  1. traction control switch and loom
  2. traction control switch
  3. mk3 astra rear cylinder size?
  4. fuel guage not working
  5. wipers stop were they want
  6. astra gte wirring problems please help
  7. corsa b, passenger electric window
  8. i thinking on puttin a 2.0 8v cav engine in my corsa b
  9. anyone have a apexi boost controller set up correctly on an let
  10. Corsa C -35mm Eibachs on Combo C?
  11. help hid and mfd prob
  12. what wire should i use for live in harness
  13. Corsa EPAS - who has done it?
  14. EGT?
  15. wiper help
  16. small black 5-stud astra
  17. 308mm brakes with v6 calipers
  18. Wider Rear Tyres
  19. show me your intercoolers!
  20. Helppp with redtop electrics please :(
  21. Difference Between Corsa B Suspension?
  22. crimping connectors (special tool??)
  23. diferent coloured digi dashes ?
  24. what master cylinders to buy for my corsa let ?
  25. Speedo Dial Problem On A Tigra
  26. Window switches
  27. White wire on digi dash
  28. Resetting Mileage On Digi Dash
  29. jenvey management setup???
  30. Hyd, Handbrake......
  31. fitting a switch to swicth between 2wd & 4wd cav gsi 2000 4x4
  32. Nova horn upgrade, ideas?
  33. cav gsi v6 f25 electric speedo
  34. nova concentric top mount (1st fit, base position)
  35. more boost problems
  36. digi dash
  37. Intermittant speedo Mk4 astra + EML??????
  38. speed sender wire
  39. i need better brakes on my vec...HELP!
  40. Astra GSI Looms
  41. temp gauge not working
  42. calibra turbo. whats this plug for?
  43. Tigra brakes
  44. mk2 escort and just wondered has anyone got any wiring diagrams
  45. Tracking
  46. Fuel pump relay for C20XE??
  47. Vectra SRi150 Track Rods
  48. Astra suspension
  49. Mk3 astra sport with aircon cant find engine rad relays help
  50. traction control
  51. fuel pump voltage
  52. will astra digi dials work in my mk4 astra sri
  53. corsa b speedo
  54. Can't get my LET to turn over.
  55. can someone pleasse help set up my apexi boost controller
  56. How to wire in an after market rev gauge
  57. hose?????
  58. corsa c ignition wire colours
  59. can someone read my fault codes please
  60. Astra mk4 power-steerin rack removal??
  61. How low can you go?
  62. Quick Question!
  63. Battery Terminals
  64. Corsa Road Rally Suspension
  65. For those with an EPAS setup
  66. c20let crankshaft sensor
  67. URGENT; xe caliper identification
  68. Joining brake pipes.
  69. Astra Sport Loom
  70. engine conversion x25xe - immobiliser problem?
  71. 2.0 8v wiring in a corsa b
  72. 288 mm cal turbo brake discs
  73. Another astra g keyfob question
  74. c20xe ancillary hose system diagram
  75. mk1 nova clocks fitting
  76. What Thread Size Eye Bolts Do I Need To Fit A Corsa?
  77. vauxhall 2.0 calipers its a mystery to me??
  78. Quaiffe quick rack fitting
  79. Various wiring questions-XE loom.
  80. vectra b display won't turn off!
  81. Corsa C woes!
  82. corsa c20let wiring help
  83. electric mirror help
  84. cav mk3 engine light grrrr !!!
  85. do the plugs for digi dash come on other cars
  86. gearbox questions for project astra
  87. Whats needed for track cars ???
  88. 160 clocks and f28 in a corsa
  89. Bigger Brakes for a Track Corsa
  90. z20let loom in astra mk4 1.6 sxi
  91. what are these for
  92. fuel pump whine
  93. Astra mk4 power steering problem??
  94. astra gte digidash in corsa sri
  95. LET chips
  96. My new brake :) Porsche caliber with Vectra C discs
  97. Tigra on 18'' porsche?
  98. corsa b steering itself slightly???
  99. no heat from vectra
  100. Astra sport fuel pressure
  101. where can i find a let ecu wiring diagram
  102. xenon bulb... how to tell if......
  103. Astra F
  104. recomend me some coilovers please
  105. Cavalier/mk4 astra suspension????
  106. will these fit gte dash?
  107. Astra G GSI key Fob Question.
  108. Frontera radiators
  109. vecrtra sri tc fault?
  110. Central locking fault? Door won't open
  111. Will 10mm spacers be ok??
  112. rear brake disc help please
  113. apexi wiring grey wire to throttle
  114. astra mk4 brake pads
  115. Electric windows sticking
  116. calibra rear subframe bushes
  117. ecu chip
  118. C20XE manifold to Z18XE?
  119. Towbars
  120. rev counter with megasquirt managment help
  121. mid wireing on standalone managment help needed
  122. Strange electrical problem.
  123. Greddy Boost Controller
  124. mk3 astra bulkhead/stearing rack
  125. HELP with lowering my corsa!
  126. Quick help plz, Cav SRI drop link nut.
  127. astra gsi engine loom
  128. heater matrix fan relay at fault?
  129. rear turrets? basic dimensions
  130. Vauxhall Astra mk4 sunroof stopped working????
  131. HI-SPEC Brake Kits...
  132. not a vox question i know but....
  133. polly bushes
  134. corsa b immobiliser/transponder wiring problem
  135. airbag light on and horn not working
  136. Astra MK4 Coupe Turbo - What suspension?
  137. astra g clocks
  138. corsa b redtop rev guage needle jumping
  139. Corsa C speedo keeps cutting out
  140. replacing mk3 astra top mount?
  141. How to wire in an air/fuel gauge???
  142. 1994 frontera swb 2.0 immobilisor prob
  143. fk coilovers (nova and corsa b)
  144. cavalier wiring loom on corsa xe
  145. magnatec 5w30 with 1.4 corsa twinport
  146. calibra rear brakes
  147. Couple of faults with vectra b
  148. Car still not starting
  149. 5 speed getrag gearbox- speedo connection
  150. wiring in horn seperatly
  151. Rear brakes release unevenly
  152. Sticky window!
  153. MFD & wiper stalk
  154. Lotus elise stack dash to xe turbo
  155. Omega 2.0l estate brake pipes !!!!
  156. astra 2.0ltr brake disc size?
  157. how does an alternator work?
  158. Alternator in nova bay....
  159. astra g 2.0 brakes on to meriva carrier
  160. wiring from scratch heated seats
  161. astra coupe light steering no grip
  162. is this where the oil filter is located?
  163. Corsa C Backbox
  164. Acoustic panel engin ebay
  165. Solid Top Mounts - Astra Mk 3
  166. wiring help- fitting a 8v into a 16v gte
  167. Fitting Oil Breather to C20NE
  168. vectra handles on cav ????
  169. astra gte REAR LIGHTS
  170. URGENT HELP! Paper clip test Corsa B
  171. VXR brakes on a MK4 Astra G?
  172. astra g clocks
  173. astra f c20let speedo query.
  174. Resetting the "INSP" message on Corsa C?
  175. wiring central lockin on corsa b 1.2 ls
  176. limiter on a combo van
  177. Why do my wheels keep goin out of balance??
  178. Upgrading FPR on LET?
  179. need help (engine stops while steering the wheel)
  180. cav engine in a mk3 astra wiring help
  181. Rear coilover setup astra mk3
  182. c20let ignition module ?
  183. Gen me up on these bolts (GTE Ball joint)
  184. engine management light
  185. Finding best road only setup (coilovers)
  186. Powerbox Fiting Issue X14XE - Urgent!
  187. Temp gauge is not working on calibra. Any help appreciated.
  188. What engines for 20XE steel sump?
  189. 1997 Astra GSi - What Alternator?
  190. 20SEH brake vacuum hose help...
  191. wiring help needed please.
  192. The state of Britains roads the cause of Wish Wash steering?
  193. custom length clutch/throtle cables????
  194. need help (electrical)
  195. no cold air coming from vents
  196. Corsa B lowering springs
  197. Chamber setting up on a corsa
  198. brakes on mk4 astra van
  199. corsa sxi steering
  200. what lb springs for 680kg front axel weight?
  201. Vectra gsi 2.6 calipers...
  202. suspension tips and set up for 1/4 mile racing. chip and all them help please.
  203. how much should i lower and best to lower with??
  204. calibra seats in to nova
  205. bosch super 4 spark plugs
  206. changing milage on digi dash
  207. corsa b ABS
  208. air con help
  209. ZC Vectra brakes on Calibra
  210. Wheels spacers for corsa B. Where from??
  211. vectra boot lock pre/post facelift
  212. Testing the spark from a coil
  213. will calibra 2.0 struts fit a astra mk3
  214. supernovas suspension
  215. 2004 Vectra 2.2 SRI Cdti getting hard to start
  216. Turreting rear suspension: Pro's and cons
  217. polyflex wishbone bush, corsa b? which one do i get ?
  218. Cav uprated spring/standard damper question..
  219. Corsa b Knocking- wishbone bushes?
  220. mk3 astra struts spacer
  221. Roof skin on Corsa
  222. Rear polybush kit
  223. Fiat coupe brembos?
  224. Fitting angel eye headlights corsa
  225. nova elec window switches, where to get/any upgrade ideas
  226. Tow bar electric
  227. V6 Conversion - Speedo Problems
  228. astra vxr brakes on corsa b
  229. corsa front brakes
  230. ign live on a corsa-c 1.2 16v 2001?
  231. corsa c central locking wont open?
  232. Corsa B C-LET Starting problem
  233. Urgent help!!! MK3 Astra rear quarterlight
  234. Bilstein b12 nova kit?
  235. astravan suspension
  236. grinding noise when i turn right???
  237. Hydraulic handbrake
  238. astra mk3 gsi & astra mk4 1.6 Brake
  239. Fuel gauge problems
  240. Position light/tail light goes dim when brake light comes on.
  241. bonnet wont open on corsa C?
  242. URGENT, corsa b brake pipe length.
  243. Battery warning light dimming Corsa XE
  244. What's this pipe for?
  245. Tracking stress!!!
  246. ecu plug earth problem
  247. Att, people with epc
  248. what springs are lowest for cavalier?
  249. Corsa B Horn Wireing Behind Steering Wheel
  250. battery kill switch
