- Astra mk2 and Daewoo Nexia... Chassis
- fog lamps
- Irmscher calibra springs, any lower?
- HELP - Where can I get a genuine front panel?
- Running a 12v pump from a battery charger?
- Help with alternator
- vectra speedo needles
- Nexen tyres
- Corsa C 1.7CDTI rear disk conversion
- 160 mph cali t clocks into corsa, how?
- nova with xe, fan not working!
- What adaptors for oil temp and pressure guages.
- C20LET lambda wire trapped and melted!
- OMP REAR Strutbrace Fitting
- Calibra Turbo Exhaust Question
- v6 brakes on astra van what mastercylinder?
- wideband o2 sensor
- labeled diagram of c20let loom? pics plz
- would a mk4 astra rear disc conv fit a corsa B ???
- Astra gsi 1993 2l 16v cutting out!!!!!!!!!!!
- which MS should i buy?
- what's wrong with my car ?!?!
- Aluminium grades?
- Lowering Astra Gsi Mk4
- Economy tech discussion
- Vauxhall Astra - Poss. ABS problem?
- Traction control and charging light issue
- Vauxhall Nova... Trouble with high beam lights!?
- HID ballast stopped working
- GSi LCD in Calibra?
- Air con Guru - vectra B CDX
- power sreering fluid change
- 308mm disc centre bore size?
- Cav Coil + Nova
- Astra convertible rear shock absorbers
- Fly by wire to cable throttle - corsa c
- FAO anyone with a calibra ecotec
- Nova turbo strengthen
- Handbrake cable catching on exhaust
- Fitted a digidash in a nova not idling? Help
- where can i get nova sills?
- Corsa B interior loom
- calibra 8v leather question
- gauges
- C20XE into MK4 Astra?
- urgent! car electricians in notts
- thread size for track rod ends
- Steering Wheel Height Adjustment Retro Fit
- Stack dash into corsa C
- phase 3.5 chips what do i need to do with the map sensor
- Taking off calibra suspension?
- XE Crank Sensor Fit NE/SEH??
- Will this ECU work?
- Does Z20LET coilpak fit into the C20LET rocker cover ?
- Excessive play on wheels
- Power steering pump - elctric rather than belt
- Help me choose new springs/dampers kit!
- immobiliser only works when key is a certain way around?
- Drums to discs conversion?
- how do you convert from mech speedo to electrical ?
- C20LET loom, what are these wires?
- ecotec to v6 wiring questions
- astra gsi ecu fault codes?please help!
- novav rev counter ... how do i wire xe into it ???
- Corsa GSi (Fault Code 35)
- Astra Rear Braided Hoses URGENT HELP
- wiring calibra turbo 160 mph dials
- Why is my car pulling to the left when accelerating?
- Traction control
- turbo timer.
- Astra M3 GSi KONI front set-up concern
- corsa b rear discs??
- MK3 Front leg???
- small car batteries?
- multiwires going to the main live on battery
- fitting a tech edge wbo2 2j1 wideband unit!
- Battery and warning light
- x14xe into nova what radiator top hose
- HELP my brakes have gone to poo, why?
- nova xe lowered 60mm but the rear sky high
- Nova Tie Bars (Esp FAO of spanish, but for anyone)
- Astra Mk3 GSi with Koni top djustables
- Mk 3 cav electric window
- mk3 let brakes
- Quick Calibra Question..
- Corsa C Anti roll bar bush replace
- no didgi dash or ignition car wont start but lights work
- vectra dash clocks etc.
- how to remove a strut??
- Meriva Dashboard rattle
- Calibra: new dash installed interferes with mpg figures???
- Nova Rear Brakes
- Frontera speedo not working?
- 308mm disc problem
- mirrows with indicators but need help with wiring
- Rear beam cavalier anti roll bar size
- Quick rack or Power hydraulic rack
- z16se & z16xe throttle compatability
- A question abot water flynch
- vaux 4 to 5 stud adaptors anyone know?
- Vauxhall Frontera Steering Box ??
- Change Steering Rack From PAS to normal ! Help
- Citroen ax tow bars
- wiring calibra engine into mk3 merit
- ecu light question
- anti-roll bar links?
- geting spare key cut, chip?
- convert my nova to 5 stud ??
- astra mk4 speedo
- 288mm V6 4 Stud Discs - Where to buy?
- throttle potentiometer problems
- mk 3 astra suspension
- XE alternator same as Eco?
- racetech mechanical guages
- Astra mk3 Convertible Lowering Springs?
- wheel bearing symptoms
- Y17DT - diagnositcs plug
- Nova XE run out of electricity!
- Xe footwell plugs
- Vectra B Rear Suspension Bushes
- Knocking from front end
- calibra turbo fuel comp??
- astra mk3 coilovers?
- Ecotec Engine Keeps Running After Switch Off
- nova 1 litre dash lights
- Electronic speedo question
- Odometer Bulb in Astra G
- Big Toubles In Little Astra
- cire colour identicfication - wing mirror switch
- Removing Injectors
- Spongy brakes with engine running?
- Wiring Up Electrics On Corsa Doors!!
- Vectra Sri-ABS light comes on with fuel light !
- rear disc conversion
- simple wiring diagram required
- Lowering springs
- how do i refit nova windows... ?
- Braid hoses Corsa B
- corsa b handbrake cable? with rear discs
- Astra mk2 GTE 16V Springs
- Cruise Control stopped working 04 Vectra SRi
- Alloy radiators...
- Lowering Astra GSi (91) Problems..
- ATE Calipers
- astra coupe 2.2 airbox
- Boost gauge T+Ecu line
- omex problems
- corsa b hub
- Corsa Rear Coils
- Calibra boot lock problems
- Celica Clutch Problems
- powersteering hydraulic hoses for vectra
- Parrot Handsfree Car Kit
- battery in boot
- hydraulic handbrake and MOT
- corsa 1.4 sport on W or V plate two questions
- Fuel pump relay astra c20let
- XE Wiring HELP so close
- Cavalier Braking Troubles
- Useful tip for all diy mechanics
- Whats easiest way to measure the voltage on my pump
- cavalier 1.7 td saloon swap into cav gsi running gear ?
- 1.8 Sport MK3 Astra pads. Same as GSi?
- Strange metaly knock coming from front passengers side?!
- vacume pipes
- Vectra B Inner Door Hinge Split
- Help please mk3 astra van
- will 308's fit under turbo rims?
- Brake options
- Corsa B speedo not working!!!! where to start????
- second air intake
- what XEs had no lambda and used the 3 little plugs near the ecu?
- will 284s fit under a 15inch wheel?
- XE Nova starting issues
- apexi turbo timer into corsa c20let
- Electrical gremlins (nova)
- 99 to 2001 dti wiring changes
- C20XE wiring help required please
- Vauxhall dual fuel systems, anyone owned one?
- changing discs without changing the pads...
- hubs
- mk3 astra suspension?
- the difference between Tigta X16XE & Tigra X14XE
- astra g + z20let - abs = ?
- replacement wilwood discs?
- 1.8 brakes.
- Changing hubs and beam etc
- Golf rear discs on Corsa
- Astra GTE 16V What Coil Over Suspension kits are avaliable in the Uk for these Cars?
- Where do you get your AFM from? (C20LET)
- Vectra Rear Light Unit
- standard sard regulator is it ok for a turbo
- where is the sard regulator adjusted from
- 8 Speed Intermittent Wipers Problem
- octane plugs
- coilovers?
- c20let corsa fault code 15 cts hight voltage?
- ARE cav & cali handbrake mechs the same?
- What features will an Astravan merit have?
- corsa b 1.4 exhaust
- need astra mk3 gsi engine wirring loom with traction control
- Mk4 Astra Strut Mounts
- ecu light flickering on corsa c20xe
- Coolant Warning Light (2001 Astra 1.6)
- I have astra gsi c18xe and lack power
- lower arms and tiebars wont line up ??
- Mk2 Astra GTE, Strange Problem
- diagnostic plug on c20let corsa
- Diffrent size springs?
- Carlton panels
- Calibra turbo 4x4 light on
- Corsa xe, air con fan ok?
- Is this wire meant to get so hot??
- Fan coming on far too early??
- dash lights stopin on when ignation off
- Engine mounts//kits/advice please
- immobiliser chip
- vectra 2.5v6 ecu tuning
- Changing the springs on P reg Vectra
- Calibra rusty rear arch repair methods?
- Lowering Astra F GSi - Need Advice..
- Help with handbrake cable
- Master cylinder upgrade
- who can remap a 2.0dti vec to run 2.2 varyflow turbo
- Robbing parts from a higher model.
- Corsa Aircon Not working.
- battery removal
- Battery going flat on astra mk4 c20let
- Error codes Help!!!
- need help elec on morrettes
- Corsa drum bleeding
- c20let electric speedo
- How much does a gearbox weigh (f18)
- Cavalier Turbo Timer and Alarm help...
- factory front & rear parking sensors HELP
- fuel pump relay
- Will Corsa B front struts fit a Nova ?
- part number check
- Zafira 1.8 16v 1999
- What is this relay thing????
- Caliper piston size question
- anyone know the headlamp aim height for uk mot?
- 2ltr servo onto nova? will it help?
- Where does this bolt up to????
- Difference in mk3 astra gsi and std srpings?
- HID Problems
- Why is it so hard to get an astra mk3 low at the front
- V6 GTE - Will cavalier/cally springs fit?
- Cav central locking failure
