  1. Oil temperature guage?
  2. nova sport brake upgrade
  3. funny noice?
  4. wiring corsa 1.6 8v
  5. Wiring in bosch high pressure fuel pump (cavalier)
  6. Has anyone lost a wheel due to a duff wheel bearing?
  7. corsa suspension problems
  8. C25XE fuel pump relay
  9. fault code need reading :)
  10. whats this pipe for c20xe????
  11. 288mm brake conversion
  12. Astra G mk4 Coolant Guage and Fan ECU Help
  13. Astra G MFD Help
  14. Torque wrench?
  15. Vectra Sri 150 spring length
  16. C25XE fuel pump relay bypassing
  17. What fuel pump wires do I need (Corsa B)
  18. can i use a LET coil on an 8v?
  19. Wet track day tyres
  20. where is my fuel filter...
  21. dash out, switchs for heater speed??
  22. Wiring - c20let > Corsa b, no ecu light?
  23. Whats causing this....... Help!!!
  24. radiator on corsa conversion wont fit
  25. Fault code - emission light flashing
  26. no temp reading on trip computer ?
  27. Power Steering 20XE
  28. GSI rear bumper fitting
  29. Halo lights
  30. brake light fault...
  31. fan???
  32. Nova exhaust
  33. I Want a Nice Sounding Exhaust
  34. mk4 astra hubs fit a corsa b?
  35. C20xe Wiring problem
  36. dump valve problem?
  37. Calibra feeling abit floaty and skittish?
  38. Supersport Coilovers - Mk3 Astra
  39. X20XEV wiring issues...
  40. Fan on ......spanner light on
  41. Any recommendations? cleaning servicing?
  42. steering
  43. vectra banging over bumps
  44. Corsa GAZ rear shocks....
  45. Corsa MC Brake line help
  46. astra 'g' slimline fan.........
  47. nova electrical fault
  48. fuel pressure check needed at billing any one help
  49. standard boost on a z20let
  50. C20let boost cut
  51. x20xev wiring diagram
  52. got a little problem
  53. Astra van lowering
  54. rattle in the back end
  55. 1.0 12v corsa b wont crank over
  56. Which transducer for digi dash?
  57. Omega brakes for xe corsa
  58. traction/launch control
  59. MK4 Astra 1.7 TD problems.
  60. decoding
  61. Car alarm fitting and door poppers !!
  62. Suspension for corsa are the same of a tigra?
  63. Dashboard lights flick on and off and front fogs not working!!
  64. Brake Judder
  65. Corsa Sport strut brace help
  66. vectra front 5 stud hubs on astra mk3 ?
  67. corsa 20xe hub problem
  68. Testing lambda 1 wire?
  69. Crankshaft sensors?
  70. vectra b 2.0 sri cigarette lighter
  71. Fitting switch to open the boot.
  72. calibra ecu in mk2 astra
  73. Washer Jets Not Working
  74. Fuel pump issues!!!!
  75. Bulb Failure Check Control Unit
  76. i dont want to get rid of my back box but want it less noisey
  77. DIY coilovers
  78. c25xe wiring help needed
  79. sealing powersteering leak.
  80. Fault code 24 help
  81. Help with car not starting please.... :)
  82. Air Con along with C20XE / C20LET in Corsa B?
  83. astra rear discs?
  84. Saab inner cv's???
  85. ecu problem
  86. zaffy A suspension
  87. Cavalier Brakes
  88. Fitting Top Nut On Spax
  89. service z20let
  90. Euroquip Brake Line Help
  91. Ecu in limp mode??
  92. anyone any know how on vehicle winch electrics?
  93. Vectra 2.2 150 SRI Immobiliser Problems
  94. M-TEC Driveshafts
  95. wheel bearings on a 5 stud
  96. NO SPARK on C20XE H&H ignition setup!!
  97. im confused, bkr6ek = fr9ix?
  98. vectra sensors HELP!
  99. mk2 astra gte radiator
  100. mk 2 astra master cylinder help
  101. my cars holding back
  102. 17s on a corsa b
  103. astra mk2 front shocks how to.....
  104. Push Start Switch
  105. Weird Starting problem on Corsa B C-LET
  106. Vectra GSi Traction Control Light On
  107. Camber adjustment on a Nova with coilovers
  108. Corsa C camber adjustment on back wheels.
  109. power steering to non power steering?
  110. Knocking noise on hard cornors...
  111. help with paperclip test
  112. price of rear axel
  113. Heated seats dont work!
  114. My sun Roof is stuck!
  115. cavalier 1.8 instrument cluster replacement
  116. C20let spluttering on boost
  117. combo cdti brakes onto corsa b
  118. ecu's
  119. Replacing shocks
  120. Nova Coilovers
  121. astra mk3 back box....
  122. Stainless steel bolts
  123. Perfomance Spark Plugs for Redtops
  124. Can I put 270mm discs on my 4 stud to replace 260mm discs
  125. HELP key fob problem
  126. BC lamp
  127. A/C fan - suction or blowing?
  128. alot of resistance
  129. Vectra Suspension
  130. indicators on permanently ???
  131. Mk3 astra 5 stud
  132. how do you test a fan switch?
  133. Anyone with a sri130 engine??
  134. how low can i go?
  135. no voltage goin to side light! any ideas??
  136. engine management light won't go out what could it be??
  137. Mk5 Astra Abs Sensor
  138. Mk3 Astra GSi Handbrake cable & bracket
  139. c25xe chip advice
  140. Corsa Wiring please look!
  141. 2 litre brakes not working
  142. c25xe loom to 1.8 astra gsi
  143. x18xe wiring loom help required
  144. Car wouldnt start what could be ?
  145. fitting electric windows to my corsa
  146. changing a corsa b to 5 stud
  147. 1.2sxi lowering spring onto a diesel?
  148. Brake pad change on Tigra - Help needed
  149. OMP strut brace for Calibra Turbo
  150. Lowering/Bias valve. Help PLEASE!
  151. Corsa B steering knuckles
  152. Do I need to weld it?!
  153. braided fuel lines smelly
  154. Fan Switch
  155. Speedo not working
  156. Impossible to find electrical/oil pressure fault
  157. Let wiring loom.
  158. anyone have an email for arno at eds motorsport germany
  159. FPR fuel pump relays
  160. my van wont start
  161. Changing the rear bumper
  162. Fuel pumps?????
  163. Corsa B Horn not working
  164. Whats the deal with changing the aircon compressor on cali
  165. corsa b handling probs
  166. can i buy an uprated coil
  167. brakes
  168. Hall effect switch cde 93
  169. fan issues, will not active?
  170. vectra sri cdti brakes
  171. temp gauge reading wrong in a 20seh conversion
  172. car not starting
  173. mk4 convertable front windows not working???
  174. whiteline arbs
  175. apexi avcr how do i check my solenoid valve is working
  176. Tow bar for a mk3 astra
  177. c20let hall effect sensor
  178. Secondary Air injection Pump?
  179. I was undoing the positive terminal on the battery and I managed to hit the car
  180. have somebody placement a/c in nova?
  181. 5 studding corsa c
  182. corsa c 308mm brake conversion
  183. Electrical Wiring diagram
  184. Brake Probs :(
  185. urgent help needed with fuel pump
  186. Master cylinder question
  187. swirl pots for fuel
  188. BumpStop
  189. Anyone running Alloy Rack Mounts on a Nova?
  190. colours of wires of c20let 1st gear switch
  191. Fuel pump to twin relay conversion
  192. central locking fault zafira 2L DTI 2001
  193. Wiring Amps into car
  194. misfiring!!!!!!!!!!
  195. MK4 Astra alarm after flat battery
  196. corsa c20let missing on boost
  197. Engine Loom Wires Spare After Conversion?
  198. c20xe starting loom problem, earth?
  199. Zafira Wiring Diagram
  200. can i use a phase 4 ecu to run phase 3.5 spec
  201. Converting a 2.0 Calibra to 5 stud?
  202. tapping out for a m12 bolt
  203. help! let immobiliser problem
  204. Best spark leads?
  205. Veccy B - Keyfob not working.
  206. What Brake Pads for Track use on 288mm V6 Brakes
  207. ABS System Removal
  208. Mk3 Astra Van Lowering!
  209. EML and starting issue
  210. cav x20xev crank sensor help
  211. indicaters stopped working
  212. vibration on braking
  213. Bleeding Willwoods
  214. confirm these spring b4 i buy....
  215. Astra VXR aux/ I pod connector issue HELP please!
  216. Tigra - rear wheel bearing play - how much is ok?
  217. Mk3 astra Steering Noise?
  218. Astra GSi Mk3 Front anti roll bars
  219. help needed to wire up temp sensor
  220. Astra G Wiring Diagrams Please
  221. Zafira GSI Towbars
  222. are evo 5 chips reliable
  223. central locking fault zafira 2lt dti comfort
  224. wideband afr gauge
  225. corsa xe type two mounts
  226. clunking sound???
  227. Wires in Electric Power Steering
  228. cav v6 volt and oil guage???
  229. cav mk3 stereo wire colours?
  230. Will This ECU Work ?
  231. Please help witch spark leads????????????????????
  232. Part number requried for Astra Mk3 GSI front bumper part
  233. Testers wanted for new ABS Amplifier product I'm selling
  234. crankshaft sensor
  235. What Brake Pads For Willwood 4Pots?
  236. Astra gte ignition switch renewal
  237. how to tune ride height and wieght distribution AVO coilovers
  238. Removing pins from electric plugs
  239. Is it possible
  240. v6 rev counter
  241. Fault between relay and fuse box?
  242. corsa b instrument panel
  243. Info on lowering a mk3 van...
  244. Veccy B - Electric door pins???
  245. new alarm fob?
  246. 5 stud conversion on mk3 astra gsi
  247. tyre wearing on inside nova
  248. new ebay rev counter ....
  249. Now this is a proper charge temp reader
  250. Gsi Corsa C20xe ABS issue
