  1. can a standard xe fuel pump take 300 bhp
  2. Corsa rear disc brakes - how to?
  3. How to get inner tie rods off Vectra?
  4. where is fuel pump relay on a corsa b 1.2 sxi
  5. 99 Omega ign. barrel / imob questions
  6. Speedo Miles out Help
  7. What rad best replaces the cali turbo one with stock cooler
  8. 2.5 v6 chip
  9. x16xel engine fault code
  10. Corsa fuel pump fuse location?
  11. Exhaust help please
  12. are saenz shot peined con rods any good
  13. rear calipers
  14. lowered car scrubin
  15. Steering Rack
  16. LET starter motor wiring?
  17. Equal length setup mount bolt size
  18. Knocking from the rear
  19. speedo problem
  20. corsa speaker problems, is it the speaker or the wiring?
  21. Position springs back
  22. Flashing EML on Ignition
  23. Urgent help required - replacing broken window
  24. Help needed!!!
  25. corsa b dash loom wires
  26. corsa lmf rear disk convertion kit
  27. what's the front brake pad minimum thickness on Tigra?
  28. By-passing secondary air injection
  29. Mk4 Astra top mount question
  30. Nova hubs into bearings using freezer+oven?
  31. converting corsa drums to discs help
  32. Astra Coupe Turbo Squeek/Grinding Noise
  33. v6 4 stud brakes
  34. Which Alternator?
  35. astra mk2 (kadett) turbo water radiator
  36. no live
  37. Recommend me some suspension...
  38. differences between cav gsi 4x4,cav and calibra turbo rear transmission assembly?
  39. temp get to point when fan kicks in engine stalls
  40. cant get petrol in the nova
  41. fitting strut brace om mk3 astra
  42. Help - keep losing power to fuel pump vectra
  43. corsa auto
  44. airbag plug which way round ?????
  45. mk3 astra gsi suspension ?
  46. coil pack feed
  47. does apexi avcr work of the revs or speedo
  48. 2ltr hub re-think
  49. HiD kits. any good??
  50. What Suspension kit for mk3 Astra TD ?
  51. Help - Wiper Fuse Keeps Blowing
  52. how to cover up ecu
  53. problem when enginge is running
  54. steering wheel not right after xe
  55. c20let ecu codes 13 and 113
  56. Vauxhall Nova Driveshaft Bearing....
  57. c20let corsab steering rack....
  58. xe running Ford Eddis setup with blackbird boddies
  59. ECU Identity help please
  60. Fits EPS of Corsa C in a Corsa B?
  61. Central locking on Corsa b keeps unlocking
  62. mk3 astra coilovers
  63. Removing wires from instrument panel
  64. Where to get polyflex bush inner sleeves from
  65. vxr nurburgring wiring
  66. slim line fans!
  67. master cylinder
  68. REC and Fitting a Bypass relay
  69. seat belt - replace
  70. Brake Master Cylinder
  71. Wheel wobble at around 60mph...
  72. slider pin rubbers swelled
  73. astra coupe display
  74. F28 HELP
  75. LMF Total Close wiring help
  76. Sound system (Remote Wire)
  77. What Clocks
  78. nova tempature gauge
  79. 2.5 v6 disc but as a 4-stud.....
  80. Nova Electric Windows ...
  81. changing to 5 stud
  82. Calibra Dashboard
  83. 20V fiat discs
  84. why would this be off?
  85. vectra rear and front brakes. HELP!!!
  86. Astra G Power Steering Help
  87. astra mk4 1998 no spark and no fuel
  88. c25xe pipes from inlet
  89. X20XEV wiring to corsa B
  90. calibra v6 springs
  91. mk3 astra 1.6 spi front disk size?
  92. Vectra C can't start after battery removal
  93. wiring fuel pump to a switch
  94. c20xe manifold on x20xev
  95. corsa camber isue
  96. Calibrating Clocks
  97. MK4 Astra hub size?
  98. corsa b rose joints
  99. Vectra Rear Wiper
  100. Goodridge Banjo bolts's pitch/size
  101. astra gte fuel pump relay
  102. mk2 astra power steering????
  103. Nova wheel bolt dimensions?
  104. removing the valve from the aircon connector on calibra turbo
  105. air/fuel gauge
  106. no spark from ht leads
  107. Corsa XE wiring issue
  108. cav gsi v6 chip
  109. cav gsi trip computer
  110. coil went pop now car can get a spark ?
  111. Alterator Problems
  112. X16xe ecu probs
  113. mk3 astra 1.7td lowering kits ???
  114. corsa/nova steering wheel boss the same?
  115. Felicia suspension feels a bit... wooden.
  116. mk3 cav clutch cable
  117. Multi timer location?
  118. External wastegates (Tial)
  119. Crankshaft sensor?
  120. Cavalier 4 stud to 5 stud conversion
  121. wiring help
  122. Which handbrake cable for redtop nova
  123. rear disc on a corsa
  124. C16SE into Corsa - ECU problem
  125. corsa b towbar wiring
  126. corsa b master cylinder upgrade....
  127. help needed asap
  128. corsa electric clocks
  129. EM light flashing car wont start
  130. moving PAS bottle?
  131. another z20let corsa c conversion issue
  132. Central Locking Mk3 Astra GSI packed up.
  133. ICV-57 C20XE MK3 Astra GSI
  134. VXR Dash Clocks into an SRi
  135. Welding and Fabrication - Brake caliper mounts - alloy grade?
  136. combo indicator fault, poss related to corsa c?
  137. car alarm!!
  138. help what battery
  139. corsa b c20let speedo not working
  140. odessey battery pc680
  141. Temp gauge on corsa not working (wire colour)
  142. Vectra B V6 Rear knocking noise
  143. Corsa B fault code plug location
  144. Vectra SRi knock when tugging wheel
  145. vectra rear wheels
  146. Corsa b rear drum picture...
  147. astra mk3 rear electric windows
  148. window prob - urgent
  149. corsa van rear brakes
  150. astra mk2 alarm wiring?
  151. Wheel Issue
  152. wiring question
  153. cav turbo and v6 rear brake discs.
  154. i need help what gear linkage do i use for a 2.0
  155. Notchy steering on calibra
  156. tigra x20xev gear linkage
  157. Vectra B , horn on older wheel .
  158. c20let alternator
  159. xe coolant pipes
  160. Rear disc conversion?
  161. random crank senser
  162. HELP! let wiring
  163. Astra G Total Closure
  164. c20let coil ?????????
  165. Corsa B anti roll bar...
  166. x20xev starting trouble
  167. weird astra g problem
  168. cavalier td front calipers
  169. comp 4 pot brake set up on corsa b
  170. ecotec 1.6 16v 2 c20xe wiring plug problem?
  171. Help: I need some resistance readings on C20XE TPS & CTS
  172. bypass key code corsa 1.6
  173. clifford needs resetting
  174. Help Please!!!! :)
  175. corsa let wiring
  176. Knocking noise on sri vectra
  177. Corsa b brake pipe ideas...
  178. Xenon Bulbs for tigra
  179. "quick rack"
  180. Tigra Bulkhead
  181. ECU light "flicking" on with engine running
  182. corsa c traction control
  183. corsa xe problem constant fuel
  184. Astra g total closure wiring info
  185. fan probs
  186. Strut Braces....
  187. reverse swicth
  188. How much travel has your pedal got (brake)...
  189. Wireing Loom Help Please
  190. Corsa front suspension components?
  191. are 6 pot brakes an overkill
  192. Anyone with EPC ? Can you help
  193. Astra mk3 heater blower test
  194. wrench size to remove astra G brake calipers
  195. Calibra v6 caliper housings wanted
  196. fault code 15
  197. fitting 6 pots do i need a bigger master cylinder.
  198. Sunroof to non sunroof
  199. are monaro and omega body shells the same?
  200. cav gsi C/L
  201. cav and vectra 5stud front hub question
  202. rear calipers
  203. corsa b v6 caliper swop
  204. where can i get universal shock asorbers?
  205. meriva key
  206. Astra MK3 performance backbox?
  207. vectra b irmscher backbox for sale!
  208. Question regarding immobilizer for c20ne
  209. calibra v6 breaks on corsa b
  210. astra mk4 inspection light
  211. parcel shelf speakers
  212. Nova fan switch question
  213. For those people having trouble wiring up a 2.0 Ecotec (XEV) into Corsa / Tigra...
  214. CD player leads
  215. Diagnostic Wiring info X16XE
  216. Early Corsa D brakes (front)
  217. Removing a steering column?
  218. O/S indicator not working (mk2 GTE)
  219. Right supension for Astra Mk2GTE
  220. what are 4 pot calipers and how do i identify them
  221. Whats this plug?
  222. 4 pot brake help...
  223. What are these connectors? (XEV)
  224. Is this the Fuel Pump Relay?
  225. Corsa B Clock swop.
  226. slammed cav -60
  227. corsa b coilovers, spring moving!!!
  228. Help with lowering my gsi!!! Please!!!
  229. can ZF rack be overhauled?
  230. Tim Rev counter wont work with XE motronic??
  231. Anyone with EPC?
  232. Z20let map sensors
  233. speedo prob
  234. astra vxr front discs and calipers onto a mk3 astra
  235. X16XE conversion - wiring problems
  236. Camber angles?? HELP!!
  237. Fuel computer .... Controls?
  238. Corsa suspension
  239. dis pack wiring
  240. Delocking a calibra
  241. Spigot rings advice
  242. removing corsa c front bumper
  243. flat battery
  244. What car is this plug off?
  245. Astra GTE Digital clock problem! - in an Astra GTE!
  246. faulty pug 407 remote key?
  247. Vectra B Ignition Barrel
  248. Indicators not working
  249. what clocks
  250. passenger side window
