  1. starting trouble.
  2. vibrating nova.
  3. Conversion has made wheels wider...
  4. 5 stud info Corsa B
  5. mk3 digi dash speedo pick up from abs?
  6. corsa wiring
  7. Calibra steering rack question
  8. Fiberglass or Carbon bonnet for astra gsi mk3
  9. 20SEH loom..will my corsa loom plug into it....
  10. Omega Brake pad Upgrade
  11. rear door
  12. tyres calibra which ones
  13. What springs do i need for my calibra
  14. XE Wiring Help!
  15. power flex question
  16. Astra MK3 brake pedal box
  17. relay identification - 92 nova spi
  18. battery relocation guide?
  19. what 2 wires do i join up to flash off my ecu codes
  20. 2000 vectra 2.0 sri abs&traction control light
  21. Bigger Radiator in Nova
  22. single wiper
  23. 1.7 turbo diesel vectra wont start
  24. 2002 Combo DI Lowering
  25. xe alternator
  26. Suspension experts - 4 link design help needed
  27. 2.2 vectra with lumpy idle
  28. Any gen c20let misfire at 11psi ok at 10
  29. wobbly wheel
  30. timing belt
  31. are cav/astra mk2 legs the same?
  32. where is the engine number on a 1.2 16v corsa
  33. corsa b shell
  34. Astra Coupe Ticking - Please help!!!!
  35. Mega Squirt on c20let, checklist
  36. Corsa C PAS
  37. No battery light at all on the dashboard - losing charge!
  38. hubcentric spacers any good?
  39. strutbrace redtop nova
  40. Fk coilovers
  41. Stereo locked out
  42. Want to know my gte roll bar size
  43. are turbo and v6 cav rear discs the same?
  44. steering grinding when stationary?
  45. Calibra turbo seats into MK2 astra GTE
  46. v6 instrument panel help..
  47. how to wire a rev counter into a corsa 1.7d?
  48. cav front legs onto astra mk3?
  49. Anyone on here used motasport hubs on their corsa conversion?
  50. Braking Improvements
  51. Help required with Alternator belt 1400/1600 EcoTec
  52. corsa 20xe hub problem
  53. adjusting ride height
  54. outside temp sensor
  55. c20xe 4 branch
  56. car on bike carbs
  57. c20xe fuel pump relay
  58. mapping LET
  59. nova
  60. FAO people with tb's and std brake servo
  61. Fitting a rev counter .
  62. Vectra B 2.5 Litre V6 C25XE ECU & TRANSPONDER Key Chip's
  63. Digi Dash - What have i done wrong?
  64. How to test Cav3 electric aerial
  65. 2001 Corsa 1.4 SRI Hot starting problem
  66. Scrap prices for Astra
  67. rear brakes prob
  68. equal length shaft into nova
  69. What damage have i done?
  70. fuse diagram, mk4 astra
  71. Pothole Nightmare!
  72. what wiring?
  73. Corsa b c.v joint knock
  74. corsa maxi kit prep
  75. Setting Up Zafira
  76. 2.0 Corsa (cutting heater matrix inlet / outlet hoses down)
  77. Eating Altenators
  78. problem with steering
  79. corsa b rev counter
  80. Throttle bodies + supercharger
  81. How to lift and support an Astra G?
  82. How would i make my own oil level light ??
  83. wiring on a 1.4 spi?
  84. tigra spongy brakes
  85. Fuel Pump + 12 v out
  86. Redtop Tigra radiator
  87. This mondeo master cylinder upgrade
  88. Corsa Clock display ??
  89. Corsa b tourqe settings 4 arms & beam..
  90. How tight for lower arms & bushes ??
  91. corsa plus 17" alloys?
  92. Hid And Vectra Help
  93. speedo cable
  94. Central Locking problem
  95. Vectra Help!
  96. astra h, HID question (canbus)
  97. Mk2 Astra Speedo Calibration
  98. octane rating plug
  99. are these any good?
  100. corsa fk coilovers
  101. Zafira traction control - how to turn it off???
  102. cheapest supplier of mintex pads for 256mm brakes?
  103. what are the connections on a 1.7 td starter?
  104. vectra td 1.7 not starting, not even turning!
  105. mk3 astra gsi removing abs system . what master cylinder??
  106. can anyone help with slick tyres????????
  107. Signum 3.0 V6 Diesel Management light
  108. ECU Failure - Help needed
  109. Xenon Bulb Markings
  110. how do you work out what front suspension springs you need?? :S
  111. remaps
  112. Battery losing charge quickly
  113. Astra MK2/MK3 top mounts
  114. Mk3 Astra v6 brakes
  115. strange braking problem
  116. Astra mk3 van, redtop?!
  117. Cav fuel hose
  118. will astra mk3 brakes fit on a corsa c?
  119. What master cylinder to use with a rear disc conversion
  120. Astra mk2 16v wiring diagram
  121. Brakes For Corsa
  122. Speedo cluster strange prob
  123. Tigra Drive belt tensioner
  124. Electronic connectors on standard loom
  125. do 288's fit under cav slabs?
  126. clock not working
  127. astra G springs
  128. Drivers window runners on a vectra
  129. Calibra LE shocks!
  130. Astra mk4 - how best to stabilise cornering?
  131. different crank sensors
  132. Cav hatch petrol cap release, from inside ?
  133. Coilver kit for the Astra mk3
  134. Caliper spacers - where from?
  135. Astra Mk3 Fuel Gauge Dead
  136. 1996 Tigra - Cutting out and now speedo not working - PLEASE HELP
  137. Corsa B battery Problem
  138. corsa quick rack
  139. Suitable H&R springs
  140. Cavalier central locking motor removal...how to ?
  141. fitting wiwood 4 pots
  142. Where is mk3 Cavalier outside temperature sensor?
  143. Ignition Barrel
  144. Corsa b lower arms length ??
  145. universal exhaust
  146. new corsa b shell
  147. No Brakes
  148. Calibra 4x4 ECU location (late spec)
  149. Boxing Chassis rails (common mod on Novas/Corsas) HELP!!
  150. GM Fan Sizes
  151. Bilstein B6 or ....
  152. Saab 93 Brakes
  153. Koni Adjustables
  154. 2006 Corsa clocks into a 1996 corsa b
  155. Front and Rear Side Lights No Live Feed O/S Only ??
  156. rev counter in a corsa
  157. lop sided nova
  158. Cavalier mk3 central locking
  159. Panel lamps
  160. Mk4 Astra x18xe cooling woes
  161. front calipers repair kits
  162. Astra Gsi wheel bearing size info needed!!
  163. dash lights coming on
  164. Anyone using the new Toyo Proxes px4?
  165. gte 16v rear beam on gte 8v
  166. Which Disc's
  167. How do you go about refurbing a caliper?
  168. brake disc sizes and 4 pot calipers on a nova
  169. Astra wires (C20XE)
  170. how do i change a astra 05 car key battery
  171. HELP no spark at all
  172. no spark on 2 and 3
  173. Nova Electric windows
  174. Are these any good?
  175. MOT question
  176. Cav hazard switch
  177. Nova billy shockers - very thick dampeners on rear?
  178. How do i change from rear drums 2 disks??
  179. mk2 astra strengthening kit
  180. cav/calibra relay
  181. Swapping Vectra 140mph clocks for 160mph. Info needed
  182. vectra rear hubs on mk3 astra
  183. Corsa C Wiper linkage issue
  184. Omega brake problem
  185. Vectra B Ignition Switch
  186. c20xe manifold 4/1
  187. Petrol Filler
  188. corsa c alternator problem
  189. Astra GTE electric issues.
  190. Corsa C alternator problem
  191. corsa C EPS fault
  192. dasboard lights
  193. 5 stud conversion
  194. ABS sensor
  195. e16se loom
  196. solid front discs...what car?
  197. mk3 cav battery light
  198. Advice Please - Loss of dash display, ABS light on, No PAS
  199. suspension question
  200. Vectra V6 sri Not starting help!!!!!
  201. Unmount Astra mk3 seats subframes
  202. corsa b rear disc, Does any body really know!!
  203. astra mk3 cab
  204. No speedo, tc and abs light on.
  205. heater options
  206. Dim light isnt working :(
  207. nova ball joints.
  208. astra/cav/calibra front strut question
  209. Astra dipped beam problem
  210. 05 vectra, no heat
  211. temp gauge
  212. Corsa B Ignition live on Indicator stalk??
  213. Steam cleaned engine bay now have electrical faults
  214. Vec ECU
  215. Cali rear bearings
  216. corsa b rear disc cables, 3 to choose from ????
  217. lower arms & bushes which part moves???
  218. Slim line fan fixings ??
  219. Stiff lower arms/ New bushes ???
  220. master cylinders for corsa b which one?
  221. Gmax rear shocks (corsa b) - thread type?
  222. Temperature sensor??
  223. astra g front legs all the same??
  224. corsa b steering column into chevette
  225. vauxhall vectra sri cuts out please help
  226. Corsa - Nova brake lines?
  227. New brakes for V6
  228. A question about suspension springs
  229. Calibra park brake handle
  230. heaters and steamy windows ( partly non vaux )
  231. How to pick some softer springs for my coilovers? What poundage?
  232. c20let
  233. Anyone help..wiring z20let into corsa b??...
  234. Strut Top Bearing
  235. alternator problems??
  236. 308mm discs on a corsa b ?
  237. Corsa GSI suspension
  238. c20xe tigra conversion, wires left over?
  239. will calibra turbo front coilovers fit a mk3 astra gsi?
  240. Ignition Live Corsa B
  241. Ecu Calibra Turbo
  242. Fuel pump mounting rubbers
  243. Dimmer switch and dash LED's ?
  244. Vectra B V6 - Temp Gauge Dead (advice)
  245. hi spec brakes
  246. Long shot...... Merc 190 Electrics
  247. astra mk3 big brake conversion
  248. Nova indicators
  249. Clocks/dials not working
  250. v6 or turbo calipers
