- c20xe air flow meter wiring 4 wire help
- how many tins of matt black to paint a mk 2 astra?
- wideband kits
- Kadett C to XE loom
- zafira ignition switch how do you remove it
- battery cable
- Is this the transponder in the key?
- Installing Brake Bias Valve on Corsa? How
- nova power steering?
- etc button?
- fuel cell/ fuel tank in boot
- Tyres, 888s v A048s?
- decat will it fit my diesel?
- turbo timer
- C20LET ECU pin data
- new cat fitted
- window not going down when opening door
- PAS Steering Rack Thread Size
- ecu on early dizzy xe?
- Corsa tie bar nut thread size?
- Any rear beam axle with discs bolt-on to Tigra/Corsa?
- ambient temp guage not working in corsa B
- Z20let baro pressure sensor
- cav gsi v6 f25 speedo
- Wanted: Someone to wire in my Gotech Pro-X ecu
- Fiat 20V Brembo on TIGRA
- Trouble finding GTE Throttle cable will others fit?
- cav, caliba 4x4
- Omega MV6 - 3.0 Calipers to Calibra V6
- replacement halogen bulbs 4 digi dash?
- Will this gasket fit c20xe sump?
- What is a switched feed?
- Please help with 2.0 Corsa wiring
- Recommend some front shockers
- rear bearing stub
- help with astra mk3 lower arms
- Did they make an cav or callibra turbo 4 stud???
- zafira gsi 52. passenger door and rear pass door and boot all have dead locked
- Help needed Astra Gsi with turbo Brakes
- front wheel bearing replacement!!!
- corsa drive shafts let
- Cutting down Nova front crossmember???
- dash dimmer question
- astra gsi drive shafts?
- Front Wheel Wobble
- rear stub for corsa b
- HELP - Tigra Boot/Roof makes painful noise when opening and closing
- Nova TD rev counter not working
- washer pump on corsa c + fuse box?
- Digi Dash
- sub frame cracked, any one else??
- rear bearing HELP
- please help wheel bearing problem
- advice
- need some one to wire my x20xev into corsa b???????
- help on choosing Spark Plugs and HT leads Early C20XE Corsa B
- need some advice
- fiesta rs 1800 seats
- wont pick up
- side mount bucket seats mot fail?
- Help with engine loom wiring (2.0 Ecotec Corsa)
- Corsa Bilstein shocks
- advice on bonnet pins...
- whitesmoke ittermittent from around the exhaust manifold
- nova heater matrix?
- Corsa TD gear linkage/stick
- Knackered bottom ball joints on corsa B
- Upgrading brakes on a corsa c
- 16 point roll cage
- rear disc conversion mk3 astra to fit Corsa B
- coilover poundage advice
- eccentric top mounts install
- wiring help
- twin carbs on vauxhall engines ...
- shock absorber question
- corsa xe speedo not working!
- fuse keeps blowing corsa c20xe?
- Bump Stops ?
- manifold
- SMALL BLOCK CAVY SHAFTS (mk3)
- c20xe running on a 1.4 fuel pump
- Radiators
- electric power steering on mk3 astra
- brake pressure regulator
- vacuum valve on side of xe inlet?
- What is the fuses and relais box in the engine bay?
- Fitting air fuel ratio gauge help
- xe ecu
- corsa let fuel pump
- astra coupe convertible hood.. NEED HELP
- steering wheel and pedals from right to left
- omega mv6 electrical prob??
- taking dash out
- eps on corsa B. different power assistance
- looking for someone to do my corsa wiring
- Exhaust. One or Two Boxes?
- whats involved in adding under piston oil cooloing on an let
- f20 into corsa
- sports cat
- fuel relay wiring mess!!!!!!!!!
- Cavalier Ignition Barrell trouble
- Op-com
- digi dash
- closed
- which dump valve for an audi 1.8t?
- transit t reg(99) bonnet release broke
- Wiring in HIDs to a calibra
- corsa rev counter
- urgent help needed, how to get driveshaft out of hub
- Can anybody help me with the golf?
- Brake line unions and m/c connections
- astra gte rear axle
- calibra rear hub bearing... how to
- How to wire in a relay?
- Is a corsa axle the same as a novas
- C20LET into Vectra B
- nova gte to xe loom connections?
- fuel pump and coil wiring
- lowering mark 4 astra 1.6 16 valve advice
- ignition live on x20xev???
- Help with multiplugs on 2.0 XEV Corsa
- need help wiring c20xe into corsa 1.0 12v
- Corsa B rose jointed tie bar brackets
- Airbag light engine sounds rough ! Advise please
- brake pad warning, mk3 astra sport
- 5 stud mk3 astra hubs?
- help! rear electric windows
- Difrence xe.let loom
- stripped out corsa
- 4/5 stud let transplant
- help ? siezed bolts on rear dampers
- switching off the eps on corsa
- Vectra 2000 obd II question
- Astra G 2.2 Fault Codes
- De-cat pipe for a mk4 astra 1.6 16v
- need help
- corsa fk coilovers
- x20xe in corsa wiring
- c20xe wiring into 1.0 12v shell help please
- help with wiring bmw seats 2 a cali "NIGHTMARE"
- cv boot question
- loud clicking from d/ side wheel when braking!!
- cavalier HELP
- What is this light for?
- Chasis plating kit - Corsa A
- Camber Compensation
- c20let m32 fitted but no speedo
- PIC REQUEST* c25xe ignition module
- Rear Disk Conversion On Mk2 Astra GTE
- What other cars are MK3 GSI calipers fitted to?
- Fan control module
- Help..Steering wheel centre position changing itself
- Nova Sx td axle
- 308mm mk4 astra GSi/Corsa VXR/Astra mk5 1.9cdti brake pad upgrade
- cavy trip computer
- Wireing Loom In Mk2 Astra GTE
- megasquirt v3 help
- ECU Question
- lowered 60 mm on the back??
- corsa b towbar mounting points
- 2.0 corsa Hub
- removing wiring loom on 92 nova
- Lowering corsa 17inch alloys by 40mm
- strut brace
- How do you space wheel out by about 25cm?
- clunky suspension
- vaux com diagnostic
- Mk3 astra polybushes
- 160 clocks in mk3 astra gsi
- Towing a dead Automatic
- Roof rattle on vectra estate
- corsa tie bars with a f28
- corsa gsi lowering help needed
- evo 8 brembos
- would this be a problem ?
- omp 10 point cage
- Haynes Wiring diagrams
- help with brake calipers
- shocking astra td
- calibra brakes onto astra
- corsa b springs
- corsa eml pin location
- Calibra undertray?
- Vectra B Dash issues
- Digi Dash NO PLUGS!!!!! for wiring.... help!!!!
- power steering help
- fan
- eps
- Corsa Motorsport Hub centre bore
- Std wires 4 aftermarket guage....
- mk3 astra strut brace
- keeping the airbag light monster at bay...
- Dreaded Rose bushes. Tool info required
- Corsa B suspension settings
- Remove Headlight Level Adjusters
- How do you remove trailing arm bushes?
- Astra mk4 power-steerin rack removal??
- trip computer in to a 1992 cavalier sri
- Corsa B C20XE What Do You Use For a Ecu Cover ?
- turbo timer positive pulse on handbrake wire
- what size vacum hose should i purchase
- wiring diagram help pls...its simple apparently lol
- PAS Fluid
- rad fan not workin
- rear eccentric bushes for calibra (powerflex)
- v6 cav gsi speedo
- track rod replacement corsa b pas 98
- Vectra Elec Windows
- Positive Fuel Pump Connector, External Pumps
- cally rear shoe adjuster wheel top or bottom??
- X25XE Calibra with immobiliser and chip from another ECU
- electronically controlled engine cooling light
- a few corsa B related questions
- Nova rear springs poundage/ DIY corner weighting....
- where can i buy the apexi avcr in line air filter
- V6 brakes probs on corsa
- battery/ignition light on all the time? HELP;]
- 106 cigrette lighter
- Vectra Condenser
- Corsa b fuel pump removal ???
- What strut bar in Corsa B with LET?
- new bolts!
- 1994 Corsa help - possibly fuses?
- mk1 nova side lights (do not turn off)
- mk4 astra fogs all the same? ie van saloon bertone coupe cabrio
- any one have an apexi avcr on their let
- Corsa 1.7D charging problem
- 2.0 conversion help and advice
- what size slimline fan 4 xe rad
- boost hoses
- digi dash oil sender wiring
- Kadett E GSi - choking
- cruise control
- Lights problem
- Vectra ABS Help!!
- No fuel Pump Or Spark c20xe ** Desperate**
- why are ny apexi avcr revs different to digital dash
- boost presure switch
- tigra wireing help
- how fixable is this??? im lacking abit on experience
- anyone got a wiring diagram for digi dash into a mk4 astra
- Nova Rear Wheel Bearing
- Vectra brakes on 4 stud calibra?
- astra mk3 sport c20let wiring help.
- speedo does not work as the f25 box does have aspeedo drive in box
- cors gsi cut out and was idling funny ?? any help thnked
- Corsa B trackrod Ends
- apexi turbo timer
- traction control switch and loom
