Google
PDA
View Full Version : Other Mechanical & Electrical
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165
  1. Window elevator not working after car service , help!
  2. How low should batt gauge drop when driving ??( h/seats and things inc) cali t
  3. urgent-ish, which handbrake cable for a rear disc nova?
  4. rear disc H/brake cable ????
  5. lambra sensor wiring??? **this is urgent**
  6. Shift Lights...
  7. corsa rear wheel bearing.
  8. c20let wiring problem. need helpplz:(
  9. C20xe Problems
  10. Can someone measure the length of a Vectra B front damper for me ??
  11. AFM for c25xe
  12. Astra MK4 Door
  13. Wiring in door window switch onto electric sunroof motor.
  14. battery light on instrument panel
  15. Astra 2.2 running problems
  16. heated seat not heating up ???
  17. op-com diagnostic interfase
  18. ASTRA mk3 saloon 2.0 16v redtop PROB
  19. bump stops on avo coilovers
  20. anyone got any idea what could be causing 4x4 fault
  21. quick question lambda sensor
  22. no mil on dash help
  23. Which Coilovers for Lowest Drop (Corsa B)
  24. digi clocks
  25. Celica GT4 Troubles
  26. wiring a 1.4 16v into a 1.2 advice plz
  27. Corsa B Spax RS Coilovers problem
  28. immobiliser fitting
  29. Corsa C EPAS column into Corsa B
  30. fueling for phase to whats best..
  31. Corsa Master Cyl
  32. Cav saloon/hatch? Green pipe.
  33. fault code check on corsa gsi ABS
  34. Can anyone run a tech 2 on my 4x4 cali for cash??
  35. oil sender wire guide ????
  36. Angel Eye Fitting (Mk4 Astra)
  37. cav turbo calipers
  38. Were do i get 4x4 ecu codes from on 97 turbo cali
  39. Spax shorted adj.
  40. Steering 'clicking'
  41. Changing the CV boot .......
  42. Corsa sport, C20XE ecu fit in original space???
  43. coilovers information
  44. xe conversion starting problem!!
  45. Corsa c20let coilver springs
  46. Apex springs?
  47. Wheel bolt question
  48. mk3 astra gsi w/let rev counter problem
  49. service light vectra c
  50. Urgent help needed replacing alternator x20xev
  51. brakes
  52. corsa b rear same as tigra
  53. digi clocks
  54. Corsa inner hub shearing
  55. Fiesta Mk6 Airbag replacment
  56. Astra springs
  57. strut top mounts mk3 astra
  58. Astra digi dash in TD nova
  59. Bosch ECU connectors (55 pin) - Purchase?
  60. part check (corsa b fuel tank/pump)
  61. how to test a c20let with no diagnostic plug?
  62. A quick question??
  63. c20let 1st gear switch?
  64. xe ecu running a let ????
  65. Master Cyl
  66. Avo coliover rebuild
  67. Oil sender 2 wire 2 where ???
  68. Ebay Tech2 lead and software
  69. Hazards come on when Indicators turned on
  70. c25xe ecu work with x25xe?
  71. immobiliser transponder wiring.
  72. Rear disc conversion - corsa b
  73. speedo not working
  74. f28 gearbox drain plug........?
  75. C20XE Earths on a Tigra
  76. Brake problem and steering issue????
  77. total vaux
  78. 2.6 Omega brakes onto a Cavalier?
  79. Need help with wiring.
  80. Brembos onto a vectra v6 with 308's
  81. FK Angel Eyes for Astra G
  82. problem is, when it warms up i get a noisey lifter
  83. Corsa B Rear Wheel Bearing Torque Setting..
  84. no spark or fuel pump
  85. best coilover springs for nova
  86. astra g speedo
  87. tigra same as nova?
  88. digi dash oil light on full ?????
  89. astra mk3 drop links
  90. astra 4 cental locking not working ?
  91. breather problem on 8v 2001 z16se
  92. ECU Light on LET corsa B
  93. Removal of speedo clock on Vectra.
  94. Astra G ignition barrel replacement
  95. cant fit caps on my speedlines since conversion
  96. 99-00 Vectra B 1.8 Simtec70 Pinouts / TIS circuit diagram
  97. cant get my bonnet open help
  98. Remote central locking key.
  99. FAO anyone with AFR gauge on a let
  100. Omega V6 Coil Pin-Outs
  101. master cylinder 2.5 calibra
  102. Rotten and Coroaded ALDL plug
  103. will calibra front legs fit astra mk2?
  104. DOT 5.1 brake fluid on Nova 1.2
  105. Astra G front bearing/hub replacement
  106. Squeeking from front wheel when braking
  107. cav springs
  108. corsa b
  109. Astra mk4 coupe interior light wiring
  110. Cav/Cally Binnacle into MK1 Nova
  111. calibra dials in a corsa
  112. avo coilover for corsa b
  113. Astra G - key sticks in ignition barrel
  114. Ignition barrel removal with no key
  115. performance tips
  116. MK4 Astra gsi trip computer
  117. power sterring fluid level
  118. 2002 vectra c immobiliser
  119. Cali subframe Q's
  120. astra mk5 cdti rear disk pad change, few q's
  121. Backbox Welded on?
  122. Aircon not working
  123. Please help with my brakes
  124. Corsa B Rear Discs benifits?
  125. corsa loom
  126. Pulling left...
  127. some help on earth locations.....
  128. corsa coilovers
  129. 4 stud to 5 stud
  130. Springs
  131. Battery Covers
  132. Vectra B 2.6 V6 Over Reving Need Help Lol.
  133. performance enhancement x16
  134. Astra mk3 spare well section
  135. Let Boost gauge problem
  136. Vauxhall Vectra CD Changer Problem
  137. Headlight warning buzzer-which cars?
  138. central locking wires corsa
  139. Odd smell
  140. Wheel bearing
  141. gsi fogs
  142. corsa-b diagnostic plug on c20let loom?
  143. Vectra B wiring/earths X25XE
  144. G-Max Suspension question
  145. Wiring Ignition using carbs
  146. Rev counter
  147. Corsa c20xe hubs/shafts.
  148. Bleeding Brakes
  149. CTS Sensor
  150. Wheels Spacers Help.
  151. Braking problem (What could it be)
  152. Chip Adapter Delco ECU X14XE
  153. brake discs cally turbo
  154. mk4 angel eye wiring
  155. MOT retest on Wednesday... quick fix needed! (horn)
  156. Wheels PCD's
  157. Calibra/Cavailer seat belt Pretensioner into Mk3 Astra
  158. few small questions
  159. vectra heater problem
  160. longer bolts
  161. c25xe runing rough
  162. advice please
  163. LET misfire ongoing problem
  164. What springs for mk3 v6?????
  165. c20let alternator problems
  166. help needed
  167. Brake Upgrade
  168. aftermarket ecu mbe,dta,omex,emmerald
  169. Lowering springs
  170. crimping brake lines
  171. track rod ends?
  172. wiring up gauges in corsa
  173. IS THIS DANGEROUS??? power steering issue...
  174. may have done somet to my ignition live
  175. cav pedal box into a corsa
  176. rear shocks
  177. Nova rear disc convertion?
  178. cav/caly rear shocks upside down on mk3 astra van?
  179. modifying accelerator pedal for heel and toe ?
  180. astra gsi petrol tank
  181. removal of vectra bumper
  182. Mk3 Gsi Wheels
  183. Corsa Gsi C20xe Power Steering....?
  184. Just Fitted Coilovers..
  185. AVO GTZ coilovers on Corsa
  186. Removing ignition barrel
  187. Calibra/Cav Interior Fan Speeds
  188. oil pressure switch
  189. Trip Computer for Diesel Astra?
  190. Astra MK4 brake problem!!
  191. Abs Fault Code 35
  192. Ignition barrel problems
  193. vacuum gauge?
  194. speedo & Cruse control not working
  195. Renewing fuel pump wiring
  196. best place to get powerflex bush kits for a corsa b
  197. astra mk3 let computer prob
  198. Scuttle panel
  199. braking problem !!!!
  200. Is this Servo hose?? Spongy brake issue
  201. When removing speedo clocks do you have to
  202. LET Superships 240hp spark plug clarification?
  203. Turning off ignition
  204. log book
  205. Main beam bulb for a '52 plate Astra?
  206. astra gte suspension on mk3 gsi ?
  207. cavalier lowering question
  208. mk4 astra 4 stud front brake upgrade
  209. gsi wishbone/pivot bolt arrghhh
  210. any ideas if a twin irmscher back box will fit 2.0dti???
  211. cav springs on a mk3 astra
  212. Mk3 Astra GSI MFD
  213. help needed. c20let loom
  214. Tigra Suspension HELP
  215. corsa 1.2 16v doing less than 18mpg help plz :(
  216. vectra sitting uneven
  217. astra mk4 rear drum removal
  218. corsa wishbone inner bush
  219. center console light problems
  220. handbrake keeps getting stuck on ????
  221. Corsa LET Dash light wiring
  222. Rear Disk Conversion Problem
  223. Crank sensor wiring
  224. Some suspension handling issues NOVA
  225. Spring clamps
  226. Astra Mk4 X18XE1 temp guage
  227. toad alarm hell!!!! :(
  228. RE-programmable ecus
  229. Joining Oil cooler lines
  230. Aeroquip brake lines?
  231. Central locking, little help.
  232. Rev counter help please
  233. Fitting angel eyes mk3 astra
  234. Corsa master cylinder brake union thread sizes?
  235. xe keeps chewing new batteries
  236. Nova bottom ball joint up-grade
  237. Wilwood brake help needed
  238. Digi Dash.. KM to MPH
  239. Fuel leak (poss from rear fuel filter ???)
  240. horn
  241. Brake Calipers
  242. Calibra 160mph clocks
  243. Can anyone explain this????
  244. which wheels will stick out more?
  245. Airbag problem on a corsa B
  246. Whos fitted braided lines to their astra mk3 help?
  247. vectra rear hub top wishbone bush r reg
  248. Steering lock pin
  249. should brake discs be replaced in pairs?
  250. Oil Pressure Senders/Gauges
