  1. corsa c brake upgrade
  2. coilovers hitting tyres
  3. c16xe Fault Codes
  4. braided hose sizes?
  5. 308mil for cav t
  6. c20let phase 2 what should the boost psi be ?????????
  7. Corsa b brake discs
  8. new bushes for my cav turbo
  9. Diggy dash problem
  10. Both elec mirrors will only go right?
  11. No interior lights working / door / visor / int
  12. Mk3 astra adjustable steering column
  13. Strutbrace in a 2.5 v6 astra?
  14. no spark from my xe
  15. BOSS KIT !
  16. Fitting a tow bar to my astra gsi?
  17. Vectra abs fault code download?
  18. no pwer to fuel pump
  19. Corsa ABS
  20. servo and master cylinder problem
  21. sqeeling front brake ( cant find cause!!!)
  22. pierburg carb 2E3
  23. C16xe Lambda Sensor Wiring
  24. Moderators please delete
  25. master cylinder problems???
  26. Wiring Short Leads to Boost Problem
  27. a few gsi questions
  28. MK4 astra HID conversion?
  29. corsa b 12v speedo not working
  30. heating system mk2 astra GTE
  31. corsa c z20let wiring diagram
  32. c20let wiring need help please
  33. chip, ecu & transponder.... does the transponder need matching up or not?
  34. help needed altenator on zafira
  35. Car Loom Connectors - Suppliers?
  36. wobble on accelaration
  37. engine management light
  38. astra gsi
  39. changing ignition barrel
  40. is the panel filter worth upgrading? which is best?
  41. gsi wires
  42. Corsa C EPAS in a Corsa B
  43. X20XEV into Corsa B engine bay wiring - Spare Connectors!!!
  44. Corsa B ignition
  45. redtop coil
  46. corsa b epas wiring help please.
  47. any 1 up on zlet engines, or even clet?
  48. Vectra GSi/V6 Suspension
  49. Omega auto dim mirror to Astra G connection
  50. corsa spax rsx
  51. mk3 astra rear calipers
  52. mk3 astra rear calipers
  53. corsa turbo best poundage springs?
  54. astra gsi
  55. c20xe distributor cap
  56. IMMOBILIZER help?? redtop to 1.8LSi
  57. Bash on front has killed the car ( imobilzer issue) i think
  58. Best coilover kit for corsa b
  59. What size are these screw heads? (astra G front Hub)
  60. Corsa GSI fog light wiring
  61. Astra G headlight problem, fuse?
  62. Best suspension setup - corsa b
  63. back box gasket
  64. f28 with v6 clocks.
  65. c20let ecu
  66. removing the abs on my corsa gsi will it pass an MOT?????
  67. which corsa had EPAS ????????
  68. seh coil
  69. What is this
  70. saab 900 wireing diagram
  71. Mk4 Astra GSI Air Bag Light
  72. Carbon Fibre Heated Seat Kit from LMF
  73. What are the negatives of a bigger front sway bar on a fwd car?
  74. Mk4 Astra bootlid.
  75. Is this a cavalier backbox?
  76. Will these Corsa B coilovers fit a Nova?
  77. apexi s-afc 2 wiring
  78. Astra dash lights
  79. Vectra B Oxygen sensor
  80. nova coil help!
  81. astra gsi mounts
  82. 1999 Astra 1.8 (X18XE1) diagnostics (Pin 7) trace colour
  83. avc-r
  84. HID Question
  85. Coilover Touble
  86. Fan belt
  87. Can a bush from the bottom of a rear shock be replaced??
  88. Need bit of help, wired a MK3 astra Trip comp into my Cav turbo but not working right
  89. Helpp plzz
  90. can anyone help me find the 9 pin plug
  91. Help, Starter motor going crazy
  92. annoying sqeeking from d/s wheel returned
  93. front exit Exhaust c20let? pros & cons
  94. Help needed on redtop wiring harnesses !! Please read
  95. vectra gsi BIG BRAKES?
  96. MK4 Dials Question
  97. handbrake switch and invertor feeds
  98. v6 cav oil light on
  99. which brakes to use
  100. Aircon on all the time
  101. quick cooling system question on red top
  102. Enhanced steering pump in Cavalier Mk3
  103. corsa brake conversion
  104. Quick starter question
  105. removing the abs
  106. lowering an astra h sri
  107. No door electrics
  108. Corsa starts and dies
  109. vectra 5 stud hubs on astra mk3
  110. Bypassing factory alarm/immobiliser
  111. F28 & Electric Clocks
  112. Vectra immobiliser
  113. plastic or metal fuel tank ?
  114. Battery light is on the dash, but alt/batt are ok
  115. converting cav gsi2000 to rwd
  116. Colour codes for Nova GTE dials PLEASE
  117. corsa turbo weight
  118. c20let ecu with immo
  119. What coilovers for C20let nova
  120. MK4 Astra Van 5 Stud Conversion Help
  121. Help MK4 Astra GSi Turbo Replica radiotor fan on constantly :S
  122. Wiring help Astra GTE 16V - lighting switches
  123. 4 pot brake info needed
  124. can i get uprated shocks for my mk3 van...
  125. 95 SRI 16V backbox
  126. Xe ecu loom.. Whats this lol?
  127. 2.0l 16v ecotec timeing setting
  128. mk3 astra gsi bushes
  129. 5 stud conversion (help) ?
  130. Corsa sport 1.6. Electrical problem !!! :(
  131. 308mm Discs Fit?
  132. on board computer trip
  133. Vectra B 1997 Immobiliser
  134. cavalier gsi central locking problem??
  135. switched live
  136. cav sri 16v redtop brakes
  137. diy tracking corsa b
  138. Bad horn wiring!
  139. EML comes on, only when the car moves
  140. mk 3 astra mfd
  141. Changing a Vectra front window driving me mad! Any advice?
  142. 2 problems - brakes & headlights
  143. Trolley jack rubber protector ? Anyone fancy a group buy ?
  144. could my rear axel be bent
  145. powercap wont fit between brake fluid lines and engine (pics)
  146. corsa b electric window wiring
  147. Another EPAS Question!
  148. Astra mk2-3 strut braces
  149. Help with brake part numbers?
  150. Helper springs
  151. Astra F GSI / GT Pas system 3 turns lock to lock.
  152. engine mount ?
  153. Water coming under my Astra GTE carpet
  154. New discs warped?
  155. stereo fuse blown and need help
  156. Hydraulic handbrake
  157. Brakes to fit under GTE wheels
  158. Corsa c rear hub nut
  159. f16 in to a f20 case
  160. v6 models brake disks Diameter & Thickness ?
  161. Nova Shocks
  162. nova rear arb... suggestions
  163. help needed on 5 stud conversion
  164. Need some help about rear Shocks !
  165. Unsprung mass/sprung mass and big brakes conversion...
  166. Tightening torque for F28 diff bolts (Quaife)
  167. astra gte 16v help
  168. fuel supply
  169. siezed brake calipers
  170. omex launch control
  171. central locking prob
  172. Do all calibra's have independant rear suspension?
  173. Anyone with an X18XE or X20XEV?
  174. astra coilover photos plz
  175. corsa let coilovers
  176. Astra G Hazards Flashing every time ignition is turned on
  177. can i run without
  178. wiring c20xe late into corsa
  179. Astra mk4 cooling system replacement
  180. Stack Rev Guage help
  181. lowering 60mm with a stripped out interior has caused some dodgey results in my corsa
  182. Lowering springs
  183. Decent alternator
  184. Vectra B headlights - H1 or H7 bulbs?
  185. astra mk3 dials c20let
  186. going 5 stud
  187. Dodgy brakes?
  188. Faulty alarm Vauxhal Astra SRI 2001!!!!
  189. unknown part help
  190. Astra GTE dash help?
  191. earthing problems
  192. Astra MK2/MK3 top mounts
  193. QH Cross drilled rotors anygood?
  194. broken central locking on corsa b
  195. astra coupe coilovers
  196. FAO nova owners and eccentric top mounts..
  197. is the 4x4 txb from a 2.0l 4x4 same as a turbo one?
  198. Cavalier Mk3 Solid Beam and IRS Shocks
  199. 1.2 16v to 2.0 8v wiring problems
  200. Tyre "Shore" ratings
  201. Setting up nova suspension camber/castor/tracking(eccentric mounts)
  202. replacing steering rack end do i use thread lock
  203. xe wiring conversion help.
  204. Corsa Fusebox Listing
  205. MG ZR wheels onto Corsa B?
  206. Which way round do camber bushes go on a Cav?
  207. Will Vectra remote locking work on my L reg Cav Turbo?
  208. corsa sport x14xe start and charge loom
  209. Dash instruments.
  210. loom/wiring for using twin carbs, c20xe
  211. snaped engine mount!
  212. Running Bike carbs
  213. Handbrake cable snapped
  214. Help!! bike carb wiring help!!
  215. please help c20xe wiring in corsa t reg
  216. Supressor on a corsa 1.2 LS
  217. headgasket turning on EML???
  218. Door chime
  219. XE/LET piston rings the same?
  220. cavalier Suspension
  221. 308s with a vaux 15" wheel
  222. brake servo
  223. AVO GTZ EVO Coilovers
  224. 288s v6 or turbo
  225. 1.7td isuzu immobiliser
  226. handbrake light comes on when turning right
  227. hot start valve
  228. wireing transponder in to corsa
  229. a full re-wire
  230. Air-conditioning in the West Midlands
  231. resetting ecu
  232. performance brake outlet ?
  233. small block 5 stud astra
  234. fitting a txb to a cavturbo
  235. Dash lights
  236. dodgy handling gsi
  237. mk3 astra 1.4 2.0 8v conversion
  238. omega elite calipers on a vec b?
  239. Mk3 Astra MFD Issue
  240. corsa b stereo fitting problem (is relevant to this section of the forum- read on)
  241. xe conversion
  242. how good are mitsubishi evo turbos on a let engine
  243. x16xe loom problem?
  244. A little help needed E16se AFM ECU Questions
  245. to strengthen or not to strengthen?
  246. confussed about fuel tank, fueling
  247. help! cant sperate ecu boards
  248. gripper diff (speedo)
  249. fuel tanks in the boot?
  250. mk3 astra let not running properly
