopion exhaust and decat pipe
  112. c20let alternator
  113. Quick question on Cav springs etc
  114. should the dash cruise control light illuminate
  115. HELP!!!!!
  116. Wiring behind heater control panel with a/c
  117. Brakes knocking
  118. Standard size of springs on a 95 Astra ??
  119. would fiat coupe turbo brakes fit?
  120. c20let fan on all the time???
  121. URGENT HELP Setting wipers on a 306
  122. corsa diesel 1.7 diesel izusu glowplug relay
  123. Recommended tyres for Corsa Turbo
  124. cav td starting problems
  125. Electrical problem help please?
  126. Fitting the PicBits Rev Counter Frequency Changer.
  127. ECU possibly dead?
  128. Fan Blades!! Pullers!!
  129. C20LET / XE Radiator Fan on cav / calibra turbo
  130. Astra MK4 wiring diagram needed
  131. quick q - fuel pump & relay wiring/volts
  132. yellowstuff pads - any good?
  133. Can anyone tell me what size head this is (let engine)
  134. Immobliser Trouble
  135. early gte digi dash question???
  136. fuel flap stuck closed on vec
  137. Astra GTE 8V Fuel Problem
  138. c20let nova running problems
  139. how to read faults on 1998 corsa?
  140. Battery earth
  141. Power steering failing! help
  142. horn not working mk3 astra?
  143. Indicators and Brake Lights not working.
  144. vectra diesel takes 4-5 secs to start in morning what operates the glow plug circuit
  145. Anyone fitted toggle switches in place of OM switches
  146. Problems with c20let dash
  147. Nova doors , whats the trick?
  148. this is for all cav gsi drivers !!
  149. Stupid!!!!
  150. Wot chip is best for C20XE
  151. cav imobaliser prob
  152. Vectra V6 CDX Anti Roll Bar Front
  153. Rear Brake conversion
  154. What is a double wishbone setup?
  155. sealant with new master cylinder?
  156. XE WIRING????
  157. Apparently I've lots to learn about taking alternators apart.
  158. Good auto electrician in sheffield?
  159. question on calibra clocks
  160. Changing a rack on a corsa
  161. vivaro outside temp
  162. calibra / cavalier speedo clocks loom help?
  163. vauxhall corsa b eps help
  164. Where to get loom size wire from ??
  165. Corsa B Redtop Strut Brace
  166. wiring
  167. which discs for 4 stud turbo calipers?
  168. mk2 golf wheel bearing, astra hubs on a corsa???
  169. Turbos and manifolds made in China?!
  170. ecotec to xe but no rev counter
  171. broken cali but how to remove loom?
  172. suspension bushes
  173. mk3 astra 1.4 brake servo with willwood 4pots
  174. 2.2 Frontera Electrical Issues No Headlights
  175. does your eml light come on if speedo is not connected?
  176. cav dash removal pics / how to plz
  177. astra mk4 dash
  178. what can cause the txb to turn off?
  179. corsa b elctric windows
  180. cav gsi 2000 head light problem
  181. Very weird noise please help
  182. Car cut out when over taking
  183. Astra / Cav Suspension Question ??
  184. Rumbling noise from running gear
  185. Wiring in my digi dash into calibra
  186. Why has my passenger side central locking died?
  187. any1 have an oil and vault gauge from a cally to hand?
  188. c20let nova power steering
  189. dodgy hot start up....
  190. rear pads moving about
  191. Brembo Calipers 308mm .... 16"
  192. colour code please
  193. Vibration
  194. can any1 colour code/ identify these wires?
  195. what master cylinder?
  196. Corsa front suspension knocking
  197. The best 'budget' track day tyre
  198. digi dash top speed reading?
  199. nova rear brakes
  200. coilovers/topmounts
  201. Movano steering wheel controls
  202. Cruise Control Clutch Switch Part Number
  203. What boost gauge?
  204. how do i put the light out help
  205. Dry cell battery
  206. Exhaust rubber hangers
  207. Buy bosch hall sensors from here
  208. Electrical experts (Dom and others)
  209. Just put a white dial cally dash back in the cav, few probs
  210. Indicator relay buzzing
  211. Vectra Ecu + Immob Prob
  212. Secondary Air pump fuse
  213. oil and volt wires, which 1s, where?
  214. help with wiring again plz
  215. Wiring pRomplem with lights
  216. quick question on abs sensors.
  217. Cav Front headlight
  218. Corsa date/clock lcd thingy in calibra?
  219. Cav Front end pannel fitting
  220. How to change front wheel bearings? Please help!
  221. Cav Gsi and Turbo suspension
  222. vectra 5stud hub v's cav T hub
  223. GSI Trip comp
  224. Clifford Eagle (first one) wiring diagram wanted
  225. Mfd Trip computer into A Mk3 astra
  226. trip computer into a MK3 Astra
  227. Oh ****.. laughter down phone from garage - how much is it gonna hurt? (Suspension)
  228. ASTRA MK4 How do i change the side light ?
  229. Disc brake direction (Help)
  230. Alarm wiring diagram
  231. Nova saloon
  232. 51 plate corsa c PAS problem
  233. does any one know where i can get
  234. water up on 20xe dizzy 1990 model
  235. can someone please check me a part on epc.
  236. ford fiesta 1994 L - heaters/blowers inop
  237. Calibra headlamp adjuster failed?
  238. Best wire to use on guages???
  239. Astra g heater control bulbs
  240. LET wiring loom??
  241. boot lid for vectra sri 2.0 (w reg)
  242. need some quick confirmation please
  243. speedo reading
  244. mk3 cav outside temp LCD not working/reading ?
  245. atrsa mk3 hubs
  246. Anyone kno what the hall sensor in dissy looks like?
  247. Vectra Panels
  248. Vectra SRI Springs...
  249. 98 vectra battery fault?
  250. Nova turreting & geometry advice
